Re: [bolger] fiberglass butt joints
bILL,
YOU ARE WELCOME.
nOTHING WRONG WITH BUTT STRAPS IF HIDDEN.
OOPS CAPS
jEFF
YOU ARE WELCOME.
OOPS CAPS
jEFF
To: <bolger@egroups.com>
Sent: Thursday, August 03, 2000 12:39 AM
Subject: Re: [bolger] fiberglass butt joints
Thanks for the drawing.
I think I've decide to cut out the parts and do them
individually instead of in one shot for the entire
piece of plywood. This is my first time using epoxy
so I want to limit my risks.
thanks.
Bill
--- Jeff Gilbert <jgilbert@...> wrote:
> Safe drawing (will help)
> Jeff Gilbert
> From: Bill Turnbull <wturn@...>
> Sent: Tuesday, August 01, 2000 11:38 AM
> Subject: [bolger] fiberglass butt joints
> Hi all,
> I'm just starting a Michalak Toto and have a
> question
> regarding fiberglass butt joints.
> I think I'm going to take the approach outlined by
> Dave Carnell for doing both sides at once. Has
> anyone had experience with this method? Reading the
> instructions for Building Toto as well as the
> instant
> boat books it seems the recommendation is to apply
> the
> butt joint (in both cases using wood instead of
> figerglass) prior to cutting out the pieces. I'm
> concerned that if I cut out the pieces prior to
> joinin them together that I'll have alignment
> problems
> when making the joint.
> Perhaps I'm having butt joint anxiety??
> Thanks,
> Bill
> Do You Yahoo!?
> Kick off your party with Yahoo! Invites.
>http://invites.yahoo.com/
> - no cursing
> - stay on topic
> - use punctuation
> - add some content: send "thanks!" and "ditto!"
> posts off-list.
> ATTACHMENT part 2 image/jpeg name=CG031.jpg
Do You Yahoo!?
- no cursing
- stay on topic
- use punctuation
thanks.
Bill
Do You Yahoo!?
thanks.
Bill
> Safe drawing (will help)__________________________________________________
> Jeff Gilbert
> Hi all,
> question
> instant
> the
> problems
> Thanks,
> Bill
> Do You Yahoo!?
> - no cursing
> - stay on topic
> - use punctuation
> posts off-list.
Do You Yahoo!?
Jeff Gilbert
Jeff Gilbert
Hi all,
I'm just starting a Michalak Toto and have a question
instructions for Building Toto as well as the instant
boat books it seems the recommendation is to apply the
joinin them together that I'll have alignment problems
Bill
Do You Yahoo!?
- no cursing
- stay on topic
- use punctuation
I did mine the same way except for using a second board on top of
the first sandwich and on each succeeding sandwich, and using
sheetrock screws through the boards instead of brads. It squeezed
everything nice and smooth, very clean joints.
Richard Spelling wrote:
% Harrywelshman@...
>_ _ _ _ _
> Join the ply before cutting. Makes life easy.
> No prob doing multiple sheets of ply, both sides at the same time.
> 1) lay down particle board on the floor, big piece where the joint will be,
> small pieces to support the ends.
> 2) Prime plywood,
> 3) lay wax paper, tape down
> 4) epoxy, glass, epoxy
> 5) ply sheet one, brads to hold in place, thickened epoxy on end
> 6) ply sheet two, brads to hold in place, scrape off excess thichened epoxy
> 7) epoxy, glass, epoxy
> 8) lay wax paper
> 9) repeat
> add cinder blocks for weight. let cook till hard and crispy.
> have done four layers, and made 24ft long pannels this way. no worries.
% Harrywelshman@...
2) Prime plywood,
8) lay wax paper
9) repeat
2) Prime plywood,
8) lay wax paper
9) repeat
Sent: Monday, July 31, 2000 8:38 PM
> Hi all,
> Thanks,
> Bill
> Do You Yahoo!?
> - no cursing
> - stay on topic
> - use punctuation
