Re: POSSIBILITY OF INBOARD ENGINE MOUNTING TO MICRO TRAWLER
One could apply similar mods to a MicroTrawler, in theory, but with a 14' boat, and a hot smelly engine, there is no cabin space. You'd have to build it as an open boat.
--- Inbolger@yahoogroups.com, "c.ruzer" <c.ruzer@...> wrote:
> > How about going with BONEFISH. Only a cartoon but meant for a small inboard and eminently buildable. Well discussd here as to performance, speed, keel, engine types and fitting etc. - see archives.
----- Original Message -----From:c.ruzerSent:Wednesday, August 29, 2012 4:48 PMSubject:[bolger] Re: POSSIBILITY OF INBOARD ENGINE MOUNTING TO MICRO TRAWLER
Bonefish
http://groups.yahoo.com/group/bolger7/files/Bonefish/
> --- Inbolger@yahoogroups.com, "michaelnotigan" <mjnotigan57@> wrote:
> > --- Inbolger@yahoogroups.com, "Ahmet" <gencahm@> wrote:
> > > Anybody studied about above mentioned project...
--- Inbolger@yahoogroups.com, <philbolger@...> wrote:
> No ! Period !
> She runs fine with a 50HP outboard doing in the high-20s kts.
> There is no inboard engine/drive-train that combines the
> - comparative light weight,
> - the Center of Gravity on this design
> and
> - the thrust-vectoring of a modern four-stroke large-prop 4-cyl Outboard.
> Finally, you'd ruin her layout.
> Susanne Altenburger, Phil Bolger & Friends
> From: Ahmet
> To:bolger@yahoogroups.com
> Sent: Sunday, August 26, 2012 5:18 AM
> Subject: [bolger] POSSIBILITY OF INBOARD ENGINE MOUNTING TO MICRO TRAWLER
> Anybody studied about above mentioned project?
> Can we install an Inboard engine at the middle of the front Cockpit
> of Micro trawler?
----- Original Message -----From:michaelnotiganSent:Sunday, August 26, 2012 10:05 PMSubject:[bolger] Re: POSSIBILITY OF INBOARD ENGINE MOUNTING TO MICRO TRAWLER
> of Micro trawler?
With the seeming thousands of hours spent epoxying/sanding/epoxying my MT this idea crossed my mind over the years. As Susanne and all pointed out, it's just not doable. The bottom hull is simply not deep enough to accomodate an inboard engine without throwing it's entire balance out of kilter. Plus, in this design, there would be simply no room to move around the boat with this engine smack in the middle..... A mini tug that will accomodate an inboard diesel is Jay Benford's Grivit and Bullhead. Both are 14 foot long pilothouse mini tugs, real beauties! The trade off is a more labor intensive build compared to the stitch and glue/tack and tape MT.
> of Micro trawler?
----- Original Message -----From:AhmetSent:Sunday, August 26, 2012 5:18 AMSubject:[bolger] POSSIBILITY OF INBOARD ENGINE MOUNTING TO MICRO TRAWLERAnybody studied about above mentioned project?
of Micro trawler?
----- Original Message -----From:Scot McPhersonSent:Sunday, August 26, 2012 4:16 PMSubject:Re: [bolger] POSSIBILITY OF INBOARD ENGINE MOUNTING TO MICRO TRAWLERYou are going to shift the center of gravity when you do. You are removing weight from the back and putting it and probably more forward. What do you think will happen if you do that?
Scot McPherson, PMP CISSP MCSAOld Lyme, CThttp://www.linkedin.com/in/scotmcphersonSent from my iPhoneAnybody studied about above mentioned project?
of Micro trawler?
of Micro trawler?
of Micro trawler?
