Re: Hot melt glue
Mike
I wonder if the impression was given I wanted to glue something up permanently this way. Not so. Am working up a little project to finish bright, more a 2 foot boat than the 10 foot ones I'm used to doing, and have been considering ways to avoid blemishes, pencil marks preserved under epoxy, too many dings or holes etc.
It was interesting to google this up a little, Like anything ya buy these days, there are many details and options to consider. The prominent hot melt glues are polyurethanes. There is a variety of formulations for different materials. They're said to clean up best with isopropyl alcohol or acetone. LocTite has a version claimed to be just right for wood, having lots of tooth into the grain, but I wonder if that makes it harder to clean off.
The downside seems to be expense. It is easy to spend $150 for a gun and shots of glue are often $13.50, though a dedicated bargain hunter could probably do better than that.
Why not wire, indeed? Or just duct tape.
Susanne Altenburger, PB&F
----- Original Message -----From:jdmeddockSent:Monday, March 04, 2013 2:52 PMSubject:[bolger] Re: Hot melt glue
> Why not use tie wraps?
I tried that once.
It just made a big mess out of my glue gun!
MAybe I need low melt tie wraps?
Justin
> Why not use tie wraps?I tried that once.
Justin
> Anyone here like using hot melt glue to hold a small s&g boat
> assembly together? Is it (really) strong enough too hold curved
> plywood in shape while flipping or moving around? Does it clean up
> easily?
> Thanks,
> Mark
Mark,
My main marine use for hot melt glue is to glue the tops on empty gallon milk jugs to provide extra flotation for Micro. That is the lightest floatation I can come up with. I wouldn’t count on it for hull assembly.
MylesJ
On Sun, Mar 3, 2013 at 3:02 PM, Mark Albanese<marka97203@...>wrote:Anyone here like using hot melt glue to hold a small s&g boat
easily?
Not I. It might hold things together for filleting and taping but is it compatible with the other glue you’re going to use? It would occupy spaces I want filled with the real thing, and I would worry that it would contaminate and compromise epoxy bonds. And in what way would it be better than wire or screws, or any easier to apply?
I had a famous guitar-maker take my class at WoodenBoat School, and he brought an array of super-glues which he recommended for all sorts of quick jobs. These glues would hold surprisingly well but prevent getting epoxy where you want it, i.e. in complete coverage of surfaces to be joined.
From:bolger@yahoogroups.com [mailto:bolger@yahoogroups.com]On Behalf OfMark Albanese
Sent:Sunday, March 03, 2013 3:03 PM
Subject:[bolger] Hot melt glue
easily?
easily?
These days a friend traveling to Miami and need an echo sounder and thought that one could tell me where to get some economic or used in good condition. Can be analog or digital.
Or if any of the friends group have any to sell.
Thank you very much
Alberto
Chubut Patagonia Argentina
