Re: [bolger] Hollow mast plug
FWIW the Windsprint plans show a square, hollow, tapered
mast, 15' 6" x 3" to carry a 113 sq. ft. balanced lug.
There's a solid plug at the bottom 2' 6". The bury is only
16". This might be a clue to the right proportions.
Richard Spelling wrote:
> snip
> put some kind of plug in it just above the partner...
snip
> It doesn't appear to have any crushing problems so far, and if it does
snap,
> I'm a daysailer, I'll troll home and make a solid mast.
Just got back from measuring my mast. The walls are 1" thick, not 7/8" as
stated earlier.
Doug fir, 3-1/2" wide, 20ft long, 40lb.
Just closely examined the bearing surface at the partner. No signs of
crushing at all, except where I didn't quite get it shaved perfectly smooth,
then the small hills of wood are slightly, say 1/16", crushed. This is raw
wood, epoxy coated, no glass.
Partner is 1-1/2" thick, "D" shaped, with the curved side of the "D" wood
and a metal plate across the strait side.
As a side note, the grain on the individual staves go pretty much every
which way but loose. I think two of them are in the "tree" position, the
rest going willy nilly.
Can you describe a "diamond shaped metal plate"? Where would it be going?
I agree with you that it would probably break at the end of the plug, this
is why I've pretty much reconsidered doing anything to it.
It doesn't appear to have any crushing problems so far, and if it does snap,
To: <bolger@egroups.com>
Sent: Monday, July 31, 2000 7:18 AM
Subject: Re: [bolger] Hollow mast plug
> If you want to prevent crushing a diamond shaped metal plate will do a lot
> better than plug. The outer part of the mast will still crush. If you have
> crushing problems you should spread them over the mast.
> Take an broken fishing pole and epoxy a plug in it and bend it until it
> breaks. I bet you ten bucks it breaks at the end of the plug.
> Gordon
> Gordon Cougergcouger@...
> Stillwater, OK www.couger.com/gcouger
> 405 624-2855 GMT -6:00
> From: "Richard Spelling" <richard@...>
> Sent: Monday, July 31, 2000 6:53 PM
> > Gordon, David.
> > I believe the failure mode is tube crushing, this is what the plug would
> > prevent. Don't think an external layer of epoxy/fiber of any reasonalble
> > thickness would help in this.
> > The tube is plenty strong, was only going to try to prevent crushing at
> the
> > partner.
> > On the other hand, I've had her out in some pretty strong wind with no
> > apparent problems. In addition, doug fir is quite a bit harder than
> spruce.
> > I may just ignore it, and build a solid one if it fails...
> > From: "Gordon Couger" <gcouger@...>
> > Sent: Monday, July 31, 2000 6:42 AM
> > > Putting solid plugs in properly sized hollow mast are a good way to
> cause
> > > the mast to fail at the end of the plug. If forms a stress riser.
> > > The proper way to strengthen a tube it with diamond shaped patches or
> > > layers of fiberglass that taper from each end to the middle.
> > > Gordon
> > > Sent: Monday, July 31, 2000 1:20 PM
> > > Subject: [bolger] Hollow mast plug
> > > All this talk about putting solid cores in hollow masts has me
> convinced I
> > > need to put a plug in mine.
> > > No problem, cut one to fit on the table saw, put some kind of plug in
> it
> > > just above the partner, stand mast on end, climb ladder, pour in
> thickened
> > > epoxy, drive plug in.
> > > The question becomes, what is the best way to plug the mast so the
> epoxy
> > > doesn't get wasted? Needs to be liquid tight, but easy to insert four
> feet
> > > into a hollow wooden tube.
> > > Any suggestions from the collective?
> > > Richard Spelling,http://www.spellingbusiness.com/boats
> > > From the muddy waters of Oklahoma
> > > Bolger rules!!!
> > > - no cursing
> > > - stay on topic
> > > - use punctuation
> > > - add your comments at the TOP and SIGN your posts
> > > - add some content: send "thanks!" and "ditto!" posts off-list.
> > - no cursing
> > - stay on topic
> > - use punctuation
> - no cursing
> - stay on topic
> - use punctuation
Gordon, David.
The tube is plenty strong, was only going to try to prevent crushing at the
partner.
apparent problems. In addition, doug fir is quite a bit harder than spruce.
> Putting solid plugs in properly sized hollow mast are a good way to cause
> Gordon
> All this talk about putting solid cores in hollow masts has me convinced I
> No problem, cut one to fit on the table saw, put some kind of plug in it
> just above the partner, stand mast on end, climb ladder, pour in thickened
> The question becomes, what is the best way to plug the mast so the epoxy
> doesn't get wasted? Needs to be liquid tight, but easy to insert four feet
> - no cursing
> - stay on topic
> - use punctuation
Fraser,
With your halyards inside the mast, do you have any problem with the lead on
the peak halyard, from the mast to the peak? I thought of putting a sheave
at the masthead, but decided against it as the halyard would chafe against
the side of the slot or box most of the time, wearing the rope, mast or
both. Also, what sort of sheave/box do you use for either halyard -- are
they just screwed to the wall of the mast, or is the mast reinforced there?
Jamie
[mailto:fraser.howell@...]
Sent: Monday, July 31, 2000 1:45 PM
To:bolger@egroups.com
...One of my reasons for a hollow mast, is to run the halyards inside, so
my plug will have to have room for them...
I agree that a plug overrllaappping the partner to boom jaw is needed.
As well, On my next mast, I will wrap the area of the partner with epoxy
and cloth, for protection against crushing(which is what caused my
failure, I think).
my plug will have to have room for them. The inside of the birdsmouth
mast is octagonal. My plug will either: a)span the opposite sides on the
inside of the octagonal, leaving room fore and aft for the 2 halyards,
or b) be octagonal, but drilled out. I intend to insert the plug, and
glue it up during assembly. I will ensure dry-fit. It might even help
with the assembly.
For the record, my hollow mast weighed 28 lb. The solid mast it replaced
(now back in service) weighs 45 lb. The old mast is whippy in comparison
to the hollow one, and makes me nervous. I didn't expect the hollow one
to break, and I am always expecting the solid one to break. Go figure.
For the plug-gluing problem, why not position the plug, drill tiny holes
through the mast walls and inject thickened epoxy with one of those
outrageously expensive WEST system syringes?
As for cassette tape as telltale, GHC, what is temporary about that?
I am now preparing the strakes for unstayed hollow mast #2. The last
one.
Cheers;
Fraser
I would be concerned with the liquid flowing all the way down to the sponge,
I'd have to make it awful thin, or leave a pretty good gap.
If I start at the bottom, then when the epoxy comes out around the top of
the plug, I know I've got good coverage...
Maybe I should glue a short plug, say 4 inches or so, next to the
sponge/noodle first, let it cure, then glue in the main? I could then apply
a LOT of presure to make the epoxy flow around the main plug...
Wonder if there is any reason I couldn't use Titebond II? Anybody have any
idea how big of a gap I could have and still get a good glue bond with
Titebond?
Sent: Monday, July 31, 2000 2:14 PM
> Why not push a sponge in first, add plug, then pour a cup of liquid on
top?
> Gregg Carlson
> At 01:32 PM 7/31/2000 -0500, you wrote:
> >Sorry, cut WOOD plug on table saw, expoxy in place. Shouldn't need more
than
> >a cup of epoxy, just enough to fill the gap between the wooden plug and
> >mast walls.
> >You think it would be liquid tite after being pushes four feet into the
> >tube?
> >From: "Orr, Jamie" <jorr@...>
> >Sent: Monday, July 31, 2000 1:30 PM
> >Subject: RE: [bolger] Hollow mast plug
> >> Sounds like an expensive plug, all that epoxy, but you could control it
> >with
> >> a piece of closed cell foam, cut just bigger than the inside diameter,
> >> pushed into place. That should keep the epoxy where you want it.
> >> Jamie Orr
> >> From: Richard Spelling [mailto:richard@...]
> >> Sent: Monday, July 31, 2000 11:21 AM
convinced I
it
thickened
epoxy
feet
> >> <http://www.spellingbusiness.com/boats>
> >> _____
> >> <http://click.egroups.com/1/7150/13/_/3457/_/965067861/>
> ><http://adimg.egroups.com/img/7150/13/_/3457/_/965067861/468x60new13.gif>
> >> _____
> >> Bolger rules!!!
> >> - no cursing
> >> - stay on topic
> >> - use punctuation
> >> Bolger rules!!!
> >> - no cursing
> >> - stay on topic
> >> - use punctuation
> >Bolger rules!!!
> >- no cursing
> >- stay on topic
> >- use punctuation
> - no cursing
> - stay on topic
> - use punctuation
I seem to have come in on the end of this thread and seemed to have missed
the initial post regarding the breakage ...However I would advise against
running halyards inside a wooden mast.
A great source for wooden mast building for me has been Reull Parkers
chapter in "The New Cold Molded Boatbuilding" great way to build a mast and
bombproof as well.
Bob Wise
St Thomas USVI
Why not push a sponge in first, add plug, then pour a cup of liquid on top?
Gregg Carlson
>Sorry, cut WOOD plug on table saw, expoxy in place. Shouldn't need more than
>a cup of epoxy, just enough to fill the gap between the wooden plug and the
>mast walls.
>tube?
>with
>> a piece of closed cell foam, cut just bigger than the inside diameter, and
>> Jamie Orr
>> _____
>> _____
>> Bolger rules!!!
>> - no cursing
>> - stay on topic
>> - use punctuation
>> Bolger rules!!!
>> - no cursing
>> - stay on topic
>> - use punctuation
>- no cursing
>- stay on topic
>- use punctuation
A couple of thoughts...
Water noodle might work pretty good. Say about a six inch section.
"Thickened epoxy" has to be thin enough to flow around the plug. Will add
wood flour to get bulk, but still want it pretty watery.
Sent: Monday, July 31, 2000 1:49 PM
> Haven't tried it, but thickened epoxy shouldn't leak (I think!) You could
> test it with water -- if it leaks, push it out from the other end or pull
it
> out with a barbed stick? You'd only lose the drying time.
> Mind you, if you are pushing it in a small hole and hoping it will expand
as
> the mast diameter increases, kind of like foam ear plugs, you might want
> test how well it will expand back to its normal shape before you stuff it
in
> there.
> Or wait for a better idea!
> Sent: Monday, July 31, 2000 11:32 AM
than
> mast walls.
> tube?
> with
> > Jamie Orr
I
thickened
feet
> > _____
> > _____
> > - no cursing
> > - stay on topic
> > - use punctuation
> > - no cursing
> > - stay on topic
> > - use punctuation
> - no cursing
> - stay on topic
> - use punctuation
> - no cursing
> - stay on topic
> - use punctuation
test it with water -- if it leaks, push it out from the other end or pull it
Mind you, if you are pushing it in a small hole and hoping it will expand as
the mast diameter increases, kind of like foam ear plugs, you might want to
test how well it will expand back to its normal shape before you stuff it in
there.
mast walls.
tube?
with
> Jamie Orr
> _____
> _____
> - no cursing
> - stay on topic
> - use punctuation
> - no cursing
> - stay on topic
> - use punctuation
- no cursing
- stay on topic
- use punctuation
mast walls.
tube?
with
> Jamie Orr
> _____
> _____
> - no cursing
> - stay on topic
> - use punctuation
> - no cursing
> - stay on topic
> - use punctuation
Sounds like an expensive plug, all that epoxy, but you could control it with
Jamie Orr
_____
_____
- no cursing
- stay on topic
- use punctuation
By a diamond shaped plate I mean a plate that conforms to the mast and
tapers to a point on each end. Cut a diamond out of a piece of paper wiht
the long axis being at least 3 times the
narrow axis. Bend the paper so it conforms wiht the mast. Epoxy or
rivet(in the case of an alumium mast) the patch to the mast. All the
contact from the boom or spar should contact the metal diamond. The
diamond shape reduces the stress risers to a minim.
There will still be a stiff spot in the mast but the stress will be
distributed along the edge of the diamond patch and will be much less
likely a place for the mast to break.
Gordon
Sent: Monday, July 31, 2000 8:48 PM
going?
this
snap,
lot
have
it
> > Gordon
> > > Gordon, David.
would
reasonalble
at
> > the
> > > partner.
no
> > spruce.
> > cause
patches or
> > > > Gordon
> > convinced I
in
> > it
> > thickened
> > epoxy
four
> > feet
> > > > Bolger rules!!!
> > > > - no cursing
> > > > - stay on topic
> > > > - use punctuation
> > > Bolger rules!!!
> > > - no cursing
> > > - stay on topic
> > > - use punctuation
> > - no cursing
> > - stay on topic
> > - use punctuation
> - no cursing
> - stay on topic
> - use punctuation
Gordon
> Gordon, David.
> partner.
spruce.
cause
> > Gordon
convinced I
it
thickened
epoxy
feet
> > - no cursing
> > - stay on topic
> > - use punctuation
> - no cursing
> - stay on topic
> - use punctuation
Gordon
