Re: [bolger] Re: Good thing that pretty horse broke my leg, saved me from the Czar's army.
Most of the stress on a mast is handled by the material near the _outside_
of the mast. Your all-thread solution is a good one for holding the two
parts of Sage's mast together and in line, Mark, but put plenty of 'glass
on the outside of the mast to carry the load. And make sure you've sanded
all the varnish away before you do it. <g>
On Fri, 28 Sep 2012 22:47:35 -0700, I wrote:
> One day I was out on the local Mudhole on a windy day with a friend. He
> commented about the noise the mast was making, but I said that the
> builder told me it would creak, but was strong enough. he felt around
> the mast near the joint between the two parts and said, "there's a crack
> here you could stick a nickel into!" <g>...
John (jkohnen@...)
Why should we take advice on sex from the Pope? If he knows
anything about it, he shouldn't. (G. B. Shaw)
When you built the mast, Rick, the birdsmouth portion ended abruptly just below the partners. You stuck a solid hexagonal piece up the a** of the birdsmouth portion to make up the length needed to reach the mast step. The joint between the two was abrupt, creating a bad stress concentration. When I picked Sage up from you, you said the mast creaked, but wouldn't fail.
One day I was out on the local Mudhole on a windy day with a friend. He commented about the noise the mast was making, but I said that the builder told me it would creak, but was strong enough. he felt around the mast near the joint between the two parts and said, "there's a crack here you could stick a nickel into!" <g> I went home and made eight wedge-shaped bits that I glued to the solid stick below the main part of the mast, then wrapped everything with fiberglass cloth to try to spread the load beyond the original, abrupt joint.
When Make brought Sage to the Mudhole a few months ago I noticed that the fiberglass was pulling away from my repair. I thought that was probably because I hadn't sufficiently sanded away the varnish. <shrug> It sounds like Mark tried to repair that.
I had many happy times in Sage, and I'm not criticizing your building of her, Rick. We all try things out that turn out not to work, and your method of stretching Sage's mast was such a case.
--- Inbolger@yahoogroups.com, Rick B wrote:
> Hmmm, When I passed this mast on to John there was no fiberglass wrapping, just varnished doug fir. John must have had trouble? If so, I never heard about that.
Just some thoughts on a quick repair, Could you insert a long enough pipe into the mast section and toss the lower section away?Or scarf the two original pieces together as best you can, then router out a series of grooves deep as you can, overlapping the splice and inlay hardwood strips, staggering their lengths to avoid hardspots?Keep us posted on what you do choose to do.Rick
--- OnThu, 9/6/12, Mark Albanese<marka97203@...>wrote:
Subject: [bolger] Re: Good thing that pretty horse broke my leg, saved me from the Czar's army.
Date: Thursday, September 6, 2012, 1:14 PMThe idea of using a short piece of pipe let in to the pieces may not
work. A two inch diameter fitting will only insert 2" into the foot
before the tapered wall gets too thin, perhaps not enough.
Now I'm considering about two feet of 3/8 or 1/2 inch all thread.
I've cleaned up the splinters. The foot of the mast is actually quite
solid. The shards are all inside the upper mast. I could pour in
epoxy to bind them together, then drill for the rod.
Question is, can the all thread just be screwed into the hole, or
does it have to be tapped first to avoid shattering the surrounding
epoxy?
<*> Your email settings:
(Yahoo! ID required)
bolger-digest@yahoogroups.com
| Just some thoughts on a quick repair, Could you insert a long enough pipe into the mast section and toss the lower section away? Or scarf the two original pieces together as best you can, then router out a series of grooves deep as you can, overlapping the splice and inlay hardwood strips, staggering their lengths to avoid hardspots? Keep us posted on what you do choose to do. Rick --- OnThu, 9/6/12, Mark Albanese<marka97203@...>wrote: |
epoxy?
Hmmm, When I passed this mast on to John there was no fiberglass wrapping, just varnished doug fir. John must have had trouble? If so, I never heard about that. Just curious,Is it your intent to join the two pieces or attach a new bottom portion.?How long is the bottom section and where exactly did the mast snap in relation to the partners? Or was it at the cabin roof contact point?I got twin unstayed masts to build for my current build, a pilothouse catamaran motorsailer. I don't want to make the same mistake again... lolRick
Date: Wednesday, September 5, 2012, 1:54 AM
Rick, thanks for the sweet deal. I'd take you up on it if only to thank you in person for the pleasure I've had from Sage already. But a trip to California is out for me now. But just to be clear, if youhadthought of everything, I wouldn't be in this jam.Inserting a new mast plug seems a tricky job, lots of chewing out the old wood and with a well fitting timber might even be splitting the tube and prying it apart some to avoid the new glue oozing to a spendy puddle.This mast is wonderfully light, among it's other virtues. I'm not all that husky but can put it up quite easily. Now, both pieces are still good. The remaining fiberglass wrapping is sound. The T-88 fill stuck. I'm proposing cleaning off the ends, then boring no farther in each piece than it takes for a glued in, heavy, metal collar; glue all over the rest of the joint upon assembly; more fg around that.I doubt this also needs either screws through the strakes into the metal or some crossing bolts through all, but am not worried about adding too much stiffness to this part of the mast.MarkOn Sep 4, 2012, at 8:12 PM, Rick wrote:It's been 11 or 12 years since I built that mast and at the moment I don't recall exactly how I put it together. I do know I built it as light as I dared. No trees around here, so I didn't put them into the design equation, lol :)
Tell you what, bring the pieces to my place and I'll do a good repair for the cost of materials...
Rick Bedard,
Original owner/builder of Sage.
| Hmmm, When I passed this mast on to John there was no fiberglass wrapping, just varnished doug fir. John must have had trouble? If so, I never heard about that. Just curious, Is it your intent to join the two pieces or attach a new bottom portion.? How long is the bottom section and where exactly did the mast snap in relation to the partners? Or was it at the cabin roof contact point? I got twin unstayed
masts to build for my current build, a pilothouse catamaran motorsailer. I don't want to make the same mistake again... lol Rick --- OnWed, 9/5/12, Mark Albanese<marka97203@...>wrote: |
Rick Bedard,
Rick Bedard,
> In the half dozen times or so out getting acquainted with my boat,
> there've been no troublesome sounds from the mast. John Kohnen warned
> it was fatally flawed though, having tried a first repair wrapping it
> in fiberglass. I dumped must have been 4 ounces of T-88 into the
> pretty good crack that persisted.
> While moving the boat around with the 20' mast up we tapped with its
> tip the very end of no more than a 2" branch. That sent a shock right
> to the base, slicing it off more or less cleanly as shown. The long
> part hopped to the side, then fell right over.
> You can see how it's made. A birdsmouth with a lower taper wrapped
> separately around a timber that's both plug for the upper part and
> its heel. I can tell you it's a very neat job.
> I don't know what fixing this right would actually be, short of
> reduplicating it all. The best I can do in wood is clean it out, then
> use one double tapered timber to fit the sockets. Or burn this foot
> and make a new four inch one with an extension lathed off to recore
> the mast itself. But the joint of either is going to be weak still.
> I'm thinking all sorts of vague, crazy ideas like abs or steel cores
> and jackets, just to save the season.
> Guess if your going to have a boating accident, land is the place to
> have it.
> Mark
What kind of boat? What kind of mast support rigging do you have? Here's my put: cut off the broken ends square. Attempt a splice joint of something like ten to one and position that splice so that it would be under load in the fore/aft direction and supported by the forestay as opposed to across the boat centerline. I'd suggest trying a couple of small splices to learn the technique. Since your mast is round, go to Home Depot and pick up a few 1/2 inch dowels to practice on. Set up a fixture in your vice and break a couple of the non-spliced dowels to get an idea of the load it takes to break. Then make a couple of splices and break them. Be sure to orient the splice in different positions to convenience yourself the splice is as strong as the original then go for the mast. You might find that you'll need to add a plug on the bottom of your mast to make up the difference for the material you took out for the splice but this will not experience a large bending load and probably could be a simple butt joint.
Critical issues: no hollow areas in the splice, wood to wood contact throughout. Use good epoxy, T-88 is good but thin and will be a challenge to use with a splice like you're gonna attempt.
Good luck.
Steve Statkus
On Tue, Sep 4, 2012 at 5:49 AM, Mark Albanese<marka97203@...>wrote:[Attachment(s)from Mark Albanese included below]
have it.
Sent:Tuesday, September 4, 2012 4:49 AM
Subject:[bolger] Good thing that pretty horse broke my leg, saved me from the Czar's army. [1 Attachment]
have it.
have it.
