Re: wood flour tip
Fillets are structural components, at least in a stitch-n-glue boat,
and I'd be concerned with wheat flour's tensile strength in an epoxy
matrix. Also, it contains starch, not a good thing near water.
Also, the length of the fiber is less with wheat flour than in the
wood flour made for plastics use. Length of fiber affects tensile
strength. All in all, I'd say use wheat flour, considering the cost
of the epoxy you are mixing it with versus the slight additional cost
of buying wood flour is inconsequential. You remind me of a boss I
used to have. He'd step over a dollar bill to pick up a
nickel. ;) Dan
--- Inbolger@egroups.com, fraser.howell@n... wrote:
> I've used flour itself as an epoxy thickener. I don't know what are
> pros and cons of using flour from the kitchen vs. wood flour, but
> kitchen stuff is cheap. I've only used it in filets, not in a
gluing or
> fairing application.
> cheers;
> Fraser Howell
I've used it too, seems to work fine.
Haven't done any testing, but I imagine wood flour is more fiberous, and
stronger in tension. Not that it matters for most applications we are
talking about.
Wonder how whole wheat flour would compair?
Richard Spelling,http://www.spellingbusiness.com/boats
From the muddy waters of Oklahoma
To: <bolger@egroups.com>
Sent: Wednesday, August 09, 2000 9:45 AM
Subject: Re: [bolger] wood flour tip
> I've used flour itself as an epoxy thickener. I don't know what are the
> pros and cons of using flour from the kitchen vs. wood flour, but the
> kitchen stuff is cheap. I've only used it in filets, not in a gluing or
> cheers;
> Fraser Howell
> - no cursing
> - stay on topic
> - use punctuation
cheers;
Fraser Howell
I've used a VitaMix for the same thing, works OK.
The dust from the collector on my belt sander works better though, much
finer, and doesn't need processing.
Plus, it has a certain symmetry. Sand wood off one part of the boat and put
it back on somewhere else...
To: <boatdesign@onelist.com>; <bolger@egroups.com>
Sent: Wednesday, August 09, 2000 9:16 AM
Subject: [bolger] wood flour tip
> From:
>clipper45@...
> Meant to tell you I picked up an Oster Food processor at a yard sale for
> 2 bucks. Well, since we already have a nice one in the kitchen this one
> went to the shop. I sift sawdust through some screen wire or
> strainer.and then put it in the food processor. I sharpened the blades
> razor sharp with a diamond steel. Makes me tons of wood flour to use a
> a filler with resin and glue! Made some some oak sawdust, and some from
> pine, fir, and whatever else was under the saw, but I have mixed sawdust
> with glue for years...This is just a super fine texture...like flour.
> Just thought I'd pass on the tip. Richard
>http://community.webtv.net/clipper45/RICHARDSBOATPAGE
> This from Richard who's built a bunch of boats the last of which was a
> Featherwind. I bet those little spice/coffee grinders would work too.
> They pop up for a buck or tow at yard sales too.
> - no cursing
> - stay on topic
> - use punctuation
