Re: [bolger] Re: Dry Bilges
On 04/02/2011 04:23 PM, John and Kathy Trussell wrote:I once was a passenger on a big deep v. The owner’s wife backed us into the water and agreed to meet us at the end of the day. We motored 6 miles offshore to an artificial reef, anchored, and began rigging the rods when we noticed a lot of water over our feet. We had a plug but we had not put in. Exciting times! Happily, the motor started, we tied a float cushion to the anchor line and dumped it, and were able to get up on a plane and suck the water out. Since then, I have painted ‘PLUG!’ on my trailer tongue as a reminder to install the plug before I launch. So far, it has worked.
JohnT
From:bolger@yahoogroups.com[mailto:bolger@yahoogroups.com]On Behalf OfRon Magen
Sent:Saturday, April 02, 2011 4:00 PM
Subject:[bolger] Re: Dry Bilges
Bill & 'yonder' -
Depending on the type of 'Drain', or more specifically 'Drain Plug', hang a
'reminder' on the hatch latch or some other VERY CONSPICUOUS place.
Something that MUST be unlocked or used BEFORE you even get the boat off the
trailer.
On the P15 I am refurbishing, I put in a scupper of brass tube and used a
'screw/snap-latch' compressing plug. It is a separate piece. If this was
used as a Bilge Drain I would attach a loop of Stainless 'safety wire' to it
and place it on the hasp of the hatch lock. It would be not only
'conspicuous, but the first thing I would touch before even entering the
boat!! It would ANNOUNCE that THIS was the FIRST thing to be done.
Even if you don't use this type of 'stopper' - use something ELSE as a
'mnemonic. I believe the P15 originally came with a simple cork - attach a
BIG one or even a large wooden plug shaped like one. Or an old latch-type
Thermos stopper, etc.
Regards & Good Luck,
Ron Magen
Backyard Boatshop
> 2a. Re: Dry Bilges
> Posted by: "yonderman@..."yonderman@...jmbell1
<snip>
> I've never regretted having a drain plug in the bottom of my larger boats.
> This is particularly useful when you are trailering during a heavy
> rainstorm.
<snip>
> Of course you have to remember to put the plug back in before you launch!
> I've forgotten this crucial step a time or two, I have to admit.
<snip>
Bill Howard<billh39@...>wrote:
>> Questions for all you experienced builders and sailors:
>> How does one get water out of the bilges? . . . But what to do about
>> casual water in the bilges of a 1300 lb boat?
JohnT
bolger@yahoogroups.com ]On Behalf OfRon Magen
4:00 PM
Bill & 'yonder' -
trailer.
Ron Magen
Backyard Boatshop
> 2a. Re: Dry Bilgesyonderman@...jmbell1
<snip>
> I've never regretted having a drain plug in the bottom of my larger boats.<snip>
> rainstorm.
> Of course you have to remember to put the plug back in before you launch!<snip>
trailer.
Ron Magen
Backyard Boatshop
> 2a. Re: Dry Bilges<snip>
> rainstorm.
Of course you have to remember to put the plug back in before you launch! I've forgotten this crucial step a time or two, I have to admit. That's when you go back and get the trailer and haul it back out to let the water drain out. Any worry about leaking through the drain plug is way overstated in my opinion. It's just not that big a deal to have an opening below the waterline.
My current boat has an Elvstrom bailer mounted in the low point of the hulll. The advantage here is if you are going fast enough you can open it and bail the bilges without any effort by you.
--- Inbolger@yahoogroups.com, Bill Howard <billh39@...> wrote:
> I am building a 1/8 scale model of Jim Michalak's Picara design. This has been an educational build. What I learned would convince me to never start a full size boat without building a model first.
> How does one get water out of the bilges? I just turn my June Bug upside down to put it on top of my CRV, and any drops fall out.
> But what to do about casual water in the bilges of a 1300 lb boat?
> My fiberglass Daysailer had a bilge plug in the transom for this purpose; when on the trailer this was the low point, and water fell out.
> What is the secret for larger wood boats?
> Thanks for your help.
> Bill Howard
> Nellysford VA
Fairwinds,
Dennis
--- Inbolger@yahoogroups.com, "Andrew" <a.c.l.yen@...> wrote:
> > Your boat cover is cat-proofed right?
> > Not too many cozy nooks around my place that the neighbor's cat hasn't found yet
> > and occasionally soiled. The upside is the area is fairly mouse-free.
> > Justin
> The bilge water is actually awful but not from wildlife - inboard motor=oil and fuel in the bilge. But I'm not as silly as I look - the tube is transparent and about 5 metres long so you know well in advance when to stop sucking.
> Andrew
> Justin
Andrew
Theodore Roosevelt
Sent:Wed, March 30, 2011 7:32:03 PM
>The tube is in place under the tarp all the time so all I have to do >is suck on the end to get the siphon going any time I am walking past >the boat.Your boat cover is cat-proofed right?
Not too many cozy nooks around my place that the neighbor's cat hasn't found yet and occasionally soiled. The upside is the area is fairly mouse-free.
Justin
Justin
On Mar 29, 2011, at 7:15 PM, Andrew wrote:I intend to do what Dennis has done someday on my 15' ply inboard trailer sailer that sits on it's trailer most of the time - But since I haven't got around to it yet I have a length of thin tubing (air hose from an aquarium) that I put one end in the bilge and siphon out any rainwater whenever needed. The tube is in place under the tarp all the time so all I have to do is suck on the end to get the siphon going any time I am walking past the boat.
It takes 1/2 an hour to drain a few litres of rainwater - but I don't have to attend to it once it is siphoning.
Andrew
--- Inbolger@yahoogroups.com, "dennislancaster36" <dennislancaster36@...> wrote:
> On my OldShoe, I installed a bronze drain at the lowest point of the cockpit sole, just to the side of the keel. Drain has a screw in plug. It does not leak and I have it removed while the boat is on its trailer just in case water should get in under my tarp. Prevents that huge cockpit from filling with water.
> Dennis
Andrew
> Dennis
> Bill Howard
> Nellysford VA
Dennis
> Bill Howard
> Nellysford VA
Bill Jones
Mechanicsville VA
> Bill Howard
> Nellysford VA
Bill Howard
Nellysford VA
I was shocked when I saw your pictures and realized just how small you shop space truly is and what you have produced from it and what you had to do to get the boat out of it! Good on you mate, she will be a fine pocket cruiser. Looking forward to more pics.
Best,
Dennis OldShoe "Pearl"
Bellingham, WA.
--- Inbolger@yahoogroups.com, "meier.denis" <meier.denis@...> wrote:
> Finally posted a few pictures of MicroWave. Started building a Micro a few years ago then wanted a Navigator, then decided I needed a roomy cockpit so I took a few ideas from here and there on this site (thank you all) and this is what will launch this summer. Way overbuilt but should be a safe camper cruiser for a novice sailor.
> Denis Meier
> Onoway, Alberta, Canada
> MicroWave
> PDRacer #435 Duck
Denis Meier
MicroWave
PDRacer #435 Duck
