Re: What is the latest understanding on keeping wet epoxied pieces from getting glued to the work-table ?
--- Inbolger@yahoogroups.com, "Susanne@..." <philbolger@...> wrote:
> Good Morning All.
> I know of wax-paper.
> Any other approaches that have proved successful ?
> Susanne Altenburger, PB&F
Bob
--- Inbolger@yahoogroups.com, "John and Kathy Trussell" <jtrussell2@...> wrote:
> I use a fairly thick, clear plastic drop cloth material. When laminating, I
> wrap the laminations in the plastic after I apply glue and then clam the
> whole package to the form. It saves a lot of mess on forms, work surface,
> clamps, and me. Cleaning up the squeeze out is the same aggravation as
> always, but at least the clean up is confined to the lamination!
> JohnT
> _____
> From:bolger@yahoogroups.com[mailto:bolger@yahoogroups.com] On Behalf Of
> Mark Hamill
> Sent: Sunday, March 13, 2011 1:54 PM
> To:bolger@yahoogroups.com
> Subject: Re: [bolger] What is the latest understanding on keeping wet
> Lee Valley sells these sharp pointed pyramids to support painted work--have
> not used them myself but they might work as well for epoxy see "Painters
> Pyramid"---Finishing section of on line catalogue
>http://www.leevalley.com/en/home/OnlineCatalog.aspx?id=6c0230a6It says
> that people used nails or screws for the same purpose.
> From: Susanne@...
> Sent: Sunday, March 13, 2011 6:46 AM
> Subject: [bolger] What is the latest understanding on keeping wet epoxied
> Good Morning All.
good results with plastic trash bags. Make a couple of quick cuts, and
you can open them up into flat sheets to cover more area. For larger
pieces, I suppose any type of plastic sheeting would work, such as a
tarp, painter's "dropcloth," etc.
On 3/13/2011 8:46 AM,Susanne@...wrote:
> Good Morning All.
On 3/13/2011 5:46 AM,Susanne@...wrote:Good Morning All.
I use a fairly thick, clear plastic drop cloth material. When laminating, I wrap the laminations in the plastic after I apply glue and then clam the whole package to the form. It saves a lot of mess on forms, work surface, clamps, and me. Cleaning up the squeeze out is the same aggravation as always, but at least the clean up is confined to the lamination!
JohnT
bolger@yahoogroups.com ]On Behalf OfMark Hamill
Sent:Sunday, March 13, 2011 1:54
PM
Subject:Re: [bolger] What is the
work-table ?
LeeValleysells these sharp pointed pyramids to support painted work--have not used them myself but they might work as well for epoxy see "Painters Pyramid"---Finishing section of on line cataloguehttp://www.leevalley.com/en/home/OnlineCatalog.aspx?id=6c0230a6 It says that people used nails or screws for the same purpose.
Sent:Sunday, March 13, 2011 6:46 AM
Subject:[bolger] What is the latest understanding on keeping wet epoxied pieces from getting glued to the work-table ?
Good Morning All.
- Peter McCorison
----- Original Message -----From:Susanne@...Sent:Sunday, March 13, 2011 6:46 AMSubject:[bolger] What is the latest understanding on keeping wet epoxied pieces from getting glued to the work-table ?Good Morning All.
