[bolger] Re: Paint & Windsprint
HenryClann@...wrote:
> Looking more and more at AF3. It's a fairly simple looking boat & rig. I
> wonder if anyone has rigged one as a Cat Yawl I think that would be quite
> nice using maybe a balance Lug on front & a sprit on the back? That would
> look "kewl"? & old timey. I am too much of a wussey to takle a Chebacco at
> this time....
> Larry
I like the AF3, mine is pretty much just a bigger version.
I don't know if anyone has rigged one as a Cat Yawl, I would think that
it would tend to take away the simplicity of the boat. Plus, at 15ft,
adding another sail to tend...
I have to admit though, I like the idea of the mizzen holding the boat
into the wind while you mess with the main... And I guess the Micro is a
cat yawl at around the same length.
BTW, the AF2 is going together very nice and quick. I picked it because
it was the most boat I could get for the time and money invested. The
same applies to the AF3, and if I didn't have a hankering to build the
prototype, and didn't need to carry more than a couple of passengers, I
would have seriously considered the AF3.
Richard
Spelling|richard@...|http://www.spellingbusiness.com
SBE Communications, Business Solutions for the next Millennium and
Beyond!
Boat building projects:http://www.sbecommunications.com/boats/index.htm
In a message dated 11/4/99 8:23:26 AM Central Standard Time,
richard@...writes:
<< Got any pictures? After i get Pointy Skiff built, i plan on building one of
> Michalak's "cuddy" boats, like AF3, or Cubit, or Pencilbox, I'd love to
see a
> pic of AF2 as i can't find any on Jim's website.
> Larry Henry >>
this time....
Larry
<A HREF="http://hometown.aol.com/henryclann/Boats/amatureboats.index.htm">The
Careenage & Blue Lagoon, A page for Home Built Boats & Owners!</A>
Remember; the Titanic was built by the professionals, but Noah's Ark by
amatuers!
I have pictures, thier being developed as we speak. Had a whole role of
construction photos but they are hiding. When they turn up I'll put them online as
well.
> In a message dated 11/3/99 8:26:14 PM Central Standard Time,
>richard@...writes:
> << Just finished priming and paiting the bottom of my 20ft Michalak AF2
> prior to flipping it. >>
> Michalak's "cuddy" boats, like AF3, or Cubit, or Pencilbox, I'd love to see a
> Larry Henry
> Palm Bay, Florida
> amatuers!
> -- eGroup Home:http://www.egroups.com/group/bolger/?m=1
> -- Free email groups at eGroups.com
How I painted my Windsprint:
I followed the advice of Dave Carnell. I used latex primer, one coat. I used
latex high gloss, two coats.
I plan to touch up my boat each winter.
MM
richard@...writes:
Larry Henry
Palm Bay, Florida
amatuers!
<snip>
> prior to flipping it. Four coats of primer and two of porch paint.
Behr
> exterior oil based primer, about a gallon and a half for the bottom
> most of the sides. ~$20 a gallon. Two coats of Behr interior/exterior
> porch paint, just on the bottom. About 1/2 gallon, ~$20 a gallon.
I've had the same problem. Porch paint don't stick to epoxy. Mine came
up in huge sheets.
Bin alachol primer does stick. Use a cheap brush, it dries very fast
and ruins good brushes, but dries very thin no matter how globed on.
Porch paint over that sticks just fine.
In a message dated 99-11-03 21:01:47 EST, you write:
<< Sanding. After trying everything, I've decided the experts are right. The
only way to get a good fair surface without raising the grain is to do it
by hand. Start with a coarse grit (40-50) and work up to about 120. It is
hard work, but strangely satisfying. I spent a lot of time pushing a
sanding block over the last few days and I'm better person for it. (I use
the time spent sanding for meditation and prayer). It builds the old
shoulder muscles, too. Unfortunately, I sanded the boat with a RO before
glassing, and there is some grain pattern showing through. Live and
learn... The next boat will be (nearly) entirely hand sanded.
John,
I have heard it said that once you hit the grit of sandpaper specified
by the paint manufacturer, you don't get any additional smoother finish by
sanding with finer paper. The argument put to me is something like, if it
fills the scratches made by 80 grit, that is the end point. Any other finer
marks will still have their scratches filled. I used Kilz over 80 grit
sanded ply finished with Latex and found no sanding or grain marks. Since
you have gone the 120 route, I would like to hear of your experience and an
observation on whether you think this theory is right. Regards, Warren
Robert N. Lundy wrote:
> Well, I got around to shaping my bottom up to the chine last night. The
> router/trimming bit worked great, but, as noted by other Windsprint
> builders, the angle of the chine leaves just a litle bit. Oh, and I wore
> out another of my harbor frieght router bits (after a trip around the boat
> the little bearing on the end siezed up. Of course I had to touch it,
> buringing my fingers).
I burned up the one I got from Home Depot on the boat I'm building. Same
symtoms, same results, even the finger burning...
I went ahead and finished the cutout, putting oil on the siezed bearing.
Then it came off, and I was riding on the little flange... Finished ok,
but had some cleanup to do.
> For the final shaping I started with my randon orbit sander. Thats a no go,
> too slow. Then the belt sander got a try; better, but still slow. The
> edgegrain of the 1/2" pine ply is tough! Soo.... 4 words: Angle Grinder, 36
> Grit. This was the rig I was ONLY going to use on really ugly blobs of
> epoxy. I was so scared of it I practiced on scrap for 10 minutes. It
> worked great though, got one side all faired and the stem and stern done.
For final shapping I use a Black and Decker power plane, then get the
final bit with the belt sander.
> Its not to soon to start thinking about paint. I've had good luck with high
> gloss exterior trim paint, as it can be bought with an anti-mildew additive.
> I'm open to ideas. The exterior will be a forest green, the interior white
> (already hae some high gloss white leftover). Mast and gunwales, varnish or
> cetol (don't know how cetol will look on fir)
> Paint stories (and costs if you don't mind)
prior to flipping it. Four coats of primer and two of porch paint. Behr
exterior oil based primer, about a gallon and a half for the bottom and
TIP: fair and smooth the bottom BEFORE you paint. I had mine pretty
smooth, and decided to longboard the primer (limestone/epoxy bottom
coating is HARD) to get the rest of the fairing done. Only parialy
successful.
Also, I roled the primer and paint on... looks like, well, as if it was
put on with a roler.... certainly not a glass smooth finish, even
sanding between coats.
The paint seems to be sticking fine. Have had trouble with porch paint
in the past going directly on epoxy. It would peel off in strips when I
scratched the canoe up.
The primer did dry faster on the bare wood surfaces than on the epoxy
ones. Electric heater under the boat speeds up the drying pretty good...
Oil based primer... one word. VENTILATION!!!
Richard
Beyond!
I used a block plane and finished up with a belt sander. But I only had
1/4" plywood to go through. It really was a fun job. Really.
I jsut finihed painting my dory this weekend. I primed the exterior with
Interlux high build primer leftover from my Windsprint and the interior
with Kilz II.
As for paint, I used Rustoleum polyurathane, applied with a nifty little 4"
wide, by 1" diameter foam roller. After rolling on the paint, I tpped it
off foam brushes. It looks ok. It might not be as nice or as tough as the
Interlux Brightsides I put on the Windsprint. At ~$6/quart compared to
$22/quart for the Interlux, it is good enough. for me.
Best,
JB
John Bell
Kennesaw, Georgia, USA
jmbell@...
J.B.'s Boatyard
http://jmbell.home.mindspring.com/boatyard.htm
Robert & Amy Lundy
St. Petersburg, Fla.
