Re: A Bolger launch?
http://www.jwboatdesigns.co.nz/plans/piwakawaka/index.htm
and Selway-Fisher offers a couple of plywood designs, Rose and Fanny:
http://www.selway-fisher.com/Steamup20.htm
--- Inbolger@yahoogroups.com, "gregmkay" <gregmkay@...> wrote:
> Did Bolger ever design his own version of some sharpie-like equivalent in function to the luxurious late 19th-early 20th Century electric launches (The ones that were often fan tailed) for leisurely and cruising protected waters with small groups of friends? If he did, do you know where I might find information on it?
http://www.storerboatplans.com/Solarboat/solarboat.html
--- Inbolger@yahoogroups.com, Greg Kay <gregmkay@...> wrote:
> What I was thinking about personally was something on the general order of
> above-water appearance as the fantail launch posted earlier
> (http://www.woodenboatstore.com/prodinfo.asp?number=400-092)but of a lighter
> build on an easily-driven lower hull, preferably flat bottom. I'm thinking the
> battery bank should go along the centerline (or possibly even inside a shallow
> box keel?) with the low weight adding maximum stability (allowing for people
> moving around) with minimum draft. It might be possible to extend the cruising
> range by making the shading canopy top dual-purpose; cover the top with solar
> cells to boost the battery charge. Granted, it wouldn't keep up with the
> discharge, but it would slow the rate down a bit while adding minimal weight.
> Just some thoughts...
> ________________________________
> From: Douglas Pollard <dougpol1@...>
> To:bolger@yahoogroups.com
> Sent: Wed, March 2, 2011 10:33:32 AM
> Subject: Re: [bolger] Re: A Bolger launch?
> Electric drives are great for small and maybe even big boats and even more
> so in the near future. If you can get or have a golfcart motor I would use
> it. I am not as sure that I would buy a motor and batteries unless just a
> trolling motor and a couple batteries where there is not a lot of money
> involved. It is my understanding that the new batteries will be much higher
> voltage and so will the motors they run. I am not sure that what I am
> saying here is true but maybe just something to think about? I think
> electric is going to very practical for sailboat auxiliaries in the not to
> distant future as long as you spend most nights in a marina where you can
> charge batteries or use the motor very little. If you are going off
> cruising they probably won't work unless you want to listen to a generator
> run all night.
> The future is almost here. Doug
----- Original Message -----From:f_swygertSent:Thursday, March 03, 2011 12:31 PMSubject:[bolger] Re: A Bolger launch?I'm with you on this Doug. I think I'd definitely rig one of the golf cart motors up for a sail boat auxiliary, at least where a 5-10 hp motor would work. An electric motor is generally rated at continuous output, a mechanical gasoline engine is typically rated at max output -- though I'm not positive about outboards. Typical golf cart motors are rated at 5-8 hp, but that should be continuous running as long as they are adequately cooled. They usually run at 48V (8x6V batteries). 12V deep cycle batteries won't last as long as 6V golf cart batts, but that's when they are drained and charged often. If more than just docking or getting out of the marina (more than 30 minutes) is needed then crank the generator and keep the batts up. Most sail boats have a small generator anyway. Not much difference between the generator running or an outboard as far as noise, though the gen can be placed in an area where the noise is muffled. Solar cells could help with the batteries, especially a trickle charge to keep them up while docked. Don't think I'd try for much more than that. The battery/gen system could double for lighting and such too.
--- Inbolger@yahoogroups.com, Douglas Pollard <dougpol1@...> wrote:
> I think electric is going to very practical for sailboat
> auxiliaries in the not to distant future as long as you spend most
> nights in a marina where you can charge batteries or use the motor very
> little. If you are going off cruising they probably won't work unless
> you want to listen to a generator run all night.
You might want to look up the details on the conversion of the Crater Lake tour boats to electric. It details the research and the numbers on changing over to zero pollution for the launch that takes you out to the Wizard and around the lake. I just took a quick look and did not spot it. It is/was the regular government style of documentation with types of motors, types of batteries, ranges, costs, etc that were researched before doing the conversion.
MylesJ
IMO using a golf cart as a donor for the drive train is a very good way to go. You need to learn the working RPM of the motor, and plan for a reducer to match your selected propeller. I'd favor motorcycle type chain, or toothed belt and avoid V-belts because of the excessive side loads. You might also find an industrial gear box surplussed out for cheap.
Regarding the hull, in the Bolger choices, I think Bonefish, which could be based on Hawkeye's construction plans would be an excellent hull for the purpose. You only need to "double end" the box keel, also round and kick up the stern for the fan tail effect. Very light (an 18' Hawkeye weighs less than a 14' MicroTrawler) it would easily trailer. The design is very easily driven, and extremely stable for a picnic/evening cruise crowd. The batteries, and the motor will reside cleanly in the box keel and it even allows for a porta-potty in the console. I'd favor a couple of bimini's over the hard dodger.
Don
Over the winter of '09-10 I changed to roof hoping to make an easy up-down mechanism for trailering, but i could not come up with anything that I liked. My wife likes the boat so much, she has forbidden me from taking it from our home lake so trailering the boat is no longer an issue. She has allowed me to make another slightly smaller launch that i may take when I want to go someplace. (will launch with ice-out)
As you can see, there is plenty of room to relax, the 8hp Yamaha High-thrust is virtually silent being so far back. the hull draws 6" fully loaded with 6 adults and cooler of beverages. We have been asked to lead the July 4th boat parade the last 2 years, a great honor.
Sent:Wed, March 2, 2011 1:25:02 PM
Subject:Re: [bolger] Re: A Bolger launch?
Here is a possibility, though it is not a Bolger Launch. I have an
Elver sailboat double ended flat bottom and a finely shaped hull
above the water. I talked to a few about a years ago to a fellow
who bought one, tore the cabin off of it and put seats down both
sides for guests to set in. The seats set facing inward so gest
would be facing each other for conversation. The seats also were
hull supports to replace the strength that had been given by the
cabin. He had planned an electric motor as well. The idea was to
have a family launch that they could take a couple neighbors and
themselves for a Sunday afternoon cruise.
Go take a look at the boats on the Elver sight by Steve Redmond.
Might be able to pick one up for $1000 or so and modify it. I can
envision she would make a handson little cruiser with only about 3"
of draft at the bow and a foot at the stern. Nice for running up on
beach.
Doug
On 03/02/2011 11:03 AM, Greg Kay wrote:
What I was thinking about personally was something on the general order of above-water appearance as the fantail launch posted earlier (http://www.woodenboatstore.com/prodinfo.asp?number=400-092) but of a lighter build on an easily-driven lower hull, preferably flat bottom. I'm thinking the battery bank should go along the centerline (or possibly even inside a shallow box keel?) with the low weight adding maximum stability (allowing for people moving around) with minimum draft. It might be possible to extend the cruising range by making the shading canopy top dual-purpose; cover the top with solar cells to boost the battery charge. Granted, it wouldn't keep up with the discharge, but it would slow the rate down a bit while adding minimal weight.Just some thoughts...
Sent:Wed, March 2, 2011 10:33:32 AM
Electric drives are great for small and maybe even big boats and even more so in the near future. If you can get or have a golfcart motor I would use it. I am not as sure that I would buy a motor and batteries unless just a trolling motor and a couple batteries where there is not a lot of money involved. It is my understanding that the new batteries will be much higher voltage and so will the motors they run. I am not sure that what I am saying here is true but maybe just something to think about? I think electric is going to very practical for sailboat auxiliaries in the not to distant future as long as you spend most nights in a marina where you can charge batteries or use the motor very little. If you are going off cruising they probably won't work unless you want to listen to a generator run all night.
On 03/02/2011 09:52 AM, Greg Kay wrote:I saw a diagram of one once, hooked up to a shaft with a drive belt. I think Glen-L or Clarkcraft has something about that.
Sent:Wed, March 2, 2011 9:41:22 AM
I've got a couple old golf carts that were given to me. I'm wondering if one of those motors would make a good slow cruiser....
--- Inbolger@yahoogroups.com, "sirdarnell"<sirdarnell@...>wrote:
> Yes. Plans $75 from the Woodenboat Store:
> David
Go take a look at the boats on the Elver sight by Steve Redmond. Might be able to pick one up for $1000 or so and modify it. I can envision she would make a handson little cruiser with only about 3" of draft at the bow and a foot at the stern. Nice for running up on the beach. Doug
On 03/02/2011 11:03 AM, Greg Kay wrote:What I was thinking about personally was something on the general order of above-water appearance as the fantail launch posted earlier (http://www.woodenboatstore.com/prodinfo.asp?number=400-092) but of a lighter build on an easily-driven lower hull, preferably flat bottom. I'm thinking the battery bank should go along the centerline (or possibly even inside a shallow box keel?) with the low weight adding maximum stability (allowing for people moving around) with minimum draft. It might be possible to extend the cruising range by making the shading canopy top dual-purpose; cover the top with solar cells to boost the battery charge. Granted, it wouldn't keep up with the discharge, but it would slow the rate down a bit while adding minimal weight.Just some thoughts...
> David
> David
> David
> David
> David
--- Inbolger@yahoogroups.com, "KK7B" <kk7b@...> wrote:
> This is not a Bolger design, but here's an elegant modern example of the type, completed this year at Grapeview Point Boatworks. Scroll down for a nice sequence of construction photographs.
>http://www.grapeviewpointboatworks.com/zimmer.html
> Rick
Rick
> Did Bolger ever design his own version of some sharpie-like equivalent in function to the luxurious late 19th-early 20th Century electric launches (The ones that were often fan tailed) for leisurely and cruising protected waters with small groups of friends?I believe he did, but it's not in any of his books. Possibly somewhere in the MAIB archives.
He did publish a 15' Electric Launch in "Different Boats", and a 44'Lake Launch in "30-Odd Boats", either of which might interest you. I think he would want you to consider Alice which is in BWAOM. It's not the elegant open launch that you're looking for, but it's a boat for a similar purpose.
