Re: Help Micro bulders - Micro bulkhead C
Hi Francisco - well, what about bulkhead A with all the water in the
anchor well? And all the holes in the keel sheating and in the hull
bottom in the aft and forward well? I'm pretty sure that this was
definitely not a consideration in PCB's mind when he drew the boat...
Anyway - in two days I've completed two bulkheads (C and D) and
started the transom... I will complete the transom tomorrow and, if
my wife will agree to extend my sabbatical leave one or two more
days, I could butt join the hull sides and be ready to go 3-D! We'll
see...
Best, Pippo
--- Inbolger@egroups.com, Francisco Ramírez <astrolabio@s...>
see...
Best, Pippo
> Well... the Micro bulkhead "C" is the lower one, the first one thatis going
> to be "attacked" if you get some rain water inside... but with epoxy
> saturation that's probably no problem.
Well... the Micro bulkhead "C" is the lower one, the first one that is going
Just my 2 pesetas.
Francisco
Just my 2 pesetas.
Francisco
> Bill - if this was the reason, then he would have designed all frames
> like that, which is not the case... Anyway, my bulkhead C is done now!
> Best, Pippo
> --- Inbolger@egroups.com, wmrpage@a... wrote:
> > In a message dated 8/25/00 9:41:07 AM Central Daylight Time,
> > astrolabio@s... writes:
> > << My first thought was rot
> > preventing... but this is may be the second reason. >>
> > This sounds like a pretty sound reason to me! Even with epoxy
> saturation (and
> > bilges so dry they can be vacuum-cleaned, I'm sure), who wants to
> put plywood
> > end-grain where it might have an opportunity to suck up water!
> Perhaps PCB
> > was killing two birds with one stone.
> > Bill in MN
Best, Pippo
Best, Pippo
saturation (and
put plywood
Perhaps PCB
> Bill in MN
astrolabio@...writes:
This sounds like a pretty sound reason to me! Even with epoxy saturation (and
bilges so dry they can be vacuum-cleaned, I'm sure), who wants to put plywood
end-grain where it might have an opportunity to suck up water! Perhaps PCB
Bill in MN
Bill in MN
Hi, Pippo,
I'm happy to here that you are building again. I know you can make a lot of
progress in... one week?
About bulkhead "C": (I have "C", "D", and "S.T." frames ready, with no
plywood... the suplyer finished it!). In my plans I can see about 2cm
separation between the gussets and the bottom. My first thought was rot
preventing... but this is may be the second reason. The first one (as Rick
have pointed) is probably material economy, not a problem for you that are
using different plywood sizes.
Good luck.
Francisco
Good luck.
Francisco
> Dear all - we've been enjoying our new beach house and I really want
> to get my Micro ready for next summer. My wife graciously agreed to
> allow me a sabbatical leave of a few (TBD) days at home by myself
> while she's at the beach with the kids - and her parents -, starting
> tonight (yeah), to allow me to work on the boat undisturbed...
> Yesterday I bought more mahogany boards for framing, and I'll build
> bulkhead C (key #6) tomorrow. One sentence on the Micro key though is
> not perfectly clear to me. Bolger says "Note that plywood gussets
> don't extend to bottom of hull". What does this mean? The profile
> drawing of the Micro plans shows the plywood going all the way down
> to the hull... Thanks all, and best, Pippo
> - no cursing
> - stay on topic
> - use punctuation
