Re: MJ hollow mast
I would consider routing a rabbit along the edge of the fore and aft
staves. It wouldn't need to be very deep, maybe 1/8 inch. Seems to me
this would be quicker than gluing on a strip and no nails in your
nice varnished mast.
Vince chew
--- Inbolger@egroups.com, "Chuck Leinweber" <chuck@d...> wrote:
> > Any tips out there as to how to prevent the side staves slipping
> > inwards when the clamps are applied? Perhaps glue it up in
stages,
> > i.e. narrow side stay to base one day, other side the next, top
after
> > that?
> > Col Mooney
> You can use 6d nails driven part way in to hold the position of the
pieces,
> then remove them after the glue has set. Alternately use drywall
screws
> that have been sprayed with WD-40 for the clamping.
> Chuck
Hi Col - I have never built a hollow mast - but when I was building my mj - I
considered laminating the first two pieces together - as if building a solid
mast - and then using a router to cut out the center - maybe a bass ackwards
way to do it tho' I also don't know if just ripping one of the planks for
"sides" to the mast and gluing them up that way would work - This mast
doesn't bend - so I can't imagine that flex which is equal in all directions
is an issue. Knowing all I know now -I would have considered the aluminum
mast. Steve
> inwards when the clamps are applied? Perhaps glue it up in stages,
> i.e. narrow side stay to base one day, other side the next, top after
> that?
> Col Mooney
You can use 6d nails driven part way in to hold the position of the pieces,
then remove them after the glue has set. Alternately use drywall screws
