Re: [bolger] Phil´s Monhegan - Friends hip sloop
Thanks
Carl
Den 08-01-2011 15:04,Susanne@...skrev:
Yes on plans.  Books cost 'mad' postage...  Correct on address.
philbolger@...works as well.
Susanne
Sent:Saturday, January 08, 2011 6:28 AM
Subject:Re: [bolger] Phil´s Monhegan - Friendship sloop
Thanks Susanne
Is it also  $200, when the drawings are to be sent to Denmark?
And the money is to be sent to this here address, I assume
Phil Bolger & Friends
P.O. Box 1209,
Gloucester, MA, 01930
USA
Carl Andersen
Den 07-01-2011 14:46,Susanne@...skrev:
Good Morning Carl,
    plans for Design #237 MONHEGAN on 6 sheets (17"x22") are available from Phil Bolger & Friends for $200 to build one boat, sent rolled in a tube.
Thanks for your interest.  The world needs more MONHEGANs...
Susanne Altenburger, PB&F
Sent:Friday, January 07, 2011 7:13 AM
Subject:[bolger] Phil´s Monhegan - Friendship sloop
I found some 3d pictures athttp://bolger.wikidot.com/bolger:mediumsailboats
I love that boat, clean fine lines. Where can I buy drawings to this fine sloop, and what is the price.
C. Andersen
Susanne
Thanks Susanne
P.O. Box 1209,
USA
Carl Andersen
Good Morning Carl,
C. Andersen
Thanks Susanne
P.O. Box 1209,
USA
Carl Andersen
Good Morning Carl,
C. Andersen
Scaling MONHEGAN is always an option with this type hull.
Sent:Friday, January 07, 2011 2:47 PM
Subject:Re: [bolger] Re: Phil´s Monhegan - Friendship sloop
Yes, and bigger boats cost more to build :-)
Carl Andersen
Den 07-01-2011 20:16, Peter skrev:
> Unfortunately, the picture showed that
> Monhegan is basically a large scale model of a Friendship sloop and is too
> small a scale for normal sized people (much like the very pretty Cape Dory
> Typhoon).
Interesting comment. I think the closest thing to a "standard" model for a Friendship sloop for pleasure use is the Pemaquid 25. That's quite a bit bigger. On the other hand, Monhegan is a little bigger than the Herreshoff 12 1/2 which is still popular, along with various more recent variants, so it depends at least a little on the details of deck and cockpit.
PCB designed a larger Friendship sloop called Master Hand, but once you start suggesting alternates, there is no end to the discussion.
Carl Andersen
> Typhoon).
> Typhoon).
Thanks Susanne.
I have contacted you directly through e-mail, hope that that's all right.
Carl Andersen
Good Morning Carl,
C. Andersen
Carl,
I was smitten by a profile drawing of Monhegan which appeared in the design section of ‘Motor Boating and Sailing’ in the late 60’s. I ordered a design portfolio from PCB shortly thereafter (‘Very Small Boats’ which was subsequently incorporated intoSmall Boats).
Monhegan is a fairly ambitious boatbuilding project and I never came close to starting construction. However, I did see a picture of one in the ‘Launchings’ section of “Woodenboat”. Unfortunately, the picture showed that Monhegan is basically a large scale model of a Friendship sloop and is too small a scale for normal sized people (much like the very pretty Cape Dory Typhoon). The crew was perched on the deck with their knees under their chins. My thinking is that building a Monhegan is a lot of work for a beautiful but not very useful boat. For something similar in profile but somewhat more useful, you might want to look at ‘Keel Whaler Sloop’, design #396 which appears in30-Odd Boats.
Plans should be available from Phil Bolger and Friends.
JohnT
From:bolger@yahoogroups.com [mailto: bolger@yahoogroups.com ]On Behalf OfCarl Andersen
C. Andersen
Good Morning Carl,
C. Andersen
C. Andersen
