Re: lexan likings
Mike:
I used clear on my boat (and will again with it's newer, higher
cabin) for night vision and better views on cloudy days. If you put a
window in the cabin top, I'd consider tinted because it's amazing how
much more heat from the sun comes in from a top rather than a side
window. I like the top windows so I can check the set of the sails
when I'm below and the boat is on autopilot (please note, MJ
stability questioners, that my boat is not an MJ and has a deep
keel). You can always make covers to cut down some or all of the
light, but you can't peel off the tinting....
Gary Blankenship,
who's deconstructed his boat cabin and nearly rebuilt it this week....
--- Inbolger@egroups.com, "Mike Stockstill" <mkstocks@b...> wrote:
> Hi -
> I am starting to research lexan for the Martha Jane revision.
> Clear
> Bronze
> Light Gray
> Gray
> I have not made up my mind yet. What colors have you folks used in
> yhour projects? Clear would seem to be the safest bet for night
> vision I suppose.
> THanks.
> Mi
Hi -
Clear
Bronze
Light Gray
Gray
vision I suppose.
THanks.
Mi
