RE: [bolger] Trim to retain seat cushion
Slightly off subject—In my neck of the woods, kids start playing baseball in January and dutiful parents get to watch while sitting on aluminum bleachers. When it is in the 30’s (about 0 C), the bleachers never get warm and sitting is uncomfortable. A solution is a back packers’ ethafoam pad. Putting it on the bleachers will keep you warm and attract as many friends as can squeeze onto it!
JohnT
From:bolger@yahoogroups.com [mailto: bolger@yahoogroups.com ]On Behalf OfDouglas Pollard
Sent:Saturday, April 28, 2012 11:22 AM
Subject:Re: [bolger] Trim to retain seat cushion
Along this same line of thinking.  After we moved off our boat I bought myself a rocking chair that I thought might simulate the motion of a boat and put a one inch cusion on it. ( pretty stiff ) This seemed to stop the hip problems I was beginning to have with hip and leg pain.  Now my wife has one, for the same reason with the same results.    For several friends who have elderly family members I bought used rocking chairs and lowered the seat so that the seat did not cut them in the back of the legs. All I can say is help them or not they are enjoying them.  I go to a doctor a couple times a year for low circulation problems in my legs. My Doctor is amazed that the problem has greatly diminished.  I modified a rocker for one of her patients.  My doctor claims I can likely thank my history of smoking (which I no longer do), for my circulation problems.  I think this is a health thing that being on a boat with it's movements and the right kind of cushions  might prove to be good for us all.     This of course is all speculation.            Doug
On 04/28/2012 10:34 AM, Roger Padvorac wrote:
Doug, this is really interesting. Now I know why I never liked thick soft cushions - thanks.
I sit comfortably for many hours a day on a computer chair with fairly thin, but stiff foam. On a wholesale level a major factor in the cost of foam is its weight because a foam that is twice as dense, has twice the expensive chemicals in it, and so costs twice as much to produce and then to ship as light foam does.
Cheap cushions have very light foam, don't provide much cushioning, but look thick and substantial and so sell well, especially because of their cheap price.
A thinner, but denser and stiffer (and more expensive) foam, will still provide adequate cushioning, and it will be less likely to squeeze the tail bone nerves because its dense and stiff and doesn't compress nearly as much as light foam does.
The best cushions use laminated foam, where you have a very thin layer of very soft foam (maybe 1/4" thick) on the outside, and then a thicker layer of stiffer denser foam on the inside. The most expensive cushions will tend to have 3 layers of foam, all with different densities and stiffness. This is much like a shock absorber for a car where there is a little bit of soft give, and then as compression increases it rapidly gets stiffer.
Sent:Friday, April 27, 2012 10:18 AM
Subject:Re: [bolger] Trim to retain seat cushionEric,here are some thoughts on holding cockpit cushions in place.  Trim that holds the cushions in place has a rendancy to bite into the backs of your thighs.  These are worse if it has rained and the cushions have been removed.  My  wife has made many cockpit cushions. She puts two straps on the back of the cushion one for each snap. We put two snaps in the coaming and snap the snap cap to it that has been installed in this strap. This keeps the cushion from sliding off.
    If they live aboard or spend long periods aboard many people develop hip problems. We found that sitting so much on foam cushions causes this sometimes.  The cushions push up around the tail bones and squeeze the sciatic nerve. We have found that no cushions in the cockpit or some in the cockpit no thicker than 2 inches greatly reduces this condition.  I know this sounds nuts but my wife has gotten high praise from some longtime cruisers for this piece of advice.
        Doug
Hi: For the stiff foam your wife doesn't like I have contact cemented two different foam densities together and on one mattress also tried a layer of the memory foam on top of the firm foam which was quite nice. The big problem in cooler climates is the condensing of body moisture in the mattress which one mattress company I visited was trying to eliminate with clear plastic and tuck tape. And then stuffing it into a mattress cover.
Depends on the foam density and thickness.
The berth cleats on my plastic boat dug in my legs bad,
After I made new cushions from top quality high density foam I never even felt the cleats. I loved my 4" thick 40# density cushions but they were too firm for my wife to sleep in comfort.
Put your foam blanks in and try a few different dimensions of cleat to see what you can get away with. Mock it up ashore if you can't do it in the boat yet.
BTW, my quick and dirty berth cushion method was...
Cut luan ply 2" smaller in each dimension than berth flat.
Cut the foam to shape with electric carving knife.
Couple spots of double side carpet tape to hold foam to board.
Then staple the upholstery cloth to the ply, just like a kitchen chair seat.
Just fold and tuck the corners. The tighter you pull the cloth the more "bullnose" you get in the cushion. If you get the foam a little rough at the cuts the "nerds" will telegraph through your cloth. You can pre-upholster with light cloth similar to peel-ply or with quilt batting to reduce print-through.
Justin
--- Inbolger@yahoogroups.com, "Eric" <eric14850@...> wrote:
> I am about to apply trim to hold the seat/birth cushions in place. Does anyone know how high above the seat edge the trim should be to retain the cushion but not impinge on legs?
> Eric
If you want I can measure cushions and the trim piece.
Tales was extensively remodeled in the early 80's by somebody who was
really good. I have her pretty torn apart right now refinishing what you
see in the photos. The remodel moved the cabin forward and made it a two
bunk off shore cruiser. The cushion retaining trim pieces fold down
across about two thirds of the bunk length, a couple of pieces of
plywood fit in and two of the back cushions fill in space to make a
double bed across the boat.
More interior Pics on Alberg site
http://albergsailboats.org/about-the-triton/national-triton-association/mir/project-show-case/185-144-tales-harry-a-mildred-james/222-144ps4.html
On 4/27/2012 9:07 AM, Eric wrote:
> Thanks Harry. Two inches total or above seat? How thick are your cushions? A relevant point as someone else pointed out. Mine are yet to be built. ROGUE's interior was never completed past the roughed in stage, and castaway stuff got me by while I decided upon final solutions. Though I considered using velcro, I decided against it because I want the finished look of trim, and because velcro attached cushions will interfere with the seat locker lids.
> You have a beautiful boat.
> Eric
> --- Inbolger@yahoogroups.com, Harry James<welshman@...> wrote:
>> Here is a pic of the interior of Tales, they are a little over 2"
>> HJ
>>> Eric
>>> Bolger rules!!!
>>> - NO "GO AWAY SPAMMER!" posts!!! Please!
>>> - no cursing, flaming, trolling, spamming, respamming, or flogging dead horses
>>> - stay on topic, stay on thread, punctuate, no 'Ed, thanks, Fred' posts
>>> - Pls add your comments at the TOP, SIGN your posts, and snip away
>>> - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax: (978) 282-1349
>>> - Unsubscribe:bolger-unsubscribe@yahoogroups.com
>>> - Open discussion:bolger_coffee_lounge-subscribe@yahoogroups.comYahoo! Groups Links
Mabe I'ot understanding the problem, but have you considered velcro?
Sent:Friday, April 27, 2012 1:18 PM
        Doug
Eric
        Doug
        Doug
        Doug
Eric
Eric
> HJ
> > Eric
Harry,
What kind of stove do you have there on Tales?
> Here is a pic of the interior of Tales.....
Try velcro on the back of the seat cushion.
> Eric
That sure looks sharp!
Mike Allison... (North of Kansas City Mo. USA)
Eric
- Unsubscribe:bolger-unsubscribe@yahoogroups.com- Open discussion:bolger_coffee_lounge-subscribe@yahoogroups.comYahoo! Groups Links
<*> To visit your group on the web, go to:http://groups.yahoo.com/group/bolger/<*> Your email settings:
<*> To change settings online go to:http://groups.yahoo.com/group/bolger/join(Yahoo! ID required)
<*> To change settings via email:bolger-digest@yahoogroups.combolger-fullfeatured@yahoogroups.com<*> To unsubscribe from this group, send an email to:bolger-unsubscribe@yahoogroups.com<*> Your use of Yahoo! Groups is subject to:http://docs.yahoo.com/info/terms/
Depends on cushion depth. Make some test strips using scrap and see what
works.
> Eric
Eric
