Re: A good filler
I've had good eperience using diatomaceous earth (swimming pool
filter
powder) as a filler. It's pure CaCO3 and the little shell shapes seem
to flow and hold better than grains or balls of other fillers. It's
cheap as well
--- Inbolger@egroups.com, chris@b... wrote:
> I have to restore small areas of plywood that were removed due to
> rot. And I would like your suggestion as to how I could go about
> returning these areas to their original thickness and strength.
> Something that I could use as a filler, that will sand well, hold a
> screw/tack and be as strong as the original wood.
> My first thought was to use good old resin and glass, and build it
> back up...but if there is other ways I sure would like to hear em'.
> Thanks,
> Chris
Chris
