Re: Design Name
Andrew
--- Inbolger@yahoogroups.com, "bobn181" <bob-norris@...> wrote:
> <snip> the more I look at Bolger articles, the more I'm drawn to his slot-top designs. <snip>
Just a quick comment on the slot top designs. Some of them use a slot top that is close to the length of the boat. Great for bad weather, drizzly days, etc. You are inside the boat. Some are half the length with a cockpit of some type. You may not like being inside when the weather is not terrible. On the other hand if you are building something light, without ballast, the full length slot designs are very stable since all your weight is at the lowest point, not a couple of feet higher on deck.
MylesJ
>Trying to fill in the details on this, reported last August by SA:
> "Camper" seems to be the smaller version of the WDJ, but reports of the original were not favorable.
"the first CAMPER completed in California suggest the need for some
ballast or lighter rig or both "
Personally knowing a little about the Sacramento Delta, during summer
time the winds can really be howling there, especially in the
afternoons.
One thing I recall that is similar about the WDJ and Birdwatcher
designs is that they are intended to be sailed heel over
significantly. I am not sure about Camper 640, but looking at the
lines, it seems that it could tolerate a lot heel under sail, but
maybe the bottom doesn't weigh enough to right it if knocked down and
the loose gear all fell towards windward?
Photo album here:
http://s926.photobucket.com/albums/ad108/pramsafloat/
David 'Thorne' Luckhardt put it up for sale in Aug 2009 with the
reason given: "(that owing a boat was) no longer a
fit with my life, which has changed dramatically in the last year",
including a move from the Sacramento to Seattle.
The MAIB article mentioned the owner as being a 'Peter Ramsey', maybe
the boat was sold once circa 2005 while in construction?
In any case, I think the original Birdwatcher, also lot less boat than the WDJ, is superior to Camper {based on nothing but my own preferences}. It is though, at the very least, well proven.
> Hello, fellow Bolgerians. I have plans for the Chebacco Navigator, which I think is really neat. But the more I look at Bolger articles, the more I'm drawn to his slot-top designs. In the last MAIB Susanne had a cartoon of his "Wandervogel" concept. I really like the esthetics and layout of the William D. Jochems, but it's too much boat for my situation. I know I have seen at least a cartoon of something smaller than the WDJ, probably a cat-yawl, but I can't find it. Does anyone know the name of the design, or where I can find anything about it? I hate to bother Susanne if I don't have to. Thanks.
Theodore Roosevelt
Sent:Wed, March 2, 2011 1:41:39 PM
Subject:[bolger] Design Name
