Re: Flex Coat on Hull interior
Waterproof in relation to plywood glue means it does not  dissolve in water, not to its water barrier properties.
even if it was; every screw, nail, incompletely filled end grain joint will destroy the seal.
mike
I was up visiting at the Great Lakes Boatbuilding School in Cedarville, MI twoyears ago and they used something like this rolled on the interior ( below the waterline) of a 18' strip-built work/fishing skiff as non-skid and I thought it was pretty neat. The boat in question was epoxied and 'glassed inside and out, very well done to a pretty high level of finish. The application was very neatly done. I thought it was a really clever solution and if properly taped off etc., on a well-applied epoxy finish, would look good, be quiet, durable and comfortable on bare feet.
Patrick A. Connor
From:bolger@yahoogroups.com [mailto:bolger@yahoogroups.com]On Behalf Ofsirdarnell
Sent:Saturday, July 21, 2012 11:19 AM
Subject:[bolger] Re: Flex Coat on Hull interior
Breathe on one side doesn't make any sense to me, at least with plywood. There are waterproof layers of glue between the wood layers.
--- Inbolger@yahoogroups.com, "jdmeddock" <jmeddock@...> wrote:
> Hydro stop flex coat, the
masonry sealer?
> Don't know.
> George Buehler suggests roofing
sealant between plywood layers, something like Blackjack IIRC.
Schools of thought are divided between the "seal it all thoroughly,Inside and out, epoxy/cloth is probably best" group and the "one side needs to breathe" group.
> Ive wasted a boatload of money on budget workarounds
that weren't!
> Maybe two boatloads, and approaching three...
> Justin
> --- In
href="mailto:bolger%40yahoogroups.com">bolger@yahoogroups.com, "Old Horse" <oldhorse77@> wrote:
> > O.K. no laughing...What do
you think about using it to seal the interior of the Hull on a plywood boat I'm building???...Cause condensation,rot???
> Hydro stop flex coat, the masonry sealer?
> Don't know.
> George Buehler suggests roofing sealant between plywood layers, something like Blackjack IIRC.
> Ive wasted a boatload of money on budget workarounds that weren't!
> Justin
> --- Inbolger@yahoogroups.com, "Old Horse" <oldhorse77@> wrote:
> > O.K. no laughing...What do you think about using it to seal the interior of the Hull on a plywood boat I'm building???...Cause condensation,rot???
Sam Devlin has used the spray on bed liner for pick up trucks on the interior of his Candlefish design and apparently it works well.
JohnT
From:bolger@yahoogroups.com [mailto:bolger@yahoogroups.com]On Behalf Ofjdmeddock
Sent:Friday, July 20, 2012 1:37 PM
Don't know.
Justin
No virus found in this message.
Checked by AVG -www.avg.com
Version: 2012.0.2197 / Virus Database: 2437/5143 - Release Date: 07/20/12
Don't know.
Justin
