Re: [bolger] Re: wyoming as deep v
Decisions, decisions...
Just flip one of your gold coins, Nels.
On Tue, Jun 14, 2011 at 2:09 PM, prairiedog2332 <arvent@...> wrote:
winds, it is better to plan the trip north to south. (We barged our
sailboat to Ketchikan and sailed to Seattle, once inside and once
outside.)
>I have done that, twice, and in my opinion considering prevailing
> Depending on the size of my lottery winnings including a planned trip
> from Vancouver to Alaska:
outside.)
Delaware Trawler?
http://groups.yahoo.com/group/BolgerCartoons/files/Delaware%20Trawler/
Sitka Explorer?
http://groups.yahoo.com/group/BolgerCartoons/files/Sitka%20Explorer/
The DT looks to be a nice tidy layout. The SE with the diesel option
would also mean a diesel heater which would be a nice item. Actually
enjoy the smell too:-)
Surprisingly similar in displacement with SE only 500 or so lb more.
Delaware Trawler?
Sitka Explorer?
--- Inbolger@yahoogroups.com, "Peter" <pvanderwaart@...> wrote:
> > intrigued with the idea of Phil's Wyoming as a deep v....comments?
> PCB did some deep-V boats, but it wasn't a favorite of his. If you
chase around in his books, somewhere you will find comments to the
effect that a deep-V has less stability and requires more power. He felt
the only virtue was smooth, high-speed running in rough water. He didn't
like big engines much.
> Going one step more complicated than the sharpie, PCB designed the
Samuel Clyde. It's a smoother-running, higher-speed boat, but still very
light and shallow.
> intrigued with the idea of Phil's Wyoming as a deep v....comments?PCB did some deep-V boats, but it wasn't a favorite of his. If you chase around in his books, somewhere you will find comments to the effect that a deep-V has less stability and requires more power. He felt the only virtue was smooth, high-speed running in rough water. He didn't like big engines much.
Going one step more complicated than the sharpie, PCB designed the Samuel Clyde. It's a smoother-running, higher-speed boat, but still very light and shallow.
On Tue, Jun 14, 2011 at 9:03 AM, Jeffery Measamer <measamerj@...> wrote:
(IMO) Wyoming is fundamentally a dirt cheap river cruiser intended to
go together quick, and be economical. A scaled up Tennessee.
>And at least an order of magnitude greater cost.
> I may be way offbase but when I first saw the FPB64 the Wyoming was what I thought of.http://dashewoffshore.com/FPB64outcome.asp
> Yes, it weighs an oder of magnitude more than a Wyoming
I may be way offbase but when I first saw the FPB64 the Wyoming was what I thought of. http://dashewoffshore.com/FPB64outcome.asp Yes, it weighs an oder of magnitude more than a Wyoming but with the long lean hull and low topsides it brought Wyoming to mind for me. Jeff --- OnTue, 6/14/11, BruceHallman<hallman@...>wrote:
It wouldn't be a Wyoming if it had a deep V bottom.
The key thing with 51 foot Wyoming is its shallow/light weight
displacement, essentially it is on plane when it is sitting still,
hence the efficiency.
If a 51 foot hull had a deep v bottom it would have tremendous
displacement, and be a vastly more heavy boat.
On Tue, Jun 14, 2011 at 3:08 AM, fluffylamb <fluffylamb@...> wrote:
> intrigued with the idea of phils Wyoming as a deep v....comments?
