[bolger] Re: LSME update: Skim coat
FBBB --
4 parts Raka resin, 1 part slow hardener, 1 part fast hardener, glass
until just thin enough to still pour. Worked it back and forth with a
squeegee from Raka. A guy who does this for a living told me, (while
he helped,) that a big piece of formica makes a good, cheap squeegee.
Understand there is still *plenty* of sanding to do -- lots of
wobbles and waves, not to mention a few goops too!
WestSystem 411 is very, very sandable. I used glass fiber because I
wanted the skim coat to be a little tougher, but I will pay for that
when I sand.
My original laminating coat was a mess! A big gop of semi-solid resin
fell on me port topsides, and I couldnt' get it off without
disturbing the glass fabric.
A body grinder makes quick work of sloppy glass work, but you need to
be careful. I had to ruin a few things to get a good touch.
I'm planning on 60, 120, 220 with a random orbital on the skim coat.
I'll post a few before and after pictures.
134 W.26th St. 12th Floor
New York, NY 10001
(212) 247-0296
when I sand.
>Glad it worked out well. Can you give me some details on this skimCRUMBLING EMPIRE PRODUCTIONS
>coating process? (mix, tools, techniques?) As you may note by my
>recent post, I am getting kind of frustrated with sanding.
>--- Inbolger@egroups.com, David Ryan <david@c...> wrote:
>> FBBB --
>> I skim coated ('poxy and glass fibers) the scooner Friday
>afternoon,
>> just before we headed over to Sag Harbor to look at the vintage
>> sharpie.
>>snip
>- no cursing
>- stay on topic
>- use punctuation
>- add some content: send "thanks!" and "ditto!" posts off-list.
New York, NY 10001
(212) 247-0296
> FBBB --
afternoon,
> sharpie.
>snip
FBBB --
I skim coated ('poxy and glass fibers) the scooner Friday afternoon,
sharpie.
Now that it's hardened up, I'm getting very satisfying at'a'boys from
lay people and real boat builders alike. I really didn't care for the
finish work in lil'winnie, and it shows. But the Raka 4-1-1 mix is
much, much easier to work with than a pot full of smoldering, kicking
polyester. I'm actually LOOKING FORWARD to sanding it out to a smooth
finish. I might even sand between coats of paint. Nothing like a
little success to encourage further effort!
New York, NY 10001
(212) 247-0296
sharpie.
New York, NY 10001
(212) 247-0296
