Re: Lead keel shaping
http://www.duckworksbbs.com/tools/shinto/index.htm
http://www.amazon.com/Stanley-21-296-Surform-Plane-Regular/dp/B00002X1ZL
I have the Surform version but no lead to try it on. It works very much
like cheese grater.
--- Inbolger@yahoogroups.com, "David" <lae52@...> wrote:
> I think it was on Welsfords Yahoo group that I heard someone, John
maybe, talking about using a power planer. If hand tools (files) load up
try coating them with a layer of chalk before using them. They also make
a file that had coarse curved teeth cut that was made for use with lead
when it was used in auto body work.
> Dave
Jason K
Everett WA
Sent:Tue, April 12, 2011 5:45:36 PM
Subject:[bolger] Re: Lead keel shaping
--- Inbolger@yahoogroups.com, "rod_cahill" <rod_cahill@...> wrote:
> I have now made sections of my Micro keel... When it is cool enough it will need to be shaved to produce a perfectly flat surface to epoxy into the keel casing. My question is, what is the easiest way to shave the lead.
An electric handplane works well. It produces shavings rather than dust, so no ingestion/inhalation risk. The build guide which came with my plans called for epoxying in addition to bronze nailing. I would recommend pre-drilling for the nails, and having a few extra drill bits since it's fairly easy to break a bit in the 'grabby' lead.
I have roughly welded a template from 40mm flat bar and sectioned it. The sectioning is so I don't need to do the pour in one sitting and to help keep the shape of the template. I then bent this template onto a waste piece of ply and screwed it in place.
I was fortunate enough to get some lead ingots from an old printing works. I filled the section with solid ingots then melted some in a kitchen saucepan and filled the gaps. The little single burner camp cooker did take about 20 minutes to melt 4 or 5 kg, lots of coffee breaks between pours. I have included some photos in "Rods Micro" photos. Any constructive criticism will be graciously accepted. I am learning as I go.
Sent:Wed, 13 April, 2011 2:30:29 AM
This is pretty close to next for me too. Did you pour it in one piece? You did say "sections". Seems like 2 or 3 smaller pieces would be easier to handle than one 400 pounder. I saw somewhere in the photos section where someone poured the keel in 3 sections and it looked much easier to deal with.
How did you heat the lead? I don't have that part figured out yet.
Right now I am sanding, sanding and sanding in preparation for painting above the waterline. I will wait until I have the lead installed before I finish below. Will order the sails from Duckworks this week and should be in the water in July.
I checked the computer where I buy my supplies here in Edmonton and find that I am now 5 years into my 18 month build. On the other hand, the idea was to have it complete by the time I am old enough to retire so that puts me over a year ahead of schedule. Glass half full stuff.
I am getting pretty excited about the prospect of finishing.
Blessings,
Denis Meier
Onoway, Alberta, Canada
#435 Duck (PDRacer)
MicroWave (Micro with a cabin for camping)
> I have now made sections of my Micro keel by pouring the hot lead into an open mould. When it is cool enough it will need to be shaved to produce a perfectly flat surface to epoxy into the keel casing. My question is, what is the easiest way to shave the lead. One side is perfectly flat as it was the bottom of the mould whereas the open top has some irregularities that need to be evened out.
<*> Your email settings:
(Yahoo! ID required)
bolger-digest@yahoogroups.com
On 04/12/2011 02:59 PM, dennislancaster36 wrote:I made a wood plug and took it to a local foundry.....
Dennis (oldshoe) Pearl
Bellingham, WA
--- Inbolger@yahoogroups.com, BruceHallman<hallman@...>wrote:
> One other thing...I transferred the molten lead from the melt pot to
> the ingot using an improvised steel ladle, scooping it like some VERY
> hot soup. Molten lead has a viscosity like water.
Bellingham, WA
Rod,
I made mine in one piece. I test fit it to get off the high spots. I didn’t have much to do, a draw knife worked well. I made a thick epoxy slurry to fill the low spots. When it was time to mount permanently I again made a thickened epoxy, coated the slot and lead, jacked it up into the slot and hammered home a couple hundred bronze ring shank nails. Once that was all set and sanded I covered the keel and about a foot on either side of the keel root with 6 layers of glass.
MylesJ
>I did one piece, per the plans, and I recommend it. Though, my pour
was in three batches, filling the ingot mold about 1/2 inch each time.
> How did you heat the lead?For the melt, I used a 5 gallon steel paint bucket setting on bricks.
Fired up with 75 lbs of BBQ briquettes, and I used my electric leaf
blower to hot it up with air. In hindsight I would have pre-melted
the wheel weights to remove the steel clips first, making a stack of
40 each 10 pound bricks, which I would then remelt for the 400 pour.
I would either try pounding the high-spots with a hammer, or a hammer and chisel (or maybe a block plane). I assembled my Long Micro keel with 50 lb. lead bricks, which I cut to length with a brick chisel and a hammer. I found that it worked better than cutting with a hacksaw (and I was too frightened to approach the lead with a circular saw or chain saw, although I've heard it works).
I slathered each brick in thickened epoxy, slid the brick into the keel, then drilled pilot holes with a well lubricated drill bit, and screwed in place with silicone-bronze screws. Belt, suspenders, and epoxy.
Bill in Texas
> On Tue, Apr 12, 2011 at 4:46 AM, rod_cahill <rod_cahill@...> wrote:
> > I have now made sections of my Micro keel by pouring the hot lead into an open mold. When it is cool enough it will need to be shaved to produce a perfectly flat surface to epoxy into the keel casing.
> Congratulations on the Micro build!
> I don't think the plans call for epoxy. If I recall correctly, the
> plans call that the lead ingot gets sandwiched between two pieces of
> 1/4" plywood and nailed in place. (I found that the stubby fat nails
> that they market with "Simpson Brand" framing hardware worked great.)
> This ply-nail sandwich method has been tested many times and it does
> work good enough. It is up to you to decide if good enough isn't good
> enough for you and your option can include "belt and suspenders".
> Also, there is no need for "perfectly flat" in my opinion. When I did
> my Micro lead casting I needed to trim some edges, and for that I used
> a Skilsaw. Small bumps can be leveled with a hammer as lead is
> malleable, or cut with a hammer and chisel .
> I understand the concern about lead toxicity, don't eat or breath the
> dust. (Many of our parents exposed themselves to much higher amounts
> of lead shooting guns at the firing range, and look how they turned
> out!) To me the biggest safety hazard was handling and moving an
> awkward 400 lbs hunk of metal. It took some ingenuity to achieve this
> without dropping it and smashing a toe or finger.
Blessings,
Denis Meier
#435 Duck (PDRacer)
Dave
--- Inbolger@yahoogroups.com, "John and Kathy Trussell" <jtrussell2@...> wrote:
> First, be aware that lead dust is nasty stuff and you a) need to wear a mask
> and b) wash thoroughly when you get done.
> Chappelle claims you can plane it with a hand plane. I haven't had much
> success. I have found that a Shinto rasp works pretty well. Files clog
> quickly and I have never tried power tools like a side grinder. I don't
> claim any expertise and likely someone else has a better approach.
> JohnT
> _____
> From:bolger@yahoogroups.com[mailto:bolger@yahoogroups.com] On Behalf Of
> rod_cahill
> Sent: Tuesday, April 12, 2011 7:47 AM
> Subject: [bolger] Lead keel shaping
First, be aware that lead dust is nasty stuff and you a) need to wear a mask and b) wash thoroughly when you get done.
Chappelle claims you can plane it with a hand plane. I haven’t had much success. I have found that a Shinto rasp works pretty well. Files clog quickly and I have never tried power tools like a side grinder. I don’t claim any expertise and likely someone else has a better approach…
JohnT
bolger@yahoogroups.com ]On Behalf Ofrod_cahill
Sent:Tuesday, April 12, 2011 7:47
AM
Subject:[bolger] Lead keel
shaping
