Re: design 369, shoal draft whaler ketch
I have "heard" this is one method to help prevent the jib and the
staysail from hanging up on the end of the boom when tacking. Guess a
staysail is the wrong name on this design as there are no stays?
--- Inbolger@yahoogroups.com, BruceHallman <hallman@...> wrote:
> I am not sure about the snotter on this design either! Probably, the
> top part is to hold up the forward end of the boom, and the bottom
> part is a multipart (four sheave, six?) to really cinch up tight.
> On Fri, Feb 11, 2011 at 12:49 PM, White & Laur White
> omegacubed@... wrote:
> > Bruce Hallman --
> > The bow-and-arrow design for the snotters on the booms seems a
strange arrangement. Too flexible by far. Snotters are great to adjust
the draft of the sail, but once adjusted, you don't want the boom
sliding around, either away from its position on the mast or fore and
aft, no? Or is there a conventioal snotter rig, with the bow strings
used just to raise and lower the tack to tighten the leach or foot? What
am I missing?
> > -- Will
<omegacubed@...> wrote:
> Bruce Hallman --
> The bow-and-arrow design for the snotters on the booms seems a strange arrangement. Too flexible by far. Snotters are great to adjust the draft of the sail, but once adjusted, you don't want the boom sliding around, either away from its position on the mast or fore and aft, no? Or is there a conventioal snotter rig, with the bow strings used just to raise and lower the tack to tighten the leach or foot? What am I missing?
> -- Will
Bruce Hallman --
-- Will
