Re: [bolger] Honda OB's
> Frank Bales wrote:
> > Please define high thrust; what exactly does it mean?
On Thu, 31 Aug 2000, Clyde S. Wisner wrote:
> Larger, slower turning prop, I think. Yamaha makes a geared down
> version with larger prop version of 9.9 and 50 hp 4 cycle. I wondered
> if anybody else did. Clyde
I have a Nissan 5hp 4-stroke. It comes with a "medium" pitch prop. I
bought the "displacement speed" prop, with less pitch. Man, it makes a
difference! I can now spin my boat in circles at hull speed! (Not that
you'd want to do that everyday.) But it makes my boat move with real
authority.
Yamaha 'high thrust' motors also have higher-output alternators, and
something about the thru-hub exhaust design is supposed to make them more
effective in reverse. (In case you're coming into the slip too hot in your
heavy sailboat.) I had one on a Pearson 26, terrific motor.
> -----Original Message-----
> From: Clyde S. Wisner [mailto:clydewis@...]
> Sent: Thursday, August 31, 2000 8:49 AM
> To:bolger@egroups.com
> Subject: Re: [bolger] Honda OB's
> Larger, slower turning prop, I think. Yamaha makes a geared down version
> with larger prop version of 9.9 and 50 hp 4 cycle. I wondered if anybody
> else did. Clyde
> > Frank Bales
> > Staunton, VA
> > Sent: Tuesday, August 29, 2000 7:28 AM
> > Does anybody make a high thrust besides Yamaha? Clyde
> > Phil Smith wrote:
> > > The key thing to look for with regard to outboards is the phrase "high
> > > thrust." This usually (always) means four cycle, lower gearing and
> > - no cursing
> > - stay on topic
> > - use punctuation
> > - add some content: send "thanks!" and "ditto!" posts off-list.
> > - no cursing
> > - stay on topic
> > - use punctuation
> - no cursing
> - stay on topic
> - use punctuation
else did. Clyde
> Frank Bales
> Staunton, VA
> - no cursing
> - stay on topic
> - use punctuation
> - no cursing
> - stay on topic
> - use punctuation
Frank Bales
Staunton, VA
- no cursing
- stay on topic
- use punctuation
Thanks Peter, good advice about dealers. I have experience in the auto
industry and have heard from friends that have worked with Honda auto
(actually any Japanese auto company) that their attention to continuous
improvement and quality is fanatical. The U.S. auto industry has made great
strides in recent years in these areas (should have listened to Dr. Demming
sooner), but they still can't touch the Japanese in continuous improvement.
I believe that the same is true for the marine engine industry.
Frank Bales
Staunton, VA
Sent: Monday, August 28, 2000 1:33 PM
Subject: [bolger] Re: Honda OB's
I don't have any info except what was in the message itself.
What's more, I don't have any experience, either first or second
hand, with recent Honda OB's myself.
Once upon a time, maybe 10-15 years ago, there were several problems
that I saw published or heard about from friends where Honda sailboat
OB's were disabled by the failure of a particular electrical part. It
was an easy $60 repair, but the engine wouldn't run at all until the
part was replaced, and sometimes the part was hard to come by. I
haven't heard anything like that for some time (not that I
necessarily would), and I assume that Honda fixed the problem at the
source long ago.
It has been my impression that Honda takes great pride in
engineering, and in being on the leading edge of design. When you
take that attitude, you are going to make a mistake now and then.
My own feeling on OB's is that they all take a lot of maintenance,
and any brand is going to be back in the shop now and then.
Therefore, the reputation and quality of the dealer, and his attitude
to you as a customer, is just as important as the engine itself.
- no cursing
- stay on topic
- use punctuation
In a message dated 8/28/2000 1:22:20 PM Eastern Daylight Time,pbs@...
writes:
<< Please make a Loose Moose 2 thread or conference so that the accumulated
wisdom can be accessed. When I get frustrated at work or with life in
general I think about buying a couple of hundred sheets of plywood and
making a Loose Moose.
I've always found this an interesting boat too - I too would hope the
discussion would be on-list. Steve Anderson
source long ago.
lm2 wrote:
> The Yamaha was replaced with the Honda because I was working with the local
> Honda dealer and they made me a great deal ( so good in fact that I bought
> two!) The Yamaha had pushed us over 2300 miles in a year long tour of the
> european canal system ( not to mention our circumnavigation of the Med and
> our West African trip)and while still performing well we thought it was time
> for a new motor...by the way we sold the Yamaha to a guy on a Multihull and
> it is still going strong.
> I would be happy to discuss LM2 with potential builders off list so drop us
> a line if you have any questions.
> Bob & Sheila
> St Thomas USVI
> From: Frank Bales <fbales@...>
> To: <bolger@egroups.com>
> Sent: Monday, August 28, 2000 1:48 PM
> Subject: RE: [bolger] Honda OB's
> > Bob, why'd you replace the Yamaha?
> > I understand the Loose Moose 2 was lost in a lightning storm (very sad).
> > Would you build another AS39? What would you change? The reason I ask is
> I
> > will retire in 11 years and want to build a boat to live aboard and do
> some
> > serious sailing. I saw (at Square Boats site) that the Loose Moose 2 made
> > an Atlantic crossing, and I believe you actually built it in France.
> > Anyway, if you would like to offer any advice I'd appreciate it.
> > - no cursing
> > - stay on topic
> > - use punctuation
> - no cursing
> - stay on topic
> - use punctuation
Phil Smith
larger propellers. Phil and Susanne have a Yamaha 50 hp high thrust
outboards on their runabout and they are very happy with it. They've had
it for several years, perhaps five, and have had next to no problems
with it.
The problem with outboards for large power cruisers, again according to
Phil and Susanne, is a lack of electrical generating capacity. Whether
this could be addressed by either rewinding the outboard's built in
alternator or by placing an external alternator atop the motor's shroud
(much like the hydraulic drives that lobster men use for pot haulers)
remains to be seen.
PB&F think that outboard manufacturers are missing a sizable unserved
market segment by not producing more high thrust outboards and by not
equipping those that are produced with substantial electrical generating
capacity.
Phil Smith
I would be 99.99% sure they are talking about the same thing, 15 and 20
inches NOMINAL. No boats I know of have a fixed waterline, so I would
choose the length that puts the prop under the water.
Think of Schrodinger's Cat - get up and walk to the back, measure, it's
20", walk back and sit down, it's 22.5", but you can't prove it...;-}
High-performance boats like fast bass boats will use both the motor tilt
and a jack plate (auto or manual) to trim the motor up to just below
cavitation to lessen drag and gain a few mph. The starting point is to put
the anti-cavitation place just below the water if you are trying to go fast.
In a displacement boat, like a 3.5 pushing a sailboat, you have no choice
but to get the prop as deep as possible to prevent ventilation by waves and
pitching.
Gregg Carlson
At 02:10 PM 8/28/2000 -0000, you wrote:
> Does anyone have experience with Honda outboards? In reading
>through their specifications, the short shaft recommended transom
>height is 16.6 inches and the long is 22.5 inches. Since most boats
>are either 15 inches and 20 inches in height for short and long shaft
>outboards respectively, how does the longer (higher?) shaft affect
>performance? Does the builder have to increase the transom height by
>some means in order to use a Honda? This would seem to be a drawback
>to purchasing a Honda.
>- no cursing
>- stay on topic
>- use punctuation
Peter, do you recall why Mr. Lampman didn't like the Honda around salt
water? His comments were for the 5hp models-I wonder if his opinions would
be different for larger motors. Thanks for remembering that.
Sent: Monday, August 28, 2000 12:03 PM
Look back at message 6168.
PHV
- no cursing
- stay on topic
- use punctuation
Would you build another AS39? What would you change? The reason I ask is I
will retire in 11 years and want to build a boat to live aboard and do some
Less than a hundred sheets and you have yourself a boat...
Bob
Bob & Sheila
St Thomas USVI
I
some
> - no cursing
> - stay on topic
> - use punctuation
PHV
Sheila and I had a Yamaha 4 stroke 9.9 that we later replace with a Honda 4
stroke 9.9 on Loose Moose 2 both engines were excellent and did the
job...but the operative word here is 4 stroke and a big prop!
Bob & Sheila
St Thomas USVI
I've known several (ok, maybe 3 or 4) people that have owned Honda outboards
and they love them. In fact, they are nearly fanatical about them. They
one and all claim Honda to be the best.
Sent: Monday, August 28, 2000 10:10 AM
Subject: [bolger] Honda OB's
- no cursing
- stay on topic
- use punctuation
