Re: More Micro keel questions
Hi Rod, lead is more like plastic than steel. The stuff from the printer has antimony in it, making it harder, but still plastic (extra good for casting bullets). Try going to a plastic store and get a drill bit made for Lexan, like these:
http://www.rplastics.com/plasticdrill.html
It has the point dulled properly. Also make sure you drill at very slow speed, use a variable speed drill, don't push too hard, and pull out frequently to clear the chips. Use kerosene as a lube, get a oilcan and keep pumping it in as you drill. Some say milk works, but I have not tried it. Jason K
--- Inbolger@yahoogroups.com, "rod_cahill" <rod_cahill@...> wrote:
> Plan A with the template wasn't too successful so I am going with plan B and have epoxied the ingots in place and melted some lead between the ingots. Seems to have worked pretty well. Problem now is that I am drilling holes for the SS screws and out of the 3 holes that I have drilled, with the utmost care, all 3 have broken. I have used some WD40 light oil lubricant but as soon as the bit touched the lead they broke. It is going to be an expensive exercise if I am to drill a couple of hundred holes! I am told that the lead is harder than normal being from a printers. Any suitable solutions would be greatly appreciated.
>__
I have a pointy skiff that is 25 years old now. I used luan underlayment for the sides and every spring I find the delaminated areas, peal them apart, let it dry, sand and apply glass and filler as needed. I can't believe it, but the boat still floats. This of course only works on thin sheets of 1/4" where there are only 3 layers. It is amazing how far you can go with this technique. I use epoxy and glass, not polyester as that would be subject to peel.
Reply tosender|Reply togroup|Replyvia web post|Start a New Topic
>Lead flashing is a standard building supply. It is used to flash shingles and other roofing material to masonry. The typical use is flashing around a brick chimney. The lead sheets are embedded in the mortar joints in the brick, and folded down over the counter flashing (aluminum or whatever that is interwoven with the shingles). The lifespan of the lead is more or less the same as the masonry, and its softness allows the roofers to pry it up, reshingle and flash, and bend down the lead again.
> I recently built a Storm 17 (English kit from Swallow Boats) and the
> instructions called for filling a void in the centerboard with lead
> flashings. I couldn't find any so I made a mixture of birdshot and epoxy to
> fill the void. It worked fine except for a couple of loose shot which
> sometimes rattle. As I recall, Old Shoe has quite a lot of lead and that
> much bird shot might be prohibitively expensive.
If not available from a general building material supplier, my next place to look would be a supplier that specializes in masonry, as the mason is the tradesman that usually installs it.
Lead flashing does not need hardness, and requires long term flexibility, so it probably has little or no antimony mixed in, and is very malleable, which is what you want if you are hammering sheets into a hole in a centerboard, then fairing and epoxying in place.
I was once at an archaeological dig at he site of an 18th century home. They dug up a bit of weathered sheet lead, and had no idea what it was. I explained what it was, and that it would be very hard to date, as the technology hadn't changed significantly since white man first came to the Americas.
Find the place that sell bricks, and they will have lead flashing, or they will know where to get it.
Allan
In the hills.
--- Inbolger@yahoogroups.com, "etap28" <dave.irland@...> wrote:
> lead drilling: yes, knocking the edge off the bit will work on lead. But, by far the easiest way to drill lead in my experience is a forstner bit. I had to prep a giant chunk of lead (47 foot boat) for keel bolts, including large side access holes for the bottom nuts, and after a learning curve (nobody knew nothin') discovered that a forstner bit pretty much works in lead the same as it works in wood, only slower. No clogging, minimal jamming (use WD40 liberally), doesn't even hurt the bit. Not much use for the tinier holes (I don't think forstners come in less than maybe 1/4"?)
> --- Inbolger@yahoogroups.com, Douglas Pollard <dougpol1@> wrote:
> > I agree with Joe. Dou't use screws ,use ring nails. I am a machinist so
> > have drilled a lot of holes. The problem is not that the lead is hard,
> > but that it is that it is soft. It is so soft that the twist in the
> > drill shape causes it to suck in bind up and break. Lead and copper
> > both soft have the same problem where drilling is concerned. Steel is
> > many times harder than any kind of lead. In it is fairly easy to drill.
> > IF there is any other way you just do not drill lead. It can be drilled
> > but you have to resharpen the drill point in a certain kind of way. It's
> > called dubbing the drill point but you have to know what you are doing.
> > I suggest not drilling lead. Doug
> > On 04/15/2011 04:01 AM, Joe T wrote:
> > > What's with drilling holes? On my Oldshoe keel I just hammered in
> > > bronze ring shank nails wherever needed. No drilling, no problem.
> > > Don't make it more complicated. However, my lead was probably softer -
> > > slabs that were likely salvaged from and x-ray booth.
> > > Joe T
> > > --- Inbolger@yahoogroups.com<mailto:bolger%40yahoogroups.com>,
> > > appreciated.
> Inside the fir planking and the end decks of my Windsprint are
> checked pretty badly. Replacing the decks is a small job. Replacing
> the planks means might as well through it all away, of course.
> I've read that warmed up 3m 5200 trowlled on could help. That's
> pretty expensive, and perhaps a hideously gooey messy job, but a
> cheaper polyurethane like PL would be worth a try if any came in
> pails rather than the tubes.
> Are the grain fillers used in new work up to this job? One doubts it,
> but would love to be wrong.
> It's too far gone for a thick, expensive glass job now. A light
> fabric stuck down with paint won't hide these cracks.
> So, what's a boy to do?
> Mark
Ste
--- Inbolger@yahoogroups.com, "Stefano" <gordas@...> wrote:
> I'm going to build an Old Shoe myself
Dennis
Bellingham, WA
--- Inbolger@yahoogroups.com, "Gene T." <goldranger02-boats@...> wrote:
> Stefano,
> You might want to think twice about turning the boat back over with
> that 200 pound keel on it. It might right itself to quickly or it
> might stress the structure. Also, smaller spheres is not the way to
> get a denser mix, you need to mix sizes so the small ones fill in the
> gaps between the larger ones. I'm sure there is an optimum formula
> but it's nothing you could follow in practice, just try for some
> improvement in density by mixing sizes.
> Sincerely,
> Gene T.
> On 15 Apr, 2011, at 4:10 PM, Stefano wrote:
> > I'm going to build an Old Shoe myself and have been wondering how to
> > make the keel lead casting. This is what I came up with stealing it
> > from other designs. Using small lead spheres from hunting guns, or
> > fishing weights, layering them in liquid resin (epoxy or other)
> > directly in place: boat upside-down and cast slot framed fore-and-
> > aft and with keel cheeks in place. All screws or nails would be
> > already in place through plywood cheeks. The smallest the spheres,
> > the closest the real weight to the designed one. (The cast slot
> > could be extended fore and aft to get the same weight keeping the
> > same COG).
> > Do you think that would do?
> > Ste
> > Joe T
> > appreciated.
Sent:Sat, April 16, 2011 3:19:22 AM
Subject:[bolger] Re: More Micro keel questions
Lead fumes are a deadly serious hazard. Minimum precaution would be to work outside and stay upwind at all times. Skin contact should also be avoided. If you handle it wash thoroughly before touching anything that goes in your mouth.
I poured mine flat in a wood mold using a metal can similar to Rick Bedard's setup. Be sure it is well supported and level.
Joe T
> The last time I melted lead I set 3 bricks on edge to form a fire box
> leaving the front open I dump charcoal in it and got it going. After the
> charcoal was burning well I set an old Cast iron pot on the bricks and
> put automotive wheel weights. As the lead melted I drug out the metal
> clips that were in the weights out and ladled up the lead and poured it
> into the mould. When I finished I took my dremel grinder and printed
> lead on the side and in the bottom using a little grinding wheel. Just
> so no one would ever use it to cook in. It is a very simple thing to do
> and it doesn't take a lot of heat to do it. I think about 450 deg.
> ?? Doug
Joe T
> ?? Doug
> I'm going to build an Old Shoe myself and have been wondering how to make the keel lead casting. This is what I came up with stealing it from other designs. Using small lead spheres from hunting guns, or fishing weights, layering them in liquid resin (epoxy or other) directly in place: boat upside-down and cast slot framed fore-and-aft and with keel cheeks in place. All screws or nails would be already in place through plywood cheeks. The smallest the spheres, the closest the real weight to the designed one. (The cast slot could be extended fore and aft to get the same weight keeping the same COG).
> Ste
I've read kerosene or antifreeze works just as well if that's what you have on hand. You only need a small amount... amazing what a little lubrication will do.
Some lead has a few percent of antimony added to it to make it harder, and you can tell the difference but you can still drill it...
Rick
Sent:Fri, April 15, 2011 7:38:25 PM
I couldn't get bronze boat nails in Chile, and broke more bits than I care think of on the first 20 holes for Oldshoes keel.
My final solution was hammering standard 1 1/4" stainless steel screws into the lead straight through the plywood side panel. It worked a treat and was fast.
I believe the problem is less about the lead being hard and more about it binding to the drill bit.
Perhaps dead slow drill speed is the solution if you are going the hard way.
<*> Your email settings:
(Yahoo! ID required)
bolger-digest@yahoogroups.com
Rick
Sent:Fri, April 15, 2011 5:35:03 PM
Subject:Re: [bolger] Re: More Micro keel questions
?? Doug
On 04/15/2011 06:45 PM, BruceHallman wrote:
>> ... cubic close packing (or face centredcubic) — ABCABC… alternance — and hexagonal close packing — ABAB… alternance. But all combinations are possible (ABAC, ABCBA, ABCBAC, etc.). In all of these arrangements each sphere is surrounded by 12 other spheres, and both arrangements have an average density = (almost) .74048.
>>ymailto="mailto:bolger-unsubscribe@yahoogroups.com" href="mailto:bolger-unsubscribe@yahoogroups.com">bolger-unsubscribe@yahoogroups.com
>> (snipped)
> 0.74 versus a density of 1.0 with melted lead.
> Melting lead is pretty easy, try it and see.
> - Unsubscribe:
> - Open discussion:bolger_coffee_lounge-subscribe@yahoogroups.comYahoo! Groups Links------------------------------------
?? Doug
>> ... cubic close packing (or face centred cubic) — ABCABC… alternance — and hexagonal close packing — ABAB… alternance. But all combinations are possible (ABAC, ABCBA, ABCBAC, etc.). In all of these arrangements each sphere is surrounded by 12 other spheres, and both arrangements have an average density = (almost) .74048.
>> (snipped)
I recently built a Storm 17 (English kit from Swallow Boats) and the instructions called for filling a void in the centerboard with lead flashings. I couldn’t find any so I made a mixture of birdshot and epoxy to fill the void. It worked fine except for a couple of loose shot which sometimes rattle… As I recall, Old Shoe has quite a lot of lead and that much bird shot might be prohibitively expensive.
JohnT
bolger@yahoogroups.com ]On Behalf OfDouglas Pollard
Sent:Friday, April 15, 2011 6:44
PM
Your
epoxy will keep the pellets from pushing outward as they would if just dumped
in the keel without the epoxy. Don't forget when you calculate the length
of the keel to compensate for the lead not being solid you have to deduct the
amount of water the keel is displacing at 8 lbs to the gallon of water. Should
work fine. Just put in a little epoxy at a time as it will overheat and
may catch on fire. Go very slow with that and watch the heat build up.
Doug
Ste
>... cubic close packing (or face centred cubic) — ABCABC… alternance — and hexagonal close packing — ABAB… alternance. But all combinations are possible (ABAC, ABCBA, ABCBAC, etc.). In all of these arrangements each sphere is surrounded by 12 other spheres, and both arrangements have an average density = (almost) .74048.0.74 versus a density of 1.0 with melted lead.
> (snipped)
On 04/15/2011 04:10 PM, Stefano wrote:I'm going to build an Old Shoe myself and have been wondering how to make the keel lead casting. This is what I came up with stealing it from other designs. Using small lead spheres from hunting guns, or fishing weights, layering them in liquid resin (epoxy or other) directly in place: boat upside-down and cast slot framed fore-and-aft and with keel cheeks in place. All screws or nails would be already in place through plywood cheeks. The smallest the spheres, the closest the real weight to the designed one. (The cast slot could be extended fore and aft to get the same weight keeping the same COG).
Ste
From:bolger@yahoogroups.com [mailto:bolger@yahoogroups.com]On Behalf OfStefano
Sent:Friday, April 15, 2011 4:10 PM
do?
Ste
Ste
Ste
The bronze ring shanks went right in for me too. If your lead alloy is too hard for that you might try the steel ringshanks, sold as colored finishing nails. When I put in my keel I needed to nail it up tight before the epoxy went off.
MylesJ
>I used galvanized stubby hanger nails. The Simpson N8 nails are much
> What's with drilling holes? On my Oldshoe keel I just hammered in bronze ring shank nails wherever needed. No drilling, no problem. Don't make it more complicated. However, my lead was probably softer - slabs that were likely salvaged from and x-ray booth.
> Joe T
tougher than bronze. (I bet you could drive them into concrete!)
http://www.amazon.com/gp/product/B000WI67SY
Dennis
Bellingham, WA
> > Joe T
> > appreciated.
On 04/15/2011 04:01 AM, Joe T wrote:What's with drilling holes? On my Oldshoe keel I just hammered in bronze ring shank nails wherever needed. No drilling, no problem. Don't make it more complicated. However, my lead was probably softer - slabs that were likely salvaged from and x-ray booth.
Joe T
Sent:Fri, April 15, 2011 12:29:12 AM
Subject:[bolger] More Micro keel questions
Joe T
