Re: Clear Coating alternatives
Eric
--- Inbolger@yahoogroups.com, Douglas Pollard <dougpol1@...> wrote:
> Holly cow Mason, I thought I was about the only person in the world that
> used Tung oil any more. I like the looks off the finish above all
> other. Doug
> On 03/01/2012 09:27 AM, Mason Smith wrote:
> > I would vote against epoxy. Whatever you do, let moisture come and go
> > with ambient conditions. Varnish will allow this. But if you want less
> > maintenance, oil might be better. I don't know spotted gum and will
> > not pretend to say what oil. I have been using tung oil of late, both
> > pure and thinned. I have long used and liked Deks Olje. Have not used,
> > and don't really like (what I've seen of it, on Drascombes) Cetol.
> > ---Mason
Ford Walton
Sent: Mon, 05 Mar 2012 17:53:55 -0500 (EST)
Subject: Re: [bolger] Re: Clear Coating alternatives
Deks Olje disappeared for a while when the parent company got bought up by
someone not interested in making it. <shrug> But an outfit in Florida got
ahold of the rights to it, and Deks Olje is again being made:
http://www.deksolje.com/
On Fri, 02 Mar 2012 16:09:53 -0800, John T wrote:
> I used Deks Olje with great success about 20 years ago, but I can't seem
> to
> find it now. Anyone know a source?
John (jkohnen@...)
A paranoid is a man who knows a little of what's going on.
(William Burroughs)
John
John Kohnen
Sent: Monday, March 05, 2012 5:54 PM
> to
John (jkohnen@...)
(William Burroughs)
horses
(978) 282-1349
Groups Links
> to
John (jkohnen@...)
(William Burroughs)
Sent:Monday, March 5, 2012 6:47 AM
Subject:Re: [bolger] Re: Clear Coating alternatives
I likely have enough left to last my lifetime so I guess I will continue to use it. With the hazmat laws being what they are, it may be too expensive now days? Doug
On 03/05/2012 09:27 AM, mkriley48 wrote:
yes
--- Inbolger@yahoogroups.com, "Andrew"<a.c.l.yen@...>wrote:
> I have a can of Penetrol (made by Flood) but it doesn't mention anything about it being a treatment in it's own right. The can talks about mixing it with oil based paint to make it stick to anything, or about painting it on rusty steel to make paint stick. Is this the same stuff?
> Andrew
> --- Inbolger@yahoogroups.com, Douglas Pollard <dougpol1@> wrote:
> > Penitrol is good stuff. <snip>
On 03/05/2012 09:27 AM, mkriley48 wrote:yes
> Andrew
> Andrew
> Andrew
Andrew
On 03/03/2012 11:37 AM, Mason Smith wrote:I have used shellac instead of epoxy for clear coating. Shellac is less porous than epoxy. A couple of coats seals the wood well. Then a few coats of varnish over top gives it the UV protection it and epoxy require. So the wood is well protected and the Shellac is easy to remove when the time comes. I have all the yellow pine bright work on my Elver canoe yawl fished with this process and though yellow pine is hard to keep varnish on this combination holds up well and is easy to redo. On this pine I use orange shellac and it really brings out the beauty of the pine. Clear is best for teak and Mahogany. Doug
More on clear coatings, since Penetrol’s been mentioned. I have heard that it is one of the ingredients of Deks Olje – for what that’s worth, not much. I have friends who never liked Deks Olje (and I never liked that you could not find out what was in it) and preferred other marine penetrating finishes, which indeed seem to work fine, too. I have use the one-two punch of Deks I and II. It’s been especially good on a very old and still very hard-used Rushton Florida model Pleasure Rowboat. Minimum maintenance and easy maintenance, and awfully good for the wood.
If anybody still wants a recommendation on clear coating with epoxy, I am sure there are other great products but I did, while I used it, admire System Three’s Clear Coat, all solids but penetrating and as brushable as varnish. And I’ll second the recommendation of Captain’s Varnish for general use. Epifanes on great antique boats and showboats. Also Interlux Schooner and its variants, which we’ve been using on the brightwork of the Sound Inter Club restorations (watch for the WB article). Over epoxy, if you must, use the best filter package you can get, i.e. Flagship over Captain’s. and still, revarnish early and often or rue the day.
Will always take function over useless beauty when it means work for me. Also, remember that "Beauty is in the eye of the beholder"; whether it be boats or women or art we all don't have to think alike LOL!
Bob
--- Inbolger@yahoogroups.com, "Eric" <eric14850@...> wrote:
> How do you apply and maintain Deks Olie? I have clear toe rails on risers that can also be used to tie off to, plus they get foot wear when people use them for their intended purpose. I've also tried Cetol and not been satisfied with it. Penetrol may be the answer as some have suggested. I hadn't thought of using Tongue Oil because I didn't think it withstood wet. Anyway, I'm interested in ideas about what to use where there is wear and tear. Epoxi and hard varnish are not a good idea, though a willingness to carry and apply varnish immediately to damaged areas will get you past the problem. I'm just not that conscientious.
> As for epoxi under varnish, It works very well when maintained. ROGUE's transom is cherry finished bright with one or two ounce fiberglass laid in epoxy of I forget how many layers. At least five layers of captains varnish over that, sanded lightly and recoated each year. Damage is attended to immediately. I am willing to do this amount of maintenance (minimal).
> I concur that unless epoxy under varnish is well maintained it is a disaster. That is why I did not finish rub rails, spars, or toe rails with epoxy under varnish.
> Eric
> > do, let moisture come and go with
> > this. But if you want less maintenance,
> > spotted gum and will not pretend to say
> > late, both pure and thinned. I have long
> > it, on Drascombes) Cetol. ---Mason
I used Deks Olje with great success about 20 years ago, but I can’t seem to find it now. Anyone know a source?
JohnT
bolger@yahoogroups.com ]On Behalf OfEric
Sent:Friday, March 02, 2012 6:58
PM
Subject:[bolger] Re: Clear
varnish.
Eric
Eric
Sent:Friday, March 2, 2012 12:09 PM
Also It was a good buisness to go down to Florida and buy a couple stingray boats, bring them back to Virginia Have the engines rebult and reinstall and replace the cockpit upholster. We could buy them in pretty nice shape with the upholstery burnt up by sunlight and the engines worn out for about $2,000 after redoing we could usually sell for $20,000. Many of the engines only needed a top end job, rings and valve job with maybe a riser replacement. We would net about $30,000 and with some canvas work on sailboats we would wind up with about $60,00 a year and living on a boat that was a lot of money back then. Doug
On 03/02/2012 02:36 PM, mkriley48 wrote:
I have tried everything in the years I was a professional boater.
Captians varnish comes out on top in terms of the least work.
lasts, touches up well. Varnish lasts best if wiped down with a rag once in a while. For a non varnish substitute oil based PENITROL
is very good and cheap. The trick to varnish is to put it on full strength.
mike
> other. Doug
> > ---Mason
On 03/02/2012 02:36 PM, mkriley48 wrote:I have tried everything in the years I was a professional boater.
mike
> other. Doug
> > ---Mason
mike
> other. Doug
> > ---Mason
Mason here again, to advise against coating with epoxy and then varnish. I have done this quite a lot, on my Goodboats and on spars, because epoxy makes such a great sealant under varnish. But I have sometimes regretted it, and do it no more, because if you do not revarnish soon enough and often enough, you will be sorry you ever epoxied under the varnish. You will have to take that sun-damaged epoxy off and start over. Better varnish and let the wood breathe through the film. Or oil.
has to be done completely on all sides. So if screwing a rub or spray
rail in place, the inside has to be attached with thickened epoxy and
even the screw holes should be pre-drilled and filled. Then only the
outer area varnished to protect agains UV damage.
This was written up by Jagels in an older WB article.
--- Inbolger@yahoogroups.com, John Weiss <jrweiss98020@...> wrote:
> I'll second the Epoxy + Varnish idea.
I did that on the cherry rails of my Adirondack Guideboat, and they look
wonderful! The epoxy (System 3) provides a great base for the varnish
(Z-Spar Captain), so the varnish will not flake off as easily. If you
want a low-gloss finish, put a coat or 2 of satin varnish over the gloss
varnish. I did that on my floorboards, and they're holding up nicely.
On 3/1/2012 6:48 AM, sirdarnell wrote:
> Apply two coats of epoxy and then cover in varnish as per directions to
> protect the epoxy from sun.
> > I always said I wouldn't have any timber finished bright - to save
> work. But the rubbing strips in spotted gum look too good to paint over.
> So if I do decide to have a fancy looking rubbing strip, what should I
> coat it with? Spar varnish? Linear Poly Urethane (LPU)? Oil of some
> sort? Epoxy and PU?
> > I am concerned that if a bump damages the coating then water entering
> will quickly create an ugly mark and more coating will come off. I am
> also afraid that boat maintenance is not my strong point.
> > What opinions/experience/recommendations is out there on hard wearing
> clear finishes?
I would vote against epoxy. Whatever you do, let moisture come and go with ambient conditions. Varnish will allow this. But if you want less maintenance, oil might be better. I don’t know spotted gum and will not pretend to say what oil. I have been using tung oil of late, both pure and thinned. I have long used and liked Deks Olje. Have not used, and don’t really like (what I’ve seen of it, on Drascombes) Cetol. ---Mason
I expect there is a rubbed-on salad bowl finish in a screw-top can at the woodworking supply store that would work as well. I like to use a finish that I wouldn't be afraid to eat off, out of respect for the marine environment. For the same reason I like to wipe it on with an old rag so there are no brushes, cleaning solvents, or cans to tip over and spill.
I don't use many coats, and I don't achieve the deep finish of bright work on old yachts at Wooden Boat Festivals. It's a working finish, and over time I've come to appreciate the look more than that glossy bright stuff.
If you decide to do some experiments, do them outdoors and don't breath the solvents. Keep in mind all the regional differences--a boat-builder has the option of doing something appropriate to his own climate and how his boat is used and stored. That glossy finish on store-bought boats is a compromise that works equally poorly in Alaska and Florida.
Have fun,
Rick
--- Inbolger@yahoogroups.com, "Bill Kreamer" <kreamers@...> wrote:
> Please, if you remember, can you be a bit more specific on the components of
> the "old oil-urethane mix?" Thanks. - Bill
> _____
> KK7B
> Sent: Thursday, March 01, 2012 12:52 AM
> Subject: [bolger] Re: Clear Coating alternatives
> I agree with Jamie for rub rails (and pretty much everything else he's done
> on that beautiful boat). Something soft, non-glossy and easily touched up
> with no sanding or old finish removal. I have a can of old oil-urethane mix
> that I apply to the rub rails with a rag a couple times a season or as
> needed after a ding. It takes less time to do than write about, and leaves
> the boat with that fresh "someone cares about me" look.
> I embrace the aesthetic of working rub rails--they don't really look right
> to me until they've absorbed an assortment of dings. Soft, easily touched up
> finish is perfect for that.
> Enjoy the boat turning--big day in the life of a boat...
> Best Regards,
> Rick
> --- Inbolger@yahoogroups.com<mailto:bolger%40yahoogroups.com> , "Jamie"
> <jas_orr@> wrote:
> > I used Cetol on all the trim. It is more like an oil finish, although it
> contains pigment - gives a somewhat mahogany-like look. It is not glossy
> like varnish although there is a gloss version (that I haven't used). It is
> softer than varnish but does not get age or lift the same way. It will wear
> off in use but can be easily touched up with no sanding or removal of the
> old finish (again, like an oil).
> > I used the original version that some object to because of the pigment,
> there is now a version with less pigment.
> > Just last year I met a professional boatbuilder that he used Cetol on his
> spars. I was about to refinish so i tried it, but I'm finding that the gaff
> and boom jaws are leaving very visible marks on it so I may go back to
> varnish on the spars. I like the look of varnish on the spruce spars better
> in any case. However I am very satisfied with Cetol on the "brightwork".
> > Jamie
> > --- Inbolger@yahoogroups.com<mailto:bolger%40yahoogroups.com> , "Andrew"
> <a.c.l.yen@> wrote:
> > > My boatbuilding has slowed since Christmas due to lack to time, but I am
> almost at the point of turning the hull of my Chebacco 25 over. Maybe in
> March sometime.
> > > I decided that it would stiffen the sides a bit more if I fitted rubbing
> strakes to the top plank before I turned over. So I have sourced some nice
> strips of "Spotted Gum" from a timber decking supplier. I've ripped them
> down and shaped the profile on my router table. I'll screw them on with 1
> 1/2" bronze screws placed every foot. It should look nice, and spotted gum
> is going to be able to take the knocks.
> > > I always said I wouldn't have any timber finished bright - to save work.
> But the rubbing strips in spotted gum look too good to paint over. So if I
> do decide to have a fancy looking rubbing strip, what should I coat it with?
> Spar varnish? Linear Poly Urethane (LPU)? Oil of some sort? Epoxy and PU?
> will quickly create an ugly mark and more coating will come off. I am also
> clear finishes?
> > > Regards,
> > > Andrew
> > >https://sites.google.com/site/warrandytewoodenboat/
On 03/01/2012 09:48 AM, sirdarnell wrote:I am still using captains varnish. I have tried poly this and that, epoxy laid over with varnish and found them to hard to get off and if scraped they pull the soft wood out of the grain when scraping.. When Living aboard I used to only use tung oil which does not last long but you can wipe over it with a rage with the oil in it and found I never had to remove to refinish as it lasted for ever when wiped over one a week. It's about a half hour once a week on a 36ft boat with a lot of treak. I also found that after about 15 years of living aboard I had more teak left on the boat because during those years I never had to strip the teak down. I also never replaced any teak. Now that I live far from n my boat I can't use that so it's Captains varnish and it mostly because it's easy to remove without doing g damage to the bright wood. DougApply two coats of epoxy and then cover in varnish as per directions to protect the epoxy from sun.
> My boatbuilding has slowed since Christmas due to lack to time, but I am almost at the point of turning the hull of my Chebacco 25 over. Maybe in March sometime.
> I decided that it would stiffen the sides a bit more if I fitted rubbing strakes to the top plank before I turned over. So I have sourced some nice strips of "Spotted Gum" from a timber decking supplier. I've ripped them down and shaped the profile on my router table. I'll screw them on with 1 1/2" bronze screws placed every foot. It should look nice, and spotted gum is going to be able to take the knocks.
> I always said I wouldn't have any timber finished bright - to save work. But the rubbing strips in spotted gum look too good to paint over. So if I do decide to have a fancy looking rubbing strip, what should I coat it with? Spar varnish? Linear Poly Urethane (LPU)? Oil of some sort? Epoxy and PU?
> I am concerned that if a bump damages the coating then water entering will quickly create an ugly mark and more coating will come off. I am also afraid that boat maintenance is not my strong point.
> What opinions/experience/recommendations is out there on hard wearing clear finishes?
> Regards,
> Andrew
> Regards,
> Andrew
From:bolger@yahoogroups.com [mailto:bolger@yahoogroups.com]On Behalf OfKK7B
Sent:Thursday, March 01, 2012 12:52 AM
Subject:[bolger] Re: Clear Coating alternatives
on that beautiful boat). Something soft, non-glossy and easily touched up with
no sanding or old finish removal. I have a can of old oil-urethane mix that I
apply to the rub rails with a rag a couple times a season or as needed after a
ding. It takes less time to do than write about, and leaves the boat with that
rub rails--they don't really look right to me until they've absorbed an
assortment of dings. Soft, easily touched up finish is perfect for
that.
boat...
Best Regards,
Rick
--- Inbolger@yahoogroups.com, "Jamie"
<jas_orr@...> wrote:
>more like an oil finish, although it contains pigment - gives a somewhat mahogany-like look. It is not glossy like varnish although there is a gloss version (that I haven't used). It is softer than varnish but does not get age or lift the same way. It will wear off in use but can be easily touched up with no sanding or removal of the old finish (again, like an oil).
>used the original version that some object to because of the pigment, there is now a version with less pigment.
> I
>professional boatbuilder that he used Cetol on his spars. I was about to refinish so i tried it, but I'm finding that the gaff and boom jaws are leaving very visible marks on it so I may go back to varnish on the spars. I like the look of varnish on the spruce spars better in any case. However I am very satisfied with Cetol on the "brightwork".
>href="mailto:bolger%40yahoogroups.com">bolger@yahoogroups.com, "Andrew" <a.c.l.yen@> wrote:
> Jamie
> --- In
> > What
> >Andrew
> > Regards,
> >href="https://sites.google.com/site/warrandytewoodenboat/">https://sites.google.com/site/warrandytewoodenboat/
I embrace the aesthetic of working rub rails--they don't really look right to me until they've absorbed an assortment of dings. Soft, easily touched up finish is perfect for that.
Best Regards,
Rick
--- Inbolger@yahoogroups.com, "Jamie" <jas_orr@...> wrote:
> I used Cetol on all the trim. It is more like an oil finish, although it contains pigment - gives a somewhat mahogany-like look. It is not glossy like varnish although there is a gloss version (that I haven't used). It is softer than varnish but does not get age or lift the same way. It will wear off in use but can be easily touched up with no sanding or removal of the old finish (again, like an oil).
> I used the original version that some object to because of the pigment, there is now a version with less pigment.
> Just last year I met a professional boatbuilder that he used Cetol on his spars. I was about to refinish so i tried it, but I'm finding that the gaff and boom jaws are leaving very visible marks on it so I may go back to varnish on the spars. I like the look of varnish on the spruce spars better in any case. However I am very satisfied with Cetol on the "brightwork".
> Jamie
> > Regards,
> > Andrew
Jamie
> Regards,
> Andrew
Andrew
