Re: Carlson's Hull Designer and Win 7 problem
I recommend you DON'T go to that link. It looks like a site that rips off shareware and probably adds spyware or other malicious stuff to it.
I wrote the program for fun and distribute it free (only here and up-to-date) on my business website (we build cutters for sailmakers):
http://www.carlsondesign.com/hulls.zip
Whatever may be new is there first and I don't have any relationships or permissions for redistribution, etc. Will let you know after looking at it.
Gregg Carlson
--- Inbolger@yahoogroups.com, "ch_bunch" <ch_bunch@...> wrote:
> Is there a way you can remove those posts with the bad link? I tried the download and install before I saw the warning that they are bad. Hope I didn't get infected.
I just tried it and it won’t install without installing Babylon which won’t happen here.
If you have access to a 32 bit version of vista or Seven it will probably work there. I support a DOS program that will run in either 32 bit Windows 7 or using the XPM mode on 64 bit windows 7.
MylesJ
Sent from my iPad
On Jul 10, 2012, at 7:55 AM, "Gregory" <gregg.carlson@...> wrote:
=I recommend you DON'T go to that link. It looks like a site that rips off shareware and probably adds spyware or other malicious stuff to it.
Gregg Carlson
--- Inbolger@yahoogroups.com, "slrrls2000" <slrrls2000@...> wrote:
> There is a new version compatible with win7 have you tried it?
>http://www.software112.com/products/carlson-hull-designer.html
> --- Inbolger@yahoogroups.com, gc4248@ wrote:
> > Gregg-
> > I tried the new Hulls 32 on a 64 bit Vista laptop. I have the following issues:
> > There is a white bar in the display that covers the bottom several inches of the model.
> > The table of offsets will not open.
> > Sometimes the results do not appear when doing a displacement calculation, other times it works fine.
> > Sometimes the heel function causes the model to flip over to the left, and "sunk or failed" appears at the bottom, other times it works fine.
> > --- Inbolger@yahoogroups.com, "Gregory" <gregg.carlson@> wrote:
> > > I don't have Win7, but I'll try to see if I can fix it. If somebody has success with the compatibility modes with either version, let me know -
> > > Gregg Carlson
Gregg Carlson
> > Gregg-
> > > Gregg Carlson
When you get a new version I'll give it a try if you'd like.
I have:
Dell Laptop Inspiron N7010
Windows 7 Home Premium
64-bit Op-system
6 GB RAM
Intel Core i5 @ 2.4 GHz
Ralph
> Gregg Carlson
> --- Inbolger@yahoogroups.com, "jdmeddock" <jmeddock@> wrote:
> > If you have Windows7 professional edition, you can download from MS a windows XP 32bit mode. It is a free download, only works with 7pro.
> > Once installed it opens a new virtualXP desktop and you install anything that doesn't work with 64bit or with W7 just like you would in XP. You can click back and forth between XP mode and W7 mode without closing programs.
> > I use it all the time at work.
> > Justin
> > --- Inbolger@yahoogroups.com, "Ralph" <ralphwoodard@> wrote:
> > > Hello,
> > > I've been using Hull Designer on my XP machine for several years and now I'm trying to move to a Win 7 PC. Everything seems to work fine except that the actual table for the Data/offset table function doesn't appear. The opening message about using the table appears but not the table.
> > > Has anyone else had this problem?
> > > Thanks,
> > > Ralph
> Gregg Carlson
Gregg Carlson
> Justin
> > Hello,
> > Thanks,
> > Ralph
The file name is hull32.exe, so I assume it's a 32-bit program.
I've tried going into properties/compatibility for hull32.exe and running in several compatibility modes but no luck.
Ralph
> If you'll uninstall the program and then reinstall but before reinstall right click on the program and go to compatibility and select xp 32bit compatibility mode then it may fix the problem.
> > Justin
> > > Hello,
> > > Thanks,
> > > Ralph
> Justin
> > Hello,
> > Thanks,
> > Ralph
In addition, I get a long white box along the bottom of the main view that obscures the bottom edge and doesn't allow me to move any points it covers up.
Guess it's free, so I shouldn't complain, but I think i'll have to find something else if these things can't be fixed.
carl
Justin
--- Inbolger@yahoogroups.com, "Ralph" <ralphwoodard@...> wrote:
> Hello,
> Thanks,
> Ralph
V/R
Chris
On 7/7/2012 10:33 AM, slrrls2000 wrote:The program probably is a 32bit app. If your using 64bit windows then you probably need to install the program as a 32bit. --- Inbolger@yahoogroups.com, "Ralph"<ralphwoodard@...>wrote:Hello, I've been using Hull Designer on my XP machine for several years and now I'm trying to move to a Win 7 PC. Everything seems to work fine except that the actual table for the Data/offset table function doesn't appear. The opening message about using the table appears but not the table. Has anyone else had this problem? Thanks, Ralph
> Hello,
> Thanks,
> Ralph
Ralph
