Re: [bolger] Re: AS 29 plans
On 04/23/2012 09:54 PM, Eric wrote:Anyone who wants to pee standing up on my boat is directed to the windward rail where it is hoped wind, waves, and Darwin take care of things.
>A few thoughts:
> Hi, Susanne:
> How do I put this tactfully? I hate the new doghouse over the
> forward head compartment! I realize that the intent is to give
> "standing headroom", but I find "shitting headroom" totally
> adequate. If I forego this, can I carry a larger dink? Perhaps a
> Big Tortoise or a Brick (are they the same design)? If the square
> boats are to wide forward, how bout a nymph or Reuben's?
> Neal
The doghouse might look better in Real Life than it appears on the drawings. Perhaps a model might be helpful.
If you replace the doghouse and use the space for a larger tender, you might be able to keep the doghouse functionality - build the tender with Lexan panels so that when the hatch is open there's light and visibility under the tender while standing up. You'd still want a hatch there for when the tender was in use or for heavy weather.
Offhand, I don't think a standard design brick will fit there, but a custom-fit tender designed along the lines of a Brick would be easy to accomplish.
-Derek
Neal
--- Inbolger@yahoogroups.com, "Eric" <eric14850@...> wrote:
> Anyone who wants to pee standing up on my boat is directed to the windward rail where it is hoped wind, waves, and Darwin take care of things. If not I attempt to get him interested in ferrocement as a boat building material.
> Eric
> --- Inbolger@yahoogroups.com, "sandidgeneal" <nsandidge@> wrote:
> > Hi, Susanne:
> > How do I put this tactfully? I hate the new doghouse over the forward head compartment! I realize that the intent is to give "standing headroom", but I find "shitting headroom" totally adequate. If I forego this, can I carry a larger dink? Perhaps a Big Tortoise or a Brick (are they the same design)? If the square boats are to wide forward, how bout a nymph or Reuben's?
> > Neal
> > > Whoo-hoo! Plans are here. Now I will spend a month studying them to see what changes I want to make. Am considering building out of ferrocement because I have a few sacks of concrete left over from an old patio project. Also, leaning towards outriggers. Or maybe I'll just build it exactly to plans. Really too close to call.
> > > Neal
> > > --- Inbolger@yahoogroups.com, Jay Bazuzi <jay@> wrote:
> > > > It seems so archaic, in these days of interconnected computers, to send
> > > > plans through the mail!
> > > > -J
> > > > On Sun, Apr 22, 2012 at 5:58 PM, David <dir_cobb@> wrote:
> > > > > Neal
> > > > > Not surprised. Payson has plans printed ready for shipment and they are
> > > > > sent folded in an envelope by standard mail. Susanne ships plans printed
> > > > > when you order them, rolled in a tube. At least, when I bought plans, the
> > > > > post office handled Susannes as a package that went through customs, while
> > > > > Paysons came through as a standard envelope.
> > > > > Both systems are respectively suited to the type of plan we are talking
> > > > > about.
> > > > > I would also recommend you buy Payson's books if you have not done so
> > > > > already.
> > > > > Best regards,
> > > > > David
> > > > > > Still anxiously awaiting my AS 29 plans. However, the Tortoise dinghy
> > > > > plans that I ordered from Payson, Inc. 4 days after arrived a week ago.
> > > > > There is a parable in there somewhere!
> > > > > > Neal
Eric
--- Inbolger@yahoogroups.com, "sandidgeneal" <nsandidge@...> wrote:
> Hi, Susanne:
> Neal
> > Neal
> > > -J
> > > > Neal
> > > > about.
> > > > already.
> > > > Best regards,
> > > > David
> > > > > Neal
----- Original Message -----From:AndrewSent:Monday, April 23, 2012 10:57 AMSubject:[bolger] Re: AS 29 plans<snip> Susanne A: "are quite a ways into the construction-project, and therefore subject to cycles of reconsideration."
I like Susanne's wisdom. In my own Chebacco 25 build I have considered many changes, alterations and improvements, some suggested by Susanne and others borrowed from other boat designs. In the end Phil's reasoning becomes apparent and many of the changes don't work or aren't as good as the original design.
However, the process of building a boat is a long one so you have time to think things through, work out problems and make improvements as you go along (Susanne's "cycles of reconsideration"). You don't have to decide if you want to build the house or not right now, decide later.
Andrew
https://sites.google.com/site/warrandytewoodenboat/
Andrew
On 04/23/2012 07:49 AM, Neal Sandidge wrote:Susanne:
OK, won't do the ferro, but there is no way I'm gonna put that ugly doghouse over the head! Can I fit a Brick up there?
Neal
Date: Mon, 23 Apr 2012 07:40:36 -0400
Subject: Re: [bolger] Re: AS 29 plansI take the ferro-cement idea to be expressed in jest...I'd study the plans and let them 'sink in'. Good thing that issues such as dinghy or even headrooom over the head are quite a ways into the construction-project, and therefore subject to cycles of reconsideration.
On the headroom his is a good look-out in ugly weather to check groundtackle via ports or just take a quick look-round should you be lost in reverie 'sitting' and an odd noise alerts you...
I'd even consider the extra labor of 'knocking off' the forward corners of the given dink to get the most stability and carrying capacity per foot-print on deck.
Susanne----- Original Message -----From:Willers32Sent:Monday, April 23, 2012 7:17 AMSubject:Re: [bolger] Re: AS 29 plansI would not use ferro cement. Lots of reasons:brittle, fracture prone, wire core rusts out, weight differences etc. The ply as specified is plenty strong and easier to repair.
The doghouse over the head can go, we did not build it. You can then leave out the extra layers of plywood around the main mast. Sitting "head" room is adequate and if you really must stand, open the hatch.Yes you can stow a dinghy on deck. We carried a nice little pram there.
Sent from my Samsung Epic™ 4G
sandidgeneal<nsandidge@...>wrote:
Hi, Susanne:
Neal
> Neal
> > -J
> > > Neal
> > > about.
> > > already.
> > > Best regards,
> > > David
> > > > Neal
Steve
Neal
> -J
> On Sun, Apr 22, 2012 at 5:58 PM, David <dir_cobb@...> wrote:
> > Neal
> > about.
> > already.
> > Best regards,
> > David
> > > Neal
----- Original Message -----From:Neal SandidgeSent:Monday, April 23, 2012 7:49 AMSubject:RE: [bolger] Re: AS 29 plansSusanne:
Neal
Susanne
sandidgeneal <nsandidge@...> wrote:
Hi, Susanne:
Neal
> Neal
> > -J
> > > Neal
> > > about.
> > > already.
> > > Best regards,
> > > David
> > > > Neal
Neal
To: bolger@yahoogroups.com
Susanne
Hi, Susanne:
Neal
> Neal
> > -J
> > > Neal
> > > about.
> > > already.
> > > Best regards,
> > > David
> > > > Neal
Susanne
Hi, Susanne:
Neal
> Neal
> > -J
> > > Neal
> > > about.
> > > already.
> > > Best regards,
> > > David
> > > > Neal
Hi, Susanne:
Neal
> Neal
> > -J
> > > Neal
> > > about.
> > > already.
> > > Best regards,
> > > David
> > > > Neal
Neal
> Neal
> > -J
> > > Neal
> > > about.
> > > already.
> > > Best regards,
> > > David
> > > > Neal
Neal
> -J
> > Neal
> > about.
> > already.
> > Best regards,
> > David
> > > Neal
On Sun, Apr 22, 2012 at 5:58 PM, David<dir_cobb@...>wrote:Neal
Not surprised. Payson has plans printed ready for shipment and they are sent folded in an envelope by standard mail. Susanne ships plans printed when you order them, rolled in a tube. At least, when I bought plans, the post office handled Susannes as a package that went through customs, while Paysons came through as a standard envelope.
Both systems are respectively suited to the type of plan we are talking about.
I would also recommend you buy Payson's books if you have not done so already.
Best regards,
David> Still anxiously awaiting my AS 29 plans. However, the Tortoise dinghy plans that I ordered from Payson, Inc. 4 days after arrived a week ago. There is a parable in there somewhere!
> Neal
Best regards,
> Neal
Susanne
----- Original Message -----From:Neal SandidgeSent:Sunday, April 22, 2012 6:11 PMSubject:RE: [bolger] AS 29 plansHi Susanne:
I'm not worried. Because of customs charge differences, I have exclusively used parcel post as my shipper, sending tens of thousands of dollars worth of goods through the mail and never lost an item. Usually it takes about 3 weeks from the US, but occasionally about 6 weeks. Just thought it was ironic that the lowly Tortoise beat the AS29!
Neal
Date: Sun, 22 Apr 2012 12:28:58 -0400
Subject: Re: [bolger] AS 29 plans
Neal
I find these delays puzzling indeed. Recently plans and video went separately to Norway, with one arriving within a week and the other (seemingly) lost for a few extra nail-biting weeks...??
Let me know when they finally show up.
On the rudder matter, we could discuss details once you have the plans.
Susanne----- Original Message -----From:sandidgenealSent:Sunday, April 22, 2012 7:17 AMSubject:[bolger] AS 29 plansStill anxiously awaiting my AS 29 plans. However, the Tortoise dinghy plans that I ordered from Payson, Inc. 4 days after arrived a week ago. There is a parable in there somewhere!
Neal
Neal
Susanne
Neal
Susanne
Neal
Justin
> Neal
Neal
