Re: Reply to Susan Alum welding
Maybe an unlikely outcome but one I will now have in the back of my mind every time I use our bench grinder at work. I am a mechanic and we have one grinder for everything that needs to be ground.
Justin
> It's funny I have been working in machine shops all my life and did not
> no that grinding aluminum on a grinder could cause it to blow up. I just
> thought you didn't do it because it clogged up the wheel, Never too old
> to learn something. It sure makes sense that somebody could get hurt
> that way.
> Doug
> On Tue, Dec 1, 2009 at 7:04 PM, Doug Jackson <svseeker@...
> <mailto:svseeker@...>> wrote:
> Aluminum in a word is awesome. And it's doable for a novice (me)
> even down to 1/8" sheet with $1K of MIG equipment. Here are the
> lessons I've been taught:
>http://www.submarineboat.com/welding_aluminum.htm
> <http://www.submarineboat.com/welding_aluminum.htm>
> And of course you can sell the equipment when you are done building
> the boat -- if you buy used and take care of it, you can probably
> recoup most (if not all) of the money you spend on it.
> There is a rule about not mixing steel and aluminum tools so you
> don't contaminate the aluminum with steel, but aluminium would
> only gum up a regular grinding wheel. I have an aluminum grinding
> disc, "Flexcel" on an old motor that works great for grinding.
> AirGas sells them for $10 each, but they last a good while.
> No, it's worse than that. My understanding is that the bits of smeared
> aluminum get down between the grains of s wheel meant for steel and
> that when they heat up again, they can expand enough to fracture the
> wheel. And that's just a bad day. Use the right tools for the job and
> things will go better.
> -p
> Checked by AVG - www.avg.com
> Version: 8.5.426 / Virus Database: 270.14.89/2539 - Release Date: 12/01/09 19:32:00
that way.
Doug
builder if he has been building wooden boats because he already has a
most of the tools he needs.He already has the knowledge and skill to
make good fits ( very important in working in a lum because you can't
just fill gaps as with epoxy. He can saw aluminum on a table saw, power
hand skill saw, saber saw and etc. He can use a router to get nice edges
and good fits and here like in wood an electric plane does the job. I
use kerosene as a cutting fluid on routers saws etc. Lots and lots of
ventilation, electric fans needed as the mist will build up in the air
when cutting and it is hard on lungs and is likely explosive though I
have seen miles of aluminum cut this way and have never heard of a problem.
A TIG welder can be bought pretty cheaply to tack things together much
like stitch and glue except you are holding things together with weld
tacks. You can likely buy a used one and then sell it when the boat is
finished though I would keep it.
There is knowledge needed to build and weld and electrolysis
avoidance.(very,very important to understand) There is all that
information available in books and on line.
Never pass up a chance to talk with welders, you almost always learn
something.
All of this is doable and yes there are dangers but I think that anyone
that is smart enough to build a boat can learn this stuff.
Having said all that I don't think its practical in really small boats.
I would say that if you want to build a 21ft keel boat or bigger to sail
the seven seas it is a perfect material. I would look for plans for a
doubled chined keel boat with a monocoupe style hull where all internal
furniture are aluminum and welded in as a monocoupe design for strength.
I would plate no thinner than 1/8 in. and preferably 3/16 in. to ease
the buckling problems. Plywood or foam core decks lighten the top sides
but a 1/8 thick aluminum deck with plenty of support and lots of camber
for strength all welded in will make a much stronger boat.
Foam insulation is a must for cold or hot climates. If sheets of foam
are used I would glue a thin light fabric over it to protect it and make
an attractive interior. A man made fabric would be best so that it will
not rot or mildew. Under the decks glued in foam makes great protection
from bumping you noggin.
Wilderness Voice, you obviously have a whole storehouse of knowledge,
information and training on this subject. If you have the time and
inclination you ought to start writing a blog on these subjects to help
the home builder in building metal boats and also to help the designer
with practical knowledge in designing in metal that can more easily be
built. You could then put your writings together and publish as book and
in the meantime you might get a little money off of advertising from
your blog.
Tom Colvin built a boat for a fellow that had been designed by another
designer and found that he had to weld three welding rods together in
order to reach the seams in the bow to weld them. There was a lot of
fussing going on about that as I remember. Tom was and old Newport News
naval architect and he was certain that the home builder could build his
boats and a lot of them did.
I see no reason Bolger and Friends could not design proper metal boats
of any size, hopefully slightly bigger boats. For that matter redesign
an existing one for metal where it is appropriate might be excellent.
Phil Bolger designed Wolftrap for me and he did an excellent job. I was
amazed that he was able to know just how much compound curve I could
squeeze in to a hull plate. I would not sell the home builder short and
especially those that have built and used a few boats. I personally
think those boats that are designed for ocean sailing are especially
good candidates
Doug
Wilderness Voice wrote:
> I have thousands of hours welding and fabricating alum. I started out
> in the shipyard builing the Fast Frigates (FFG) for the US Navy. The
> superstructure is all alum. The big problem for the home fabricator is
> keeping it clean and keeping the wind out so you don't get porosity.
> In addition you cannot grind alum on a bench grinder set up for steel
> without danger. Alum has many advantages for the home builder since
> you can put an alum saw blade in a circular saw and use the common
> tools to fabricate with. There is the added cost of alum over plywood.
> My advice still stands though, you have to realize that if the cost of
> the equipment is folded into the cost of the boat it can be
> prohibitive. I know a guy a PSF Industries in Seattle that lost his
> eye from someone having ground alum on the bench grinder there and he
> went and ground steel and it exploded. Learning the safety rules and
> procedures is easy for anyone that picks up any number of books on
> metal fabrication. I know too many people killed and injured by taking
> short cuts. I in turn have been injured by the short cuts of others,
> so take it very seriously, but not impossible to learn if the desire
> is there
> *From:* oceannavagator <Mikieq@...>
> *To:*bolger@yahoogroups.com
> *Sent:* Tue, December 1, 2009 1:33:00 PM
> *Subject:* [bolger] Re: Reply to Susan
> I've been a certified welder for 35 years and I'd be more than happy
> to enlighten you on the in's and outs of the trade. Aluminum is the
> ideal material for metal boats. With modern equipment it welds as
> easily as steel and with the correct alloys and care it lasts forever.
> The dangers of welding can be mitigated by using a little common sense
> and proper attire. Aluminum fabrication is ten times cleaner than
> steel and the material can be cut and machined with woodworking tools.
> Also, aluminum is available practically anywhere unlike high quality
> boat building wood. Argon gas is nontoxic but it will displace oxygen
> in a closed in area so welders use exhaust fans to remove it. The
> welding equipment for thin sections is very reasonable in price. A
> small mig power source with a spoolgun runs about 1500 bucks, a spool
> of wire is about 5 bucks and argon gas costs 40 dollars per fill up.
> Mike
> --- In bolger@yahoogroups. com <mailto:bolger%40yahoogroups.com>,
> Douglas Pollard <dougpol1@.. .> wrote:
> > Also don't forget the argon gas in mig and the oxygen-less gas created
> > by the flux on welding rodes and flux cored wire is deadly so if you
> are
> > welding inside a boat you need to change the air now and then this may
> > mean a fan that does not blow toward your welding. You could die and
> > never know it until you hear the angels sing. Every now and then in
> > shipyards a welder used to die from going into a tight place where
> > welding gas has accumulated.
> > Doug
> > Douglas Pollard wrote:
> > > Fred I agree with you. I have owned and run a machine shop for a
> lot of
> > > years and we in that business train most of our employees
> ourselves and
> > > of course at some point most of them leave and go to large companies
> > > where the pay and benefits are better. AS a teenager I went through a
> > > shipyard welding school (flunked out) and we were not taught much of
> > > anything other than how to run a bead. I became a machinist instead.
> > > Welding is not rocket science and most welders learn in doing factory
> > > maintenance and on the farm or in an Automotive shops. A good book if
> > > you want to bother can teach all that is needed to learn the
> technical
> > > side of it. Yes there are pitfalls and things to learn so that an
> > > acetylene torch doesn't back burn and blow your hand off and
> that's for
> > > sure. There are good books out there on steel boat building by Tom
> > > Colvin and Gill Clingle and a host of others where you can learn
> all you
> > > need to know about welding up a boat. I think anyone who has built in
> > > wood can also build in steel if they take the time to study a
> little and
> > > practice some. Building in aluminum is a little different in that it
> > > takes a heck of a lot more practice and know how. For that I would
> hire
> > > a good welder who has welded boats before. For one thing he will weld
> > > with a water cooled mig machine that can weld about 6ft a minute as
> > > compared to one of us sputtering a long with a cheap lit mig machine
> > > that is constantly over heating and jamming up.
> > > When comes to designing a boat the information is all out there
> for the
> > > designer to use and there is no reason they should not be able to
> design
> > > in steel or aluminum boat. For most of us at least in small boats, I
> > > don't see much point in it as we for the most part we can get all the
> > > plywood we want pretty cheap. Where bigger boats are concerned
> metal is
> > > great stuff you can build a 40ft sailboat in the backyard with out
> even
> > > so much as a shed roof. Just don't weld when the wind is blowing.
> > > Building in metal is dirty, heavy and nasty work. Since most metal
> boats
> > > rust out from the inside they really should be sandblasted on the
> > > inside. What a hell of a job that is, it requires a sandblasting
> suite
> > > with outside air pumped in. Small sections should be blasted and then
> > > coated as corrosion begins right away. This is even more critical
> in a
> > > aluminum.
> > > If you build a small metal boat the material will have to be light to
> > > keep the weight down and there in lies the problem. Welding thin
> > > material is hard. It warps from the shrinkage of the weld bead and
> > > puckers at every frame and stringer. I am a decent welder and I would
> > > not attempt it. I might try welding 1/8 steel but the really thin
> steel
> > > needed to weld a small boat is out of my league. I suspect that most
> > > small metal boats built by less than highly skilled welders will
> be more
> > > body putty the steel.
> > > Now I think a small aluminum boat riveted might be another story. It
> > > would be little harder than stitch and glue but reqires two
> people, one
> > > to rivet and one to buck. With modern metal glues you likely don't
> even
> > > need the rivets except as a failsafe for the glue joint.
> > > There is also the possibility of laying up a hull of really thin
> > > aluminum layed and glued much as cold molding id done. A hull lay
> up in
> > > a cross diagonal pattern of 6 inch wide .010 inch thick aluminum
> could
> > > be shaped to almost any fine shape desired including a fine wine
> glass
> > > shaped hull. Todays glues are really the cats whiskers. When you
> > > consider a lot of modern airplanes are glued together they better
> be good.
> > > Doug
> > > Fred Schumacher wrote:
> > >> On Sun, Nov 29, 2009 at 10:54 PM, Susanne@...
> > >> <mailto:Susanne@ ...> <philbolger@ ...
> > >> <mailto:philbolger@ ...>> wrote:
> > >> W.V. I agree with your serious note of serious caution about
> > >> casual welding or even casual swapping construction- materials from
> > >> ply to steel.
> > >> I agree too about some dangers inherent in welding; however, as a
> > >> retired farmer, I have to state that there are thousands of
> > >> non-professional welders out there doing quite creditable jobs of
> > >> welding. It's virtually impossible to be a farmer today and not be
> > >> able to weld or use a cutting torch. Those are two absolutely
> > >> essential tools on a modern farm.
> > >> With the ready availability of wire welders, it's much easier these
> > >> days to weld light gauge steel. But leave the aluminum work to
> experts.
> > >> Fred Schumacher
> > > Bolger rules!!!
> > > - NO "GO AWAY SPAMMER!" posts!!! Please!
> > > - no cursing, flaming, trolling, spamming, respamming, or flogging
> dead horses
> > > - stay on topic, stay on thread, punctuate, no 'Ed, thanks, Fred'
> posts
> > > - Pls add your comments at the TOP, SIGN your posts, and snip away
> > > - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA,
> 01930, Fax: (978) 282-1349
> > > - Unsubscribe: bolger-unsubscribe@ yahoogroups. com
> <mailto:bolger-unsubscribe%40yahoogroups.com>
> > > - Open discussion: bolger_coffee_ lounge-subscribe @yahoogroups.
> com <mailto:bolger_coffee_lounge-subscribe%40yahoogroups.com> Yahoo!
> Groups Links
On Tue, Dec 1, 2009 at 7:24 PM, Doug Jackson<svseeker@...>wrote:"when you are done building the boat" -- LOL You're funny! We haven't finished that boat, and we've started 2 more.
And thanks for the explanation about the exploding wheel.From: Pierce Nichols <rocketgeek@...>
Doug
"I began life as a bad boy." --Simon Lake, father of the modern submarine
Join "Bad Boy Submarines" at ArgonautJr.com
________________________________
Sent: Tue, December 1, 2009 9:16:09 PMSubject: Re: [bolger] Re: Reply to Susan Alum weldingOn Tue, Dec 1, 2009 at 7:04 PM, Doug Jackson <svseeker@ymail. com> wrote:
>Aluminum in a word is awesome. And it's doable for a novice (me) even down to 1/8" sheet with $1K of MIG equipment. Here are the lessons I've been taught:http://www.submarineboat.com/welding_aluminum.htm
And of course you can sell the equipment when you are done building the boat -- if you buy used and take care of it, you can probably recoup most (if not all) of the money you spend on it.
>>There is a rule about not mixing steel and aluminum tools so you don't contaminate the aluminum with steel, but aluminium would only gum up a regular grinding wheel. I have an aluminum grinding disc, "Flexcel" on an old motor that works great for grinding. AirGas sells them for $10 each, but they last a good while.
No, it's worse than that. My understanding is that the bits of smeared aluminum get down between the grains of s wheel meant for steel and that when they heat up again, they can expand enough to fracture the wheel. And that's just a bad day. Use the right tools for the job and things will go better.
-p------------------------------------
<*> Your email settings:
(Yahoo! ID required)
bolger-digest@yahoogroups.com
Doug
-p
On Tue, Dec 1, 2009 at 7:04 PM, Doug Jackson<svseeker@...>wrote:Aluminum in a word is awesome. And it's doable for a novice (me) even down to 1/8" sheet with $1K of MIG equipment. Here are the lessons I've been taught:http://www.submarineboat.com/welding_aluminum.htmAnd of course you can sell the equipment when you are done building the boat -- if you buy used and take care of it, you can probably recoup most (if not all) of the money you spend on it.
There is a rule about not mixing steel and aluminum tools so you don't contaminate the aluminum with steel, but aluminium would only gum up a regular grinding wheel. I have an aluminum grinding disc, "Flexcel" on an old motor that works great for grinding. AirGas sells them for $10 each, but they last a good while.No, it's worse than that. My understanding is that the bits of smeared aluminum get down between the grains of s wheel meant for steel and that when they heat up again, they can expand enough to fracture the wheel. And that's just a bad day. Use the right tools for the job and things will go better.-p
Doug
Sent: Tue, December 1, 2009 8:36:51 PM
I have thousands of hours welding and fabricating alum. I started out in the shipyard builing the Fast Frigates (FFG) for the US Navy. The superstructure is all alum. The big problem for the home fabricator is keeping it clean and keeping the wind out so you don't get porosity. In addition you cannot grind alum on a bench grinder set up for steel without danger. Alum has many advantages for the home builder since you can put an alum saw blade in a circular saw and use the common tools to fabricate with. There is the added cost of alum over plywood. My advice still stands though, you have to realize that if the cost of the equipment is folded into the cost of the boat it can be prohibitive. I know a guy a PSF Industries in Seattle that lost his eye from someone having ground alum on the bench grinder there and he went and ground steel and it exploded. Learning the safety rules and procedures is easy for anyone that picks up any number of books on metal
fabrication. I know too many people killed and injured by taking short cuts. I in turn have been injured by the short cuts of others, so take it very seriously, but not impossible to learn if the desire is there
To: bolger@yahoogroups. com
Sent: Tue, December 1, 2009 1:33:00 PM
Subject: [bolger] Re: Reply to Susan
I've been a certified welder for 35 years and I'd be more than happy to enlighten you on the in's and outs of the trade. Aluminum is the ideal material for metal boats. With modern equipment it welds as easily as steel and with the correct alloys and care it lasts forever. The dangers of welding can be mitigated by using a little common sense and proper attire. Aluminum fabrication is ten times cleaner than steel and the material can be cut and machined with woodworking tools. Also, aluminum is available practically anywhere unlike high quality boat building wood. Argon gas is nontoxic but it will displace oxygen in a closed in area so welders use exhaust fans to remove it. The welding equipment for thin sections is very reasonable in price. A small mig power source with a spoolgun runs about 1500 bucks, a spool of wire is about 5 bucks and argon gas costs 40 dollars per fill up.
Mike
> by the flux on welding rodes and flux cored wire is deadly so if you are
> Doug
> > Fred I agree with you. I have owned and run a machine shop for a lot of
> > years and we in that business train most of our employees ourselves and
> > you want to bother can teach all that is needed to learn the technical
> > acetylene torch doesn't back burn and blow your hand off and that's for
> > Colvin and Gill Clingle and a host of others where you can learn all you
> > wood can also build in steel if they take the time to study a little and
> > takes a heck of a lot more practice and know how. For that I would hire
> > When comes to designing a boat the information is all out there for the
> > designer to use and there is no reason they should not be able to design
> > plywood we want pretty cheap. Where bigger boats are concerned metal is
> > great stuff you can build a 40ft sailboat in the backyard with out even
> > Building in metal is dirty, heavy and nasty work. Since most metal boats
> > inside. What a hell of a job that is, it requires a sandblasting suite
> > coated as corrosion begins right away. This is even more critical in a
> > aluminum.
> > not attempt it. I might try welding 1/8 steel but the really thin steel
> > small metal boats built by less than highly skilled welders will be more
> > would be little harder than stitch and glue but reqires two people, one
> > to rivet and one to buck. With modern metal glues you likely don't even
> > aluminum layed and glued much as cold molding id done. A hull lay up in
> > a cross diagonal pattern of 6 inch wide .010 inch thick aluminum could
> > be shaped to almost any fine shape desired including a fine wine glass
> > consider a lot of modern airplanes are glued together they better be good.
> > Doug
> >> ply to steel.
> >> days to weld light gauge steel. But leave the aluminum work to experts.
> >> Fred Schumacher
> > - Open discussion: bolger_coffee_ lounge-subscribe @yahoogroups. com Yahoo! Groups Links
Sent:Tue, December 1, 2009 1:33:00 PM
Subject:[bolger] Re: Reply to Susan
Mike
> Doug
> > aluminum.
> > Doug
> >> ply to steel.
> >> Fred Schumacher
> > - Unsubscribe:bolger-unsubscribe@ yahoogroups. com
> > - Open discussion:bolger_coffee_ lounge-subscribe @yahoogroups. comYahoo! Groups Links
Mike
> Doug
> > aluminum.
> > Doug
> >> <mailto:Susanne@...> <philbolger@...
> >> casual welding or even casual swapping construction-materials from
> >> ply to steel.
> >> Fred Schumacher
http://intheboatshed.net/page/10/
It is on Gavin Atkin's cool intheboatshed blog/website.
There is also a small Dutch dingy/utility boat shown that is to be restored and repainted.
Quite a bit of other stuff worth having a look at too. If you click on "forest-stream" in the links at the bottom of the section it will take you to other pictures of the build.
Cheers, Brian
done when only gluing a small section of a boat. Bolger and I talked
about building something like a Monroe Presto or may be a Moccasin like
hull with rounded chines and compound curves in bow and stern. I think
he suggested building each half and then bolting them on either side of
a keel with the idea that a half a hull could more easily bagged. Funny
now that I am thinking about it some things are being remembered. I
guess when you drop something because you can't do it, it just gets set
aside in the mind.
Doug
Pierce Nichols wrote:
> That sounds about like what I've used -- bead blast followed by etch
> and a final clean. IIRC, it also has to be done shortly before gluing
> or you've got to do it again -- something about the reformation of the
> oxide layer. When it's done right, it's really strong... you can get
> better joint performance than with rivets due to the lack of stress
> concentrations and the relatively large surface area. I'd be
> interested to hear if anyone did it successfully... but it's probably
> a science project.
> -p
> On Mon, Nov 30, 2009 at 6:08 PM, Douglas Pollard <dougpol1@...
> <mailto:dougpol1@...>> wrote:
> I guess that kind of answeres the glueing metal thing. I don't
> remember
> much about it as My welder did most of the work with the instructions
> the engineers gave him. We did sandblast the metal with micro sand or
> glass beads or something. I think they also tried a product call
> luminator that is an acid or costic to etch the metal in
> preperation for
> gluing. We really never got very far with the project. I know this the
> finished product was very strong.
> Doug
> > I've done a little work with aluminum adhesive bonding, and most of
> > the adhesives I've heard of are forms of epoxy. They are *NOT*
> easy to
> > use. In particular they require excellent fit-up and complex,
> > difficult surface preparation in order to develop their rated
> > strength. It's the kind of thing that's reasonable if you're
> building
> > airplanes (where those requirement are already common), but it's a
> > very long way from wood/epoxy.
> > Riveting, however, is a perfectly reasonable approach for thin-gauge
> > metal structures. Self-plugging blind rivets might even be usable,
> > which would remove the need for someone to hold the bucking bar.
> > Cherry Q rivets are structural self-plugging rivets available in a
> > variety of materials. Not sure that any of the commonly
> available ones
> > are a usable combo, however.
> > -p
> > On Mon, Nov 30, 2009 at 5:31 PM, Gene Tehansky
> > <goldranger02-boats@...
> <mailto:goldranger02-boats@...>
> <mailto:goldranger02-boats@...>>>
> > wrote:
> > Doug,
> > What types of glues are you referring to? Are they forms of epoxy?
> > Gene T.
> a lot
> > > of
> ourselves
> > > and
> companies
> > through a
> much of
> instead.
> > factory
> > book if
> > technical
> that's
> > > for
> learn all
> > > you
> > built in
> little
> > > and
> that it
> > > hire
> > weld
> minute as
> machine
> there for
> > > the
> > > design
> boats, I
> > all the
> metal
> > > is
> > > even
> > > boats
> > suite
> > then
> > critical in a
> > > aluminum.
> > light to
> > would
> > > steel
> that most
> will be
> > > more
> story. It
> people,
> > > one
> > > even
> lay up
> > > in
> > could
> > glass
> better be
> > > good.
> > > Doug
> > >> On Sun, Nov 29, 2009 at 10:54 PM,Susanne@...
> > <mailto:Susanne@...<mailto:Susanne@...>>
> <mailto:Susanne@...<mailto:Susanne@...>>>
> > <philbolger@...<mailto:philbolger@...>
> <mailto:philbolger@...<mailto:philbolger@...>>
> from
> > >> ply to steel.
> not be
> these
> > >> experts.
> > >> Fred Schumacher
> > > Bolger rules!!!
> > > dead horses
> > > posts
> 01930,
> > > Fax: (978) 282-1349
> <mailto:bolger-unsubscribe@yahoogroups.com>
> <mailto:bolger-unsubscribe@yahoogroups.com>>
> > > - Open discussion:
> <mailto:bolger_coffee_lounge-subscribe@yahoogroups.com>
> <mailto:bolger_coffee_lounge-subscribe@yahoogroups.com>>
> > > Yahoo! Groups Links
> > dead horses
> > posts
> > - Open discussion:
> <mailto:bolger_coffee_lounge-subscribe@yahoogroups.com>> Yahoo!
> > Groups Links
> > <mailto:bolger-fullfeatured@yahoogroups.com
> <mailto:bolger-fullfeatured@yahoogroups.com>>
> dead horses
> posts
> <mailto:bolger_coffee_lounge-subscribe@yahoogroups.com> Yahoo!
> Groups Links
On Mon, Nov 30, 2009 at 6:08 PM, Douglas Pollard<dougpol1@...>wrote:I guess that kind of answeres the glueing metal thing. I don't remember
luminator that is an acid or costic to etch the metal in preperation for
Doug> <goldranger02-boats@...<mailto:goldranger02-boats@...>>
> the adhesives I've heard of are forms of epoxy. They are *NOT* easy to
> strength. It's the kind of thing that's reasonable if you're building
> variety of materials. Not sure that any of the commonly available ones
> -p
> On Mon, Nov 30, 2009 at 5:31 PM, Gene Tehansky> >> <mailto:Susanne@...<mailto:Susanne@...>>> wrote:
> Doug,
> Gene T.
> > of
> > and
> through a
> factory
> book if
> technical
> > for
> > you
> built in
> > and
> > hire
> weld
> > the
> > design
> all the
> > is
> > even
> > boats
> suite
> then
> critical in a
> > aluminum.
> light to
> would
> > steel
> > more
> > one
> > even
> > in
> could
> glass
> > good.
> > Doug
> >> <mailto:philbolger@...> <mailto:philbolger@...>>> wrote:> <mailto:bolger-unsubscribe@yahoogroups.com>
> >> ply to steel.
> >> experts.
> >> Fred Schumacher
> > dead horses
> > posts
> > Fax: (978) 282-1349
> <mailto:bolger_coffee_lounge-subscribe@yahoogroups.com>> > Yahoo! Groups Links> <mailto:bolger-unsubscribe@yahoogroups.com>
> dead horses
> posts
> - Unsubscribe:bolger-unsubscribe@yahoogroups.com> - Open discussion:bolger_coffee_lounge-subscribe@yahoogroups.com> <mailto:bolger_coffee_lounge-subscribe@yahoogroups.com> Yahoo!
> Groups Links
Doug
> -p
> wrote:
> Doug,
> Gene T.
> > of
> > and
> through a
> factory
> book if
> technical
> > for
> > you
> built in
> > and
> > hire
> weld
> > the
> > design
> all the
> > is
> > even
> > boats
> suite
> then
> critical in a
> > aluminum.
> light to
> would
> > steel
> > more
> > one
> > even
> > in
> could
> glass
> > good.
> > Doug
> >> ply to steel.
> >> experts.
> >> Fred Schumacher
> > dead horses
> > posts
> > Fax: (978) 282-1349
> > - Open discussion:
> > Yahoo! Groups Links
> dead horses
> posts
> Groups Links
never got out of the talking stage.
Doug
Gene Tehansky wrote:
> Doug,
> Gene T.
> > of
> > and
> > for
> > you
> > and
> > hire
> > the
> > design
> > is
> > even
> > boats
> > aluminum.
> > steel
> > more
> > one
> > even
> > in
> > good.
> > Doug
> <mailto:Susanne%40comcast.net>
> >> <mailto:Susanne@...<mailto:Susanne%40comcast.net>>
> <philbolger@...<mailto:philbolger%40comcast.net>
> >> <mailto:philbolger@...<mailto:philbolger%40comcast.net>>>
> >> ply to steel.
> >> experts.
> >> Fred Schumacher
> > dead horses
> > posts
> > Fax: (978) 282-1349
> > Yahoo! Groups Links
Building Wolftrap an aluminum boat and at the same time we were a
contractor for Nasa I talked to several mastics engineers that worked
for Nassa at the time ( about 1979) and I was interested in building a
boat to be layed up as I described and they were very interested. Nassa
gave us some aluminum and mastic and we made up some test panels with
the idea would might try building a boat. After some testing we found
the panels to be really tough. We never built the boat as we got
involved making turbine blades for a couple of battle ships and we were
just to busy to build boats. All I can tell you is to search the web, I
think I have seen mention of this stuff for aircraft use on a couple of
web sites. I think they used tons of the stuff on the shuttles. Doug
> Doug,
> Gene T.
> > of
> > and
> > for
> > you
> > and
> > hire
> > the
> > design
> > is
> > even
> > boats
> > aluminum.
> > steel
> > more
> > one
> > even
> > in
> > good.
> > Doug
> >> ply to steel.
> >> experts.
> >> Fred Schumacher
> > dead horses
> > posts
> > Fax: (978) 282-1349
> > Yahoo! Groups Links
On Mon, Nov 30, 2009 at 5:31 PM, Gene Tehansky<goldranger02-boats@...>wrote:Doug,
Gene T.
> of
> and
> for
> you
> and
> hire
> the
> design
> is
> even
> boats
> aluminum.
> steel
> more
> one
> even
> in
> good.
> Doug
>> ply to steel.
>> experts.
>> Fred Schumacher
> dead horses
> posts
> Fax: (978) 282-1349
Gene T.
> of
> and
> for
> you
> and
> hire
> the
> design
> is
> even
> boats
> aluminum.
> steel
> more
> one
> even
> in
> good.
> Doug
>> ply to steel.
>> experts.
>> Fred Schumacher
> dead horses
> posts
> Fax: (978) 282-1349
Doug
> aluminum.
> Doug
>> ply to steel.
>> Fred Schumacher
aluminum.
Doug
> ply to steel.
> Fred Schumacher
On Sun, Nov 29, 2009 at 10:54 PM,Susanne@...<philbolger@...>wrote:W.V. I agree with your serious note of serious caution about casual welding or even casual swapping construction-materials from ply to steel.I agree too about some dangers inherent in welding; however, as a retired farmer, I have to state that there are thousands of non-professional welders out there doing quite creditable jobs of welding. It's virtually impossible to be a farmer today and not be able to weld or use a cutting torch. Those are two absolutely essential tools on a modern farm.With the ready availability of wire welders, it's much easier these days to weld light gauge steel. But leave the aluminum work to experts.Fred Schumacher
My recollections from the 70s had more to do with the size apparently doable in good-looking perfectly usable results to modest performance ambitions - if designed for it and build competently.
About well-performing small steel-boats, Phil/we thought that H.G. Hasler's shape might address that quite well.
----- Original Message -----From:Wilderness VoiceSent:Sunday, November 29, 2009 8:56 PMSubject:[bolger] Reply to SusanThe subject of steel boat building has migrated in discussion. Originally it was a response to a boat desire from someone who didn't have access to plywood. There are many dangers inherent with steel boat building and many skills to Master. I have looked at the wiring of the Depression era farmers who did their own wiring, welding and so on. Often it was done dangerously thru ignorance. Now even in woodworking we can easily amputate hands or get chemical poisoning etc, but if someone wants to build with steel, they should use plans by someone who is trained to design in steel. Then be able to pass an smaw1 test. There are safety factors with burning like the fact that skin oil can cause an acetylene tank to explode and they have or to find out the proper pressures for cutting (10lbs fuel, 40lbs air, which are the default pressures in industry). So there is quite a learning curve, we haven't even discussed rigging (not sail rigging, but moving steel rigging). The fact is that professionals with yrs of experience and knowledge are maimed and killed and I have known too many of each. Many of the people who attempt to build in steel will grind alum and then grind steel on the same grinding wheel not knowing they just created a bomb!
I have been fortunate to survive my injuries, but I know what it feels like to have your hand crushed and 3rd degree burns I have had many. The argument that you can just transfer plywood designs into steel are like saying anyone can design boats as good as Phil Bolger. There is much craft in the simplest boats he designed. In all of this I am not saying to not build boats of steel. I don't know of any small steel boats under 20' that have good performance. I am recommending that anyone desiring to build steel craft small or otherwise learn to do it properly and that can be done at a local vocational school. If they have a cavalier attitude and think all the safety and skill is just BS, then they have a high likelihood of creating a boat that can maim or kill them or the next owner. This is serious business, but obviously there must be safety with power tools as there is with steel fabrication tools.
If someone is too lazy to do it right, then it is best for all concerned not to do it until they are ready to make the commitment to learn.
