[bolger] Re: mj mast step collar
I built a Martha Jane and raised the mizzen step 1 1\2 inches above the
cockpit seat on four little blocks which were 1 1\2 inch cubes-I don't
remember whether the cubes were fir or plywood, but it worked very well.
Bill Jochems
To:bolger@egroups.com<bolger@egroups.com>
Date: Thursday, November 04, 1999 6:44 AM
Subject: [bolger] mj mast step collar
Bill Jochems
>Here's a question - I'm building martha jane and looking at the
>construction key - number 48 is a bit tricky - it reads " mizzen step
>collar 1/2" plywood about 8" square, mounted on 1 1/2 square feet." I
>follow it all until the end - what does "mounted on 1 1/2 square feet
>mean?? Does it mean mount the collar on a pad or a base of 1/2 inch
>plywood which is 1 1/2' x 1 1/2'? Steve Anderson
>-- Check out your eGroup's private Chat room
>--http://www.egroups.com/ChatPage?listName=bolger&m=1
That is unfortunate wording and I can see how you would be confused. I
believe what is meant is that the feet of the mizzen stem are made of 1
1/2 x 1 1/2 (square) pieces. Bolger usually specifies that there be
spaces in the corners for drainage. Hope that helps.
Hello everyone - I'm new to the group and building a martha jane -
