Re: [bolger] Re:Lapstrake or Steel Long Micro
I think the best option if reliable plywood is not available is strip plank. Glued lapstrake uses plywood, and conventional lapstrake requires developed skills. I suppose one could plank edge to edge and build a micro-type hull, but there would be a lot of seams to caulk on a yearly basis. It would also be likely to work the seams loose because it would lack the diagonal stiffness of the plywood.
V/R
Chris
Peter wrote:
I shouldn't tell the Dutch that you can't build small steel boats,they've been doing it for the last 150 years.I don't think anyone said you can't build a small steel boat. I know what I said was the building a small boat designed for ply out of steel is bad idea. That's a different thing. Separate topic: I noted that on the cruise ships that I have been on, most of the lifeboats were of the round-bottom, 5kt type, but there were two with high-speed bottoms and capable of planning speeds. The latter are used to transfer passengers to/from shore when the mother ship is moored offshore. All fiberglass, of course.
> I shouldn't tell the Dutch that you can't build small steelI don't think anyone said you can't build a small steel boat. I know what I said was the building a small boat designed for ply out of steel is bad idea. That's a different thing.
cheers
Andy Airey
Send instant messages to your online friendshttp://uk.messenger.yahoo.com
cheers
Andy Airey
