Re: What is the Micro 2? and the plus and minus
--- Inbolger@yahoogroups.com, Gene Tehansky <goldranger02-boats@...> wrote:
> Sorry, if you get these messages via email, the address and fax for
> the plans can be found at the bottom.
> Sincerely,
> Gene T.
> On 24 Jan, 2010, at 6:55 PM, thewildernessvoice wrote:
> > I am still weighing in on a small crusing sailboat. I keep seeing
> > references to a Micro Navigator, I am assuming this is a conversion
> > to a Micro. Anyway, if so, what changes to the std micro is it?
> > Where are the plans available? and what are the pros and cons of the
> > conversation?
> > Thanks
Sorry, if you get these messages via email, the address and fax for the plans can be found at the bottom.
Gene T.
I am still weighing in on a small crusing sailboat. I keep seeing references to a Micro Navigator, I am assuming this is a conversion to a Micro. Anyway, if so, what changes to the std micro is it? Where are the plans available? and what are the pros and cons of the conversation?
Thanks
Person without a Name,
The Micro Navigator one of the updates to the basic Micro.  The modifications can be applied to the basic Micro or to the Micro II, a slightly updated cuddy cabin Micro.  The Navigator version is basically a pilot house boat with sails that are controlled from inside.  Advantages, it's a Micro, disadvantages, windage on the upper structure.  I am working on one now.  I expect you will hear more and also get a reference to photos of a beautiful completed one.  I don't have the link on hand.
Gene T.
Thanks
Thanks
