RE: Re: [bolger] Paint, Glass or Dynel for my cockpit
dynel is for when you want to duplicate the look of canvas, but want a more peramanent solution. I found it tougher to fill the weave.
--- In bolger@yahoogroups.com, <bolger@yahoogroups.com> wrote:On 39’x7’5x1’x 225hp SACPAS-3 all outside surfaces were glassed with 10-oz cloth set in epoxy, plus coats of oil-based paint.
Local commercial repair yard doing steel draggers, tugs, wooden schooners etc. suggest using hard-edged sand-blasting ‘shot’ to sprinkle salt-shaker-fashion into the wet-paint, with another coat helping to keep the ‘traction’ in place. Avoid that non-slip around cleats and on-deck moving lines as both skin and fibers will be abraded...
Ditto on Jed’s glass-cloth comment versus Dynel.Susanne Altenburger, PB&FFrom:philbolger@...Sent:Tuesday, September 03, 2013 10:02 AMSubject:Re: [bolger] Paint, Glass or Dynel for my cockpitGood question.After all this work, I’d go conservative.
Glass-cloth in epoxy, plus paint (with non-slip in wet paint plus another coat), all for physical wear and protection from the effects of sun/heat, whether afloat or on wheels.
Susanne Altenburger, PB&FFrom:a.c.l.yen@...Sent:Tuesday, September 03, 2013 9:52 AMSubject:[bolger] Paint, Glass or Dynel for my cockpitI am thinking about what to coat the cockpit plywood with in my Chebacco 25 build. (that indicates that I am getting closer to finished - the cockpit is almost finished and the cabin structure is being built
From what I have read and experienced with other boats, I should be glassing the foredeck to protect from checking and damage . I might use Dynel as an alternative as it did pretty well on the bottom of my Cartopper.But if the foredeck needs protecting then surely the cockpit will need similar.What advice/experience is there for how much coating is enough. Epoxy+paint? Epoxy+glass+paint?, what paint?. The boat will basically be a trailer sailer so should have a cover on it most of the time - but "should" doesn't mean that it won't blow off.Andrew
this is an interesting thread. I have successfully stored my boats under simple A frame tarps for years with no ill effects. I agree that that key is to prevent water from pooling, and to ensure good air circulation under the tarp. Current boat has 6oz glass set in epoxy on all surfaces. So far, so good 4 years later! no delam at all.
FYI - i tied a steel cable to a large tree and then to a frame positioned at the tongue of the trailer. Then, draped a tarp over the whole contraption and held it to the rail of the boat with C clamps. This keeps the snow off as well. it is kind of fun to sneak under the tarp and work on the boat in the middle of winter while laughing off the weather.
Happy building,
--- In bolger@yahoogroups.com, <bolger@yahoogroups.com> wrote:stored a small ply trailer sailer under a large plastic tarp for a year and had zero success in stopping water puddling in the boat no matter how i arranged the tarp. if nothing else, condensation in damp weather - even overnight dew -dripped off the contact points into the boat.
i now store it under a FREE-STANDING plastic tent (what is herabouts called an "igloo") and the airspace around seems to evaporate more water than gets in (though the salt spray residues sometimes gather water drops)
rgds, frank
To: bolger@yahoogroups.com
Date: Tue, 3 Sep 2013 19:22:15 -0700
Subject: [bolger] RE: Paint, Glass or Dynel for my cockpit
I have another smaller trailer boat that doesn't get looked after as well as it should (I spend my spare time building the Chebacco, not maintaining the old boat the Chebacco will eventually replace.) I have found the foredeck suffers the most from weather and damage, so I will go with glass and epoxy on the deck and in the cockpit.I have acquired some tins of Dulux Aquanamel http://www.dulux.com.au/products/dulux-interior-products/trim/product-detail?product=2184 which I intend to use on the deck and in the cockpit. It is water based but higher gloss and hardness than your average acrylic paint. It is used for doors and trim, inside and outside houses. I have noticed that the acrylic paint on my Cartopper and on my Eureka Canoe tends to rub off where it comes in contact with the trailer etc. Hopefully the Aquanamel will provide the benefits of acrylic with the hardness of an oil based paint.
Any thoughts or experience on this sort of paint?
Andrew
--- In bolger@yahoogroups.com, <goodboat@...> wrote:I don’t mean to argue with those who advise glassing plywood in deck and cockpit areas, but I do want to register the advantages of not doing so. Let’s remember the savings in epoxy and fiberglass and time and labor and weight. Let’s remember that only fir plywood checks badly. Oukoume doesn’t and of course still better mahogany plywoods don’t. Let’s remember that plywood glassed onbothsides can’t get rid of moisture and will rot fast f it does get wet, and that moisture will follow the grain in laminates of plywood a long long way. Let’s remember that paint breathes vapor pretty freely, while it does seal and protect against wear and water. In short, for most small plywood trailer-sailers and other dry-sailed plywood boats, paint is fine for cockpits and decks. I would only prime with epoxy after sanding and shaping fillets and while giving them and the tapes their final coat of epoxy. I leave off what glass I can, even topsides, and I use very light glass anywhere I do use it, mainly to guarantee a uniform layer of epoxy, except on bottoms.
These observations come from a builder who finds modern “composite� boatbuilding, with plywood and fiberglass and epoxy, almost too slow and laborious! Oh for joints put together once and fastened and done with, so neat and clean! Just think how fast you could build a dory, traditionally. Paint it and go rowing, while the rest of us Instant Boatmakers are still coating and grinding and laying on glass.
Dynel, by the way, as we’ve used it on Reuben’s restorations of the Sound Inter Clubs, for decks and cabin-tops, is more texture than I’d want, myself. A little sand in the paint, as Susanne suggests, over glass, would be enough, and save weight and money.
De gustibus non est disputandum. Mason
From:bolger@yahoogroups.com [mailto:bolger@yahoogroups.com]On Behalf OfJed Lavoie
Sent:Tuesday, September 03, 2013 10:49 AM
A little extra work now saves you a ton of extra work later. Epoxy, fiberglass and paint. The only thing I use Dynel for is abrasion resistance. Fiberglass is stronger structurally and lighter since it requires less resin.
JedFrom:"a.c.l.yen@..." <a.c.l.yen@...>
Sent:Tuesday, September 3, 2013 9:52 AM
Subject:[bolger] Paint, Glass or Dynel for my cockpitI am thinking about what to coat the cockpit plywood with in my Chebacco 25 build. (that indicates that I am getting closer to finished - the cockpit is almost finished and the cabin structure is being built).
I also have to do extra clicking on links and to help refresh the page.
markA
On Sep 13, 2013 6:43 AM, <otter55806@...> wrote:You should maybe be looking at your computer being infected. I am not having any of the problems you mention. My email is working normally. I don't like the changes to the groups, especially the way it takes clicking to two pages tor reply to post, but it does work. I run No Script also and that is working normally. In short, while some of the changes are a nuisance everything does work. If it all works on my computer and it is not working on yours you should be looking at your computer and not Yahoo.
Bob
--- Inbolger@yahoogroups.com, <bolger@yahoogroups.com> wrote:Yahoo is badly screwed up right now. The on line mail doesn’t work right but pulling it down with Outlook works. I lost a $2,500 sale this week because Yahoo mail was blocked for nearly a day by Spamcop and I didn’t get a bounce soon enough to contact the customer again. News is unusable. It runs the CPU into turbo mode and stays there for several minutes with everything else frozen. I’ve had my personal and company email and web sites and e-commerce there for 15 years, but won’t by the end of the month. I’m not sure if they started using the Google V8 stuff and are forcing the issue by breaking anything that can’t handle V8. Personally I don’t allow any scripting in the browsers on the company machines. You get a few pages that don’t work. You can’t get 90% of the malware if you don’t allow scripting and don’t run as full admin.
MylesJ
Bob
--- In bolger@yahoogroups.com, <bolger@yahoogroups.com> wrote:Yahoo is badly screwed up right now. The on line mail doesn’t work right but pulling it down with Outlook works. I lost a $2,500 sale this week because Yahoo mail was blocked for nearly a day by Spamcop and I didn’t get a bounce soon enough to contact the customer again. News is unusable. It runs the CPU into turbo mode and stays there for several minutes with everything else frozen. I’ve had my personal and company email and web sites and e-commerce there for 15 years, but won’t by the end of the month. I’m not sure if they started using the Google V8 stuff and are forcing the issue by breaking anything that can’t handle V8. Personally I don’t allow any scripting in the browsers on the company machines. You get a few pages that don’t work. You can’t get 90% of the malware if you don’t allow scripting and don’t run as full admin.
MylesJ
MylesJ
rgds, frank
Andrew
--- In bolger@yahoogroups.com, <bolger@yahoogroups.com> wrote:I am thinking about what to coat the cockpit plywood with in my Chebacco 25 build. (that indicates that I am getting closer to finished - the cockpit is almost finished and the cabin structure is being built).
I have never regretted glassing anything. I remember the first large project I did when I read that the whole boat inside and out, that was to the weather, needed to be glassed. I was outraged, what excess. But it all reduces maintenance in the long run. Detailing is very important though, one needs to be sure there aren't any penetrations, or potential for zippers. It isn't necesarry to go heavy on many boats, you aren't going to let your wear go through the paint. So 4 oz is normally ample, use good epoxy. Good epoxy, glass, and ok ply work extremely well together, and are worries about more flexible epoxies and clothes are misplaced. There are plenty of 40 year old plus boats out there without any problems.
Andrew
--- In bolger@yahoogroups.com, <goodboat@...> wrote:I donât mean to argue with those who advise glassing plywood in deck and cockpit areas, but I do want to register the advantages of not doing so. Letâs remember the savings in epoxy and fiberglass and time and labor and weight. Letâs remember that only fir plywood checks badly. Oukoume doesnât and of course still better mahogany plywoods donât. Letâs remember that plywood glassed onbothsides canât get rid of moisture and will rot fast f it does get wet, and that moisture will follow the grain in laminates of plywood a long long way. Letâs remember that paint breathes vapor pretty freely, while it does seal and protect against wear and water. In short, for most small plywood trailer-sailers and other dry-sailed plywood boats, paint is fine for cockpits and decks. I would only prime with epoxy after sanding and shaping fillets and while giving them and the tapes their final coat of epoxy. I leave off what glass I can, even topsides, and I use very light glass anywhere I do use it, mainly to guarantee a uniform layer of epoxy, except on bottoms.
These observations come from a builder who finds modern âcompositeâ boatbuilding, with plywood and fiberglass and epoxy, almost too slow and laborious! Oh for joints put together once and fastened and done with, so neat and clean! Just think how fast you could build a dory, traditionally. Paint it and go rowing, while the rest of us Instant Boatmakers are still coating and grinding and laying on glass.
Dynel, by the way, as weâve used it on Reubenâs restorations of the Sound Inter Clubs, for decks and cabin-tops, is more texture than Iâd want, myself. A little sand in the paint, as Susanne suggests, over glass, would be enough, and save weight and money.
Jed
Andrew
These observations come from a builder who finds modern “composite” boatbuilding, with plywood and fiberglass and epoxy, almost too slow and laborious! Oh for joints put together once and fastened and done with, so neat and clean! Just think how fast you could build a dory, traditionally. Paint it and go rowing, while the rest of us Instant Boatmakers are still coating and grinding and laying on glass.
Jed
Andrew
Jed
Leigh Ross
