Re: Progress! Congratulations!save the sawdust
save the sawdust, it makes a great filler! somewhere between light
fairing compound and high strength filler. I dropped some on my
driveway in October, and it is still in a clump after a New England
Summer and Winter.
David Jost "delaying the obvious, get to work"
Summer and Winter.
--- Inbolger@egroups.com, "Giuseppe Bianco" <pippobianco@t...> wrote:
> David - thanks for the feedback!
> Of course I've read every single message on the double bottom
issue.
> My idea is to predrill the top layer and using every other hole to
> screw, in order to allow the air to escape. This might also somehow
> allow for automating filling of 50% of the holes: I plan to fill
> others with a siringe. Now I go downstairs to cut the bevels on the
> transom and to remove the ton or sawdust that I've produced in the
> last three days. Getting ready to butt join the hull sides...
> Best, Pippo
> P.S.: the page on drumming is in the thinking phase still...
> -- Inbolger@egroups.com, "David Jost" <djost@m...> wrote:
> > Pippo,
> > I can't wait for the page on drumming!
> > I hope you have been following the discussion on Double Bottoms as
> I
> > found this to be a very tedious process. I strongly recommend
> going
> > for a single 1/2" bottom and getting your wife to hold the
backing
> > maul while you clinch or vice versa. If you do the double
bottom,
> > follow Chuck L's advice and predrill the top layer, I had quite a
> > few
> > spin outs and cannot guarantee no air gaps in the layers.
> > I glassed the bottom and am in the middle of installing the keel
> > batten and the reinforcing strips. I like the extra thickness
> piece
> > of mind when one drops the marine battery on the floor. these
> steps
> > are quite easy and doable by oneself.
> > Ciao,
> > David Jost "first day of school year 2000-2001 tomorrow"
Of course I've read every single message on the double bottom issue.
allow for automating filling of 50% of the holes: I plan to fill the
Best, Pippo
Best, Pippo
> Pippo,I
> found this to be a very tedious process. I strongly recommendgoing
> for a single 1/2" bottom and getting your wife to hold the backingpiece
> maul while you clinch or vice versa. If you do the double bottom,
> few
> of mind when one drops the marine battery on the floor. thesesteps
> Ciao,
--- Inbolger@egroups.com, "David Jost" <djost@m...> wrote:
bagging, tho I admit I haven't done it on my own boat projects yet
(and haven't needed it). I've occasionally used it to glue this and
that thing, tho. Any time my clamps won't do, I think of it.
>snip and cannot guarantee no air gaps in the layers.This is why some of us put up with the extra complication of vacuum
Pippo,
I hope you have been following the discussion on Double Bottoms as I
found this to be a very tedious process. I strongly recommend going
few
batten and the reinforcing strips. I like the extra thickness piece
of mind when one drops the marine battery on the floor. these steps
Ciao,
few
Ciao,
Dear all - I've just completed the last bulkhead (the transom,
actually) for my Micro - to be honest I still have to cut the bevels,
but that is easy peasy... So, as David Jost said, ready to go 3-d!
I've also updated my web page:http://space.tin.it/io/jfwbi/.
Hower, gotta go back to the beach tomorrow... Best, Pippo
