Re: [bolger] Re: to seal or not to seal
paranoia is where it's at !!!!!!!!! doc :) --- OnMon, 12/28/09, eric14850<eric14850@...>wrote:
Eric
--- Inbolger@yahoogroups.com, "dnjost" <davidjost@...> wrote:
> I will give up the space for the styrofoam. Peace of mind should I take a little too much water on board some day. A compartment that should be watertight that isn't would be a bad surprise at that time.
Since the area is packed with foam, I am going for the free ventilating version. Sides are glassed where any permanent damage would be tragic, and the seat insides will be coated with epoxy and painted. Hoping this will work to slow the progression of rot. At least I can periodically inspect the area.
To answer Rick, I moved a bit aways from the salt and now spend a great deal of time on local lakes in Central MA. Narragansett Bay is closest body of salt to me now.
It is actually the non use that seems to hurt my boats the most.
--- Inbolger@yahoogroups.com, "markh" <mhamill1@...> wrote:
> Can one not soak all the unenclosed or enclosed areas with paintable preservative??
> From: Andrew Wallace
> To:bolger@yahoogroups.com
> Sent: Saturday, December 26, 2009 6:52 PM
> Subject: Re: [bolger] to seal or not to seal
> I should have added that the Featherwind will be kept indoors, slung up against the garage trusses with just enough headroom for 5ft-10" bod to walk underneath. The two hatches are a good size - 500x250mm, and the covers will be left off when stored. It's quite warm under the garage roof even in winter.
> From: the doctor <scotedoc2@...>
> Sent: Sun, 27 December, 2009 1:55:07 PM
> I had a featherwind, , very well built by someone else... it had 6" ports in the compartments. I cut and installed hatches similar to yours..
> Sure wish I had kept that boat !!!!!
> doc
> --- On Sat, 12/26/09, Andrew Wallace <visayannz@yahoo. co.nz> wrote:
> From: Andrew Wallace <visayannz@yahoo. co.nz>
> To: bolger@yahoogroups. com
> Date: Saturday, December 26, 2009, 6:42 PM
> I was at a similar point with my 'Featherwind' . Was going to have fully drained compartments bow and stern - put appropriate limber holes in the stern compartment bulkhead, then had second thoughts. Ended up making good sized top hatches for both, sealed with window-strip seal. Seemed like too usable a space (for light storage) to be sealed up for the life of the hull. Hope I've made the right decision, but think it will be ok. I now have to plug those limber holes..
> Andrew Wallace,
> New Zealand.
> From: dnjost <davidjost@verizon. net>
> Sent: Sun, 27 December, 2009 11:59:43 AM
> Subject: [bolger] to seal or not to seal
> I am at an interesting stage with the Work Skiff. Do I seal the bow and stern flotation compartments air tight; or allow for ventilation and drainage?
> Compartments are completely sealed with epoxy and can be filleted and glassed shut forever. Or...I could add drainage holes as the compartments are also foam filled. I was going to put the covers on with polysulfide sealant if that is the case.
> Opinions are never at a loss on this board. Have at it.
> David Jost
> "celebrating the small nick on his index finger from the Makita planer. stupid but lucky man."
> Email slow, clunky, unreliable? Switch to Yahoo!Xtra Mail, New Zealand's new email address.
> Need mail bonding? Bring all your contacts to Yahoo!Xtra with TrueSwitch
----- Original Message -----From:Andrew WallaceSent:Saturday, December 26, 2009 6:52 PMSubject:Re: [bolger] to seal or not to sealI should have added that the Featherwind will be kept indoors, slung up against the garage trusses with just enough headroom for 5ft-10" bod to walk underneath. The two hatches are a good size - 500x250mm, and the covers will be left off when stored. It's quite warm under the garage roof even in winter.
To:bolger@yahoogroups. com
Sent:Sun, 27 December, 2009 1:55:07 PM
Need mail bonding? Bring all your contacts to Yahoo!Xtra withTrueSwitch
I had a featherwind, , very well built by someone else... it had 6" ports in the compartments. I cut and installed hatches similar to yours..Sure wish I had kept that boat !!!!!doc
Date: Saturday, December 26, 2009, 6:42 PMI was at a similar point with my 'Featherwind' . Was going to have fully drained compartments bow and stern - put appropriate limber holes in the stern compartment bulkhead, then had second thoughts. Ended up making good sized top hatches for both, sealed with window-strip seal. Seemed like too usable a space (for light storage) to be sealed up for the life of the hull. Hope I've made the right decision, but think it will be ok. I now have to plug those limber holes..
Andrew Wallace,
New Zealand.
Sent:Sun, 27 December, 2009 11:59:43 AM
Subject:[bolger] to seal or not to seal
Email slow, clunky, unreliable?Switch to Yahoo!Xtra Mail, New Zealand's new email address.
I had a featherwind, , very well built by someone else... it had 6" ports in the compartments. I cut and installed hatches similar to yours.. Sure wish I had kept that boat !!!!! doc --- OnSat, 12/26/09, Andrew Wallace<visayannz@yahoo. co.nz>wrote:
| David, Well I guess you can now blame any future rot problem on me! lol Have you moved away from salt water or do I remember wrong? I thought you were near Boston Harbor... My son and I really enjoyed a boat tour of the harbor islands when he was on his east coast college search... I thought that was where you hung out with your Micro and Diablo? Not sure if the harbor islands played a role, but he is now enjoying starving student life in Boston. Rick --- OnSat, 12/26/09, dnjost<davidjost@...>wrote: |
You talked me into it. With the flotation firmly packed in the stern areas and bow, I will now add the drainage holes. then coat all and wish for success.
Yes, I park it under trees, sometimes the boat cover fails, sometimes the rain water stands too long undetected. and if it should end up in a non-accessible area doom would shortly follow. Had much better luck when not around fresh water and was just a salty.
I am thinking launching next June, as my window of opportunity of weather and time is in that area. Although the project list is getting shorter each weekend.
| David, Some key words from your post; "seal" "air tight" "completely sealed" "glassed shut forever" Are words that don't exist in my little boating world, and David I know your boating environment is much harsher than mine. How you'll use/or abuse, store/or park uncovered under a tree, and maintain/or neglect is unknown to me, but will be important considerations. (I'm guilty of all the latter choices). However the phrase you wrote; "allow for ventilation" sounds to me like the best idea. When's launchin day? Rick --- OnSat, 12/26/09, dnjost<davidjost@...>wrote: |
I had a featherwind,, very well built by someone else... it had 6" ports in the compartments. I cut and installed hatches similar to yours.. Sure wish I had kept that boat !!!!! doc --- OnSat, 12/26/09, Andrew Wallace<visayannz@...>wrote:
Andrew Wallace,
New Zealand.
If they are large enough for useful storage, it might be best to put a water tight port in them. IMHO doc --- OnSat, 12/26/09, dnjost<davidjost@...>wrote:
