Re: Lightweight marine ply
I've placed a scan of "water resistance of epoxy coatings" a
test results article, in Jan/Feb/Mar 2012 Australian Amateur Boatbuilder #76, pp7&8, by Dr Bruce McConkey, Boatcraft Pacific, in the BOATBUILDING folder in group Files:
http://groups.yahoo.com/group/bolger/files/BOATBUILDING/(Seems similar to the tests Dr Dave Carnell conducted.)
Dr McConkey's article authoritatively advises on what type of epoxy coating, thinners & etc. Does it mean ENCAPSULATION or just one side though?
Sheathing counteracts checking and or abraision if that's a likely issue with the material or location... A good paint system alone is often advised for unwetted, low wear areas... or all over for light, dry-sailed boats.
my 2cents...
--- Inbolger@yahoogroups.com, "sandidgeneal" <nsandidge@...> wrote:
> I suspect what you are saying is correct. Epoxy coating is not the be-all-end-all. However, monkey see monkey do, so I will sheathe and coat my AS29. But I will use a local epoxy that costs 40% of WEST. Is this false economy? I don't know. What does everyone else think?
> Neal
Neal
--- Inbolger@yahoogroups.com, "c.ruzer" <c.ruzer@...> wrote:
> --- Inbolger@yahoogroups.com, "Eric" <eric14850@> wrote:
> > Whatever reference I had in mind I cannot find. I thought it was
> > from The Gougeon Brothers On Boat Construction, but do not have
> > time to read the whole thing. I've done research on line and what
> > I have found seems to indicate that Epoxy has much better
> > resistance to moisture penetration than other options.
> "ENCAPSULATION
> You will note that I have not mentioned epoxy encapsulation; i.e., coating both sides of everything with several coats of epoxy resin. It has no advantages and is a waste of money and time that adds useless weight. It won't turn lauan underlayment into marine plywood, though it will make it cost nearly as much. It does not keep the water out of the wood boat that lives in the water and a dry sailed boat doesn't need it."http://www.angelfire.com/nc3/davecarnell/epoxy.html
> "A modern myth is that epoxy resin penetrates sound wood and that epoxy coating prevents water from being absorbed by wood." " Boats are immersed in water, so I measured water absorption while immersed of ¾" pine coated with three heavy coats of epoxy resin. These coatings were about twice as thick as used at FPL. In fact, their total weight was a little over 30% of the weight of the uncoated wood. Immersed in water they absorbed 20% by weight of water in 200 days. That is the water content required to sustain rot organisms. There are two other requirements for rot to occur-presence of the organisms and oxygen to sustain them. The rot spores are astronomically larger than water molecules, so if the wood did not have them to begin with, epoxy coating would likely keep them out. As to oxygen, the oxygen molecules are far larger than water molecules and do not have the unique properties of water molecules that make them capable of penetrating any organic material-natural or synthetic. I learned this the hard way while supervising spending a couple of million dollars around 1960 on a DuPont research project to make building products and pipes of resins reinforced with kraft paper. Dry kraft paper is a pretty strong, stiff material; wet, it is like the proverbial dishrag. The chemists doing the experiments tried every polymerizable mix they could conceive, including epoxy resins, to make products that wouldn't lose their stiffness in long-term contact with water. The research director held his head in his hands when I reported that we had had zero success. I also coated exterior fir plywood (three equal thickness plies) and underlayment lauan plywood (thin skins and thick core) with about 30% of their weights of epoxy resin. The fir plywood took about 1½ years of soaking to reach 20% water absorptiion, but the lauan hadn't reached that point in two years and looked as if it never might. This resuly hints that the glue lines between skins and cores of plywood are quite effective barriers to water absorption. David W. Carnell 11 March 2004"http://www.angelfire.com/nc3/davecarnell/articles.html
"ENCAPSULATION
You can also get 2-stroke motor oil with a fuel stabilizer already added to it. This is what I use, but not suggesting it is superior. Just what my local hardware store sells. I does seem to produce less (visible) smoke as well if used with the recommended 89 octane gasoline.
http://www.echo.ca/products_detailed.aspx?CategoryID=16&ProductID=88
Ever wonder why we pay road tax on boat and lawnmower gas?
--- In bolger@yahoogroups.com, "John Kohnen" <jhkohnen@...> wrote:
> Just this year I started using Sta-Bil gas stabilizer in the fuel for my
> small engines. It's cheap, even for the "marine" grade, considering how
> little gas I use, even including the lawnmower and weedeater. Probably
> cheaper than not using it, because I was discarding small amounts of old
> gas I no longer had faith in.
Any gasoline engine sold in the US since the late '70s is designed to use
no-lead fuel. Using leaded fuel in an engine designed for unleaded
shouldn't cause any serious problems (spark plugs won't last quite as
long).
Gasohol is nasty stuff, but engines sold in the US for at least the last 5
years or so are designed to tolerate it, though many older engines can
stand it also, especially relatively "modern" motors. The problem is that
the alcohol can attack some plastic and "rubber" parts in the fuel system.
Older gas lines are often susceptible to damage from alcohol, but
fortunately are easily replaced. Alcohol also absorbs water (you can buy
alcohol "gas dryer" at the auto parts store), until at a certain point it
can't absorb any more, at which point it dumps the water into the gas, :o(
I've yet to have a problem with "phase separation" (I think they call it)
in my gas tanks or gas cans, but I've noticed minor corrosion in the
bottom of carburettor float bowls, probably from water sitting there after
phase separation of that small amount of gas when left in the carb over
the winter (run the gas out of the carb, and/or drain it before storing a
motor!). Gasohol left in a carb for a long time seems to be more likely to
clog things up than "real" gas, though not real gas premix for two-stroke
motors (I don't know how bad gasohol premix is <g>, though I haven't yet
had trouble with my 2-stroke weedeater even though I leave gas in the carb
over the winter <shrug>). But the first time the idle jet clogged on my
Tohatsu 3.5 it was alcohol free gas I left in the carb. <shrug>
I don't know why your BIL had trouble with gasohol in the 2011 Tohatsu, it
was built to use it. I haven't had any trouble with my 2006 Tohatsu 9.9
with the Merc decals, which wasn't specifically built to use gasohol, nor
did the previous owner. <shrug> But I do run the gas out of the carb
before storing, and I'll bet he did too. I wouldn't be afraid to take my
9.9 anywhere in the world, but I'd use a real good fuel filter! <g>
On Mon, 30 Apr 2012 07:51:44 -0700, Eric wrote:
> My brother inlaws 2011 Tohatsu 8hp gave him all kinds of problems. Back
> to dealer over and over. Turned out the problem was 10% Ethanol. At
> least one of the local marinas sells gas that does not have Ethanol and
> that is what he uses now. If an engine is designed to run on lead it
> will not work well on lead free gas, and vice-versa unless specifically
> designed to. Given that I will be sailing in different regions and
> countries this would be a problem. Lead, lead free, ethanol if I use a
> gas engine it would have to work properly with any combination.
John (jkohnen@...)
We must respect the other fellow's religion, but only in the
same sense and to the extent that we respect his theory that his
wife is beautiful and his children smart. (H. L. Mencken)
I would think that the electric option would work fantastic with any sail boat designed for internal ballast.  A small get home generator would be a simple thing depending on the power characteristics of the chosen motor/charging setup.
I've had 2 8D's and a pair of Trojans in my trawler for 6 years, and I went to the trouble of installing a 3 bank, 3 stage charger (440.00 6 years ago), and they're all still working well.
when I look at what I've spent over the years for impellers, oil changes, fan belts, hoses, heat exchangers, alternator rebuilds, injector rebuilds, raw water pump replacement, and last but not least fuel and additives, the high initial cost on the batteries doesn't faze me.
Tom
Sent from my iPad
On Apr 30, 2012, at 9:20 AM, John Boy <t1ro2003@...> wrote:
If you can't get boat gas (non-ethanol) and you only burn a few gallons you can use avgas.  Just run out to the FBO at your local airport and buy some 100 octane Low Lead.  Works great in an old outboard.
John Boy
You can trust me, I have a degree in science...
Sent:Monday, April 30, 2012 9:51 AM
Subject:[bolger] Re: Four Cycle Gasoline? (was: Sustainability (world-wide forest die-off now))
My brother inlaws 2011 Tohatsu 8hp gave him all kinds of problems. Back to dealer over and over. Turned out the problem was 10% Ethanol. At least one of the local marinas sells gas that does not have Ethanol and that is what he uses now. If an engine is designed to run on lead it will not work well on lead free gas, and vice-versa unless specifically designed to. Given that I will be sailing in different regions and countries this would be a problem. Lead, lead free, ethanol if I use a gas engine it would have to work properly with any combination. I have no confidence that this would be the case, but have not done any research.
Eric
--- Inbolger@yahoogroups.com, "John Kohnen" <jhkohnen@...> wrote:
> Touchy about gas?? Where'd you hear that? What's special "four cycle
> gasoline?" I've never heard of the stuff, even though I've been driving
> cars and riding motorcycles with 4-stroke engines for many decades...
> I run my little Honda and the Tohatsu 4-strokes I've owned (including the
> one I've got now with "Mercury" decals on it) on regular gas from the gas
> station. Never had a problem, even though they've forced gasohol on us,
> except the Tohatsu 3.5 would clog it's idle jet if I forgot to run the gas
> out of the carb before letting it sit over the winter. That's not a
> 4-stroke problem. I've had far more trouble over the years with gummed up
> carbs on 2-stroke engines of all sorts than I've ever had with 4-strokes.
> <shrug> With any gasoline boat engine you want to run the gas out of the
> carb before storing for a long time.
> On Sat, 28 Apr 2012 23:10:51 -0700, Eric wrote:
> > The initial investment is steep compared with a 4 stroke outboard. The
> > outboard needs gas (unfortunately can be touchy about type of gas)...
> > $200 per year at $5 per gallon for special four cycle gasoline 40
> > gallons, 10 gallons per year. Which I would suppose would be about
> > equivalent to gas used when using the outboard about like you use your
> > electric propulsion.
> John (jkohnen@...)
> The whole problem with the world is that fools and fanatics are
> always so certain of themselves, and wiser people so full of
> doubts. (Bertrand Russell)
John Boy
Eric
> John (jkohnen@...)
Whatever reference I had in mind I cannot find. I thought it was from The Gougeon Brothers On Boat Construction, but do not have time to read the whole thing. I've done research on line and what I have found seems to indicate that Epoxy has much better resistance to moisture penetration than other options. I do not have definitive information about whether there could be problems with moisture penetration and condensation into plywood voids. I think the problem is far less than I though it might be. Small enough to use CDX as a center core in multi-ply hull build up in a large craft??? Given the very small portion of total cost this "savings" would represent, I would not take the chance.
Eric
--- Inbolger@yahoogroups.com, james fry <hunter02_2002@...> wrote:
> Eric, I don't know why you'd say epoxy doesn't seal out moisture. I used to live on the Jersey shore and about 25-27 years ago I used W.E.S.T. epoxy system to put together three small boats. When I was back up there 18 months ago, I tried looking them up. Two were still afloat and being used. I couldn't find the other people or what happened to that skiff. This stuff saturates the wood and the finish is like a fibre-glass resin. The only thing done to the boats still in use was to give them a W.E.S.T. coat every 6-8 years.
> If epoxy didn't seal out moisture, as opposed to just water, it would be totaly useless as there are small voids and pockets of air even in the most solid wood.
> Jim
> ________________________________
> From: Eric <eric14850@...>
> Sent: Wednesday, April 25, 2012 1:35 PM
> Subject: [bolger] Re: Lightweight marine ply
> Â
> A question. Regarding voids in marine and other plywood used in a boat's hull and decks, is there a problem caused by water vapor condensing in the voids in the cold climate of New England and cold West coast waters? Epoxy will not seal out moisture, only water. A high humidity interior would drive moisture toward the cold. It seems moisture would penetrate into the plywood and precipitate out if the dew point happened to be where the void was. Does anyone have an experience or real information about this possibility?
> Eric
> --- Inbolger@yahoogroups.com, <philbolger@> wrote:
> > On the SACPAS-3 project I used only domestically farm-grown Douglas Fir ply, well-understood, no pretty grain, fairly non-toxic, with a fully-known environmental-impact trail, quite affordable at $91.- for 1", well under $50 for 1/2" etc. from a local dealer. The 1/4 stuff kept 'smiling' a us with 'wild grins', but even on the flat roof its smirk soon turned into a 'stiff upper lip', level and straight. Despite 'Marine-Grade' stamp there are core-voids here and there, but at the load of epoxy and glass on this job, I'd expect little drama long-term, particularly with bottom and side double-skinned. On a government job staying all domestic, affordable and non-experimental is a safe bet. The project itself had enough hair-raising episodes anyway...
> > Susanne Altenburger, PB&F
> > ----- Original Message -----
> > From: c.ruzer
> > Sent: Wednesday, April 25, 2012 8:42 AM
> > I wonder what part of Borneo or West Papua is being denuded in the supply of this stuff. I rather hope none, save the whale and all, but as it seems to be China sourced I won't be holding my breath that the "light weight" is due to some SE Asian plantaion grown Paulonia spp or somesuch.http://www.goldcorelight.com/specifications.htm- that BS1088 standard is beyond meaningless in the Australian context. Is the weight all that less than Oz plantation grown hoop marine plywood anyway (38% seems a stretch)? Such Oz marine plywood conforms to the superior and meaningfull AS/NZS2272, and is as likely manufactured to F14, and may carry a 40 year bond warranty. I'd guess that the Goldcore Light interior veneers should never be exposed to water, never, and that may be a big ask in a small boat. It's not cheap. Lightness up high is something, but I don't understand how the strength can be had by increasing thickness by one millimetre. It seems that a jump to
> the next standard size, so from 6mm to 9mm etc, is mandated. That, or increased supporting frame and stiffening members, and either would seem to cancel the Goldcore alleged 38% weight advantage - and cost more.
> > --- Inbolger@yahoogroups.com, "Andrew" <a.c.l.yen@> wrote:
> > > My Chebacco 25 hull is finally up the right way. I had a party for friends, relatives and the wooden boat club, gave everyone a rope, or piece of wood and we had it off it's building frame right way up on its trailer in 40 minutes. I'll post some photos when I get time.
> > > Now I have to get serious about decks, cockpits, carlins, beams, frames etc. In shopping for suitable plywood I have come across "lightweight marine ply" (see www.goldcorelight.com). I have obtained a sample and am impressed with the quality (no voids, nice face veneers)and the lightness of the product. It feels not much heavier than balsa wood yet gives the impression of being plenty strong enough.
> > > The strength grade is F7 - which means a designed working stress of 7MPa. I did a bit of research that suggests that this is not as strong as "standard" ply but that adding a mm to the thickness will compensate for the lower strength:
> > >http://oak.arch.utas.edu.au/tbia/view_article.asp?articleID=133
> > > It isn't cheap at A$71 for 6mm, A$94 for 9mm and A$112 for 12mm but these prices are comparable with good Gaboon marine ply.
> > > Has anyone used it or have opinions about lightweight ply for "above waterline". I figure that lighter sheets are easier to handle and will reduce the weight of the boat by some 50kg or more.
> > > Andrew
> > >http://sites.google.com/site/warrandytewoodenboat
Eric
> John (jkohnen@...)
John (jkohnen@...)
Nah, the 'glass' is really a plastic cup and the 'line' that make the glass look half full or half empty is really just a line drawn on the emptyplasticcup.Pessimist?...Optimist?...Realist.
Sent:Saturday, April 28, 2012 5:48 PM
Subject:[bolger]Screw Sustainability (and the rest of the green stuff) (was Re: Lightweight marine ply)
> The Glass is Half Full or Half Empty - ALL in how someone CHOOSES to view it
I say the glass is too large.
Justin
LIFE is FULL of Pessimists & Optomists YOU DECIDE
To: bolger <bolger@yahoogroups.com>
Sent: Sun, Apr 29, 2012 10:46 am
Subject: [bolger]Screw Sustainability (and the rest of the green stuff) (was Re: Lightweight marine ply)
Or the glass is overflowing, like trying to fit 10 lbs of S*&# into a 5 lb bag :o
> Justin
> Justin
LOL!  - OK one of the best responses from EY users is lack of BOAT - Bring On Another Thousand !
I originally thought Marinas would love this technology, WRONG ! diesel maint $$$$ is a huge income resource.
add dock fuel, winterizing etc.
Sent: Sun, Apr 29, 2012 1:20 am
Subject: [bolger] Sustainability (world-wide forest die-off now) (was Re: Lightweight marineply)
Oops. Didn't come out right. Wishing you many years with no maintenance issues to report. Years of flawless operation and battery longevity.
--- Inbolger@yahoogroups.com, GNHBus@... wrote:
> Good morning
> Electric Hybrid System -www.electricseas.orgwww.electricyacht.com
> The EY 360ibl System will provide 18kW of power
> "Hopefully it will be many years before you give feedback about system reliability and longevity."
> Can you add more to what is meant by your comment above?
> Sent: Sat, Apr 28, 2012 5:53 am
> Please post your experiences with this electric hybred system you have created, including cost of installation, electric HP and how it performs, battery bank amperage, hours of performance and what rate of draw you use while doing the work you do. Hopefully it will be many years before you give feedback about system reliability and longevity.
> Eric
> --- Inbolger@yahoogroups.com, GNHBus@ wrote:
> > Good morning
> > We are installing an Electric Yacht System 360ib into a 1948 38' Novi Lobster Lobster Boat out of Quincy MA.
> > This vessel has a WWII Detroit Diesel Landing Craft Propulsion System that costs $100 day to fuel and bellows
> > pollutants like crazy while hauling traps at idle.
> > She will go from 6-8 hrs diesel idle per day, to 6-8 hrs electric and 45 min diesel out,45 min In.
> > From: philbolger <philbolger@>
> > Sent: Fri, Apr 27, 2012 8:50 am
> > Subject: Re: [bolger] Sustainability (world-wide forest die-off now) (was Re: Lightweight marineply)
> > Serious stuff indeed.
> > Still, climate-change deniers abound. Good thing that serious people are waking up - albeit possibly too late ?!
> > As you know, we've pushed hard and I continue to raise the issue of sustainable fishing-fleets for starters, but resistance to burning less fuel and thus money is astonishingly high and stubborn, typically wrapped in some sort of tortured internally-incoherent justification, often fading out with nebulous references to 'evil forces' beyond the horizon. Childish, ignorant, clearly dangerous all around in its consequences if allowed to govern policy.
> > I wished WOODENBOAT would see and leverage its potentially quite potent political role beyond a lot of varnish and 'period-pieces'. There's always hope...
> > From: c.ruzer
> > Sent: Friday, April 27, 2012 8:38 AM
> > --- Inbolger@yahoogroups.com, james fry <hunter02_2002@> wrote:
> > > a study was done in New Jersey a while back that showed the Pine
> > > Barrens put more hydrocarbons into the air every week than all the
> > > trucks on the NJ Turnpike put out in a year.
> > It's by far the amount of truck CO2 emitted that ought be compared, not HCs (trucks shouldn't be emitting methane or much other nasty CO2 equivalent in any quantity - carcinogenic particulates etc being another thing). As for CO2, just how much CO2 did those trucks absorb from the air every week? Any?
> > A study done a while back?
> > Well then, SEEN LAST NIGHT - coincidental to this topic, on a televised science programme segment concerning climate related tree death numbers now massively increasing globally. The greenhouse planet could now be on the edge of "wholesale mortality of the world's forests". Those forests have much to do with producing and regulating climate, of course... So, one more example of accelerated nasty climate change via runaway positive feedback in the greenhouse and resulting in a nastier climate and possibly a timberless world... (side note: this is about a spreading drying and dying, but, wetlanders, don't smile too soon, you may also have seen sometime that overwatered plants often show similar signs of stress to those deprived of water... gaseous exchange, water psi, physiology, pathogens, parasites, pests: a balancing act.)
> > CATALYST
> > Thursday, 26 April 2012 [snipped...]
> > video and transcript here:http://www.abc.net.au/catalyst/stories/3488105.htm
> > TREE DEATHS
> > "NARRATION
> > The Rocky Mountains of North America - home to some of the most beautiful, pristine forests in the world. But the shades of burnt golden reds aren't the changing tones of Autumn; they're dead and dying trees.
> > Dr Craig Allen
> > We're looking at tree mortality over a scale of tens of millions of hectares in the last decade alone.
> > NARRATION
> > In fact, right across the globe, there are reports of trees dying in mass numbers.
> > Dr Craig Allen
> > We see all around the world in places where there have been droughts, that drought - particularly droughts and heatwaves - trigger mass waves of mortality. No major forest type is immune.
> > NARRATION
> > Across the western US, tree death rate have more than doubled in the past few decades.
> > Dr Craig Allen
> > So what we're seeing in these forest die-off events around the world are trees passing the tipping point of stress - the thresholds of mortality. Unfortunately we don't know very much about these thresholds at this point.
> > Dr Craig Allen
> > There may be insects and fungal pests that emerge at that point in time, but underlying it is the physiological stress on the trees that compromises their defences. You could think of it actually sort of like HIV in humans. HIV doesn't directly kill people, but by compromising our immune systems, it makes us vulnerable to secondary ah, you know, viruses and other things that can kill us. It's similar in trees.
> > NARRATION
> > The effect climate change may have on our forests is a huge concern. But an even greater worry - how will dying trees affect the climate? In 2005, the heart of the world's biggest rainforest suffered a drought so hot and severe it turned the Amazon jungle from a carbon sink to a carbon source. A second once-in-a-century drought happened five years later.
> > Dr Craig Allen
> > What's most alarming is that these die-off events may be just the tip of the iceberg. We know that warming, temperatures exacerbate tree mortality, and the climate predictions are that the world is going to get much warmer soon. Um, so we may be just at the very front edge of what could be wholesale mortality of the world's forests - the forests that we know and care about today."
> > Related article:
> > _What's Killing the Great Forests of the American West?_
> > 15 Mar 2010: Report
> > "Across western North America, huge tracts of forest are dying off at an extraordinary rate, mostly because of outbreaks of insects. Scientists are now seeing such forest die-offs around the world and are linking them to changes in climate." "In 2008, so much of British Columbia's forests had died they also went from being a net carbon sink to carbon source." "Russian researchers also are concerned that warmer, dryer conditions will lead to increased outbreaks of the Siberian moth, which can destroy large swaths of Russia's boreal forest." "Although western North America has been hardest hit by insect infestations, sizeable areas of forest in Australia, Russia, France, and other countries have experienced die-offs, most of which appears to have been caused by drought, high temperatures, or both." "In Africa where I work, suddenly whole hillsides are dropping dead," she said. "It's happening so fast people are in shock. It's a tragedy." "Trees across the world are stressed already from fragmentation, air pollution, and other problems... I don't know how much stress the forests of the world can take," said Allen."http://e360.yale.edu/feature/whats_killing_the_great_forests_of_the_american_west/2252/Yale Environment 360http://e360.yale.edu/
> > _A global overview of drought and heat-induced tree mortality reveals emerging climate change risks for forests_
> > (the paper cited in the above article. 20 co-authors)Forest Ecology and Management, Volume 259, Issue 4, 5 February 2010, Pages 660–684
> > "Although episodic mortality occurs in the absence of climate change, studies compiled here suggest that at least some of the world's forested ecosystems already may be responding to climate change and raise concern that forests may become increasingly vulnerable to higher background tree mortality rates and die-off in response to future warming and drought, even in environments that are not normally considered water-limited... Overall, our review reveals the potential for amplified tree mortality due to drought and heat in forests worldwide."http://www.sciencedirect.com/science/article/pii/S037811270900615X
> >http://www.sciencedirect.com/science/journal/03781127/259/4
> > related articleshttp://www.sciencedirect.com/science?_ob=ArticleListURL&_method=list&_ArticleListID=1972582475&_sort=v&_st=17&view=c&_origin=related_art&_acct=C000228598&_version=1&_urlVersion=0&_userid=10&md5=85d8d9867f2ac47a6e556d619172a78d&searchtype=a
> > THERE'S NO SOLACE FOR TREES FROM THE OCEANS EITHER. SEEN TODAY, JUST IN... are news reports of results from CSIRO in Hobart and Lawrence Livermore National Laboratory in California as published in the journal SCIENCE. Thousands of robotic ocean monitoring diving bouys now accurately confirm wet climates getting wetter and dry climates getting drier - but at much faster rates than predicted...
> >http://theconversation.edu.au/dry-parts-of-the-planet-to-get-drier-wet-parts-wetter-6700http://theconversation.edu.au/
> > "They revealed a repeating pattern of change believed to be the result of climate change, Wijffels said. "And we see it in the north Atlantic, the south Atlantic, the north Pacific, the south Pacific, the Indian; it's repeated in every ocean basin independently," she said."http://www.google.com/hostednews/afp/article/ALeqM5gta4Ck8xze5I-sHAzazzvCB-4GBA?docId=CNG.30fcb51b66f59d429f40a78cff17d57e.3e1
> > These facts came as news to me here today on yahoo (aap sourced):
> >http://au.news.yahoo.com/queensland/a/-/mp/13533217/new-study-warns-of-tough-aussie-climate/by David Beniuk, AAP, April 27, 2012, 6:19 am [snipped...]
> > "Scientists from the CSIRO in Hobart and the Lawrence Livermore National Laboratory in California have used the most accurate study yet of ocean saltiness to show the world's dry areas, like Australia, are getting drier and its wet areas getting wetter.
> > The scientific team says the rate at which the atmosphere moves water from dry spots to wet spots increased by four per cent between 1950-2000 - twice as fast as predicted by current climate models.
> > They conservatively estimate it could triple by the end of the century, leaving dry land masses like Australia struggling to meet their need for fresh water.
> > "We're pretty sure that this is clear evidence it's already happening, that the water cycle has accelerated and the rates at which it's accelerating per degree of warming are probably higher than our current models project," Dr Wijffels says.
> > The study is considered one of the most accurate of its type because data was collected from ocean monitoring equipment, including the Argo fleet of 3,500 robotic floats deployed over the past decade.
> > Scientists have previously struggled to produce estimates of water cycle changes because land-based observations of rainfall and evaporation are sparse."
> >http://www.smh.com.au/environment/climate-change/extremes-in-weather-more-likely--scientists-20120427-1xpq8.html
> > "The team's leader, Paul Durack, said the finding was important because reductions in the availability of fresh water posed more of a risk to human societies and natural ecosystems than a rise in temperature alone. "Changes to the global water cycle and the corresponding redistribution of rainfall will affect food availability, stability, access and utilisation," said Dr Durack, a former CSIRO researcher now at the Lawrence Livermore National Laboratory in California.
> > Interesting audio file and transcript of recent interview with Dr Susan Wijffels, CSIRO oceanographer, who leads the Argo profiling program in Hobart, Tasmania. Pirates show an interest in Argo...
> >http://www.abc.net.au/radionational/programs/scienceshow/ocean-data-feeds-into-weather-and-climate-forecasting/3963080
> > "Pine Barrens" may sadly take on a different meaning in many places sometime soon...
I have yet to find an Electric Yacht customer dissatisfied with the results.
The initial apprehension is well documented, kind of funny giving that this is 100 + yrs technology,
but the end result speaks for itself.
Have you been on a boat with e-prop?
Sent: Sun, Apr 29, 2012 2:12 am
How long does your battery bank last? I take it that you do pay attention to it and use and charge it on a regular basis all year long. What do you actually do?
I don't think price is the best argument in favor of electric power. The initial investment is steep compared with a 4 stroke outboard. The outboard needs gas (unfortunately can be touchy about type of gas) and oil, but battery bank must be replaced, how often? I had a couple Exide golf cart batteries for house batteries that got very little use. I apparently did not maintain them properly with correct trickle charge or remembering to top off the charge every month and they did not last. Less than four years. By your battery bank costs of $800 that would be $200 per year at $5 per gallon for special four cycle gasoline 40 gallons, 10 gallons per year. Which I would suppose would be about equivalent to gas used when using the outboard about like you use your electric propulsion.
However, I just priced batteries and the best cost per amp I saw was Lifeline 6v 330 amp 82 lb at $392 delivered. I would hope they would be of good quality and last longer than the Exide batteries of my previous experience.
Advantages of electric include flexibility about placement of weights, and lack of smell. Disadvantages: well, no one runs their engine at three knots. They run it at near hull speed except for slowing down to dock, and they usually have enough fuel on board for a couple of days continuous operation. My dad's 10 hp Yanmar inboard runs for days on a couple of gallons of diesel or more pleasantly smelling biofuel.
The least awkward auxiliary solution for ROGUE would be a Torqeedo electric outboard, but it is at least twice as expensive an installation as a 9.9 Honda would be. And I have heard things which make me doubt the Torqeedo would have the reliability I would expect for the price asked.
I keep choking on imperfect solutions and installation/acquisition costs approaching $6000 on a 26' sailboat. A lot of money for something to be seldom used. I keep doing nothing. Well not nothing. I am adding a light weather sail that will likely move ROGUE when other boats are sitting still.
Eric
--- Inbolger@yahoogroups.com, "loosemoosefilmworks" <loosemoosefilmworks@...> wrote:
> As it happens we have an Electric Yacht system on our boat "So It Goes" and it has worked out very well. We have not used diesel/gasoline to power the boat in almost eight years in full time cruising mode... I think that says that electric propulsion is actually more than ready for prime time.
> Something that most folks don't get about electric propulsion is the cost of running and maintaining it is near zero. Over the last four years we have spent less than $100... Compare that to the cost of keeping a Yamaha 9.9HP four stroke running and topped up with fuel and oil for four years...
> All the best
> Bob
>http://boatbits.blogspot.com/
>http://fishingundersail.blogspot.com/
>http://islandgourmand.blogspot.com/
Here in the Philippines, a new Yamaha 9.9 HT with elec. tilt is $4500!  And you still need a battery bank of some kind, plus a means to charge it.  So elec propulsion seems about the same outlay.
Neal
To: bolger@yahoogroups.com
Date: Sun, 29 Apr 2012 06:10:51 +0000
Eric
> All the best
> Bob
Eric
> All the best
> Bob
> Good morning
> Electric Hybrid System - www.electricseas.org www.electricyacht.com
> Eric
> > Good morning
> > From: c.ruzer
> > CATALYST
> > TREE DEATHS
> > "NARRATION
> > Dr Craig Allen
> > NARRATION
> > Dr Craig Allen
> > NARRATION
> > Dr Craig Allen
> > Dr Craig Allen
> > NARRATION
> > Dr Craig Allen
> > Related article:
> > 15 Mar 2010: Report
Justin
May I chime in here, on subjective results on a NON-Bolger boat - changing prop to
feathering/folding...
Since selling my Black Skimmer, I now have a much larger, much more "plain-Vanilla" cruising sloop
-- a 1985 Irwin 43 center cockpit sloop, which has a lengthwise-long but very shallow-draft thick
fin-keel, housing a narrow deep centerboard, then a long aperture of many feet to a skeg-hung
rudder. Ted Irwin originally fitted this with a typical Michigan 3-blade powerboat prop --
interestingly, he had a very tall reduction ratio of 2.72:1 on the fitted gearbox, giving only 1100
shaft rpm at full-engine-speed... I can only assume Ted might have done that so that the prop's
blades had to have a lot of pitch, nearly "square" dimensions of 19x18 as I remember -- perhaps so
those blades had strong angle of 45 degrees rather than nearly flat (which would be the case if
shaft were turning much faster at cruise..).. Did he have any data to believe that angled blades
have less drag than nearly-flat blades?? hmmm.....
Looking for better performance in the all-too-typical light summer winds up here in the Salish Sea
(once known as Puget Sound), I explored all options for a feathering/folding prop. No manufacturer
could assure me that their available props could couple my 56hp to the water at such low shaft-rpm,
within the rather small prop diameter allowed by position of shaft/strut/underbody... only 22"
clearance, and you DO have to leave some gap (10% is the rule-of-thumb...) to avoid prop-slap
noise...
Finally the local Volvo dealer believed their largest (19" diameter) 3-blade folder, with their
most-aggressively-pitched set of cast blades (NOT re-pitch-able!) could work... as it's a prop with
long scimitar-shaped blades (like the nuclear-sub "quiet" props), it has about the most blade-area
possible within the prop-diameter. Well, he was WRONG in his sizing, drat -- I could peg the
diesel's governor, and still lost over a knot of top-speed. Only solution was to "change the
gear-ratio" by (finally this last winter) finding the very rare 2.2:1 ratio Hurth gearbox -- now
installed, and now once again I DO get up to full hullspeed of some 8 knots under power. Plenty of
"coupling" to the water; headwinds/headseas don't slow us down much at all...
Oh yes, back to the purpose of this information:
The folding prop had a marked effect on light-air sailing! My best guess is that the boat gained a
knot for sure, maybe even two knots of boatspeed in similar wind-conditions, when puttering about in
our typical 3 to ten knot summer winds... I could sense that the boat was much more free in
responding to puffs (yes, all 13 tons of her...), and strangely, she pointed much higher in
light-wind conditions (creating my own apparent-wind like a catamaran, with the additional
knot-or-two of speed? maybe that's all it is...). Once the wind pipes up to 15 knots or so, the
difference between the folder and the fixed prop isn't as noticeable, as by then the sails have
harnessed enough power to overcome the obviously greater drag of the fixed prop. (SO I'm not sure
why all the long-distance sailors lust after feathering/folding props, as a fair bit of their
offshore sailing SHOULD be done in the 15+ knot trades, no? oh c'mon, back to reality: : rumor has
it that much ocean-crossing can turn into a drifting-frustration... occasionally "punctuated by
abject moments of terror")
All in all, the prop's been worth all the fuss I went thru to get it to perform correctly under
power. And it's been no maintenance-hassle: it always unfolds reliably (the three blades are geared
to unfold together, and there's a LOT of peripheral weight in those not-thin cast blades), it is
authoritative in reverse, I swear there's far less turbulence aft, and noticeably less under-hull
hydraulic "noise" coming thru the eggshell-hull. Maintenance consists only of pushing out the
pivot-pins and re-greasing, once every three years when I "do the bottom"... Nothing like the
hassles I have seen with the feathering props on other boats I've taken thru survey during my
selling of them. A win for MY boat.
for photos of this prop-type, see:
http://www.volvopenta.com/volvopenta/uk/en-gb/marine_leisure_engines/accessories/Sailboat_accessorie
s/Pages/Foldingpropellers.aspx
But then, the majority of Bolger-owners following this group, can avoid all these big-boat hassles,
simply by tilting up the outboard, right? I do on occasion yearn for the simplicity of my Black
Skimmer...
Wayne Gilham
s/v "Hakuna Matata", 1985 Irwin 43 center-cockpit sloop, now lying Tacoma WA
From:bolger@yahoogroups.com[mailto:bolger@yahoogroups.com] On Behalf Ofphilbolger@...
Sent: Saturday, April 28, 2012 8:25 AM
So, under sail the same motor plus controller act also as the re-generators to feed charge back into
the batteries ?
And, much has been made of folding and feathering props on (western) pleasure sailing-craft in order
to not too noticeably impact performance under sail with a fixed or rotating propeller big enough to
get off a leeshore with. Much colorful language has been printed on the experience of sailing with
such an able propeller, with the worst accounts quite insistent on the notable loss of speed because
of the leeshore-capable prop's drag 'below'. What's your experience ?
From: loosemoosefilmworks <mailto:loosemoosefilmworks@...>
Sent: Saturday, April 28, 2012 11:07 AM
Oops... One last thing on the weight issue.
Our electric propulsion system replace an Atomic 4 gas engine which weighed in at 335 so the weight
of fuel and tankage came to pounds and we had a thirty gallon fuel tank came to about 210 pounds so
a total of 540 pounds...
So the weight of our installation including batteries is actually less than the internal combustion
system it replaced.
The devil being in the details!
Bob
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.1913 / Virus Database: 2411/4963 - Release Date: 04/27/12
> So, under sail the same motor plus controller act also as the re-generators to feed charge back into the batteries ?
Yep.
> And, much has been made of folding and feathering props on (western) pleasure sailing-craft in order to not too noticeably impact performance under sail with a fixed or rotating propeller big enough to get off a leeshore with. Much colorful language has been printed on the experience of sailing with such an able propeller, with the worst accounts quite insistent on the notable loss of speed because of the leeshore-capable prop's drag 'below'. What's your experience ?
We have a big fixed prop and the drag is manageable. Folding props are expensive and don't work half as well as you'd think and unless someone is a serious racer are hardly worth the trouble. The added drag of having the regen on is well worth the advantage of coming into port after a ten day passage with a fully charged battery bank and cold beer in the fridge.
When I'm not regenning the prop is parked in the path of least resistance so not a lot of drag when all is said and done.
Bob
Sent:Saturday, April 28, 2012 11:07 AM
Subject:[bolger] Sustainability (world-wide forest die-off now) (was Re: Lightweight marineply)
Our electric propulsion system replace an Atomic 4 gas engine which weighed in at 335 so the weight of fuel and tankage came to pounds and we had a thirty gallon fuel tank came to about 210 pounds so a total of 540 pounds...
So the weight of our installation including batteries is actually less than the internal combustion system it replaced.
Bob
Bob
> - The system's first cost and then life-expectancy of batteries.
We've had two electric propulsion systems aboard "So It Goes" the first was a home brew made up of off the shelf golf cart parts (total cost of the motor/ controller and various bits excluding batteries was about $800.) This system worked well but we replaced it in favor of the Electric Yacht system because as we'd be cruising full time we felt we needed a better controller with the ability to regenerate and charge the batteries while we sailed... In our opinion Electric Yacht makes the best controller out there.The cost of the installation (less batteries) is less than $5500.
For batteries we use stock golf cart batteries in a 48 volt bank (eight batteries) and their cost comes to around $800 (less if you shop a bit) and we've found properly cared for a battery bank will last a minimum of five years but our last bank was doing just fine at seven years but we found a deal so replaced them but we plan to have the current bank last at least ten.
> - How do the batteries get charged ?
We have a solar bank of 250 watts, the regen ability and a small 2000 watt gasoline generator. So far 95% of our charging has been solar/regen.
> - What is the range at what speed ?
This is where it gets complicated because electric propulsion is not quite the same thing on a sailboat as it would be on a motor boat. We treat our system like an auxiliary so we only use it when we have no wind or when we need to get into a harbor/marina... We never make passages under power which, I might add, is exactly how we used our outboard on Loose Moose 2... Anyway the thing is we can sustain hull speed of about seven knots when we need to but seeing the amp meter hovering at 100 amps keeps us from enjoying it so we throttle down to a more, shall we say, sustainable speed. for "So It Goes" we've found the "sweet spot" is right about three knots where we are only using a kiss over ten amps.
So, where that puts in range with a small battery bank is we can quite happily motor at three knots all day and taking advantage of a tiny amount of breeze to motor sail that allows us to go further at say four knots (but keep in mind the minute real wind comes up we turn off the motor and do what "So IT Goes is best at...sailing)... If for some reason we'd need to go further under power we can use our 2000 watt generator as a poor man's hybrid and go a lot further using only a liter of gas per hour.
> - Size of batteries and weight ?
Standard golf cart batteries the bank is 200+ amp hours (batteries are rated at 240 amp hours) and the weight is 66 pounds per so a total of 528. Note if I were putting this system into the next boat I'd be able to design in a larger bank as part of the ballast...
> - And finally, relative impact of salt-water conditions/atmosphere on electrical components ?
Pretty much zero... The installation is inside the boat the shaft has an anode and there really has been hardly any corrosion or rust. We do a wipe down every six months or so with Boesheild bu that really is the only maintenance other than topping up the water in the batteries on a regular basis.
> plus whatever I forgot to think of...
I think that pretty much covers it all.
Bob
Could you re-summarize several questions:
Sent:Saturday, April 28, 2012 8:56 AM
All the best
Bob
All the best
Bob
Good morning
Eric
> Good morning
> From: philbolger <philbolger@...>
> From: c.ruzer
> CATALYST
> TREE DEATHS
> "NARRATION
> Dr Craig Allen
> NARRATION
> Dr Craig Allen
> NARRATION
> Dr Craig Allen
> Dr Craig Allen
> NARRATION
> Dr Craig Allen
> Related article:
> 15 Mar 2010: Report
As promised, I HAVE uploaded a good bunch of articles from the great "Rudder" magazine of over a
century ago, about the build and launch of "Viper", which appears to be the design-inspiration (thus
predecessor) of all of Bolger's "states-class" power-sharpies (and of course SneakEasy).
Settle in for a good long read (early 20th century prose was long-winded!!)
These are informative of how getting speed was an obsession in the first days of internal-combustion
power --, and how it really was for the "inventor" even more than the schooled Naval Architect, to
come up with breakthru concepts.
And they are a hoot to read! What amazing prose-style.... Of course, Hickman was contentious and a
real rascal -- had NO public-relations skills -- a true "Flamer" but in PRINT not just thru
e-mails... there for posterity to read (and chuckle at???)
These articles are now in the YahooGroup "Bolger - Phil Bolger's Boats" , under "files" in the new
folder "Hickman's Viper"
Enjoy. (heck, there's even a very complete "how to build a Viper" article with offsets AND enough
construction details to construct one in the old plank-on-frame method -- reading THAT will
certainly make us appreciate Bolger's plywood "box-boat" methods...)
And throw up your own ideas/feedback... whatever bubbles up from your reading of this early
pioneering work.
Wayne Gilham
Sent: Tuesday, April 24, 2012 1:46 PM
Subject: RE: [bolger] FOR SALE Bolger Idaho -- and its predecessor, Hickman's "Viper"
AHA! looks like there's an add-on of horizontal "spray-boards" at gunwale forward -- exactly what
Albert Hickman had on "Viper", the 1907 flat-bottom power sharpie that may have been
Bolger's inspiration for this whole fleet of "states-class" boats.
Any comments from Roger (please!), why his splash-boards were added (I presume the flat sides can
give a lot of spray at some wind-angles...) and what effect it had?
On the one long visit with Phil way back in 1982 - that I treasure - he proudly pulled out all the
old feisty "rudder magazine" articles from Hickman, which articles extolled the virtues of the first
"Viper" and (in Hickman's in-imitable grating form) derided all detractors -- great early 20th
century writing!
This original Viper was a long, slender flatbottom.
Length: 20'2"
Beam: 3'6"
Slight rocker: 2-1/4" over 20 ft.
Speed: 3hp= 8mph
7hp= 14.3mph
12hp= 18mph
His subsequent "Viper II" and "Viper IV" played around a bit with the length/beam ratio, but didn't
change much...
Sounds familiar?? Awfully close to "SneakEasy"... or "Tennessee" -- or (of course) "Idaho"
To show the genesis, I have in my files, a two-sheet BOLGER plan, Design #358, with all offsets and
construction details, for a 20'2" x 4'3" flat-bottom slab-side inboard-powered sharpie specifying a
Yanmar 2qm15G inboard (rated 14hp) -- this plan clearly includes the note in Phil's simple/elegant
printed hand, at the bottom of each sheet (next to title block): "Rework of design by Albert
Hickman, 1910" -- so obviously Bolger puts some credence in Hickman's design, to go to all that
effort, to essentially "re-create" this historical boat. Wonder if was ever built??
By the way, THIS Bolger design incorporated similar but much wider and much longer "spray-boards"
than I see on the "Idaho" now for sale, sticking nearly 8" out from the gunwale by the fourth spaced
12" station, and tapering back to only disappear at the twelfth station, thus more than half the
length of the boat! That duplicates the original "Viper" pretty closely...
Bolger also designed around the same time a very similar but larger boat called "Firebrand" to make
use of a client's steam engine -- He thought it would also work to get some creditable speed out of
one of those heavy slow-turning long-stroke Palmer ZR t-head gas-engines, which I owned at the time
-- that was the purpose of our meeting, to discuss what sort of boat might work for this gem of an
old engine. Unfortunately, I lost the engine in a warehouse fire some years later.
I was going to put a link here, to ANY sketch / photo / details of "Viper" that might be on-line,
only to find that (although many blogs or websites REFER TO "Viper" as an important milestone in
boat design) actually there's nothing in the way of a photo out here in the ethers....
So I guess it falls to me, to post the many many many pages I have subsequently copied from 1910 and
1911 "Rudder" (found at the Seattle Library's great marine collection) about this design -- which
include LOTS of photos! -- maybe in one of the Bolger photo files? stay tuned...
Wayne Gilham
p.s.: Hickman went on to "invent" and (finally) successfully market the "Sea Sled" - considered by
Dave Gerr to be the most efficient offshore-suitable hullform ever developed - and a clear
predecessor to the Boston Whaler... He also was the first to actually "make work" surface-piercing
propellers! quite a brilliant mind. worth a Google-hour or two.
Eric
> Good morning
> From: c.ruzer
> CATALYST
> TREE DEATHS
> "NARRATION
> Dr Craig Allen
> NARRATION
> Dr Craig Allen
> NARRATION
> Dr Craig Allen
> Dr Craig Allen
> NARRATION
> Dr Craig Allen
> Related article:
> 15 Mar 2010: Report
The pine pitch chewbacca defence
http://rationalwiki.org/wiki/Trees_cause_pollution
--- Inbolger@yahoogroups.com, "mkriley48" <mkriley48@...> wrote:
> the scent of a pine tree and the stench of a diesel truck exhaust
> are both hydrocarbons, which one do you want up your nose?
> Seams like your dad was a tea bagger ahead of his time.
> mike
> > In a conversation I had with my dad forty years ago, he said to me "Son, this eco crap will be the new communism. It will be how the 'special people', you know, the people that 'know best', will tell the rest of us how to live. Dad was right.
> > 'Carbon Footprint'? I don't know how that figure from Australian forests and plantation came about but a study was done in New Jersey a while back that showed the Pine Barrens put more hydrocarbons into the air every week than all the trucks on the NJ Turnpike put out in a year.
Very late great Vonnegutian that. Kurt, knowing stuff about the species had also concluded emphatically that we're done for by this "stupidity" well before most others that have concluded similarly. IIRC, last century, mid-nineties, he was saying in lectures that we'd, true to form, already "missed the bus" on climate catastrophe. He was attacked for being a depressive etc by some without acknowledgement of his reasoning or proven insight into the human condition - another instance of the denialerati proffering a Chewbacca defence of business as usual.
http://www.youtube.com/watch?v=6Xywqv1cDH8
http://www.abc.net.au/rn/features/inbedwithphillip/episodes/127-kurt-vonnegut/
Yet, while there's life there's hope. "Do not go gently into that goodnight..."
--- Inbolger@yahoogroups.com, "RSS" <otter55806@...> wrote:
> In the end it won't matter, because due to overwhelming human stupidity we are all toast! We are arrogant and think we deserve to have everything the way we want it. What we seem to want now is to overpopulate and over consume everything. We are just another species of animal on this planet and we will go extinct just as many species have before us!
Clutched belt-drive for the e-motor if diesel is still in place ?
Sent:Friday, April 27, 2012 9:03 AM
Subject:Re: [bolger] Sustainability (world-wide forest die-off now) (was Re: Lightweight marineply)
Good morning
Sent:Friday, April 27, 2012 8:38 AM
CATALYST
TREE DEATHS
"NARRATION
Dr Craig Allen
NARRATION
Dr Craig Allen
NARRATION
Dr Craig Allen
Dr Craig Allen
NARRATION
Dr Craig Allen
Related article:
15 Mar 2010: Report
RIGHT ON SUSANNE !
Sent: Fri, Apr 27, 2012 9:10 am
Subject: Re: [bolger]Screw Sustainability (and the rest of the green stuff) (was Re: Lightweight marine ply)
May want to try though...before opting out of solutions for good.
Of course some find the Mayan-Scenario quite attractive...giving it , say, 7-8 months.
On the other hand, how many times has Nostradamus been quoted for 'certainty'...?
So on with the effort !  What else is there to do ?
Sent:Friday, April 27, 2012 8:58 AM
--- Inbolger@yahoogroups.com, Greg Kay <gregmkay@...> wrote:
> The environmental concerns and future fuel prices are certainly important, true, but the primary and most immediate concern is your own life and the lives of your passengers; use whatever wood it takes, no matter where it comes from, to make the soundest boat you can afford.
> Both ecologically and economically, too much cutting corners in the name of the latest "green" obsession can also be "penny-wise and pound-foolish." Using less than proper wood often translates to your boat not lasting as long, meaning you'll have to use more wood to build yet another boat when this one finally fails (Kind of like the morons who splash old ladies' fur coats with paint to "protect the animals," when what it actually means that she'll just go and buy another one instead of keeping the one she has.). It would seem that, given the choice, a boat that lasts a lifetime is better for both the environment and the pocket book than having to build three or four in that same period, no matter what the sounder boat is made from.
> In the end, it's your boat, and you should build it the way you want. If something you need is legally on the market and you can afford it, by all means buy it and use it; there is no moral onus on doing so.
Recent Activity:
    - NO "GO AWAY SPAMMER!" posts!!!  Please!
    - Unsubscribe: bolger-unsubscribe@yahoogroups.com
    __,_
    Good morning
    CATALYST
    TREE DEATHS
    "NARRATION
    Dr Craig Allen
    NARRATION
    Dr Craig Allen
    NARRATION
    Dr Craig Allen
    Dr Craig Allen
    NARRATION
    Dr Craig Allen
    Related article:
    15 Mar 2010: Report
    CATALYST
    TREE DEATHS
    "NARRATION
    Dr Craig Allen
    NARRATION
    Dr Craig Allen
    NARRATION
    Dr Craig Allen
    Dr Craig Allen
    NARRATION
    Dr Craig Allen
    Related article:
    15 Mar 2010: Report
    Timber, trees... will become more scarce. Plant lots. Look after 'em. Great idea, good investment.
    --- Inbolger@yahoogroups.com, "Ed Drapela" <edrapela@...> wrote:
    > If want to be "green" don't build a boat. If you have a lick of common
    > sense and are worried about sustainability, plant a tree. My place has 4
    > new Maples and 3 new Black Walnuts. That's hell of lot more wood that I
    > will use on my next boat.
    > Cheers,
    > Ed
    CATALYST
    TREE DEATHS
    "NARRATION
    Dr Craig Allen
    NARRATION
    Dr Craig Allen
    NARRATION
    Dr Craig Allen
    Dr Craig Allen
    NARRATION
    Dr Craig Allen
    Related article:
    15 Mar 2010: Report
    Indeed it is the biggest domestic consumer of fossil-fuel.  One of the many running-costs of living the hyper-consumption life-style requiring 'presence' and 'reach' to maintain the access to and transport of respective resources.  Heck, US MCM-class wood-composite Ocean Minesweepers of 1450tons find their way circling the globe ??
    But with for instance powerful European economies with only somewhat lower such habits much less able/willing to guarantee that 'presence' and 'reach', the strategic and thus fiscal burden falls upon the US.  'Swords into plow-shares' piety there - but not necessarily here...since someone has to pick up the slack.
    Good thing that as the global 'Reserve Currency' you can recover 'the investment' some with a few nips and tucks here and there on the exchange-rate, inflation-rate, etc.  Old Shtick.  Still works.  Side-effect is that China holding 'Notes' may not be a good 'investment' for China...May decline in value as the imported gadgets wear out.
    In Phil's family from his brother's volunteering to the Navy in 1940 to control his WW-2 experience, over Phil '46-47 in Japan, until today, someone has always served serious uniform-time, apparently from 'quiet spook-duty' to a full-tilt Captain-rank running the maintenance of the air-craft on a Super-Carrier.
    Meanwhile in the happy world of designing boats and building them, being able to contribute a tiny speck of 'input' is just fine: 'It takes all kind'.  "Plywood, Susanne ??"   "Yep."    "You've got to be kidding with your talk about plywood-jobs ?!"  "Well, we did some concepts in steel and alu as well...   Some with rather intriguing geometries to cut fuel-burn by serious numbers.  We'll see what happens with that."
    Sent:Thursday, April 26, 2012 7:31 PM
    Subject:Re: [bolger] Sustainability (was Re: Lightweight marine ply)
    Its a joke saying the US military is going green.  Its the biggest emitter of gases and radiation on earth.
    Sent:Thursday, April 26, 2012 1:35 PM
    I should have added my appreciation that you brought to the discussion these excerpts from your well-evolved understanding of this issues on your continent 'down-under'.  As implied by my post, you confirm the wide-spread understanding that focused regional responses to overarching challenges is the most promising approach.  No one-dictate-fits-all, except that we all live on the same globe and can't argue out of that hard fact once we share/imposed upon each other the costs of certain earlier and current on-going life-style choices.
    Not knowing is one thing that was true several decades ago and excused inactivity.  But Phil and I argued this stuff in-house before we got together, i.e, 20 years ago.  And like for so many, who figured certain hard realities well before we 'woke up', it's been clear for a good while now that emerging hard data literally force appropriate action.  And Phil always thought of 'lean' solutions, good-looking or not, as long as it works...
    The US Navy aiming for one 'green'-fueled Aircraft-Carrier-Group by 2020 is one most serious political and technical indicator, defining 'green' asnon-carbon-emittingnuclear-reactor-based drivetrain on the carrier running for decade-plus on one set of fuel-rods making these the fastest man-made structures across the broadest range of sea states at 40+ kts on 100,000tons.  The gas-turbine based destroyers of that Carrier-group would burn sustainably-sourced fuel, currently tested on ships and aircraft.  Subs are all nuclear.  VTOL-carrier dock-landing LHD-8 at 40,000tons is the largest conventionally-powered surface type and the latest such example of fine-tuning the challenges and routines of burning less fuel.  We'll eventually see what this actually costs, first and last.  And how 'green' it really is.  But the signal is unambiguous.  The Pentagon does not follow 'pinko eco-weeny' clap-trap...
    Down here on the 'Nano'-level, such thoughts have their place as well, as I'd rather have options to pursue a broad range of 'doing the right thing' than face regulatory dictates.  And since one of Phil's legacies is the persistent respect for and design of de facto low-carbon types for human-power, power and sail, there is a lot to maximize upon.  Obviously, this goes far beyond 'Instant-' or 'box-boat' fixations...and deep into the 21st century.
    Sent:Thursday, April 26, 2012 12:45 PM
    Thanks.
    There are indeed some fishers for instance who'd consider motor-sailing again for certain fisheries, assuming the sailing-related cost does not eat up any plausible savings in fuel...  Federal regs. favoring 'greenest' commercial fishing types would help.  We'll see how that evolves.  Any halfway successful 'green' project makes that thinking more plausible.  Under the current Obama-Administration NOAA (Natl. Oceanograph. Atmosph.Admin.)  also governing fishing is certainly aware of the favorable political opportunities that would emerge from R&D into Low-to-Least Carbon Fishing-Types.
    Sent:Wednesday, April 25, 2012 10:03 PM
    Subject:[bolger] Sustainability (was Re: Lightweight marine ply)
    --- Inbolger@yahoogroups.com, <philbolger@...> wrote:
    > There sure seems no way to go 'green' boat-structurally here in the North-Eastern US while slicing tropical woods - whatever the pious 'sustainably-sourced' claims plus the inevitable carbon-footprint of transport. Lucky for folks in the Northwest of the US.
    > Eventually, New England will be doing its own regional marine-grade plywood again to avoid trans-continental ply-trucking/rail-voyage. There are decent tree-species hereabouts to do this with. But no remaining plywood-mill in the region for the moment, except for one in Quebec. But we'll get one yet.
    Excellent - keep on pushing for that - more power to you! The "carbon-footprint of transport" certainly is a deep one. One answer, wooden sailing ships? I agree 'sustainably-sourced' claims can be "pious", or greenwash, so it's important that their credibility is tested.
    From page 2 of the 36 page Boral Plywood Handbook brochure (July, 2009):
    Australian plantation
    and commercial forests
    absorb an amount of
    carbon equivalent to
    taking 9 million cars off
    the road each year.1
    For further information on timber and its
    sustainability credentials contact Boral Plywood and
    ask for the Building a Sustainable Future brochure.
    Timber and Sustainability
    Excess carbon gas in the earth's atmosphere
    contributes to the effects of climate change. Forestry
    is one of the best carbon sinks and long-term carbon
    reservoirs on the planet.
    Unlike other building materials, wood can be harvested,
    re-grown and re-harvested in an average person's lifetime.
    Furthermore, finished wood products store carbon for
    many decades, sometimes centuries.
    Timber has one of the lowest embodied energy ratings
    of all building products. Compared to other common
    building materials, timber generates much less carbon
    in the production process. Other building materials
    such as steel and aluminium do not store carbon and
    can contribute significant amounts of carbon to the
    atmosphere during the manufacturing process.
    Australian plantation and commercial forests absorb an
    amount of carbon equivalent to taking 9 million cars off the
    road each year.
    Australian forests are protected by strict Federal and
    State controls and regulations ensuring that there is a
    healthy balance between long term conservation and
    sustainable forestry management.
    Only 6.3% of total Australian forests (9.4 million
    hectares) are available for timber harvesting each year. Of
    the forestry available for harvesting only 1% is harvested
    each year.2
    When specifying for a sustainable future and a smaller
    carbon footprint, architects, builders and consumers
    should consider the following recommendations
    • Consider timber products wherever possible. Together
    with good design, lightweight timber construction is
    generally a better option in terms of embodied energy
    and carbon storage.
    • Keep in mind the impact of disposal. Of all building
    products, timber presents the least number of
    concerns when it comes to reuse or disposal.
    • Choose certified, legal products.
    • Specify Australian products. Australia has a world-class
    forestry regulatory system which can be trusted.
    Table 1.0
    Material Carbon released (kg/m3) Carbon stored (kg/m3)
    Timber products 15 250
    Steel 5,320 0
    Concrete 120 0
    Aluminium 22,000 0
    Forest and Wood Products Research and Development Corp, 1997. Figures indicated for guideline purposes only. The figures are a measure directly related to manufacture of material.
    Timber is renewable, recyclable and sustainable.
    To which I would add that certification by the FSC (Forest Stewardship Council) is most highly desirable. Especially if foreign sourced. More so if of tropical/sub-tropical sourced timbers.
    http://www.fsc.org/
    http://www.fscaustralia.org/
    http://en.wikipedia.org/wiki/Forest_Stewardship_Council
    The Boral brochure quoted above states that Boral Plywood is certified by The Australian Forestry Certification Scheme (AFCS). AFCS is a forest certification scheme developed to promote sustainable forestry management specifically for the Australian environment. AFCS is mutually acknowledged by the internationally recognised Program for the Endorsement of Forestry Certification (PEFC). The AFCS is the only forest certification scheme with an Australian Standard AS4708-2007.
    http://www.forestrystandard.org.au/
    http://en.wikipedia.org/wiki/Programme_for_the_Endorsement_of_Forest_Certification
    http://en.wikipedia.org/wiki/Forests_of_Australia
    mike
    > As for our own 'sustainability', you speak of the NorthEast and I'm quite familiar with New Hampshire. Approximately 110 years ago the state was 75-80% cleared farm land. Today it's 80+% forested. So things can bounce back.
    > You mention that there's 'no way to go green structurally'; I don't know what you think you need, but I've built eight boats, everything from a large pirogue and an airboat, to a version of Mr Bolger's SneakEasy. All I've ever needed for the frame was Southern Yellow Pine. I've never had a problem with fastenings or anything else.
    > From: c.ruzer <c.ruzer@...>
    > Sent: Wednesday, April 25, 2012 10:03 PM
    > Subject: [bolger] Sustainability (was Re: Lightweight marine ply)
    > Â
    > absorb an amount of
    > road each year.
    > each year.2
    > and carbon storage.
    > Table 1.0
    > Steel 5,320 0
    > Concrete 120 0
    > Aluminium 22,000 0
    >http://www.fsc.org/
    Thanks.
    absorb an amount of
    road each year.
    each year.2
    and carbon storage.
    Table 1.0
    Steel 5,320 0
    Concrete 120 0
    Aluminium 22,000 0
    http://www.fsc.org/
    Our home and office plus shop are all in one two-story cube, almost 'there' with super-insulating, and typically burn under 200gals of oil-equivalent heat/year here in solid New England winters.  We do not commute.
    No, we have no paperwork pending towards 'sainthood'.  But if you can do such basics, it all helps.
    Sent:Thursday, April 26, 2012 3:27 PM
    Subject:Re: [bolger]Screw Sustainability (and the rest of the green stuff) (was Re: Lightweight marine ply)
    In the heating industry we're starting to consider biofuels such as vegetable diesel or pellet stoves the most sustainable with the lightest carbon foot print.  with traditional oil or natural gas (or coal) you're dragging up carbon that's been sequestered for eons and releasing it into the atmosphere.  with the biofuels, they pull existing carbon out of the air to grow and so essentially "net zero" on the carbon scale.
    I leave electrical out of the mix because we produce so much of it using coal, oil and gas.  Then we compound the problem with the distribution grid losses.
    50 percent of the energy used in this country is to heat and cool buildings and homes.  conservation through more efficient design and retrofit is the least cost/most effective way to address the energy and carbon issues.
    Kudos Suzanne on being part of at least a partial solution.
    Tom
    Sent from my iPad
    On Apr 26, 2012, at 7:14 AM, <philbolger@...> wrote:
    As a commercial proposition for both USN and for instance commercial fishing all the romantic conspiratorial lingo you father educated you with is just that.
    We are talking hard numbers here and necessary fiscal-, business- and political plausibility if any such water-borne commerce are to cope with what is happening in the energy-market, regulatory realm (fishing), or just what the Department of Defense states in its Quadrennial Defense Review 2010 fully embracing and increasingly responding to as the unambiguous reality of climate-change and progressively challenging energy-prospects.
    While there won't be plywood aircraft carriers or destroyers, economic and ecological realities are serious enough  to produce R&D efforts even deep in the Pentagon.  And of course USN runs a fleet of 80-90s-era 1450-tons wooden frontline surface combatants.
    Here in Gloucester, MA.USA, both commercial fishing and tourism-fleets - typically built for $1/gal - will not be economically viable unless they adapt to $5/gal (as we had already in 2008).  What you do in your pleasure-craft likely matters little as it is neither here nor there, unless it is a 'high-carbon' type that won't run much anymore 'for fun' at $5/gal.
    As to trees growing, the vector of CO2 is outpacing any capacity to fight its ill effects.  And we can indeed distinguish between the sources of these massive negative alteration to the chemistry of our atmosphere.  Yes, trees grow faster yet with that extra dose of CO2 but the rest of the uglies that come with it overshadow everything.  So while there are more trees again in NH - a fraction of the original stock of course - the local, regional, national, global cost of hyper-consumption of non-renewable energy and materials will be with us and increasing far beyond our life-times.  That is without fretting over fiscal 'debt' that is loaded on the next generation's back.  None is sustainable by the measure of the most hard-core MBA Math-heads and their spreadsheets.
    What Phil and then both of us had on the brain is indeed plausible minimalism where doable.  And that thinking attracted USN and DMF and quite a few of his and later our clients.  There's always more to learn.  But you got to 'do it' versus dismissing the challenges on whatever level of analysis.  Being part of the urgent quest for solutions...
    Sent:Thursday, April 26, 2012 1:45 AM
    absorb an amount of
    road each year.
    each year.2
    and carbon storage.
    Table 1.0
    Steel 5,320 0
    Concrete 120 0
    Aluminium 22,000 0
    http://www.fsc.org/
    Tom
    Sent from my iPad
    absorb an amount of
    road each year.
    each year.2
    and carbon storage.
    Table 1.0
    Steel 5,320 0
    Concrete 120 0
    Aluminium 22,000 0
    http://www.fsc.org/
    Thanks.
    absorb an amount of
    road each year.
    each year.2
    and carbon storage.
    Table 1.0
    Steel 5,320 0
    Concrete 120 0
    Aluminium 22,000 0
    http://www.fsc.org/
    Thanks.
    absorb an amount of
    road each year.
    each year.2
    and carbon storage.
    Table 1.0
    Steel 5,320 0
    Concrete 120 0
    Aluminium 22,000 0
    http://www.fsc.org/
    Meanwhile new seedlings grow out of that forest-floor to eventually supply the next hull...  But you've got to let it grow indeed in its forest ecology.
    Sawing that tree into planks might allow for three hulls per cut tree.
    Sent:Thursday, April 26, 2012 9:48 AM
    Subject:RE: [bolger]Screw Sustainability (and the rest of the green stuff) (was Re: Lightweight marine ply)
    A friend of mine is a film documentary maker, in recent years, he was
    working with original native people of South America. They have been around
    here for thousands years... then the europeans "discover" América :)
    To make a small canoe for fishing, they didn t "kill" a tree, the look for a
    fallen one, with only a small axe in 9 hours one person make a boat. That s
    the most "green" amateur boatbuilding I know :)
    link to a photo
    http://www.atriunfar.net/fotonoticias/Fotos/1275343213_culturahoy3.jpg
    Máximo
    absorb an amount of
    road each year.
    each year.2
    and carbon storage.
    Table 1.0
    Steel 5,320 0
    Concrete 120 0
    Aluminium 22,000 0
    http://www.fsc.org/
    link to a photo
    Máximo
    Let's agree that building any boat for recreational purposes, especially using modern materials, is by definitionnot"green", regardless of propulsion method. If you build a boat, unless maybe you are building a curragh from woven willow branches and covering it with the hide of your just-slaughtered grass-fed cow, you are going to kill a tree and/or mine a mountain for coal, iron, aluminum, copper and tin, and/or use hydocarbons pumped from deep in the ground and refined in a chemical plant, for nothing more than your selfish enjoyment.
    However, thoughtful selection of woods, method of construction employed and materials used may make the process "green-er" just as altering fishing methods and tools used to collect the fish may make commercial fishing more sustainable and thus greener.
    I will now go back to selfishly looking forward to participating in the Wood Boat Regatta (coming soon) up in May, while painting my Reuben's Nymph with oil-based paints and cleaning up my Whalewatcher Utilis. I shall lose no sleep in doing so. In fact, I will sleep better.
    From:bolger@yahoogroups.com [mailto:bolger@yahoogroups.com]On Behalf Ofjames fry
    Sent:Thursday, April 26, 2012 1:46 AM
    absorb an amount of
    road each year.
    each year.2
    and carbon storage.
    Table 1.0
    Steel 5,320 0
    Concrete 120 0
    Aluminium 22,000 0
    http://www.fsc.org/
    That is a most peculiar line of 'reasoning'.
    Nobody who ever built a wooden boat has ever been kept from closing the circle and indeed plant saplings to match the equivalent in the boat once these trees reach maturity, hopeful just as your current boat is going 'soft' and those tree will 'yield' the material for the next one.
    Good thing that trees grow 'by themselves', not subject to political musings...  or personal definitions of 'licks' or 'common sense'...
    P.S. Thanks for your delight in and respect for in this unusual project.  Share yours with us.
    Sent:Thursday, April 26, 2012 8:40 AM
    If want to be “green” don’t build a boat.  If you have a lick of common sense and are worried about sustainability, plant a tree.  My place has 4 new Maples and 3 new Black Walnuts.  That’s hell of  lot more wood that I will use on my next boat.
    Ed
    From:bolger@yahoogroups.com[mailto:bolger@yahoogroups.com]On Behalf OfNeal Sandidge
    Sent:Thursday, April 26, 2012 2:35 AM
    The apple doesn't fall far from the soon-to-be logged tree.
    Neal
    Date: Wed, 25 Apr 2012 22:45:49 -0700
    absorb an amount of
    road each year.
    each year.2
    and carbon storage.
    Table 1.0
    Steel 5,320 0
    Concrete 120 0
    Aluminium 22,000 0
    http://www.fsc.org/
    I'd be careful with that Australian wood. Sure, the price is right and the veneer looks grade A. But I've got some where the inner ply was pure Kangaroo. And one time it was even worse. Koala Bear.
    Ed
    From:bolger@yahoogroups.com [mailto:bolger@yahoogroups.com]On Behalf OfNeal Sandidge
    Neal
    absorb an amount of
    road each year.
    each year.2
    and carbon storage.
    Table 1.0
    Steel 5,320 0
    Concrete 120 0
    Aluminium 22,000 0
    http://www.fsc.org/
    Neal
    absorb an amount of
    road each year.
    each year.2
    and carbon storage.
    Table 1.0
    Steel 5,320 0
    Concrete 120 0
    Aluminium 22,000 0
    http://www.fsc.org/
    absorb an amount of
    road each year.
    each year.2
    and carbon storage.
    Table 1.0
    Steel 5,320 0
    Concrete 120 0
    Aluminium 22,000 0
    http://www.fsc.org/
    absorb an amount of
    road each year.
    each year.2
    and carbon storage.
    Table 1.0
    Steel 5,320 0
    Concrete 120 0
    Aluminium 22,000 0
    http://www.fsc.org/
    There may be different ways of using and applying epoxy to build up a decent thickness.  We went with all WEST.  Typically gravity-applied.  No vacuum-bagging or other exotics.
    We used 10oz glass-cloth over all outside surfaces, 2 and 3 layers of 10oz glass-cloth over all hull pieces below sheerline, with all episodes/pieces with the weavesoaked level,not the glass sanded-down.  Ergo most thickness per layer of glass.  We sanded epoxy-ripples - not glass-cloth.
    This was possible by building everything (!) from smallest to biggest panels in pieces on tables/across horses.  Flat everything, and typically finished horizontally to at least a solid first coat of final paint.  No drips or runs in paint or epoxy.  Gravity as your friend.  With epoxy leveling out to near perfection - but never without a few bubbles here or there; as Phil would say "the gods would be jealous..."
    Heavy epoxy coat on all inside surfaces.  Plus along much of her topsides closed-cell foam plus ply with epoxy in between everything.
    We got better at wet-in-wet epoxy + glass + epoxy sequencing for a manic but single episode efforts to get the lamination down.  Full-length hull-bottom in one shot was strenuous and required 3 folks plus 1 on the big-$$$ #309 5:1 gear-pump.  No such work without the 309.  Pays for itself as the sticker-shock wears off...
    And no rollers, disposable or alu.  A few 1" cheapo brushes for selected vertical and horizontal cleat-fastening during assembly into 3-D structure for applications.  Ergo limited use of acetone for cleaning.
    Average shop-conditions, limited budget, with reasonable 'back-up' provisions, such as the aforementioned double-skinning of all outer hull-surfaces against eventual dramatics, should glass-shredding gouges go unattended.  Rot should at worst only travel half-depth.  Taking out/grinding off damaged/rotting/offending patches/sections of the first layer would not be a terrible challenge to then re-laminate to re-establish full skin-thickness.
    One way to do this.  And it does indeed take a lot of epoxy.
    But we traded 'costly' thickness built-up fast horizontally for costly man-hours doing 6 coats with its wiping and sanding regimes each time and 'hanging upside from the rafters' while likely eventually burning through the same epoxy-bill.
    Susanne Altenburger, PB&F
    Sent:Wednesday, April 25, 2012 2:12 PM
    Subject:Re: [bolger] Re: Lightweight marine ply
    Eric, I don't know why you'd say epoxy doesn't seal out moisture. I used to live on the Jersey shore and about 25-27 years ago I used W.E.S.T. epoxy system to put together three small boats. When I was back up there 18 months ago, I tried looking them up. Two were still afloat and being used. I couldn't find the other people or what happened to that skiff. This stuff saturates the wood and the finish is like a fibre-glass resin. The only thing done to the boats still in use was to give them a W.E.S.T. coat every 6-8 years.
    If epoxy didn't seal out moisture, as opposed to just water, it would be totaly useless as there are small voids and pockets of air even in the most solid wood.
    Jim
    Sent:Wednesday, April 25, 2012 1:35 PM
    Subject:[bolger] Re: Lightweight marine ply
    A question. Regarding voids in marine and other plywood used in a boat's hull and decks, is there a problem caused by water vapor condensing in the voids in the cold climate of New England and cold West coast waters? Epoxy will not seal out moisture, only water. A high humidity interior would drive moisture toward the cold. It seems moisture would penetrate into the plywood and precipitate out if the dew point happened to be where the void was. Does anyone have an experience or real information about this possibility?
    Eric
    > On the SACPAS-3 project I used only domestically farm-grown Douglas Fir ply, well-understood, no pretty grain, fairly non-toxic, with a fully-known environmental-impact trail, quite affordable at $91.- for 1", well under $50 for 1/2" etc. from a local dealer. The 1/4 stuff kept 'smiling' a us with 'wild grins', but even on the flat roof its smirk soon turned into a 'stiff upper lip', level and straight. Despite 'Marine-Grade' stamp there are core-voids here and there, but at the load of epoxy and glass on this job, I'd expect little drama long-term, particularly with bottom and side double-skinned. On a government job staying all domestic, affordable and non-experimental is a safe bet. The project itself had enough hair-raising episodes anyway...
    > From: c.ruzer
    > Sent: Wednesday, April 25, 2012 8:42 AM
    > Subject: [bolger] Re: Lightweight marine ply
    > I wonder what part of Borneo or West Papua is being denuded in the supply of this stuff. I rather hope none, save the whale and all, but as it seems to be China sourced I won't be holding my breath that the "light weight" is due to some SE Asian plantaion grown Paulonia spp or somesuch. http://www.goldcorelight.com/specifications.htm - that BS1088 standard is beyond meaningless in the Australian context. Is the weight all that less than Oz plantation grown hoop marine plywood anyway (38% seems a stretch)? Such Oz marine plywood conforms to the superior and meaningfull AS/NZS2272, and is as likely manufactured to F14, and may carry a 40 year bond warranty. I'd guess that the Goldcore Light interior veneers should never be exposed to water, never, and that may be a big ask in a small boat. It's not cheap. Lightness up high is something, but I don't understand how the strength can be had by increasing thickness by one millimetre. It seems that a jump to the next standard size, so from 6mm to 9mm etc, is mandated. That, or increased supporting frame and stiffening members, and either would seem to cancel the Goldcore alleged 38% weight advantage - and cost more.
    > --- Inbolger@yahoogroups.com, "Andrew" <a.c.l.yen@> wrote:
    > > My Chebacco 25 hull is finally up the right way. I had a party for friends, relatives and the wooden boat club, gave everyone a rope, or piece of wood and we had it off it's building frame right way up on its trailer in 40 minutes. I'll post some photos when I get time.
    > > Now I have to get serious about decks, cockpits, carlins, beams, frames etc. In shopping for suitable plywood I have come across "lightweight marine ply" (seewww.goldcorelight.com). I have obtained a sample and am impressed with the quality (no voids, nice face veneers)and the lightness of the product. It feels not much heavier than balsa wood yet gives the impression of being plenty strong enough.
    > > The strength grade is F7 - which means a designed working stress of 7MPa. I did a bit of research that suggests that this is not as strong as "standard" ply but that adding a mm to the thickness will compensate for the lower strength:
    > > http://oak.arch.utas.edu.au/tbia/view_article.asp?articleID=133
    > > It isn't cheap at A$71 for 6mm, A$94 for 9mm and A$112 for 12mm but these prices are comparable with good Gaboon marine ply.
    > > Has anyone used it or have opinions about lightweight ply for "above waterline". I figure that lighter sheets are easier to handle and will reduce the weight of the boat by some 50kg or more.
    > > Andrew
    > >http://sites.google.com/site/warrandytewoodenboat
    Jim
    Eric
    > From: c.ruzer
    > > Andrew
    Eric
    > From: c.ruzer
    > I wonder what part of Borneo or West Papua is being denuded in the supply of this stuff. I rather hope none, save the whale and all, but as it seems to be China sourced I won't be holding my breath that the "light weight" is due to some SE Asian plantaion grown Paulonia spp or somesuch.http://www.goldcorelight.com/specifications.htm- that BS1088 standard is beyond meaningless in the Australian context. Is the weight all that less than Oz plantation grown hoop marine plywood anyway (38% seems a stretch)? Such Oz marine plywood conforms to the superior and meaningfull AS/NZS2272, and is as likely manufactured to F14, and may carry a 40 year bond warranty. I'd guess that the Goldcore Light interior veneers should never be exposed to water, never, and that may be a big ask in a small boat. It's not cheap. Lightness up high is something, but I don't understand how the strength can be had by increasing thickness by one millimetre. It seems that a jump to the next standard size, so from 6mm to 9mm etc, is mandated. That, or increased supporting frame and stiffening members, and either would seem to cancel the Goldcore alleged 38% weight advantage - and cost more.
    > > Now I have to get serious about decks, cockpits, carlins, beams, frames etc. In shopping for suitable plywood I have come across "lightweight marine ply" (see www.goldcorelight.com). I have obtained a sample and am impressed with the quality (no voids, nice face veneers)and the lightness of the product. It feels not much heavier than balsa wood yet gives the impression of being plenty strong enough.
    > > Andrew
    Sent:Wednesday, April 25, 2012 8:42 AM
    > Andrew
    > Andrew
    Congratulations, Andrew!
    Neal
    > Andrew
    Andrew
