Enlarging a Plan
Thank you for all the comments. I am probably not as inept at boat
design and construction as I appear, and, much more probably, more so
than I know. So, thanks for your restraint.
Several mentioned the new Martha Jane. I can find nothing about it.
I have an old Commonsense catalogue, the web, and PB's "Boats with an
Open Mind." So far I have seen nothing new. Can someone put me onto
a better, available source?
Phil Sharp
Phil Sharp
Afterall, you're only adding four feet to the Long Micro!
--- Inbolger@egroups.com, pmcrannell@y... wrote:
> Dear Phil,
> There was a trick to enlarging boats, mostly cargo carriers,
that
> the shipyards used. The boatbuilders would simply move the bow and
> stern further apart. They would increase the length by adding to
> middle of the boat, keeping the beam and mid-section shape the same
> at the point of the cut. What you end up with is a roomier boat,
that
> will be faster with the same power as the original. You should be
> able to keep the sailplan and ballast the same by this method.
> There are a number of examples of this. Phil Bolger did this
with
> a number of designs. The one that comes to mind is Surf. He took
> mid-section of the Elegant Punt, and stretched her out 7' 9", and
> tapered the ends somewhat. Surf uses the same rig, rudder, and
> leeboard as the Punt. She sails rings around the shorter boat, can
> carry a lot more weight, and rows much better.
> Pearson Yachts used to build a boat called a Vanguard, 32' long,
> designed by Phil Rhodes. She looks vaguely Concordia-ish. They took
> this design, and added an 8' mid-section, and came up with a very
> fast boat called the Rhodes Reliant 40. This boat has more sail
area
> than the Vanguard, and more ballast, I'm sure. This is a very fast
> boat. A local one (St. Michael's, Md., Chesapeake Bay) won her
class
> in this year's Bermuda Race. She's a hard boat for us to beat in
> local races (I race on a friend's old Cal 36). We owe her an
eighteen
> second per mile handicap. She whips us consistently, boat for boat.
> Another boatbuilder, I can't think of whom, used another old
trick
> to get a bigger boat. They'd take the molds of a successful design,
> and simply space them farther apart, say, 4' centers instead of 3'
> centers. The stem and transom bevels would be different, but not
much
> else was. This technique was widely used by workboat builders for
> centuries.
> The key to all this was that the builders didn't change the size
> or shape of the mid-section. The determination of this section is
> first step in designing a boat, governing displacement. Everything
> else grows out of the mid-section.
> Using one of these techniques is how I'd go about expanding an
> extant design. I'd simply add whatever length to the middle of the
> boat. If you increase the beam, as you proposed, you're going to
have
> to change everything about the design. Sail area, ballast, lateral
> plane area, centers of gravity and bouyancy would all have to be
> recalculated.
> The cautionary advice everyone is giving you is good. Enlarging
> the boat needs a lot of thought and planning. I wouldn't hesitate
> do it, however, if you keep what's been learned over time about
boat
> design firmly in mind. Do your research. Read as much about boat
> design as you can. I recommend Bolger's books, Dave Gerr's "The
> Nature Of Boats" (a little corny in style, but totally interesting
> information), and "How To Design A Boat" by John Teale (so far very
> good. I haven't finished reading it yet).
> Take care,
> Pete Reynolds
> --- Inbolger@egroups.com, srelt@i... wrote:
> > I am thinking about purchasing a Long Micro plan and enlarging it
> > mathematically to 23' 6". Anyone see a problem from that? I
> thought
> > I would increase the scantlings by 1/4" ply all about.
> > Phil Sharp
> > srelt@i...
Dear Phil,
There was a trick to enlarging boats, mostly cargo carriers, that
stern further apart. They would increase the length by adding to the
at the point of the cut. What you end up with is a roomier boat, that
There are a number of examples of this. Phil Bolger did this with
a number of designs. The one that comes to mind is Surf. He took the
fast boat called the Rhodes Reliant 40. This boat has more sail area
boat. A local one (St. Michael's, Md., Chesapeake Bay) won her class
local races (I race on a friend's old Cal 36). We owe her an eighteen
Another boatbuilder, I can't think of whom, used another old trick
centers. The stem and transom bevels would be different, but not much
centuries.
or shape of the mid-section. The determination of this section is the
boat. If you increase the beam, as you proposed, you're going to have
recalculated.
the boat needs a lot of thought and planning. I wouldn't hesitate to
do it, however, if you keep what's been learned over time about boat
Take care,
Pete Reynolds
centuries.
recalculated.
Take care,
Pete Reynolds
thought
> Phil Sharp
> srelt@i...
Phil,
I don't want to be a dead horse, or even a living horse, but I have a
specific point to add.
The Bolger boxes have, on average, a frame or bulkhead every 4 feet.
The LM has 5. Your boat would need six. That raises questions about
the layout.
The bulkhead between cabin and cockpit is about midships. If you
space 6 bulkheads equidistant, then you don't have a one at midships,
and would have to decide between a bigger cockpit or a bigger cabin.
Or, you could decide, sensibly enough, that proper construction
requires a bulkhead at midships and then have to arrange an
additional frame both forward and aft.
p.s. The mast would probably have to be in a proper, pivoting
tabernacle. This would end up being a big boat to trailer in any case.
the layout.
Peter--thanks for the many good points. As a 60 year old, I want and
need a boat stable enough I don't worry about it, able enough to take
the bumps of trailering but also do offshore work if I should decide
to, large enough to let my wife and I spend some time aboard but
small
enough to be singlehanded. The Sea Bird (I still consider a raised
flush decked version of the original) by PB is great, but too tiddly
for my taste and purpose--perhaps too tiring. I don't know much
about
Black Skimmer. And the point about the sails, I thought I would do
an
enlargement of the modified cross between gaff and fully battened lug
that PB worked out for a Micro. You are right about the ballast,
etc.
I must be very careful.
Thanks for all your ideas.
Phil Sharp
small
about
an
etc.
Phil Sharp
--- Inbolger@egroups.com, "Peter Vanderwaart" <pvanderw@o...> wrote:
> I think that it is too big an increase to do without a careful
> computation of weights and sail area, not to mention the
construction
> plan. Are thinking of just making it longer, or also wider?
> All sorts of things can get out of whack, and from what I hear, you
> don't want to risk getting the rig any bigger porportionally than
it
> is. But the crew (live ballast) will be smaller for the size of the
> boat. If you make the boat wider, how does the bottom make use of
> plywood sheets? If the keel is the same width, is the ballast to
> little? If the keel is the same width, is the ballast too light?
> Should the keel be deeper? What about the mast dimensions? Thicker?
> Longer?
> You will find, I think, when you start to work out the details of
> construction that PCB has made very efficient use of the materials.
> He has had a lot of practice. If you just charge into it, you could
> end up with a much higher material cost.
> On the other hand, if you want to do your own design at the new
size,
> modeled after the LM, I think it's probably a fairly safe way to
go.
> Just do the homework.
> Why not Sea Bird '86? Black Skimmer?
> Peter
computation of weights and sail area, not to mention the construction
don't want to risk getting the rig any bigger porportionally than it
Longer?
You will find, I think, when you start to work out the details of the
On the other hand, if you want to do your own design at the new size,
modeled after the LM, I think it's probably a fairly safe way to go.
Longer?
mathematically to 23' 6". Anyone see a problem from that? I thought
Phil Sharp
srelt@...
Phil Sharp
srelt@...
