Re: Turtle 2
> Thank you for your reply. My problem is that I hope to pull the boat with a Pontiac Vibe which has a maximum trailer weight of 1500 pounds, so the boat and trailer should weight about 1000 pounds.I had a Vibe and it towed a similar sized boat just great. I would also tow a Gravely Garden tractor with attachments and never had an issue. Gravely's are HEAVY.
At the Kingston Messabout a few years ago, I was pulling the boat out with the Vibe and wondered why all the gravel under the tires was making such a racket. Turns out I had the emergency brake on and I was towing the boat, trailer and rear wheels locked up, all without any problem. I had the standard engine and auto transmission.
Mark, Thank you for your reply. My problem is that I hope to pull the boat with a Pontiac Vibe which has a maximum trailer weight of 1500 pounds, so the boat and trailer should weight about 1000 pounds.Have you seen the Bolger Clam Cabin Skiff named Grinder? You can find it by going to Google and typing in Grinder Cabin Clam Skiff. A blog for it will come up ( you have to page down to it) and also an article on it at Duckworks will come up. Please read about it. What I like so much is the layout. Very good for two people. Only problem is the MPG. If made longer and lighter it should get fantastic MPG. But it has to be built strong enough so the hull won't get holed if it hits something.I love the idea of an enclosed pilot house but I think my weight limitations rule this out.This will be my first time building a boat so the build can't be to difficult. I might build a smaller boat first to learn about building. I'll also build a scale model of the larger boat I build. This should help out quite a bit.My wife and I plan on living on the boat I build for a few weeks or longer at a time and we hope to trailer the boat about 1500 one way miles from Michigan. If you have any suggestions I would love to hear them.Thanks again for your help.All the best,Bud
| Mark, Thank you for your reply. My problem is that I hope to pull the boat with a Pontiac Vibe which has a maximum trailer weight of 1500 pounds, so the boat and trailer should weight about 1000 pounds. Have you seen the Bolger Clam Cabin Skiff named Grinder? You can find it by going to Google and typing in Grinder Cabin Clam Skiff. A blog for it will come up ( you have to page down to it) and also an article on it at Duckworks will come up. Please read about it. What I like so much is the layout. Very good for two people. Only problem is the MPG. If made longer and lighter it should get fantastic MPG. But it has to be built strong enough so the hull won't get holed if it hits something. I love the idea of an enclosed pilot house but I
think my weight limitations rule this out. This will be my first time building a boat so the build can't be to difficult. I might build a smaller boat first to learn about building. I'll also build a scale model of the larger boat I build. This should help out quite a bit. My wife and I plan on living on the boat I build for a few weeks or longer at a time and we hope to trailer the boat about 1500 one way miles from Michigan. If you have any suggestions I would love to hear them. Thanks again for your help. All the best, Bud --- OnMon, 4/19/10, MarkAlbanese<marka97203@...>wrote: |
While looking at the photos yesterday I saw Turtle 2 and think she may be the right boat for my wife and I to cruise in both comfortably and economically. I've looked but have not been able to find more information on her. Will someone please tell me the thickness of the bottom, sides, deck and top. Please also tell me her dry weight and explain the layout inside the cabins. If you can send me a link with more information on her it would be greatly appreciated. Where do I buy plans for her? Thanks for your help. Bud
