Re: [bolger] Re: Lapstrake
Walter wrote:
--- Inbolger@yahoogroups.com, "Christopher C. Wetherill"<wetherillc@...>wrote:Bear in mind that Chebacco is designed for _glued_ lapstrake. This construction style is dependent on the plywood for stability. I suspect building this style with sawn planks would lead to failure along the grain. Why not look for a design that uses strip construction? V/R ChrisI think that if you built a Chebacco using traditional lapstrake construction, you would have to add framing. In traditional lapstrake construction, especially in round bilged dories such as the Swampscott, there are several sawn frames which define the shape of the boat. The boat is planked up around these frames, then intermediate bent frames are added between the sawn frames. I see no reason why this style of construction couldn't be used for a Chebacco. It has been successful for a hundred years or so. John Gardner's "Dory Book" has an excellent description of the technique.
> V/R
> Chris
Bear in mind that Chebacco is designed forgluedlapstrake.
construction?
V/R
Chris
prairiedog2332 wrote:
V/R
Chris
A Chebacco 25 with added off-shore pilot house that Susanne designed for the regular Chebacco would be awesome! Nels --- Inbolger@yahoogroups.com, Wilderness Voice<thewildernessvoice@...>wrote:I would think that steel would not be a suitable material for a microor long micro. I was a steel boatbuilder for 3 decades, but not designer. Generally steel is good for larger boats esp sailboats. There are plans for a lapstrake Cheebacco and if I were considering a long micro, I would instead take a long look at that design which is designed for lapstrake construction. Harold Payson's latest book has information about it, but the plans are avalable from Phil Bolger
--- Inbolger@yahoogroups.com, Wilderness Voice <thewildernessvoice@...>
I would think that steel would not be a suitable material for a micro or long micro. I was a steel boatbuilder for 3 decades, but not designer. Generally steel is good for larger boats esp sailboats. There are plans for a lapstrake Cheebacco and if I were considering a long micro, I would instead take a long look at that design which is designed for lapstrake construction. Harold Payson's latest book has information about it, but the plans are avalable from Phil Bolger
