Re: AS29 bottom plating cost
What's the plywood for?
(Burgundy, 30-Odd)
I know we've addressed the question in this group of threads.
Maybe the ply layers could be reduced in the area of the shoe to buy down the shipyard plate?
Not really forwarding the discussion here at all, just sharing.
Justin
To:bolger@yahoogroups.com; bolger@yahoogroups.com
Sent:Thursday, May 31, 2012 2:21 PM
Subject:Re: [bolger] Re: AS29 bottom plating cost
Neal, from your original post it sounded as if you were planning to have the bottom plate manufactured as a single piece -- hence my concern that if the shape and curve of the bottom of the boat and the bottom plate are not identical you will have a major problem: e.g. if the curve of the bottom plate is either too shallow or too great, it will not mate with the hull -- and no amount of fairing compound will help. Hence the better option of eight separate sections that will allow for greater tolerance of inaccuracies -- and the judicious use of fairing compound! At the moment I'm stuck on the Wet Coast of Canada, building the masts and sails for the AS29. Deadline for launching: July 31. Don't expect to be back in Asia until
Oct/Nov. Regards Rod |
To:<bolger@yahoogroups.com>;
Subject:[bolger] Re: AS29 bottom plating cost
Sent:Thu, May 31, 2012 12:26:37 PM
| Exactly, Rod. That is specified in the latest version of the plans. You have to scribe the bottom curve in a piece of 1"X stock for each of the four plate stations. Then the steel provider uses that as a guide. Will this work? Not sure, but worse case scenario, we'll have to use a bunch of faIring compound to smooth out the lumps. When are you going to be in the Phil's? Let's get together and talk Bolger! Neal --- Inbolger@yahoogroups.com, Rod Symington <rodsymington@...> wrote: |
Neal, from your original post it sounded as if you were planning to have the bottom plate manufactured as a single piece -- hence my concern that if the shape and curve of the bottom of the boat and the bottom plate are not identical you will have a major problem: e.g. if the curve of the bottom plate is either too shallow or too great, it will not mate with the hull -- and no amount of fairing compound will help. Hence the better option of eight separate sections that will allow for greater tolerance of inaccuracies -- and the judicious use of fairing compound! At the moment I'm stuck on the Wet Coast of Canada, building the masts and sails for the AS29. Deadline for launching: July 31. Don't expect to be back in Asia until Oct/Nov. Regards Rod |
| Exactly, Rod. That is specified in the latest version of the plans. You have to scribe the bottom curve in a piece of 1"X stock for each of the four plate stations. Then the steel provider uses that as a guide. Will this work? Not sure, but worse case scenario, we'll have to use a bunch of faIring compound to smooth out the lumps. --- Inbolger@yahoogroups.com, Rod Symington <rodsymington@...> wrote: |
Neal
> Neal:
> The problem with "rolled to the contour of the bottom" is this: You will have to construct the hull precisely to the specifications in the plans and your steel manufacturer will also have to fabricate the steel plate precisely to the specifications also -- otherwise the two surfaces will not mate. And it won't be easy to guarantee that as Subic Bay is a long way from Bohol!
> The designer foresaw this problem: that is why he advised taking a pattern off the finished hull for the eight separate pieces...
> Good luck!
> Rod (AS29 builder)
Neal: The problem with "rolled to the contour of the bottom" is this: You will have to construct the hull precisely to the specifications in the plans and your steel manufacturer will also have to fabricate the steel plate precisely to the specifications also -- otherwise the two surfaces will not mate. And it won't be easy to guarantee that as Subic Bay is a long way from Bohol! The designer foresaw this problem: that is why he advised taking a pattern off the finished hull for the eight separate pieces... Good luck! Rod (AS29 builder) |
Subject:[bolger] AS29 bottom plating cost
Sent:Thu, May 31, 2012 4:58:28 AM
| We finagled a final price for the bottom plating from a shipyard in Subic Bay, Philippines. $2140 includes the 1/2" plate, cut to size with edges chamfered, bolt holes bored and countersunk, rolled to the contour of the bottom, sandblasted and galvanized. |
This is about 2/3 the cost of lead. More than double the price of scrap steel inside ballast, though. However, the bottom protection makes it worth it in my opinion.
Neal
