Re: [bolger] Re: Yamato Launch isometeric (was Large, big, long Diablo )
>Ditto for Advanced Sharpie 19, nearly identical side and bottom
> My observation is that Whalewatcher comes very close.
> Nels
curvatures, I believe.
> Black Skimmer for a start.
> HJ
> On 12/30/2010 6:03 AM, cecbell wrote:
> > I'm curious. Which of his boats actually follows the
> > "equal-curves-in-plan-and-profile paradigm" you mention?
> > --- Inbolger@yahoogroups.com, Fred Schumacherfredschum@ wrote:
> >> On Wed, Dec 29, 2010 at 10:03 AM, Bruce Hallman hallman@ wrote:
> >>>> Bruce, can you post straight-on bow and stern shots, so we can
see
> > how
> >>> the lines work out? Thanks.
> >>>> fred s.
> >>>http://www.hallman.org/bolger/Yamato/Linesplan.jpg
> >> Bruce, thanks for posting the lines plan. Phil didn't follow his
> >> equal-curves-in-plan-and-profile paradigm for this boat but stayed
> > with the
> >> traditional form. Is it possible that it is from the yamato boats
that
> > Phil
> >> got his idea for the thick shoe keel, as on Clam Skiff?
> >> This design looks like it would work very well as a fishing boat.
It
> > would
> >> ride soft, but not heel too much when leaning over the gunwale to
work
> > lines
> >> or nets.
> >> fred s.
> > - no cursing, flaming, trolling, spamming, respamming, or flogging
dead horses
posts
> > - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930,
Fax: (978) 282-1349
> --- Inbolger@yahoogroups.com, Fred Schumacher<fredschum@...> wrote:
>> On Wed, Dec 29, 2010 at 10:03 AM, Bruce Hallman hallman@... wrote:
>>>> Bruce, can you post straight-on bow and stern shots, so we can see
> how
>>>> fred s.
> with the
>> traditional form. Is it possible that it is from the yamato boats that
> Phil
>> This design looks like it would work very well as a fishing boat. It
> would
>> ride soft, but not heel too much when leaning over the gunwale to work
> lines
>> or nets.
>> fred s.
On Thu, Dec 30, 2010 at 10:56 AM, cecbell<cecbell@...>wrote:
Thanks Fred and Bruce. I'd read that comment in BWAOM (under the Presto
Cruiser, I believe) and some others a while back in a thread here. I
recently had a tentaive interest in scaling the AS-29 by half as a cheap
rowboat to see how that played out, thinking the AS-29 had that
property. But as I started to draw it, the difference between the bottom
profile and the arc of the side was more than I'd call reasonably close.
I suspect it would be difficult to design a practical boat that follows
that principle literally without accepting a wide bow transom (or a very
narrow boat or excessive rocker and draft). From what I'm able to see,
the Micro seems to be similar to the AS-29 in that regard. Perhaps it's
good enough to come closer to the idea in the way the AS-29 and Micro
(and others) do.
You're exactly right. Phil flattened the bottom curve toward the bow to keep it from coming too high out of the water. If a box keel cutwater is added, however, it is then possible to make the two curves exactly the same. I have played around with sketching such a change on Micro. Perhaps Susanne could step in and give us a fuller explanation.
fred s.
(and others) do. I didn't mean to hijack this thread with this diversion
so I'll bail out at this point. Thanks.
> His square boats from the 80s on tend to follow this plan. If looked
at from
> bow-on or stern-on, the chine line will bisect the angle formed by the
side
> and bottom. Phil talked about this in BWAOM, stating that by evenly
> splitting the water flow, eddies swirling across the chine would be
reduced.
> That is why boats like Micro have a transom bow, since taking the
lines out
> to a pointy stem would result in a bow too high out of the water.
However,
> by adding a box-keel cutwater under the bow, he could get around this
> problem.
> Perhaps Bruce could post some of his lines plans or links to them to
show
> Phil's methodology.
> fred s.
His square boats from the 80s on tend to follow this plan. If looked at from bow-on or stern-on, the chine line will bisect the angle formed by the side and bottom. Phil talked about this in BWAOM, stating that by evenly splitting the water flow, eddies swirling across the chine would be reduced. That is why boats like Micro have a transom bow, since taking the lines out to a pointy stem would result in a bow too high out of the water. However, by adding a box-keel cutwater under the bow, he could get around this problem.
Perhaps Bruce could post some of his lines plans or links to them to show Phil's methodology.
fred s.
>I think the so called "box boats" like the Micro, AS-19, AS-29 and
AS-39 come pretty close to having equal curvature of their sides to
their bottoms.
how
> > > fred s.
with the
Phil
would
lines
> or nets.
> fred s.
On Wed, Dec 29, 2010 at 10:03 AM, Bruce Hallman<hallman@...>wrote:> Bruce, can you post straight-on bow and stern shots, so we can see how the lines work out? Thanks.http://www.hallman.org/bolger/Yamato/Linesplan.jpg
> fred s.
Bruce, thanks for posting the lines plan. Phil didn't follow his equal-curves-in-plan-and-profile paradigm for this boat but stayed with the traditional form. Is it possible that it is from the yamato boats that Phil got his idea for the thick shoe keel, as on Clam Skiff?
This design looks like it would work very well as a fishing boat. It would ride soft, but not heel too much when leaning over the gunwale to work lines or nets.
fred s.
> fred s.
On Tue, Dec 28, 2010 at 1:02 PM, Bruce Hallman<hallman@...>wrote:http://www.hallman.org/bolger/Yamato/
Here is a quick isometric of Yamato Launch, design 511.
This boat looks very much like the yamato-gata boats Phil saw in Tokyo Bay during his service in the army of occupation after WW II, and as he wrote about in his first magazine article, which was republished by Watercraft magazine a couple of years ago. The cutwater and thick, wide bottom plank, instead of a keel, is distinctive of these boats.
fred s.
http://www.amazon.com/Simplified-Boatbuilding-V-Bottom-Harry-Sucher/dp/0393031802 His boats are not instant boats but he has a lot of good information on them. His plate 29 on page 243 looks similar to the Bolger cartoon somebody linked to earlier.
."It's the tides, man. They can either work for you or they can work against you...Confidentially, I've had this problem with the tides before."--Captain RonFrom:Peter <pvanderwaart@...>
Sent:Tue, December 28, 2010 4:13:59 PM
Subject:[bolger] Re: Yamato Launch isometeric (was Large, big, long Diablo )
Very nice, Bruce.>http://www.hallman.org/bolger/Yamato/
Unless he had some good reason not too, PCB usually worked within a accepted American style. I think his adaptations of other types really display genius at capturing shape and style. (Could anyone else have done the Plywood 12 1/2?) The Yamato looks great. (PCB would say it looks "well." He was a purist about some points of language.)
>http://www.hallman.org/bolger/Yamato/Very nice, Bruce.
Here is a quick isometric of Yamato Launch, design 511. Not exactly
like a Diablo, with the cutwater and all. It is worth mentioning that
design 511 is a relatively recent number and in the text writeup to
Samuel Clyde, PCB mentioned he wanted to add a cutwater to the hull,
and this cutwater on Yamato might be a reflection of that train of
thought.
On Tue, Dec 28, 2010 at 9:33 AM, Peter <pvanderwaart@...> wrote:
> > No one has mentioned the discussions of
> > "Yamato Boats" that were bouncing
> > around over the last couple of years.
> I found this reference to a MAIB article.
> V11 N01 Yamato Fishing Launch 5/15/1993
> I would take that to mean Volume 11, Number 1. I have a vague memory of the article, but not of the boat.
