RE: [bolger] Re: Towing a Chebacco
I have a friend who tows a West Wight potter 19 from SC to the keys with a Forester with no apparent ill effects—he normally keeps a car for 150,000 to 200,000 miles. He is also pretty conservative, drives sedately, and the trip to the keys is very flat. It might be a different story in hilly terrain…
JohnT
bolger@yahoogroups.com ]On Behalf OfStefan Topolski
Sent:Monday, December 28, 2009
12:55 AM
Subject:Re: [bolger] Re: Towing a
Chebacco
yep - trailer brakes and lucky we live up in the north where it (never) gets that hot.
I was curious to hear what others who do tow Chebacos with what look like Subaru wagons might say, but it sounds like moderately sized Bolger designs up to about 20 feet and wide or a sneakeasy's 24 feet and narrow can be towed well but wearingly in reasonable safely with a Subaru type vehicle if you can carefully get the tongue weight down to under 200 pounds which is not easy.
Such sized boats would be towed more safely and more reliably with much less vehicle wear over consistently longer distances by something heavier like a truck framed vehicle. I hope that helps - it certainly helped me.
Best Wishes,
Stefan
"One gathers peace as a feather in the palm of one's hand." -anonymous
On Dec 26, 2009, at 10:14 AM, donm172001 wrote:
I
am looking at the brochures as I write this. The 2005 - 2010 Forester has a
rated towing capacity of 2400 lbs. The 2010 Outback has a rated towing capacity
of 2700 lbs. for the 2.5 liter 4 cylinder and 3000 lbs for the 3.6 liter 6
cylinder engine. According to the Forester User's manual, if you are towing a
trailer on a long uphill grade continuously for over 5 miles with an outside
temperature of 104 degrees or above, the maximum towing capacity is reduced to
1000 lbs. Brakes are also required on trailers with a weight of 1000 lbs or
more.
--- In bolger@yahoogroups. com, the
doctor <scotedoc2@. ..> wrote:
>of towing a trailer...  That is ,,, Stopping the rig!  I don't recall seeing any relatively small boat trailers with brakes?   Horsepower is not the only issue... I occasionally VERY occasionally towed a Rhoades 19 with a v/w bug !!  A mile or so...Â
> I believe most of this discussion is overlooking the most important aspect
> Âhref="mailto:bolger%40yahoogroups.com">bolger@yahoogroups. com
> just my input.
> Â
> doc
> --- On Fri, 12/25/09, rrusk9 <rrusk9@...> wrote:
> From: rrusk9 <rrusk9@...>
> Subject: [bolger] Re: Towing a Chebacco
> To:
> Date: Friday, December 25, 2009, 8:06 PMgeneral. Everybody is throwing around generalities about small cars but few if any are talking about the Subaru itself.
> Â
> OK, responding to GBroadlick's posting in particular but to this topic in
>Whaler (around 2100 lbs on a trailer). Same rating with any of the three available transmissions.
> A friend just bought an Outback. 2700 lb rating. Works fine towing a 17'
>geared reasonably, it should have no trouble towing <3000 lb. Years ago I used to tow 3500-4000 lbs behind a 2900 lb Toyota pickup with 115 hp. The Subaru has about 50% more power and 10% more weight. Before someone yells "a pickup is not a car", I have also towed many miles with smallish cars (from 1.5L-3.5L).
> The base Subaru currently comes with a 2.5L 4-cylinder engine. If it is
>distances to something that seems stupidly conservative (it isn't). Install brakes on the trailer. Keep your speeds conservative. Try not to use the last 10-15% of available power for very long at a time.
> Stay out of the fast lane. Don't use top gear. Open up your following
>weight of 5-7% works well with a boat trailer. Higher tongue weights are required for travel trailers (sail area) and utility trailers (tight-coupled) . If the tongue is too light it will wander and the trailer may wag back and forth dangerously. If the tongue is too heavy the rear suspension will be overloaded. It will bottom out and it will sway dangerously. With an empty luggage area or empty back seat, a mid-sized car can easily deal with 125-150 lbs of tongue weight.
> The 300 lb tongue weight may be a bit high. In my experience, a tongue
>effects of sway and gives you traction when climbing hills and ramps. A late-model Subaru will also have anti-lock brakes.
> The Subaru's four wheel drive is your friend while towing. It reduces the
>and in the right gear. If it shows signs of heating up, slow down or pull over. If you are not comfortable with trying this, then borrow a larger vehicle or rent a u-haul or something to take it to the truck scales and find out what your trailer actually weighs. A Chebacco on a reasonable trailer should be within the capabilities of your Subaru, but not everybody is comfortable towing without a monster tow vehicle. Find your own comfort level.
> You are not likely to hurt your car towing an oversized load once slowly
>automatic.
> Bob Rusk
> --- In bolger@yahoogroups. com, GBroadlick@ .. wrote:
> > tow ratings for autos is lower for manual transmission than
> > I have lost 3 transmissions towing boats, never an engineclass=apple-converted-space>
> > you must put on an oil cooler but make sure they use new hoses
> > From: Doug Pollard <dougpol1@ .>
> > To: bolger@yahoogroups. com
> > Sent: Wed, Dec 23, 2009 9:55 am
> > Subject: Re: [bolger] Re: Towing a Chebacco
> > I recently replaced my van with a new to me used one. I had wanted to
> > uy a sedan but in checking out the specs on most of the lighterclass=apple-converted-space>
> > utomobiles I found them not suitable for towing. Yes you can tow withclass=apple-converted-space>
> > hem. I wanted a v6 engine thinking that towing my Elver would do lessclass=apple-converted-space>
> > amage to the engine if it were a little bigger than a 4cylinder one.class=apple-converted-space>
> > ll the lighter sedans I checked had a 1000 lb towing limit on them.class=apple-converted-space>
> > ars with v8 engines were much higher and mini vans had 2000 lb limitclass=apple-converted-space>
> > nless you add a transmition oil cooler. Then the limit is 3000 lbsclass=apple-converted-space>
> > enerally.class=apple-converted-space>
> > suspect that limit is based on the damage caused by overloading the
> > ransmition rather than breaking power. Modern breaks with the metalclass=apple-converted-space>
> > mpregnated shoe's can stand tremendous heat though it is possible toclass=apple-converted-space>
> > arp the rotors. If you over heat a transmition you are likely lookingclass=apple-converted-space>
> > t several thousand dollars to replace it. Considering this I wouldnot
> > ull more than the are recomended for. If your car is old and has aclass=apple-converted-space>
> > anual transmition it will likely pull a much heavier load. Moderncars
> > re built to get good gas milage not to pull heavy loads. With reallyclass=apple-converted-space>
> > ood breaks they may be safer though than older cars pulling loads.This
> > s my opinion only but it is based on about a month of online researchclass=apple-converted-space>
> > n order to buy a towing vehicle for my Elver. The van I just got ridof
> > 164,000 miles still had the original breaks ( all country miles).Just
> > efore selling it because I was selling to a young single mom with aclass=apple-converted-space>
> > ouple kids I didn't want to risk killing them so replaced the breaksclass=apple-converted-space>
> > nd rotors because the rotars were getting thin. the shoes were lessclass=apple-converted-space>
> > han half worn out. What I am saying is the transmitions are the bigclass=apple-converted-space>
> > roblem with towing. I was told to not tow with overdrive engaged butto
> > hift into 3rd gear for towing.class=apple-converted-space>
> > oug
> > tefan Topolski wrote:
> > :) - yes, i can see how to do that now that you have got me thinking.
> > I could probably place the 2 x 4 under the trailer frame right behindclass=apple-converted-space>
> > each wheel (not forgetting the tongue too) to make it easier withoutclass=apple-converted-space>
> > adding significant error to the calculation.-anonymous
> > Leave it to an engineer to suggest i play at Archimedes.
> > Best Wishes,
> > Stefan
> >href="http://www.cottagem">http://www.cottagem ed.org <http://www.cottagem ed.org>
> > On Dec 23, 2009, at 12:50 AM, Christopher C. Wetherill wrote:
> > Off the wall suggestion time. If you are uncomfortable taking the
> > trailer to the scale, take the scale to the trailer. PA StateTroopers
> > set up portable weigh stations using load pads that weigh individualclass=apple-converted-space>
> > wheels. Gross vehicle weight is the sum of the weight on each wheel.class=apple-converted-space>
> > If you have a flat hard surface, you may be able to use one of these.class=apple-converted-space>
> > Perhaps they are available for rental.class=apple-converted-space>
> > You may be able to do something similar with a 2x4, a fulcrum, your
> > weight, and algebra. (Yes, I am a Mechanical Engineer)Not
> > Stefan Topolski wrote:
> > > Displacement calculations should include all the above (below).
> > > included might be people, food, clothing, and bric a brac.hand." -anonymous
> > > I'm prepared for others to correct me with no quarter taken...
> > > Best Wishes,
> > > Stefan
> > >it's
> > > On Dec 23, 2009, at 12:18 AM, Christopher C. Wetherill wrote:
> > > I agree with you about the meaning of displacement. However,
> > > pretty often true that the weight of stowed gear creeps up. Itis
> > > also quite possible that the builder could add weight or useheavier
> > > wood than PCB used for the design calcs. I feel it is thereforeclass=apple-converted-space>
> > > prudent to base the selection on design displacement plus about30%
> > > for a margin of safety. If, using this method, you calculate2500
> > > pounds and the car can tow 2500 pounds, you have ample margin.sails,
> > > Also, is the 250kg the mass of the hull alone or hull, spars,
> > > rigging and, auxiliary?Wetherill"
> > > V/R
> > > Chris
> > > pkortlucke wrote:
> > >> --- In bolger@yahoogroups. com, "Christopher C.
> > >> <wetherillc@ > wrote:8 ") on page
> > >>> The drawing of the type 1 Chebacco in sheet plywood (19'
> > >>> 226 of Boats with an Open Mind shows design displacementat 1740
> > >>> pounds. The drawing on page 232 shows thew 25 footer tohave 2300
> > >>>this for a
> > >> pound
> > >>> displacement. It is prudent to assume a percentage over
> > >>> margin of safety. You must also add the weight of thetrailer.
> > >>>for crew and
> > >> I suspect those displacement figures include an allowance
> > >> equipment i.e. it's not the empty weight which is theapplicable figure
> > >> when looking to trail. My Folding Schooner (31ft and with asteel
> > >> centreplate) weighs about 250kg empty (about 600 lbs). Hardto believe a
> > >> standard 19 ft 8 inch Chebacco could be 3 times the emptyweight of a
> > >> boat 50% longer even allowing for the light weightconstruction of the
> > >> schooner.flogging dead
> > >> Cheers
> > >> Peter
> > >> Bolger rules!!!
> > >> - NO "GO AWAY SPAMMER!" posts!!! Please!
> > >> - no cursing, flaming, trolling, spamming, respamming, or
> > orsesFred' posts
> > >> - stay on topic, stay on thread, punctuate, no 'Ed, thanks,
> > >> - Pls add your comments at the TOP, SIGN your posts, andsnip away
> > >> - Plans: Mr. Philip C. Bolger,w:st="on">P.O. Box 1209 , Gloucester , MA , 01930 , Fax:
> > 978) 282-1349@yahoogroups. com Yahoo!
> > >> - Unsubscribe: bolger-unsubscribe@ yahoogroups. com
> > >> - Open discussion: bolger_coffee_ lounge-subscribe
> > roups Linkshref="http://www.avg.com">www.avg.com
> > No virus found in this incoming message.
> > Checked by AVG -
> > Version: 8.5.430 / Virus Database: 270.14.117/2582 - Release Date:12/22/09
> > 8:22:00horses
> > no cursing, flaming, trolling, spamming, respamming, or flogging dead
> > stay on topic, stay on thread, punctuate, no 'Ed, thanks, Fred' postsclass=apple-converted-space>
> > Pls add your comments at the TOP, SIGN your posts, and snip awayw:st="on">P.O. Box 1209 , Gloucester , MA , 01930 , Fax: (978)
> > 82-1349Yahoo! Groups
> > Open discussion: bolger_coffee_ lounge-subscribe @yahoogroups. com
> > inksface=Verdana>http://docs. yahoo.com/ info/terms/
> > Individual Email | Traditional
Checked by AVG - www.avg.com
Version: 9.0.722 / Virus Database: 270.14.121/2589 - Release Date: 12/27/09 04:18:00
Best Wishes,
I am looking at the brochures as I write this. The 2005 - 2010 Forester has a rated towing capacity of 2400 lbs. The 2010 Outback has a rated towing capacity of 2700 lbs. for the 2.5 liter 4 cylinder and 3000 lbs for the 3.6 liter 6 cylinder engine. According to the Forester User's manual, if you are towing a trailer on a long uphill grade continuously for over 5 miles with an outside temperature of 104 degrees or above, the maximum towing capacity is reduced to 1000 lbs. Brakes are also required on trailers with a weight of 1000 lbs or more.
--- In bolger@yahoogroups. com, the doctor <scotedoc2@. ..> wrote:
> I believe most of this discussion is overlooking the most important aspect of towing a trailer...  That is ,,, Stopping the rig!  I don't recall seeing any relatively small boat trailers with brakes?   Horsepower is not the only issue... I occasionally VERY occasionally towed a Rhoades 19 with a v/w bug !!  A mile or so...Â
> Â
> just my input.
> Â
> doc
> Â
> OK, responding to GBroadlick's posting in particular but to this topic in general. Everybody is throwing around generalities about small cars but few if any are talking about the Subaru itself.
> A friend just bought an Outback. 2700 lb rating. Works fine towing a 17' Whaler (around 2100 lbs on a trailer). Same rating with any of the three available transmissions.
> The base Subaru currently comes with a 2.5L 4-cylinder engine. If it is geared reasonably, it should have no trouble towing <3000 lb. Years ago I used to tow 3500-4000 lbs behind a 2900 lb Toyota pickup with 115 hp. The Subaru has about 50% more power and 10% more weight. Before someone yells "a pickup is not a car", I have also towed many miles with smallish cars (from 1.5L-3.5L).
> Stay out of the fast lane. Don't use top gear. Open up your following distances to something that seems stupidly conservative (it isn't). Install brakes on the trailer. Keep your speeds conservative. Try not to use the last 10-15% of available power for very long at a time.
> The 300 lb tongue weight may be a bit high. In my experience, a tongue weight of 5-7% works well with a boat trailer. Higher tongue weights are required for travel trailers (sail area) and utility trailers (tight-coupled) . If the tongue is too light it will wander and the trailer may wag back and forth dangerously. If the tongue is too heavy the rear suspension will be overloaded. It will bottom out and it will sway dangerously. With an empty luggage area or empty back seat, a mid-sized car can easily deal with 125-150 lbs of tongue weight.
> The Subaru's four wheel drive is your friend while towing. It reduces the effects of sway and gives you traction when climbing hills and ramps. A late-model Subaru will also have anti-lock brakes.
> You are not likely to hurt your car towing an oversized load once slowly and in the right gear. If it shows signs of heating up, slow down or pull over. If you are not comfortable with trying this, then borrow a larger vehicle or rent a u-haul or something to take it to the truck scales and find out what your trailer actually weighs. A Chebacco on a reasonable trailer should be within the capabilities of your Subaru, but not everybody is comfortable towing without a monster tow vehicle. Find your own comfort level.
> Bob Rusk
> > tow ratings for autos is lower for manual transmission than automatic.
> > enerally.
> > t several thousand dollars to replace it. Considering this I would not
> > anual transmition it will likely pull a much heavier load. Modern cars
> > ood breaks they may be safer though than older cars pulling loads. This
> > n order to buy a towing vehicle for my Elver. The van I just got rid of
> > 164,000 miles still had the original breaks ( all country miles). Just
> > roblem with towing. I was told to not tow with overdrive engaged but to
> > oug
> > Best Wishes,
> > Stefan
> > trailer to the scale, take the scale to the trailer. PA State Troopers
> > > Displacement calculations should include all the above (below). Not
> > > Best Wishes,
> > > Stefan
> > > I agree with you about the meaning of displacement. However, it's
> > > pretty often true that the weight of stowed gear creeps up. It is
> > > also quite possible that the builder could add weight or use heavier
> > > prudent to base the selection on design displacement plus about 30%
> > > for a margin of safety. If, using this method, you calculate 2500
> > > Also, is the 250kg the mass of the hull alone or hull, spars, sails,
> > > V/R
> > > Chris
> > > pkortlucke wrote:
> > >> --- In bolger@yahoogroups. com, "Christopher C. Wetherill"
> > >>> The drawing of the type 1 Chebacco in sheet plywood (19' 8 ") on page
> > >>> 226 of Boats with an Open Mind shows design displacement at 1740
> > >>> pounds. The drawing on page 232 shows thew 25 footer to have 2300
> > >> pound
> > >>> displacement. It is prudent to assume a percentage over this for a
> > >>> margin of safety. You must also add the weight of the trailer.
> > >> I suspect those displacement figures include an allowance for crew and
> > >> equipment i.e. it's not the empty weight which is the applicable figure
> > >> when looking to trail. My Folding Schooner (31ft and with a steel
> > >> centreplate) weighs about 250kg empty (about 600 lbs). Hard to believe a
> > >> standard 19 ft 8 inch Chebacco could be 3 times the empty weight of a
> > >> boat 50% longer even allowing for the light weight construction of the
> > >> schooner.
> > >> Cheers
> > >> Peter
> > >> Bolger rules!!!
> > >> - no cursing, flaming, trolling, spamming, respamming, or flogging dead
> > orses
> > >> - stay on topic, stay on thread, punctuate, no 'Ed, thanks, Fred' posts
> > >> - Pls add your comments at the TOP, SIGN your posts, and snip away
> > >> - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax:
> > 978) 282-1349
> > >> - Open discussion: bolger_coffee_ lounge-subscribe @yahoogroups. com Yahoo!
> > roups Links
> > Version: 8.5.430 / Virus Database: 270.14.117/2582 - Release Date: 12/22/09
> > 8:22:00
> > no cursing, flaming, trolling, spamming, respamming, or flogging dead horses
> > Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax: (978)
> > 82-1349
> > Open discussion: bolger_coffee_ lounge-subscribe @yahoogroups. com Yahoo! Groups
> > inks
> Â
> just my input.
> Â
> doc
> To: bolger@yahoogroups.com
> Â
> Bob Rusk
> > enerally.
> > oug
> > Best Wishes,
> > Stefan
> > > Best Wishes,
> > > Stefan
> > > V/R
> > > Chris
> > >> pound
> > >> schooner.
> > >> Cheers
> > >> Peter
> > >> Bolger rules!!!
> > orses
> > 978) 282-1349
> > roups Links
> > 8:22:00
> > 82-1349
> > inks
I believe most of this discussion is overlooking the most important aspect of towing a trailer... That is ,,, Stopping the rig! I don't recall seeing any relatively small boat trailers with brakes? Horsepower is not the only issue... I occasionally VERY occasionally towed a Rhoades 19 with a v/w bug !! A mile or so... just my input. doc --- OnFri, 12/25/09, rrusk9<rrusk9@...>wrote:
The 300 lb tongue weight may be a bit high. In my experience, a tongue weight of 5-7% works well with a boat trailer. Higher tongue weights are required for travel trailers (sail area) and utility trailers (tight-coupled). If the tongue is too light it will wander and the trailer may wag back and forth dangerously. If the tongue is too heavy the rear suspension will be overloaded. It will bottom out and it will sway dangerously. With an empty luggage area or empty back seat, a mid-sized car can easily deal with 125-150 lbs of tongue weight.
Bob Rusk
> From: Doug Pollard <dougpol1@...>
> enerally.
> oug
> Best Wishes,
> Stefan
>http://www.cottagemed.org<http://www.cottagemed.org>
> > Best Wishes,
> > Stefan
> > V/R
> > Chris
> > pkortlucke wrote:
> >> --- Inbolger@yahoogroups.com, "Christopher C. Wetherill"
> >> pound
> >> schooner.
> >> Cheers
> >> Peter
> >> Bolger rules!!!
> orses
> 978) 282-1349
> >> - Unsubscribe:bolger-unsubscribe@yahoogroups.com
> >> - Open discussion:bolger_coffee_lounge-subscribe@yahoogroups.comYahoo!
> roups Links
> 8:22:00
> 82-1349
> Open discussion:bolger_coffee_lounge-subscribe@yahoogroups.comYahoo! Groups
> inks
Been looking for a decent pre-OBD II F150 with skinny tires, a smallish six and a 5 speed... they don't seem to exist. There's a cheap S10 2.2 near me
Truly dislike my '03 subaru, automatic for many reasons but this isn't a car thread
Once you get a tow vehicle, you're kind of obliged to build a boat for it... good multiple articles on Red Znger in Messing About about this issue..
--- Inbolger@yahoogroups.com, John Weiss <jrweiss98155@...> wrote:
> Synthetic oil is a good idea in any vehicle that is put to hard use like
> towing. I had an oil temp gauge in one car that I had in Albuquerque.
> Normal oil temp was around 180F in hot summer, city traffic. When I
> switched to synthetic, it immediately dropped to 150F, which was the
> thermostat on the aux oil cooler. When I got the boat a few years
> later, I hardly ever saw the oil temp at the 180 mark when towing.
> Some modern automatics are quite good. The 5-speed in my VW Passat
> doesn't "hunt" at all, and the torque converter lockup feature works well.
> etap28 wrote:
> > I killed an engine by towing a 19' RIB with a 200HP mercury (not mine) from MA to Fla. and back. It was a 1987 Dodge Caravan, 3.0 V6 Mitsubishi. Beware cooling issues!! A guy in Montana told me it was the undersized radiator that did it. The van still ran great and towed the boat without issues, but started going through oil, though it never technically overheated. Economy went from 24 hwy to 12. So it was slaving away under there. Apparently the insufficient cooling led to shrinkage of the valve guide seals. (that engine had other endemic problems too but the heat really killed it). So my tiny grain of advice would be, along with transmission coolers, oil coolers also.
> > I dislike automatics and consider them the bane of civilization
> > I don't mind them so much on bigger vehicles. Never on a 4 cylinder. My curmudgeonly 2 cents.
On Thu, Dec 24, 2009 at 1:02 PM, John Kohnen<jhkohnen@...>wrote:That Chrysler 3.3 liter engine is indeed a Good one, but the automatic
transmissions they put in those old mini-vans are No Good.
The first generation Mopar 4-speed automatics were problematic but after that they were as problem free as any modern automatic, which, by the way, is by far the most complicated part of an automobile, much more complicated and requiring tighter tolerances than the engines. I've driven four of these 4-speed automatics past the 250,000 mile mark. They'll tow 3,500 pounds. My past practice is to buy an early 90s minivan for about $1,000; drive it for 100,000 miles and then park it for parts. It ends up costing me 3 cents per mile to own and repair one of these vehicles and 10 cents per mile for fuel. It doesn't get any cheaper than that.
If you want to stay on the cheap side, don't buy a tow vehicle that you're going to use for general purpose. It's going to be much much more expensive and you'll end up burning a lot of fuel driving around lightly loaded. A friend had his Toyota pickup die on him last year. Instead of repairing his Toyota or getting another one, which wasn't going to be cheap, he bought a beater rust-bucket American 4-wheel drive pickup for $800, which he uses to haul a trailer back and forth 600 miles round-trip to his cabin in northern Minnesota, which he's rebuilding. The rest of the time, he drives something sensible.
Fred
I've been towing boats,tractors, stock trailers and what ever else has a hitchon it for about 60 years now.... My choice has always been the biggest thing i can afford,, sometimes bigger... have never had a problem... Now,,, about Bolger boats--------------- does anyone have a clamshell ??? doc --- OnThu, 12/24/09, John Weiss<jrweiss98155@...>wrote:
transmissions they put in those old mini-vans are No Good. I know from
experience! I shoulda know better when I bought the thing...
On Thu, 24 Dec 2009 06:10:25 -0800, Fred S wrote:
> minivan, I would recommend a
> Chrysler product with the 3.3 liter engine. These engines are
> bullet-proof
> (they'll easily last 300,000 miles) and have lots of low end torque,
> which
> is what you need when towing. The frame can handle the weight. I've towed
> full-sized cars on towing dollies (no brakes) all over the country with a
> rig like this and never had a problem. (I used to tow dealer trades for a
> friend). You can get a decent used minivan for a couple thousand dollars
John (jkohnen@...)
Borrowers of books--those mutilators of collections, spoilers of
the symmetry of shelves, and creators of lost volumes. (Charles
Lamb)
I would however look for a trailer with brakes.
To convince the Admiral, have her drive the RAV4. that is what sold her in my house.
Good luck,
david jost
Doug,
Mileage on a current higher powered Subaru sucks. Two sleepers are the Matrix/Vibe and the TDI VW. Both have 1500 pound tow ratings. The Matrix/Vibe gets 34mpg and the VW gets 50mpg when not towing. That VW diesel has more torque than a lot of 6 cylinders.
The Pontiac will be really cheap if you can find one as Pontiacs get discounted at closing dealerships. There is no mechanical difference between the Toyota and Pontiac. The cars are built at the NUMMI factory jointly owned by Toyota and GM. You will be able to continue to buy parts from Toyota except for trim.
I liked the Pathfinder but was not prepared to buy a 17 mpg rig. A real sleeper if you find one used is the Jeep Liberty diesel, gets about 36mpg not towing. I’ve had my Micro for nearly 20 years. Boat and trailer go about a ton. If you are not going through the mountains 150 hp is plenty and 175 if you go over mountains. A diesel with a 90hp rating may have more torque than the 175hp gas motor. I’ve towed it with 110, 150, 175, and 200hp gas engine rigs. With 110hp I downshifted a lot and could not maintain speed up much of a grade.
MylesJ
> For a minivan, I would recommend aFor my Mariner, I had a Class I hitch (2000lb max) on my Plymouth Voyager. No problems. When I traded up to my Capri 22 (2250lbs, much heavier trailer), I boldly thought the same would do for the three mile trip to the boat yard. The creaking and groaning changed my mind.
When I traded the Voyager, I got a Mercury Villager which was rated to handle the Class II hitch (3500lb max). I had no problems with that either, but I never towed either boat very far with either minivan. The Villager (sister to Nissan Quest) was very solid.
On Thu, Dec 24, 2009 at 8:37 AM, etap28<dave.irland@...>wrote:I killed an engine by towing a 19' RIB with a 200HP mercury (not mine) from MA to Fla. and back. It was a 1987 Dodge Caravan, 3.0 V6 Mitsubishi. Beware cooling issues!!
Yes, the Mitsi 3.0 liter is nothing like the Chrysler 3.3. It's got nowhere near the torque and causes the transmission to hunt and search trying to maintain speed under load. Heat is always a potential problem when towing. I once towed a Jeep from Chadron, Nebraska to Orr, Minnesota in 100+ temperatures. Even though the tow vehicle was a pickup with the 318 engine and had no trouble pulling the load, I kept the transmission out of overdrive and the air conditioning off in order to avoid overheating the engine and tranny. It was a hot drive, but nothing went wrong.
Fred
--- Inbolger@yahoogroups.com, "rowerwet" <rowerwet@...> wrote:
> rent a U-haul truck, tow to the scales and back, problem solved.
> > Best Wishes,
> > Stefan
> > anonymous
> > Troopers set up portable weigh stations using load pads that weigh
> > individual wheels. Gross vehicle weight is the sum of the weight on
> > each wheel. If you have a flat hard surface, you may be able to use
> > one of these. Perhaps they are available for rental.
> > > Best Wishes,
> > > Stefan
> > > anonymous
> > > V/R
> > > Chris
> > >>> page
> > >> pound
> > >> and
> > >> figure
> > >> believe a
> > >> the
> > >> schooner.
> > >> Cheers
> > >> Peter
> > >> Bolger rules!!!
> > >> dead horses
> > >> posts
> > >> 01930, Fax: (978) 282-1349
> > >> Yahoo! Groups Links
Fred
> Best Wishes,
> Stefan
> anonymous
> > Best Wishes,
> > Stefan
> > anonymous
> > V/R
> > Chris
> >>> page
> >> pound
> >> and
> >> figure
> >> believe a
> >> the
> >> schooner.
> >> Cheers
> >> Peter
> >> Bolger rules!!!
> >> dead horses
> >> posts
> >> Yahoo! Groups Links
Best Wishes,
A couple of comments.
I had a Rhodes Mariner which is a similar size and configuration to a Chebacco. FG construction (which would be heavier than the Chebacco) and a couple hundred pounds of ballast. The brochure weight was about 1350 lbs.
The weight limit for the car and hitch include the weight of the trailer. I figured 2000 lbs. to be a generous estimate. Reading the manual of my Plymouth Voyager carefully, I learned that the van's tow weight limit included cargo weight (including passengers) inside the van, not just the trailer etc. The brakes and transmission have to cope with the weight wherever it is.
If you are within the prescribed limits for your tow vehicle, trailer brakes are not required for this class of hitch. If you bump up to the 3500 lb class, then they are.
The hitch weight is suppose to be 10% or less of the total load (you can look it up). If you have 300 lbs at the hitch, your boat is too far forward.
Sent: Wed, Dec 23, 2009 11:07 am
That is surprising to me. Modern transmition are constantly shifting according to computer demands that allows you to hold your foot steady on the gas while the transmition is constantly shifting on even slight upgrades, running level and down hill. I read in an article that these computers have to be trained for the kind of driving you do. When you start pulling a trailer the first few miles is spent retraining the computer for the heavier load and after you remove the trailer the computer retrains itself. You may well be right though as most manual transmitions are of older design and a lot has been done to improve automatic ones. Also the manual transmitions use thicker oil to lubricate the gears and it doesn't carry off heat as well. Maybe so! DougGBroadlick@...wrote:> > tow ratings for autos is lower for manual transmission than automatic. > I have lost 3 transmissions towing boats, never an engine > you must put on an oil cooler but make sure they use new hoses > > > -----Original Message----- > From: Doug Pollard <dougpol1@...> > To:bolger@yahoogroups.com> Sent: Wed, Dec 23, 2009 9:55 am > Subject: Re: [bolger] Re: Towing a Chebacco > > I recently replaced my van with a new to me used one. I had wanted to > buy a sedan but in checking out the specs on most of the lighter > automobiles I found them not suitable for towing. Yes you can tow with > them. I wanted a v6 engine thinking that towing my Elver would do less > damage to the engine if it were a little bigger than a 4cylinder one. > All the lighter sedans I checked had a 1000 lb towing limit on them. > Cars with v8 engines were much higher and mini vans had 2000 lb limit > unless you add a transmition oil cooler. Then the limit is 3000 lbs > generally. > I suspect that limit is based on the damage caused by overloading the > transmition rather than breaking power. Modern breaks with the metal > impregnated shoe's can stand tremendous heat though it is possible to > warp the rotors. If you over heat a transmition you are likely looking > at several thousand dollars to replace it. Considering this I would not > pull more than the are recomended for. If your car is old and has a > manual transmition it will likely pull a much heavier load. Modern cars > are built to get good gas milage not to pull heavy loads. With really > good breaks they may be safer though than older cars pulling loads. This > is my opinion only but it is based on about a month of online research > in order to buy a towing vehicle for my Elver. The van I just got rid of > @ 164,000 miles still had the original breaks ( all country miles). Just > before selling it because I was selling to a young single mom with a > couple kids I didn't want to risk killing them so replaced the breaks > and rotors because the rotars were getting thin. the shoes were less > than half worn out. What I am saying is the transmitions are the big > problem with towing. I was told to not tow with overdrive engaged but to > shift into 3rd gear for towing. > Doug > > > > > Stefan Topolski wrote: > > > > :) - yes, i can see how to do that now that you have got me thinking. > > I could probably place the 2 x 4 under the trailer frame right behind > > each wheel (not forgetting the tongue too) to make it easier without > > adding significant error to the calculation. > > > > > > Leave it to an engineer to suggest i play at Archimedes. > > > > > > Best Wishes, > > Stefan > > > > "One gathers peace as a feather in the palm of one's hand." -anonymous > > > >http://www.cottagemed.org<http://www.cottagemed.org/> <http://www.cottagemed.org<http://www.cottagemed.org/>>> > > > > > > > > > > > On Dec 23, 2009, at 12:50 AM, Christopher C. Wetherill wrote: > > > > Off the wall suggestion time. If you are uncomfortable taking the > > trailer to the scale, take the scale to the trailer. PA State Troopers > > set up portable weigh stations using load pads that weigh individual > > wheels. Gross vehicle weight is the sum of the weight on each wheel. > > If you have a flat hard surface, you may be able to use one of these. > > Perhaps they are available for rental. > > > > You may be able to do something similar with a 2x4, a fulcrum, your > > weight, and algebra. (Yes, I am a Mechanical Engineer) > > > > Stefan Topolski wrote: > > > >> Displacement calculations should include all the above (below). Not > >> included might be people, food, clothing, and bric a brac. > >> > >> I'm prepared for others to correct me with no quarter taken... > >> > >> Best Wishes, > >> Stefan > >> > >> "One gathers peace as a feather in the palm of one's hand." -anonymous > >> > >> > >>http://www.cottagemed.org<http://www.cottagemed.org/> <http://www.cottagemed.org<http://www.cottagemed.org/>>> >> > >> > >> > >> > >> > >> On Dec 23, 2009, at 12:18 AM, Christopher C. Wetherill wrote: > >> > >> I agree with you about the meaning of displacement. However, it's > >> pretty often true that the weight of stowed gear creeps up. It is > >> also quite possible that the builder could add weight or use heavier > >> wood than PCB used for the design calcs. I feel it is therefore > >> prudent to base the selection on design displacement plus about 30% > >> for a margin of safety. If, using this method, you calculate 2500 > >> pounds and the car can tow 2500 pounds, you have ample margin. > >> > >> Also, is the 250kg the mass of the hull alone or hull, spars, sails, > >> rigging and, auxiliary? > >> > >> V/R > >> Chris > >> > >> pkortlucke wrote: > >> > >>> --- Inbolger@yahoogroups.com<mailto:bolger@yahoogroups.com>,"Christopher C. Wetherill"> >>> <wetherillc@...> wrote: > >>> > >>>> The drawing of the type 1 Chebacco in sheet plywood (19' 8 ") on page > >>>> 226 of Boats with an Open Mind shows design displacement at 1740 > >>>> pounds. The drawing on page 232 shows thew 25 footer to have 2300 > >>>> > >>> pound > >>> > >>>> displacement. It is prudent to assume a percentage over this for a > >>>> margin of safety. You must also add the weight of the trailer. > >>>> > >>> I suspect those displacement figures include an allowance for crew and > >>> equipment i.e. it's not the empty weight which is the applicable figure > >>> when looking to trail. My Folding Schooner (31ft and with a steel > >>> centreplate) weighs about 250kg empty (about 600 lbs). Hard to believe a > >>> standard 19 ft 8 inch Chebacco could be 3 times the empty weight of a > >>> boat 50% longer even allowing for the light weight construction of the > >>> schooner. > >>> > >>> Cheers > >>> > >>> Peter > >>> > >>> > >>> > >>> > >>> > >>> > >>> ------------------------------------ > >>> > >>> Bolger rules!!! > >>> - NO "GO AWAY SPAMMER!" posts!!! Please! > >>> - no cursing, flaming, trolling, spamming, respamming, or flogging dead > horses > >>> - stay on topic, stay on thread, punctuate, no 'Ed, thanks, Fred' posts > >>> - Pls add your comments at the TOP, SIGN your posts, and snip away > >>> - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax: > (978) 282-1349 > >>> - Unsubscribe:bolger-unsubscribe@yahoogroups.com<mailto:bolger-unsubscribe@yahoogroups.com> > >>> - Open discussion:bolger_coffee_lounge-subscribe@yahoogroups.com<mailto:bolger_coffee_lounge-subscribe@yahoogroups.com> Yahoo!> Groups Links > >>> > >>> > >>> > >>> > >>> > >> > >> > > > > > > > > ------------------------------------------------------------------------ > > > > > > No virus found in this incoming message. > > Checked by AVG -www.avg.com<http://www.avg.com/> > > Version: 8.5.430 / Virus Database: 270.14.117/2582 - Release Date: 12/22/09 > 18:22:00 > > > > > > > > ------------------------------------ > > Bolger rules!!! > - NO "GO AWAY SPAMMER!" posts!!! Please! > - no cursing, flaming, trolling, spamming, respamming, or flogging dead horses > - stay on topic, stay on thread, punctuate, no 'Ed, thanks, Fred' posts > - Pls add your comments at the TOP, SIGN your posts, and snip away > - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax:(978)> 282-1349 > - Unsubscribe:bolger-unsubscribe@yahoogroups.com<mailto:bolger-unsubscribe@yahoogroups.com> > - Open discussion:bolger_coffee_lounge-subscribe@yahoogroups.com<mailto:bolger_coffee_lounge-subscribe@yahoogroups.com> Yahoo! Groups> Links > > > > > ------------------------------------------------------------------------ > > > No virus found in this incoming message. > Checked by AVG -www.avg.com> Version: 8.5.430 / Virus Database: 270.14.117/2583 - Release Date: 12/23/0908:28:00> >------------------------------------ Bolger rules!!! - NO "GO AWAY SPAMMER!" posts!!! Please! - no cursing, flaming, trolling, spamming, respamming, or flogging dead horses - stay on topic, stay on thread, punctuate, no 'Ed, thanks, Fred' posts - Pls add your comments at the TOP, SIGN your posts, and snip away - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax: (978) 282-1349 - Unsubscribe:bolger-unsubscribe@yahoogroups.com- Open discussion:bolger_coffee_lounge-subscribe@yahoogroups.comYahoo! Groups Links <*> To visit your group on the web, go to:http://groups.yahoo.com/group/bolger/<*> Your email settings: Individual Email | Traditional <*> To change settings online go to:http://groups.yahoo.com/group/bolger/join(Yahoo! ID required) <*> To change settings via email:bolger-digest@yahoogroups.combolger-fullfeatured@yahoogroups.com<*> To unsubscribe from this group, send an email to:bolger-unsubscribe@yahoogroups.com<*> Your use of Yahoo! Groups is subject to:http://docs.yahoo.com/info/terms/
V/R
Chris
I was really interested in that model yesterday, and I'm actually trying to lean my wife that way now. I didn't know why there was a difference in the towing capacity between subaru models, and I still don't know why my wife hasn't shown much interest in the Legacy Outback yet, but that's what we husbands do - live in darkness and ignorance until enlightened by she who must be obeyed.
than the transmission itself. I towed a #1200 rig with my '82 Saab
Turbo 5-speed for 4 years without any problems. I replaced the clutch
at 100K miles (before I had the boat) because of the throwout bearing --
clutch itself was fine. I also used synthetic oil in the engine and
transmission, and had an aux oil cooler.
Doug Pollard wrote:
That is surprising to me. Modern transmition are constantly shiftingaccording to computer demands that allows you to hold your foot steadyon the gas while the transmition is constantly shifting on even slightupgrades, running level and down hill. I read in an article that thesecomputers have to be trained for the kind of driving you do. When youstart pulling a trailer the first few miles is spent retraining thecomputer for the heavier load and after you remove the trailer thecomputer retrains itself. You may well be right though as most manualtransmitions are of older design and a lot has been done to improveautomatic ones. Also the manual transmitions use thicker oil tolubricate the gears and it doesn't carry off heat as well. Maybe so!Doug
What about a 3L 6 cyl outback? The towing capacity should be much higher than the Forrester, which is built on the Impreza platform. The downsides are that it requires a higher grade of gas than the naturally aspirated 4 cyl. and that you pay a premium for the fancy interior.
This sounds like great advice.A manual should be able to pull more than an automatic, but then again perhaps the slippage in an automatic gives more leeway against the pulls, pushes, and bounces of a heavy trailer that would provide shock loads on the transmission.As for the issue of the admiral, she hates the image of SUV's and low gas mileage in general - she really seems like a subaru or similar type of gal.We're actively negotiating right now.-stow ratings for autos is lower for manual transmission than automatic.I have lost 3 transmissions towing boats, never an engineyou must put on an oil cooler but make sure they use new hoses-----Original Message-----
Subject: Re: [bolger] Re: Towing a ChebaccoI recently replaced my van with a new to me used one. I had wanted to buy a sedan but in checking out the specs on most of the lighter automobiles I found them not suitable for towing. Yes you can tow with them. I wanted a v6 engine thinking that towing my Elver would do less damage to the engine if it were a little bigger than a 4cylinder one. All the lighter sedans I checked had a 1000 lb towing limit on them. Cars with v8 engines were much higher and mini vans had 2000 lb limit unless you add a transmition oil cooler. Then the limit is 3000 lbs generally. I suspect that limit is based on the damage caused by overloading the transmition rather than breaking power. Modern breaks with the metal impregnated shoe's can stand tremendous heat though it is possible to warp the rotors. If you over heat a transmition you are likely looking at several thousand dollars to replace it. Considering this I would not pull more than the are recomended for. If your car is old and has a manual transmition it will likely pull a much heavier load. Modern cars are built to get good gas milage not to pull heavy loads. With really good breaks they may be safer though than older cars pulling loads. This is my opinion only but it is based on about a month of online research in order to buy a towing vehicle for my Elver. The van I just got rid of @ 164,000 miles still had the original breaks ( all country miles). Just before selling it because I was selling to a young single mom with a couple kids I didn't want to risk killing them so replaced the breaks and rotors because the rotars were getting thin. the shoes were less than half worn out. What I am saying is the transmitions are the big problem with towing. I was told to not tow with overdrive engaged but to shift into 3rd gear for towing. Doug Stefan Topolski wrote: > > :) - yes, i can see how to do that now that you have got me thinking. > I could probably place the 2 x 4 under the trailer frame right behind > each wheel (not forgetting the tongue too) to make it easier without > adding significant error to the calculation. > > > Leave it to an engineer to suggest i play at Archimedes. > > > Best Wishes, > Stefan > > "One gathers peace as a feather in the palm of one's hand." -anonymous > >http://www.cottagem ed.org<http://www.cottagem ed.org> > > > > > > On Dec 23, 2009, at 12:50 AM, Christopher C. Wetherill wrote: > > Off the wall suggestion time. If you are uncomfortable taking the > trailer to the scale, take the scale to the trailer. PA State Troopers > set up portable weigh stations using load pads that weigh individual > wheels. Gross vehicle weight is the sum of the weight on each wheel. > If you have a flat hard surface, you may be able to use one of these. > Perhaps they are available for rental. > > You may be able to do something similar with a 2x4, a fulcrum, your > weight, and algebra. (Yes, I am a Mechanical Engineer) > > Stefan Topolski wrote: > >> Displacement calculations should include all the above (below). Not >> included might be people, food, clothing, and bric a brac. >> >> I'm prepared for others to correct me with no quarter taken... >> >> Best Wishes, >> Stefan >> >> "One gathers peace as a feather in the palm of one's hand." -anonymous >> >> >>http://www.cottagem ed.org<http://www.cottagem ed.org> >> >> >> >> >> >> On Dec 23, 2009, at 12:18 AM, Christopher C. Wetherill wrote: >> >> I agree with you about the meaning of displacement. However, it's >> pretty often true that the weight of stowed gear creeps up. It is >> also quite possible that the builder could add weight or use heavier >> wood than PCB used for the design calcs. I feel it is therefore >> prudent to base the selection on design displacement plus about 30% >> for a margin of safety. If, using this method, you calculate 2500 >> pounds and the car can tow 2500 pounds, you have ample margin. >> >> Also, is the 250kg the mass of the hull alone or hull, spars, sails, >> rigging and, auxiliary? >> >> V/R >> Chris >> >> pkortlucke wrote: >> >>> --- Inbolger@yahoogroups. com, "Christopher C. Wetherill" >>> <wetherillc@. ..> wrote: >>> >>>> The drawing of the type 1 Chebacco in sheet plywood (19' 8 ") on page >>>> 226 of Boats with an Open Mind shows design displacement at 1740 >>>> pounds. The drawing on page 232 shows thew 25 footer to have 2300 >>>> >>> pound >>> >>>> displacement. It is prudent to assume a percentage over this for a >>>> margin of safety. You must also add the weight of the trailer. >>>> >>> I suspect those displacement figures include an allowance for crew and >>> equipment i.e. it's not the empty weight which is the applicable figure >>> when looking to trail. My Folding Schooner (31ft and with a steel >>> centreplate) weighs about 250kg empty (about 600 lbs). Hard to believe a >>> standard 19 ft 8 inch Chebacco could be 3 times the empty weight of a >>> boat 50% longer even allowing for the light weight construction of the >>> schooner. >>> >>> Cheers >>> >>> Peter >>> >>> >>> >>> >>> >>> >>> ------------ --------- --------- ------ >>> >>> Bolger rules!!! >>> - NO "GO AWAY SPAMMER!" posts!!! Please! >>> - no cursing, flaming, trolling, spamming, respamming, or flogging dead horses >>> - stay on topic, stay on thread, punctuate, no 'Ed, thanks, Fred' posts >>> - Pls add your comments at the TOP, SIGN your posts, and snip away >>> - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax: (978) 282-1349 >>> - Unsubscribe:bolger-unsubscribe@ yahoogroups. com>>> - Open discussion:bolger_coffee_ lounge-subscribe @yahoogroups. comYahoo! Groups Links >>> >>> >>> >>> >>> >> >> > > > > ------------ --------- --------- --------- --------- --------- --------- ------ > > > No virus found in this incoming message. > Checked by AVG -www.avg.com> Version: 8.5.430 / Virus Database: 270.14.117/2582 - Release Date: 12/22/09 18:22:00 > > ------------ --------- --------- ------ Bolger rules!!! - NO "GO AWAY SPAMMER!" posts!!! Please! - no cursing, flaming, trolling, spamming, respamming, or flogging dead horses - stay on topic, stay on thread, punctuate, no 'Ed, thanks, Fred' posts - Pls add your comments at the TOP, SIGN your posts, and snip away - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax: (978) 282-1349 - Unsubscribe:bolger-unsubscribe@ yahoogroups. com- Open discussion:bolger_coffee_ lounge-subscribe @yahoogroups. comYahoo! Groups Links <*> To visit your group on the web, go to:http://groups. yahoo.com/ group/bolger/<*> Your email settings: Individual Email | Traditional <*> To change settings online go to:http://groups. yahoo.com/ group/bolger/ join(Yahoo! ID required) <*> To change settings via email:bolger-digest@ yahoogroups. combolger-fullfeatured @yahoogroups. com<*> To unsubscribe from this group, send an email to:bolger-unsubscribe@ yahoogroups. com<*> Your use of Yahoo! Groups is subject to:http://docs. yahoo.com/ info/terms/
Best Wishes,
> Doug
This sounds like great advice.A manual should be able to pull more than an automatic, but then again perhaps the slippage in an automatic gives more leeway against the pulls, pushes, and bounces of a heavy trailer that would provide shock loads on the transmission.As for the issue of the admiral, she hates the image of SUV's and low gas mileage in general - she really seems like a subaru or similar type of gal.We're actively negotiating right now.-sOn Dec 23, 2009, at 10:36 AM,GBroadlick@...wrote:tow ratings for autos is lower for manual transmission than automatic.I have lost 3 transmissions towing boats, never an engineyou must put on an oil cooler but make sure they use new hoses-----Original Message-----
I recently replaced my van with a new to me used one. I had wanted to buy a sedan but in checking out the specs on most of the lighter automobiles I found them not suitable for towing. Yes you can tow with them. I wanted a v6 engine thinking that towing my Elver would do less damage to the engine if it were a little bigger than a 4cylinder one. All the lighter sedans I checked had a 1000 lb towing limit on them. Cars with v8 engines were much higher and mini vans had 2000 lb limit unless you add a transmition oil cooler. Then the limit is 3000 lbs generally. I suspect that limit is based on the damage caused by overloading the transmition rather than breaking power. Modern breaks with the metal impregnated shoe's can stand tremendous heat though it is possible to warp the rotors. If you over heat a transmition you are likely looking at several thousand dollars to replace it. Considering this I would not pull more than the are recomended for. If your car is old and has a manual transmition it will likely pull a much heavier load. Modern cars are built to get good gas milage not to pull heavy loads. With really good breaks they may be safer though than older cars pulling loads. This is my opinion only but it is based on about a month of online research in order to buy a towing vehicle for my Elver. The van I just got rid of @ 164,000 miles still had the original breaks ( all country miles). Just before selling it because I was selling to a young single mom with a couple kids I didn't want to risk killing them so replaced the breaks and rotors because the rotars were getting thin. the shoes were less than half worn out. What I am saying is the transmitions are the big problem with towing. I was told to not tow with overdrive engaged but to shift into 3rd gear for towing. Doug Stefan Topolski wrote:> > :) - yes, i can see how to do that now that you have got me thinking. > I could probably place the 2 x 4 under the trailer frame right behind > each wheel (not forgetting the tongue too) to make it easier without > adding significant error to the calculation. > > > Leave it to an engineer to suggest i play at Archimedes. > > > Best Wishes, > Stefan > > "One gathers peace as a feather in the palm of one's hand." -anonymous > >http://www.cottagem ed.org<http://www.cottagem ed.org> > > > > > > On Dec 23, 2009, at 12:50 AM, Christopher C. Wetherill wrote: > > Off the wall suggestion time. If you are uncomfortable taking the > trailer to the scale, take the scale to the trailer. PA State Troopers > set up portable weigh stations using load pads that weigh individual > wheels. Gross vehicle weight is the sum of the weight on each wheel. > If you have a flat hard surface, you may be able to use one of these. > Perhaps they are available for rental. > > You may be able to do something similar with a 2x4, a fulcrum, your > weight, and algebra. (Yes, I am a Mechanical Engineer) > > Stefan Topolski wrote: > >> Displacement calculations should include all the above (below). Not >> included might be people, food, clothing, and bric a brac. >> >> I'm prepared for others to correct me with no quarter taken... >> >> Best Wishes, >> Stefan >> >> "One gathers peace as a feather in the palm of one's hand." -anonymous >> >> >>http://www.cottagem ed.org<http://www.cottagem ed.org> >> >> >> >> >> >> On Dec 23, 2009, at 12:18 AM, Christopher C. Wetherill wrote: >> >> I agree with you about the meaning of displacement. However, it's >> pretty often true that the weight of stowed gear creeps up. It is >> also quite possible that the builder could add weight or use heavier >> wood than PCB used for the design calcs. I feel it is therefore >> prudent to base the selection on design displacement plus about 30% >> for a margin of safety. If, using this method, you calculate 2500 >> pounds and the car can tow 2500 pounds, you have ample margin. >> >> Also, is the 250kg the mass of the hull alone or hull, spars, sails, >> rigging and, auxiliary? >> >> V/R >> Chris >> >> pkortlucke wrote: >> >>> --- Inbolger@yahoogroups. com, "Christopher C. Wetherill" >>> <wetherillc@. ..> wrote: >>> >>>> The drawing of the type 1 Chebacco in sheet plywood (19' 8 ") on page >>>> 226 of Boats with an Open Mind shows design displacement at 1740 >>>> pounds. The drawing on page 232 shows thew 25 footer to have 2300 >>>> >>> pound >>> >>>> displacement. It is prudent to assume a percentage over this for a >>>> margin of safety. You must also add the weight of the trailer. >>>> >>> I suspect those displacement figures include an allowance for crew and >>> equipment i.e. it's not the empty weight which is the applicable figure >>> when looking to trail. My Folding Schooner (31ft and with a steel >>> centreplate) weighs about 250kg empty (about 600 lbs). Hard to believe a >>> standard 19 ft 8 inch Chebacco could be 3 times the empty weight of a >>> boat 50% longer even allowing for the light weight construction of the >>> schooner. >>> >>> Cheers >>> >>> Peter >>> >>> >>> >>> >>> >>> >>> ------------ --------- --------- ------ >>> >>> Bolger rules!!! >>> - NO "GO AWAY SPAMMER!" posts!!! Please! >>> - no cursing, flaming, trolling, spamming, respamming, or flogging deadhorses>>> - stay on topic, stay on thread, punctuate, no 'Ed, thanks, Fred' posts >>> - Pls add your comments at the TOP, SIGN your posts, and snip away >>> - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax:(978) 282-1349>>> - Unsubscribe:bolger-unsubscribe@ yahoogroups. com>>> - Open discussion:bolger_coffee_ lounge-subscribe @yahoogroups. comYahoo!Groups Links>>> >>> >>> >>> >>> >> >> > > > > ------------ --------- --------- --------- --------- --------- --------- ------ > > > No virus found in this incoming message. > Checked by AVG -www.avg.com> Version: 8.5.430 / Virus Database: 270.14.117/2582 - Release Date: 12/22/0918:22:00> >------------ --------- --------- ------ Bolger rules!!! - NO "GO AWAY SPAMMER!" posts!!! Please! - no cursing, flaming, trolling, spamming, respamming, or flogging dead horses - stay on topic, stay on thread, punctuate, no 'Ed, thanks, Fred' posts - Pls add your comments at the TOP, SIGN your posts, and snip away - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax: (978) 282-1349 - Unsubscribe:bolger-unsubscribe@ yahoogroups. com- Open discussion:bolger_coffee_ lounge-subscribe @yahoogroups. comYahoo! Groups Links <*> To visit your group on the web, go to:http://groups. yahoo.com/ group/bolger/<*> Your email settings: Individual Email | Traditional <*> To change settings online go to:http://groups. yahoo.com/ group/bolger/ join(Yahoo! ID required) <*> To change settings via email:bolger-digest@ yahoogroups. combolger-fullfeatured @yahoogroups. com<*> To unsubscribe from this group, send an email to:bolger-unsubscribe@ yahoogroups. com<*> Your use of Yahoo! Groups is subject to:http://docs. yahoo.com/ info/terms/
Doug
> generally.
> Doug
> > Best Wishes,
> > Stefan
> >> Best Wishes,
> >> Stefan
> >> V/R
> >> Chris
> >> pkortlucke wrote:
> >>> --- Inbolger@yahoogroups.com<mailto:bolger@yahoogroups.com>, "Christopher C. Wetherill"
> >>> pound
> >>> schooner.
> >>> Cheers
> >>> Peter
> >>> Bolger rules!!!
> horses
> (978) 282-1349
> Groups Links
> > Checked by AVG - www.avg.com <http://www.avg.com/>
> 18:22:00
> 282-1349
> Links
> Version: 8.5.430 / Virus Database: 270.14.117/2583 - Release Date: 12/23/09 08:28:00
in a truck? If the latter, check out the Nissan Pathfinder -- used to
have a fairly large engine plus the body engineering inherits from a
sedan rather than a pick-up, so it is more comfortable for the
admiral types.
Patrick
On Dec 22, 2009, at 7:19 PM, reddoc000 wrote:
> I've searched posts and can't be sure...
> How much does a standard professionally built Chebacco on a good
> trailer as long as the boat is weigh? Can a Subaru tow it safely
> (with trailer brakes etc.) ?
> The reason for asking is this - i was assured that i could easily
> tow it but now that the boat has arrived the tongue weight's almost
> 300 pounds and I have second thoughts. Even if i adjust the wheels
> and tongue weight, I don't really want to haul it down the mountain
> with my Forester or Impreza to find out how much it weighs at the
> truck stop scale if i shouldn't be hauling it with my Forester or
> Impreza to begin with...
> Here's a second question - IF i can't (trusting that we american
> yanks do choose overkill even to tow bananas) how do you suggest i
> convince the admiral that we need a more truck-like non-subaru to
> do said tows on the highways and byways of New England?
> dead horses
> posts
I recently replaced my van with a new to me used one. I had wanted to buy a sedan but in checking out the specs on most of the lighter automobiles I found them not suitable for towing. Yes you can tow with them. I wanted a v6 engine thinking that towing my Elver would do less damage to the engine if it were a little bigger than a 4cylinder one. All the lighter sedans I checked had a 1000 lb towing limit on them. Cars with v8 engines were much higher and mini vans had 2000 lb limit unless you add a transmition oil cooler. Then the limit is 3000 lbs generally. I suspect that limit is based on the damage caused by overloading the transmition rather than breaking power. Modern breaks with the metal impregnated shoe's can stand tremendous heat though it is possible to warp the rotors. If you over heat a transmition you are likely looking at several thousand dollars to replace it. Considering this I would not pull more than the are recomended for. If your car is old and has a manual transmition it will likely pull a much heavier load. Modern cars are built to get good gas milage not to pull heavy loads. With really good breaks they may be safer though than older cars pulling loads. This is my opinion only but it is based on about a month of online research in order to buy a towing vehicle for my Elver. The van I just got rid of @ 164,000 miles still had the original breaks ( all country miles). Just before selling it because I was selling to a young single mom with a couple kids I didn't want to risk killing them so replaced the breaks and rotors because the rotars were getting thin. the shoes were less than half worn out. What I am saying is the transmitions are the big problem with towing. I was told to not tow with overdrive engaged but to shift into 3rd gear for towing. Doug Stefan Topolski wrote:> > :) - yes, i can see how to do that now that you have got me thinking. > I could probably place the 2 x 4 under the trailer frame right behind > each wheel (not forgetting the tongue too) to make it easier without > adding significant error to the calculation. > > > Leave it to an engineer to suggest i play at Archimedes. > > > Best Wishes, > Stefan > > "One gathers peace as a feather in the palm of one's hand." -anonymous > >http://www.cottagemed.org<http://www.cottagemed.org> > > > > > > On Dec 23, 2009, at 12:50 AM, Christopher C. Wetherill wrote: > > Off the wall suggestion time. If you are uncomfortable taking the > trailer to the scale, take the scale to the trailer. PA State Troopers > set up portable weigh stations using load pads that weigh individual > wheels. Gross vehicle weight is the sum of the weight on each wheel. > If you have a flat hard surface, you may be able to use one of these. > Perhaps they are available for rental. > > You may be able to do something similar with a 2x4, a fulcrum, your > weight, and algebra. (Yes, I am a Mechanical Engineer) > > Stefan Topolski wrote: > >> Displacement calculations should include all the above (below). Not >> included might be people, food, clothing, and bric a brac. >> >> I'm prepared for others to correct me with no quarter taken... >> >> Best Wishes, >> Stefan >> >> "One gathers peace as a feather in the palm of one's hand." -anonymous >> >> >>http://www.cottagemed.org<http://www.cottagemed.org> >> >> >> >> >> >> On Dec 23, 2009, at 12:18 AM, Christopher C. Wetherill wrote: >> >> I agree with you about the meaning of displacement. However, it's >> pretty often true that the weight of stowed gear creeps up. It is >> also quite possible that the builder could add weight or use heavier >> wood than PCB used for the design calcs. I feel it is therefore >> prudent to base the selection on design displacement plus about 30% >> for a margin of safety. If, using this method, you calculate 2500 >> pounds and the car can tow 2500 pounds, you have ample margin. >> >> Also, is the 250kg the mass of the hull alone or hull, spars, sails, >> rigging and, auxiliary? >> >> V/R >> Chris >> >> pkortlucke wrote: >> >>> --- Inbolger@yahoogroups.com, "Christopher C. Wetherill" >>> <wetherillc@...> wrote: >>> >>>> The drawing of the type 1 Chebacco in sheet plywood (19' 8 ") on page >>>> 226 of Boats with an Open Mind shows design displacement at 1740 >>>> pounds. The drawing on page 232 shows thew 25 footer to have 2300 >>>> >>> pound >>> >>>> displacement. It is prudent to assume a percentage over this for a >>>> margin of safety. You must also add the weight of the trailer. >>>> >>> I suspect those displacement figures include an allowance for crew and >>> equipment i.e. it's not the empty weight which is the applicable figure >>> when looking to trail. My Folding Schooner (31ft and with a steel >>> centreplate) weighs about 250kg empty (about 600 lbs). Hard to believe a >>> standard 19 ft 8 inch Chebacco could be 3 times the empty weight of a >>> boat 50% longer even allowing for the light weight construction of the >>> schooner. >>> >>> Cheers >>> >>> Peter >>> >>> >>> >>> >>> >>> >>> ------------------------------------ >>> >>> Bolger rules!!! >>> - NO "GO AWAY SPAMMER!" posts!!! Please! >>> - no cursing, flaming, trolling, spamming, respamming, or flogging deadhorses>>> - stay on topic, stay on thread, punctuate, no 'Ed, thanks, Fred' posts >>> - Pls add your comments at the TOP, SIGN your posts, and snip away >>> - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax:(978) 282-1349>>> - Unsubscribe:bolger-unsubscribe@yahoogroups.com>>> - Open discussion:bolger_coffee_lounge-subscribe@yahoogroups.comYahoo!Groups Links>>> >>> >>> >>> >>> >> >> > > > > ------------------------------------------------------------------------ > > > No virus found in this incoming message. > Checked by AVG -www.avg.com> Version: 8.5.430 / Virus Database: 270.14.117/2582 - Release Date: 12/22/0918:22:00> >------------------------------------ Bolger rules!!! - NO "GO AWAY SPAMMER!" posts!!! Please! - no cursing, flaming, trolling, spamming, respamming, or flogging dead horses - stay on topic, stay on thread, punctuate, no 'Ed, thanks, Fred' posts - Pls add your comments at the TOP, SIGN your posts, and snip away - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax: (978) 282-1349 - Unsubscribe:bolger-unsubscribe@yahoogroups.com- Open discussion:bolger_coffee_lounge-subscribe@yahoogroups.comYahoo! Groups Links <*> To visit your group on the web, go to:http://groups.yahoo.com/group/bolger/<*> Your email settings: Individual Email | Traditional <*> To change settings online go to:http://groups.yahoo.com/group/bolger/join(Yahoo! ID required) <*> To change settings via email:bolger-digest@yahoogroups.combolger-fullfeatured@yahoogroups.com<*> To unsubscribe from this group, send an email to:bolger-unsubscribe@yahoogroups.com<*> Your use of Yahoo! Groups is subject to:http://docs.yahoo.com/info/terms/
generally.
Doug
> Best Wishes,
> Stefan
>> Best Wishes,
>> Stefan
>> V/R
>> Chris
>>> pound
>>> schooner.
>>> Cheers
>>> Peter
>>> Bolger rules!!!
Best Wishes,
Off the wall suggestion time. If you are uncomfortable taking the trailer to the scale, take the scale to the trailer. PA State Troopers set up portable weigh stations using load pads that weigh individual wheels. Gross vehicle weight is the sum of the weight on each wheel. If you have a flat hard surface, you may be able to use one of these. Perhaps they are available for rental.
You may be able to do something similar with a 2x4, a fulcrum, your weight, and algebra. (Yes, I am a Mechanical Engineer)
Displacement calculations should include all the above (below). Not included might be people, food, clothing, and bric a brac.I'm prepared for others to correct me with no quarter taken...
Best Wishes,Stefan"One gathers peace as a feather in the palm of one's hand." -anonymousOn Dec 23, 2009, at 12:18 AM, Christopher C. Wetherill wrote:I agree with you about the meaning of displacement. However, it's pretty often true that the weight of stowed gear creeps up. It is also quite possible that the builder could add weight or use heavier wood than PCB used for the design calcs. I feel it is therefore prudent to base the selection on design displacement plus about 30% for a margin of safety. If, using this method, you calculate 2500 pounds and the car can tow 2500 pounds, you have ample margin.
Also, is the 250kg the mass of the hull alone or hull, spars, sails, rigging and, auxiliary?
V/R
Chris
pkortlucke wrote:--- Inbolger@yahoogroups. com, "Christopher C. Wetherill"<wetherillc@. ..>wrote:The drawing of the type 1 Chebacco in sheet plywood (19' 8 ") on page 226 of Boats with an Open Mind shows design displacement at 1740 pounds. The drawing on page 232 shows thew 25 footer to have 2300pounddisplacement. It is prudent to assume a percentage over this for a margin of safety. You must also add the weight of the trailer.I suspect those displacement figures include an allowance for crew and equipment i.e. it's not the empty weight which is the applicable figure when looking to trail. My Folding Schooner (31ft and with a steel centreplate) weighs about 250kg empty (about 600 lbs). Hard to believe a standard 19 ft 8 inch Chebacco could be 3 times the empty weight of a boat 50% longer even allowing for the light weight construction of the schooner. Cheers Peter ------------ --------- --------- ------ Bolger rules!!! - NO "GO AWAY SPAMMER!" posts!!! Please! - no cursing, flaming, trolling, spamming, respamming, or flogging dead horses - stay on topic, stay on thread, punctuate, no 'Ed, thanks, Fred' posts - Pls add your comments at the TOP, SIGN your posts, and snip away - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax: (978) 282-1349 - Unsubscribe:bolger-unsubscribe@ yahoogroups. com- Open discussion:bolger_coffee_ lounge-subscribe @yahoogroups. comYahoo! Groups Links <*> To visit your group on the web, go to:http://groups. yahoo.com/ group/bolger/<*> Your email settings: Individual Email | Traditional <*> To change settings online go to:http://groups. yahoo.com/ group/bolger/ join(Yahoo! ID required) <*> To change settings via email:bolger-digest@ yahoogroups. combolger-fullfeatured @yahoogroups. com<*> To unsubscribe from this group, send an email to:bolger-unsubscribe@ yahoogroups. com<*> Your use of Yahoo! Groups is subject to:http://docs. yahoo.com/ info/terms/
> I agree with you about the meaning of displacement. >
> rigging and, auxiliary?Yes that's all sailing gear and 3.3hp auxiliary and fuel- the empty
weight as she sits on the trailer.
Cheers
V/R
Chris
The drawing of the type 1 Chebacco in sheet plywood (19' 8 ") on page 226 of Boats with an Open Mind shows design displacement at 1740 pounds. The drawing on page 232 shows thew 25 footer to have 2300 pound displacement. It is prudent to assume a percentage over this for a margin of safety. You must also add the weight of the trailer. Once you have this number, look in the manual for the Forrester to see what it is rated to tow. You may need to deduct weight of cargo in the vehicle from the towing weight.
Whatever you decide, the way you drive on hills can have a serious effect. A few months ago, I followed an oilfield services truck up US 220 from Cumberland, MD to Somerset, PA on a hill about 5 or 6 miles long. I followed too close at slow speed. The heat of the air coming from the truck I was following reduced my cooling capacity and I almost overheated.
V/R
Chris
reddoc000 wrote:I've searched posts and can't be sure... How much does a standard professionally built Chebacco on a good trailer as long as the boat is weigh? Can a Subaru tow it safely (with trailer brakes etc.) ? The reason for asking is this - i was assured that i could easily tow it but now that the boat has arrived the tongue weight's almost 300 pounds and I have second thoughts. Even if i adjust the wheels and tongue weight, I don't really want to haul it down the mountain with my Forester or Impreza to find out how much it weighs at the truck stop scale if i shouldn't be hauling it with my Forester or Impreza to begin with... Here's a second question - IF i can't (trusting that we american yanks do choose overkill even to tow bananas) how do you suggest i convince the admiral that we need a more truck-like non-subaru to do said tows on the highways and byways of New England? ------------------------------------ Bolger rules!!! - NO "GO AWAY SPAMMER!" posts!!! Please! - no cursing, flaming, trolling, spamming, respamming, or flogging dead horses - stay on topic, stay on thread, punctuate, no 'Ed, thanks, Fred' posts - Pls add your comments at the TOP, SIGN your posts, and snip away - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax: (978) 282-1349 - Unsubscribe:bolger-unsubscribe@yahoogroups.com- Open discussion:bolger_coffee_lounge-subscribe@yahoogroups.comYahoo! Groups Links <*> To visit your group on the web, go to:http://groups.yahoo.com/group/bolger/<*> Your email settings: Individual Email | Traditional <*> To change settings online go to:http://groups.yahoo.com/group/bolger/join(Yahoo! ID required) <*> To change settings via email:bolger-digest@yahoogroups.combolger-fullfeatured@yahoogroups.com<*> To unsubscribe from this group, send an email to:bolger-unsubscribe@yahoogroups.com<*> Your use of Yahoo! Groups is subject to:http://docs.yahoo.com/info/terms/
Best Wishes,
V/R
Chris
Best Wishes,
V/R
Chris
reddoc000 wrote:
I've searched posts and can't be sure... How much does a standard professionally built Chebacco on a good trailer as long as the boat is weigh? Can a Subaru tow it safely (with trailer brakes etc.) ? The reason for asking is this - i was assured that i could easily tow it but now that the boat has arrived the tongue weight's almost 300 pounds and I have second thoughts. Even if i adjust the wheels and tongue weight, I don't really want to haul it down the mountain with my Forester or Impreza to find out how much it weighs at the truck stop scale if i shouldn't be hauling it with my Forester or Impreza to begin with... Here's a second question - IF i can't (trusting that we american yanks do choose overkill even to tow bananas) how do you suggest i convince the admiral that we need a more truck-like non-subaru to do said tows on the highways and byways of New England? ------------ --------- --------- ------ Bolger rules!!! - NO "GO AWAY SPAMMER!" posts!!! Please! - no cursing, flaming, trolling, spamming, respamming, or flogging dead horses - stay on topic, stay on thread, punctuate, no 'Ed, thanks, Fred' posts - Pls add your comments at the TOP, SIGN your posts, and snip away - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax: (978) 282-1349 - Unsubscribe:bolger-unsubscribe@ yahoogroups. com- Open discussion:bolger_coffee_ lounge-subscribe @yahoogroups. comYahoo! Groups Links <*> To visit your group on the web, go to:http://groups. yahoo.com/ group/bolger/<*> Your email settings: Individual Email | Traditional <*> To change settings online go to:http://groups. yahoo.com/ group/bolger/ join(Yahoo! ID required) <*> To change settings via email:bolger-digest@ yahoogroups. combolger-fullfeatured @yahoogroups. com<*> To unsubscribe from this group, send an email to:bolger-unsubscribe@ yahoogroups. com<*> Your use of Yahoo! Groups is subject to:http://docs. yahoo.com/ info/terms/
V/R
Chris
pkortlucke wrote:
--- Inbolger@yahoogroups.com, "Christopher C. Wetherill"<wetherillc@...>wrote:The drawing of the type 1 Chebacco in sheet plywood (19' 8 ") on page 226 of Boats with an Open Mind shows design displacement at 1740 pounds. The drawing on page 232 shows thew 25 footer to have 2300pounddisplacement. It is prudent to assume a percentage over this for a margin of safety. You must also add the weight of the trailer.I suspect those displacement figures include an allowance for crew and equipment i.e. it's not the empty weight which is the applicable figure when looking to trail. My Folding Schooner (31ft and with a steel centreplate) weighs about 250kg empty (about 600 lbs). Hard to believe a standard 19 ft 8 inch Chebacco could be 3 times the empty weight of a boat 50% longer even allowing for the light weight construction of the schooner. Cheers Peter ------------------------------------ Bolger rules!!! - NO "GO AWAY SPAMMER!" posts!!! Please! - no cursing, flaming, trolling, spamming, respamming, or flogging dead horses - stay on topic, stay on thread, punctuate, no 'Ed, thanks, Fred' posts - Pls add your comments at the TOP, SIGN your posts, and snip away - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax: (978) 282-1349 - Unsubscribe:bolger-unsubscribe@yahoogroups.com- Open discussion:bolger_coffee_lounge-subscribe@yahoogroups.comYahoo! Groups Links <*> To visit your group on the web, go to:http://groups.yahoo.com/group/bolger/<*> Your email settings: Individual Email | Traditional <*> To change settings online go to:http://groups.yahoo.com/group/bolger/join(Yahoo! ID required) <*> To change settings via email:bolger-digest@yahoogroups.combolger-fullfeatured@yahoogroups.com<*> To unsubscribe from this group, send an email to:bolger-unsubscribe@yahoogroups.com<*> Your use of Yahoo! Groups is subject to:http://docs.yahoo.com/info/terms/
>pound
> displacement. It is prudent to assume a percentage over this for aI suspect those displacement figures include an allowance for crew and
schooner.
Cheers
V/R
Chris
Sent: Tue, Dec 22, 2009 11:02 pm
Subject: Re: [bolger] Towing a Chebacco
| Perhaps you can find your answer somewhere on this site; http://www.chebacco.com/ --- OnTue, 12/22/09, reddoc000<public@cottagemed. org>wrote:
| Perhaps you can find your answer somewhere on this site; http://www.chebacco.com/ --- OnTue, 12/22/09, reddoc000<public@...>wrote: |
I tow a light schooner and an overbuilt trailer (it was built for a 5500 lb Catalina) with a 4 cylinderCRVwith no problems. I cannot imagine that a Chebacco with an appropriate trailer would be a problem.--- OnTue, 12/22/09, pkortlucke<pkortlucke@...>wrote: |
full of sodas food and and a bunch of other stuff. I am guessing 1500
lbs in all plus 3oo for the trailer I was using a Plymouth short van
with a small 3 liter v6 engine I cross a mountain each way. I have no
trailer breaks. I usually shift the automatic transmition down to second
gear crossing the mountain. These vans all have a transition cooler from
the factory. we stop for coffee now and then and I pull the dipstick on
the transmition to smell it for a burnt smell and look for
discoloration. I'm guessing you chebacco weighs a fair amount more. I
would put a cooler on the transmition and heavy springs on the back of
the vehicle breaks on the trailer would make the difference in an
emergency stops. My present van has a 3.3 liter engine with a 3speed
transmition plus over drive. It is rated to pull 3000 lbs if you install
a second transmition cooler. On a 3000 lb load I would have trailer
breaks with out a doubt. I can stop pretty quick towing my boat but I
try to drive a long way down the road ahead of myself. Doug
> Not sure about the weight of a Chebacco but my brother tows our 31ft
> Folding schooner with an old Honda CRV without any problems. When he
> put the Elegant Punt on the roof racks as well he said he noticed the
> windage but not too much of a problem.
>http://sports.webshots.com/photo/2524994870086666558OXOdAi
> <http://sports.webshots.com/photo/2524994870086666558OXOdAi>
> Cheers
> Peter
Not sure about the weight of a Chebacco but my brother tows our 31ft Folding schooner with an old Honda CRV without any problems. When he put the Elegant Punt on the roof racks as well he said he noticed the windage but not too much of a problem.
Cheers
No matter what you use as a tow vehicle, I would think tailer brakes were essential. And not 'surge' brakes,,,, real pedal activated brakes. Best ! doc --- OnTue, 12/22/09, Stefan Topolski<public@...>wrote:
Best Wishes,
You might start by mentioning burned up transmissions, ,,, running out of brakes and follow that up with having a long boat stuck up your ???????????? Been towing trailers since 1949,,,, my Dad was a contractor !!! The vehicles you mention were not intended or desgned to be tow trucks. IMHO doc --- On Tue, 12/22/09, reddoc000 <public@cottagemed. org> wrote:
You might start by mentioning burned up transmissions,,,, running out of brakes and follow that up with having a long boat stuck up your ???????????? Been towing trailers since 1949,,,, my Dad was a contractor !!! The vehicles you mention were not intended or desgned to be tow trucks. IMHO doc --- OnTue, 12/22/09, reddoc000<public@...>wrote:
