Re: [bolger] Re: Flotation Help
| My solution is to build the compartments with big limber holes at the low point and big vent holes up high (are they still limbers when up high?) and set in a foam block built up from slabs of the blue stuff that has "feet" (small, 3/4" square blocks of 1/2" thick foam glued to the "motherblock") attached to the bottom, top and sides in just enough places to wedge the main block in place yet keep the block clear of the walls by enough to allow air and water to pass all around and under with very little contact area between the painted plywood and the foam, just where the "feet" are, no contact between the plywood and the "motherblock". Air movement and drainage keep the compartments dry and I'm able to flush them out by sticking a hose in though the limbers on occasion. Yes, I've lost some volume of flotation, a trade-off I'll take to avoid what I found in the
past when I dug and scraped waterlogged foam out of a compartment only to discover rotted plywood underneath. I did this on a Diablo I built in 2001 and so far it works great. Well... the flotation hasn't been put to the ultimate test but the flotation compartments, hull and foam blocks were in good condition when I pulled them during a remodeling re-fit last winter. Rick --- OnSat, 1/30/10, Douglas Pollard<dougpol1@...>wrote: |
Bob Hauser
case of a leak. But it is still a good idea to keep the foam away from
the wood so that air can circulate between foam and wood. Wood is going
to rot sooner or later and nothing can be done about that. Poisons will
stop it for a while until they leach or wash out. Wooden boats are not
permanant. I suspect that foam takes up less space in the boat than
bottles and space is at a premium in small boats. A wooden boat with
water ballast doesn not need flotaion for it's self as it will float but
it does need flotation for a great deal of it's contents.
The really good thing about bottles is they can be put in a net and air
can circulate all around and through them. That is a huge advantage. Doug
Rick Bedard wrote:
> Not to stir up trouble but this (quote below) is exactly the reason
> why I do not use this type of foam.
> In my world if there is a leak on a boat kept in the water, I may not
> know it until the foam is softened and waterlogged, allowing rot to
> get a good start on the wood in contact with that soggy foam.
> Rick
> Not to worry. Here's from their FAQ
> 14. *Is this foam water resistant?*
> Yes, but with the following caveat.
> ...it should never be submerged in contact with water permanently.
> Over a period of years the water contact can begin to soften the
> foam and cause it to lose its closed-cell status.
> On Jan 29, 2010, at 7:40 AM,GBroadlick@...
> </mc/compose?to=GBroadlick@...> wrote:
>> This is what is coming
>>http://www.uscomposites.com/ foam.html
>> <http://www.uscomposites.com/foam.html>
Sent:Fri, January 29, 2010 9:23:54 PM
Subject:[bolger] Re: Flotation Help
| Not to stir up trouble but this (quote below) is exactly the reason why I do not use this type of foam. In my world if there is a leak on a boat kept in the water, I may not know it until the foam is softened and waterlogged, allowing rot to get a good start on the wood in contact with that soggy foam. Rick
14.Is this foam water resistant?
contact with water permanently. Over a period of years the water contact can begin to soften the foam and cause it to lose its closed-cell status.
And as I mentioned in an earlier post, expanded polystyrene doesn't absorb water... doc --- OnFri, 1/29/10, Mark Albanese<marka97203@...>wrote:
Yes, but with the following caveat. The foams that we sell are considered closed-cell, which means that each cell that makes up the foam structure is completely closed off from surrounding cells which prevents it from acting like a sponge. It is completely safe for this foam to be in contact with water for hours/days/weeks and even months with no adverse effects. However, it should never be submerged in contact with water permanently. Over a period of years the water contact can begin to soften the foam and cause it to lose its closed-cell status. This foam is designed primarily to be used as an insurance policy in case of damage/holes that could cause a vessel to lose buoyancy. Pinhole sized openings would essentially have no effect on the foam since the amount of exposure is so minimal but you should always make repairs as soon as possible to keep the foam effectiveness as good as possible. This will be the case with all after market closed-cell polyurethane foams and even manufacturer installed foams.
I hot glued the caps onto gallon milk jugs and filled the bow area below the standing platform of my Micro that way. I also have about 10 cu ft of closed cell foam under the deck.
MylesJ
To: bolger@yahoogroups.com
Sent: Fri, Jan 29, 2010 9:22 am
Subject: [bolger] Re: Flotation Help
--- Inbolger@yahoogroups. com, Mark Albanese <marka97203@ ...> wrote:
> On the other hand I think you'll find that all the two part pour in
> marine flotation foams are the closed cell type, similar to this.
>http://tinyurl. com/y96qsrx
> I've got some filling the ends of a ten year old, very neglected 16'
> sharpie. No rot. I filled the chambers before adding the deck so had
> to do a little trimming through its self generated crust, which
> seemed to require sealing. Light fiberglass is good, though the
> trimmed through cells looked like they'd use up an awful lot of
> epoxy. I used a coating of Snow Roof. The stuff does generate some
> mechanical force while expanding, but anything well built ought to
> hold up.
> I tested some once by holding it under water for a week with no
> addition in weight.
> It adds extra structural integrity.
> Air bags are also quite nice for the occasional spill.
> Mark
Yes. the two part marine flotation foams are closed cell- check this web page -
http://www.shopmani nc.com/foam. html
Coast Guard regulations on flotation for boats under 20' state that the boat should have positive, level flotation. This eliminates any kind of sealed air chambers, bags, ping pong balls, etc. or any flotation not permanently installed, if you are going to pay attention to CG regs.
I have been using two part foam in sealed chambers in many boats over many years, and have not had any problems reported to me. Seal the interior with epoxy before you pour the foam, make sure the space is totally full, seal the top after you trim the excess, and glue on the cover.
Walter Baron, Old Wharf Dory Co.
>http://tinyurl.com/y96qsrx
> hold up.
> addition in weight.
> Mark
http://www.shopmaninc.com/foam.html
I am of the school of thought that any small sailboat boat, especially a sharpie can get knocked down. So once you've got her all together, I'd do a capsize test. I'd take her into the shallows and deliberately capsize her. Here's the procedure, get some buddies and some barley pops and anchor the bow and stern. Have your buddies hold her in place and then tie a line to the mast head and pull her over. You'll get a good idea how far she can heel, what it takes to right her, how much water she can ship, how she'll behave swamped, and how to get back in her to start bailing. You can make this a family adventure with the kids too.
John Boy
Sent:Wed, January 27, 2010 10:59:04 PM
Subject:[bolger] Flotation Help
I have built to plan a Parker Ohio Sharpie. The hull is ready to paint but the interior is not finished needing deck, seats, center board etc installed. I would like to use the boat for trips such as the Texas 200, Everglades challenge etc. The boat as drawn has no flotation. I could use some help determining how and where to place the flotation. My most recent idea is to create enclosed compartments in the bow and stern with a hatch for access, and to skin the inner surface of the frames creating a space between the hull and skin. I thought i would fill this space with 2 part urithane foam. This would create a closed space with no access. Is this a problem?
Location Displacement
Bow 1025 lb
Transom 850 lb
Port side 600 lb
Starbord side 600 lb
Total 3075 lb
http://www.parker-marine.com/parker2_3.htm
I don't think is a good idea for several reasons. 1 Compressing air will generate moisture. 2 Expanding air in cold weather from a nozzle will have the tendency to freeze around the nozzle and then the ice will melt and generate water in the compartment. 3 Pressurizing a compartment is a risky job, cracks may develop even with a minimum pressure. I witness large ocean going tankers having the deck lifted just for loading ballast water without venting the tank and also tanks imploded for discharging ballast without opening the vent. Giuliano --- OnThu, 1/28/10, Douglas Pollard<dougpol1@...>wrote:
John Boy
Sent:Thu, January 28, 2010 6:56:09 AM
Subject:Re: [bolger] Flotation Help
Here's a discussion I bogarted from a boat building group, I didn't attribute it when I copied it so I don't remember if it is from the Wooden Boat forum or Boat Building forum.
"You
guys are scaring me.
I suggest to do it right or don't do it at all.
First use ABYC H-5 - Boat Load Capacity
Next ABYC H-8 - Buoyancy in the Event of Swamping
Both guidlines cover about 32 pages and give nice diagrams and examples. I haven't
worked with boats under 20' in a while but to summarize in general:
Capacity: Imagine the boat in the water with the scuppers sealed. Then add as
much weight as possible, distributed properly, to submerge the hull just to the
point where water is about to come over the sheer. This is called the static
float plane. The amount of weight you added will determine the capacity. The
book has formulas to estimate capacity at static float plane.
Floatation: You have three things you need to float, the boat, the engine and
the person capacity (includes gear).
The calculations are tedious but not difficult. Just follow it step by step. At
the risk of a copyright violation, from ABYC H-8:
H-8.7.2 Calculations - Basic Flotation
H-8.7.2.1 Perform the following steps to calculate the volume of flotation
material required to support the swamped boat (Fb), the submerged propulsion
equipment (Fp), the persons capacity (Fc1), and the dead weight (Fc2).
H-8.7.2.1.1 Step 1: Determine the flotation needed to support the swamped boat
(Fb).
Formula: Fb = (Wh x K1 + Wd x K2 + .69 We) ÷ B
Where
Wh = dry weight of hull, i.e., everything below swamped water line
Wd = dry weight of deck and superstructure
We = dry weight of factory installed equipment, hardware, and accessories
K1 and K2 = conversion factors for materials
used from Table I (See Note 1.)
B = buoyancy of flotation material in pounds per cubic foot
(NOTES DELETED)
EXAMPLE
Calculate the flotation material needed to support the swamped boat (Fb).
Assume
Wh = weight of hull (fiberglass) = 600 lbs.
Wd = weight of deck and superstructure (plywood) = 120 lbs.
We = weight of equipment, hardware and accessories = 50 lbs.
Fb = ((Wh x K1) + (Wd x K2 ) + (0.69 x 50)) ÷ B
Fb =((600x0.33)+ (120x-0.81) + 0.69x50)) ÷ 60.4*
Fb = (198 - 97.2 + 34.5) ÷ 60.4
Fb = 135.3 ÷ 60.4
Fb = 2.24 cu. ft.
*The figure for a two pound flotation material.
Next there are formulas to calculate the floatation for submerged propulsion
equipment, persons capacity and dead weight (gear).
Good luck.
djs"
Here's my two cents about sealing flotation chambers in a plywood boat. Seal the inside of the chamber well with epoxy before filling it with foam. Paint is somewhat porous and water can and will soak into the wood and create conditions for rot and lamination failures. Even standing water as little as 1/4 will work its way through a flat roof over time. I'd also do my best to not have ANY air pockets between the foam and the structure of the boat. Voids are places where condensation can form and some foams can and will absorb water when exposed to it over time. Read your label. This will increase the weight of the foam and decrease the flotation ability over time. Some foams when allowed to stay wet will actually turn to heavy wet spongy dust over time. If you go with air chambers, I'd put some drain plugs and screw on deck plates in so you can inspect and allow the chamber to dry out.
I noticed you posted some weight and balance numbers for your boat. Now all you've got to do is some college level geometry to figure out where and how much flotation chambers to build. :-)
Have fun,
John Boy
BTW How 'bout some pics? We'd all like to see your boat.
Bow 1025 lb
Transom 850 lb
Port side 600 lb
Total 3075 lb
John Boy
Sent:Thu, January 28, 2010 2:32:37 PM
Subject:Re: [bolger] Re: Flotation Help
If you have any table tennis afficionado friends, ping pong balls would
work, too, and will more efficiently fill up the space. Otherwise, use
the small bottles so they pack more efficiently, and so you can insert &
retrieve them more easily through a standard inspection port.
May not be USCG approved, but will do the job!
BllFs6@...wrote:
> My plan would be this.
> Make the areas well sealed with an inspection hatch. Then fill those
> areas with empty plastic water/soda bottles.
> If the areas are not breached then you have lots of flotation. If they
> are breached, all those empty bottles will provide anywhere from 50 to
> 70 percent of the flotation that you would get if the whole thing was
> filled with foam.
> Cheap, very lightwieght, easy to inspect, wont trap water in there,
> adjustable, and easy to undo.
John Boy
Sent:Thu, January 28, 2010 10:25:55 AM
Bravo! Doug
Tom
--- Inbolger@yahoogroups.com, the doctor <scotedoc2@...> wrote:
> I would avoid the two part or spray in foams..... I have seen some that expanded as they matured doing structural damage.
> Â
> Expanded Polystyrene in blocks or sheets would be my choice. It doesn't absorb water and can be cut / fit in irregular spaces.
> Â
> I floated a 10000 sq. ft. marina as well as a 12x30 work barge on it.
> Â
> doc
> --- On Thu, 1/28/10, J.J. C1200 <jjc1200@...> wrote:
> From: J.J. C1200 <jjc1200@...>
> Subject: RE: [bolger] Re: Flotation Help
> Date: Thursday, January 28, 2010, 11:13 AM
> Â
> On early long distance flights they filled airplanes with ping pong ballsÂ
> > To: bolger@yahoogroups. com
> > From: dougpol1@verizon. net
> > Date: Thu, 28 Jan 2010 11:19:09 -0500
> > Subject: Re: [bolger] Re: Flotation Help
> > > filled with foam.
> > > Bravo! Doug
> > - no cursing, flaming, trolling, spamming, respamming, or flogging dead horses
> > - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax: (978) 282-1349
> > - Unsubscribe: bolger-unsubscribe@ yahoogroups. com
> > - Open discussion: bolger_coffee_ lounge-subscribe @yahoogroups. com Yahoo! Groups Links
> Hotmail: Free, trusted and rich email service. Get it now.
> filled with foam.
I would avoid the two part or spray in foams..... I have seen some that expanded as they matured doing structural damage. Expanded Polystyrene in blocks or sheets would be my choice. It doesn't absorb water and can be cut / fit in irregular spaces. I floated a 10000 sq. ft. marina as well as a 12x30 work barge on it. doc --- OnThu, 1/28/10, J.J. C1200<jjc1200@...>wrote:
Sent:Thu, January 28, 2010 10:13:49 AM
Subject:RE: [bolger] Re: Flotation Help
> To: bolger@yahoogroups. comIndividual Email | Traditional
> > filled with foam.
> > Bravo! Doug
> <*> To visit your group on the web, go to:
> <*> Your email settings:
> <*> To change settings online go to:
>http://groups. yahoo.com/ group/bolger/ join
> (Yahoo! ID required)
> <*> To change settings via email:
> bolger-digest@ yahoogroups. com
> bolger-fullfeatured @yahoogroups. com
> <*> To unsubscribe from this group, send an email to:
> <*> Your use of Yahoo! Groups is subject to:
>http://docs. yahoo.com/ info/terms/
Hotmail: Free, trusted and rich email service.Get it now.
> From: dougpol1@...
> > filled with foam.
> > Bravo! Doug
> - Unsubscribe: bolger-unsubscribe@yahoogroups.com
> - Open discussion: bolger_coffee_lounge-subscribe@yahoogroups.com Yahoo! Groups Links
> http://groups.yahoo.com/group/bolger/join
> bolger-digest@yahoogroups.com
> bolger-fullfeatured@yahoogroups.com
> http://docs.yahoo.com/info/terms/
On Thu, Jan 28, 2010 at 5:41 AM, Tom<tomseigler@...>wrote:Gene is right. Moisture will be absorbed by two part foam even if it is in a sealed compartment. The water molecule is called the "universal solvent" because it is so small it can pass thru anything. Once the moisture condensates inside a sealed area, it stays there. Even with the boat out of the water, moisture will condensate inside a sealed area and continue to collect until the foam is saturated.
Tom
--- Inbolger@yahoogroups.com, Gene Tehansky <goldranger02-boats@...> wrote:
> I personally have seen that 2 part foam absorbs and holds water. It
> was a fiberglass boat so it was just an inconvenience lifting out the
> massive blocks of foam. And sloppy. You are much better off with the
> blue stuff (or pink) and letting air circulate around it to keep the
> wood dry. You will never truly be able to seal the 2 part foam in so
> it will get water and even if the wood is sealed, cracks will form and
> you will get rot. Don't do it! Keep asking around...
> Sincerely,
> Gene T.
> On 28 Jan, 2010, at 7:37 AM, John and Kathy Trussell wrote:
> > There are a lot of different views on flotation. In general,
> > flotation up high is better than flotation down low. In general,
> > enclosed "flotation tanks" serve to limit the amount of water which
> > a boat will hold when it is capsized or swamped. At various times, I
> > have used blue insulation foam cut to fit and stacked in the ends of
> > a boat (under a deck), swimming pool "noodles", airbags, and sealed
> > chambers (which were accessed by Beckson ports—not home made hatches
> > which are difficult to make water tight). I don't see why a 2 part
> > foam wouldn't work, but I would suggest that you make an effort to
> > seal the adjoining wood before you install the foam to eliminate
> > potential rot traps.
> > Have fun.
> > JohnT
> > From:bolger@yahoogroups.com[mailto:bolger@yahoogroups.com] On
> > Behalf Of gbroadlick
> > Sent: Wednesday, January 27, 2010 11:59 PM
> > Subject: [bolger] Flotation Help
> > this a problem?
> > Bow 1025 lb
> > Transom 850 lb
> > Port side 600 lb
> > Total 3075 lb
> > No virus found in this incoming message.
> > Checked by AVG -www.avg.com
> > Version: 9.0.733 / Virus Database: 271.1.1/2650 - Release Date:
> > 01/27/10 14:36:00
- Unsubscribe:bolger-unsubscribe@yahoogroups.com- Open discussion:bolger_coffee_lounge-subscribe@yahoogroups.comYahoo! Groups Links<*> Your email settings:
Bravo! Doug > >
> filled with foam.
> Bravo! Doug
Douglas Pollard wrote:
> I have wondered if it might not be possible to in ject a small amount of
> airpressure into a block of sealed foam to maintain a positive pressure
> to keep water out. A cylinder and piston with a weight on it could be
> used to pressurize the foam. Of course the injected air would need to be
> dry. The piston might be lifted and released to re pressurize the foam
> every now and then. Some simpler variation of this might work. Doug
>> Tom
>> --- Inbolger@yahoogroups.com<mailto:bolger%40yahoogroups.com>, Gene
>>> Sincerely,
>>> Gene T.
>>>> Have fun.
>>>> JohnT
>>>> From:bolger@yahoogroups.com<mailto:bolger%40yahoogroups.com>
>> [mailto:bolger@yahoogroups.com<mailto:bolger%40yahoogroups.com>] On
>>>> To:bolger@yahoogroups.com<mailto:bolger%40yahoogroups.com>
>>>> this a problem?
>>>> Bow 1025 lb
>>>> Transom 850 lb
>>>> Port side 600 lb
>>>> Total 3075 lb
>> <http://www.parker-marine.com/parker2_3.htm>
>>>> Checked by AVG - www.avg.com
>>>> 01/27/10 14:36:00
> Tom
> > Sincerely,
> > Gene T.
> > > Have fun.
> > > JohnT
> > > this a problem?
> > > Bow 1025 lb
> > > Transom 850 lb
> > > Port side 600 lb
> > > Total 3075 lb
> > > 01/27/10 14:36:00
Tom
> Sincerely,
> Gene T.
> > chambers (which were accessed by Beckson portsnot home made hatches
> > Have fun.
> > JohnT
> > this a problem?
> > Bow 1025 lb
> > Transom 850 lb
> > Port side 600 lb
> > Total 3075 lb
> > 01/27/10 14:36:00
"You
(Fb).
Where
(NOTES DELETED)
EXAMPLE
Assume
Fb = 135.3 ÷ 60.4
Fb = 2.24 cu. ft.
Good luck.
djs"
Have fun,
John Boy
Bow 1025 lb
Transom 850 lb
Port side 600 lb
Total 3075 lb
There are a lot of different views on flotation. In general, flotation up high is better than flotation down low. In general, enclosed “flotation tanks” serve to limit the amount of water which a boat will hold when it is capsized or swamped. At various times, I have used blue insulation foam cut to fit and stacked in the ends of a boat (under a deck), swimming pool “noodles”, airbags, and sealed chambers (which were accessed by Beckson ports—not home made hatches which are difficult to make water tight). I don’t see why a 2 part foam wouldn’t work, but I would suggest that you make an effort to seal the adjoining wood before you install the foam to eliminate potential rot traps.
Have fun.
JohnT
From: bolger@yahoogroups. com [mailto: bolger@yahoogroups. com ] On Behalf Of gbroadlick
Bow 1025 lb
Transom 850 lb
Port side 600 lb
Total 3075 lb
http://www.parker- marine.com/ parker2_3. htmNo virus found in this incoming message.
Version: 9.0.733 / Virus Database: 271.1.1/2650 - Release Date: 01/27/10 14:36:00
Have fun.
JohnT
bolger@yahoogroups.com ]On Behalf Ofgbroadlick
Sent:Wednesday, January 27, 2010
11:59 PM
this a problem?
Bow 1025 lb
Transom 850 lb
Port side 600 lb
Total 3075 lb
Bow 1025 lb
Transom 850 lb
Port side 600 lb
Total 3075 lb
