Re: Question about Bolger Skimmer (Instant Boats)
That bottom cross-piece is just a length of 2X4 with a 14 degree bevel cut along the bottom edge to match the outward angle on the transom.
On mine the outside edges have been rounded over and a couple layers of 6" wide 10 oz tape installed for additional strength.
> Photos of panels prior to assembly may be instructive: Photos
> <http://www.instantboats.com/skimmer.htm>
> On 7/21/2010 10:25 PM, yp_artist_guy wrote:
> > Hi group, (long time occasional lurker)
> > I am beginning a 4x8 Skimmer (Poor Man's Whaler) and have a couple questions.
> > 1. Are the official plans the same (but larger) sketches as in the book 'Build The New Instant Boats', or are they more detailed and complete? So as to avoid confusion about the below?
> > 2. At the base of the transom, on the outside, at bottom, along the short extended planing surface, there is a 1 1/2 by 2 1/2 angled item? "Transom bottom frame from 1 1/2 by 2 1/2" ? Confused because I thought the bottom frame is the piece beneath the motor board on the same side of the transom as the motor board? You can see the part I mention on the side plan view, but not from the top, so am not sure what it is. It is given a 14 degree bevel.
> > Perhaps I am reading the sketch incorrectly. I am not sure I can afford the plans right now though, so any help would be welcome. If they are just an enlarged sheet from the book, that won't be much additional help anyway.
> > Thanks for any clarification,
> > Robert
Thank you Mark, that is indeed a help.
> Robert,
> I don't know if that would be any clearer to you with the full sized
> plans. Though the full scale drawings are always helpful, for a guy
> with a couple sheets of plywood and an old motor laying around it's
> certainly legitimate to build from the book if your eyesight is good
> enough.
> The piece you're looking at is the the bottom framing piece of the
> transom. Without it, there'd be nowhere to nail the bottom all the
> way across. It is shown in the plan view. Remember the transom is at
> an angle.
> The boat's plan and profile views are aligned exactly. Run your
> straight edge down from the framing piece shown in the side view to
> the plan view. Just to the right of the transom top are a pair of
> lines adjacent to the motor board. That's the part.
> It's tricky because both the transom's bottom and top edges can't be
> shown in plan view without obscuring the other detail.
> Hope this helps.
> Mark
> > questions.
> > Robert
I second Harry's perspective.
Any project for a POWER boat implies financial wherewithall in vast excess of the cost for a set of plans.
Susanne Altenburger, PBF
Sent:Wednesday, July 21, 2010 11:22 PM
Subject:Re: [bolger] Question about Bolger Skimmer (Instant Boats)
The plans are only $30 a small percentage of boat and engine, if you
can't afford those you are going to have trouble with the cost of
building the boat.
> Robert
Robert,
I don't know if that would be any clearer to you with the full sized plans. Though the full scale drawings are always helpful, for a guy with a couple sheets of plywood and an old motor laying around it's certainly legitimate to build from the book if your eyesight is good enough.
The piece you're looking atisthe the bottom framing piece of the transom. Without it, there'd be nowhere to nail the bottom all the way across. It is shown in the plan view. Remember the transom is at an angle.
The boat's plan and profile views are aligned exactly. Run your straight edge down from the framing piece shown in the side view to the plan view. Just to the right of the transom top are a pair of lines adjacent to the motor board. That's the part.
It's tricky because both the transom's bottom and top edges can't be shown in plan view without obscuring the other detail.
Hope this helps.
Robert
Robert
building the boat.
> Robert
Robert
