Re: Newbie question
Why not just painted Okoume? You'll sve yourself a boatload of money, weight, time and sanding if you abstain from epoxy coating your GLD - with no unpleasant consequences.
Meranti is going to be heavier and stiffer, in any case, though reportedly more rot resistant in the long term.
Good luck!
--- Inbolger@yahoogroups.com, "robert.maselek" <robert.maselek@...> wrote:
> I'm about to build a Bolger Light Dory. I would like it light . Should I use Occume plywood with epoxy coating or Meranti just painted? THANKS Bob
Occume plus an epoxy coating will be lighter than uncoated meranti. You can also save weight by using cedar for chines and frames, as well as leaving the bow and stern thwarts out.
JohnT
From:bolger@yahoogroups.com [mailto: bolger@yahoogroups.com ]On Behalf Ofrobert.maselek
Sent:Thursday, April 21, 2011 6:33 PM
Subject:[bolger] Newbie question
