Re: Pointy Skiff on life support
--- Inbolger@yahoogroups.com, Doug <dougpol1@...> wrote:
> come, on David, I have roted a boat or two by laying them upside down
> in the grass. I bet you have too. Fess Up!
> R There was a skiff laying around the marine up side down rotting.
> I didn't use lywood but I had some pine sideing boards and f sawed the
> toung off one side and put around the top of the skiff that has been a
> lot of years ago a long time tenant there recently told me she was still
> around. So it works.
> Doug
> On 09/19/2011 02:56 PM, dnjost wrote:
> > The deal is sealed. I found a couple bags of copper clench nails in
> > the cabinet downstairs. If it comes out poorly, I will just through
> > some dirt in it and plant tomatos.
> > David
> > --- Inbolger@yahoogroups.com<mailto:bolger%40yahoogroups.com>,
> > "dnjost" <davidjost@> wrote:
> > > hey group.
> > > I built my Pointy Skiff over 25 years ago from lumber store materials.
> > > Luan sides, AC bottom, fir strapping for the rails, fir stem, etc...
> > > the rot at the top edge all around appears to be past repair. It is
> > to the point that I won't got out in it.
> > > I have an idea to prolong the life of the skiff.
> > > Strike a line app. 6" down and cut all the rotted wood out. Then cut
> > a piece of plywood 2" bigger and attach it ala a lapstrake technique.
> > Has anyone tried this?
> > > Although this might be a good excuse just to build a June Bug.
> > > David jost
--- Inbolger@yahoogroups.com, "dnjost" <davidjost@...> wrote:
> hey group.
> the rot at the top edge all around appears to be past repair. It is to the point that I won't got out in it.
> Strike a line app. 6" down and cut all the rotted wood out. Then cut a piece of plywood 2" bigger and attach it ala a lapstrake technique. Has anyone tried this?
> David jost
>I think it would probably end up lookingbetter than before David!
> The deal is sealed. I found a couple bags of copper clench nails in the cabinet downstairs. If it comes out poorly, I will just through some dirt in it and plant tomatos.
> David
R There was a skiff laying around the marine up side down rotting. I didn't use lywood but I had some pine sideing boards and f sawed the toung off one side and put around the top of the skiff that has been a lot of years ago a long time tenant there recently told me she was still around. So it works.
Doug
On 09/19/2011 02:56 PM, dnjost wrote:The deal is sealed. I found a couple bags of copper clench nails in the cabinet downstairs. If it comes out poorly, I will just through some dirt in it and plant tomatos.
--- Inbolger@yahoogroups.com, "dnjost"<davidjost@...>wrote:
> hey group.
> David jost
> hey group.
> David jost
Then I'd either make a paper pattern of what I cut off to create the strake to install.
Sounds solid to me.
Don
Your repair proposal sounds good.
Reed
> Luan sides, AC bottom, firstrapping for the rails, fir stem, etc...
> the rot at the top edge allaround appears to be past repair. It is to the point that I won't got out in it.
>skiff.
>David jost
>NO "GO AWAY SPAMMER!" posts!!! Please!
> - no cursing, flaming,trolling, spamming, respamming, or flogging dead horses
> - stay on topic,stay on thread, punctuate, no 'Ed, thanks, Fred' posts
> - Pls add yourcomments at the TOP, SIGN your posts, and snip away
> - Plans: Mr. PhilipC. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax: (978) 282-1349
> -Unsubscribe: bolger-unsubscribe@yahoogroups.com
>on the web, go to:
> <*> To visit your group
>href="http://groups.yahoo.com/group/bolger/">http://groups.yahoo.com/group/bolger/
> <*> Your emailsettings:
> Individual Email | Traditionalhttp://groups.yahoo.com/group/bolger/join
> <*> To change settings online go to:
> (Yahoo! ID required)
><*> To change settings via email:
>href="mailto:bolger-digest@yahoogroups.com">bolger-digest@yahoogroups.com
>href="mailto:bolger-fullfeatured@yahoogroups.com">bolger-fullfeatured@yahoogroups.com
> <*> To unsubscribe from this group, send an emailto:
>href="mailto:bolger-unsubscribe@yahoogroups.com">bolger-unsubscribe@yahoogroups.com
> <*> Your use of Yahoo! Groups is subjectto:
>href="http://docs.yahoo.com/info/terms/">http://docs.yahoo.com/info/terms/
Its cheap , relatively easy and quick , and I don`t think it would hurt the looks either.Strike the line with a bendy batten , and get a nice taper on it.
On Sep 18, 2011, at 12:07 PM, dnjost wrote:hey group.
David jost
>I have done similar, and I found it acceptable to just scab on
replacement plywood 'lapstrake' over top of rotted wood. It looks
kind of makeshift, but it holds water.
Sent:Sunday, September 18, 2011 11:07 AM
Subject:[bolger] Pointy Skiff on life support
David jost
David jost
