Re: 50% heavier.. WAS.. [bolger] Re: Options for ply thickness for similar sharpie construction on simila
"1/3rd of 1/4 is 1/12th of an inch, so 1/3rd thicker would be 1/12 plus 3/12 (another way to say 1/4) = 4/12 or 1/3rd of an inch. Oddly enough this means 1/3 of an inch is 1/3 thicker than 1/4 of an inch... "
And a quarter inch is 1/4 thinner than a third of an inch.
Truth. You can feel it with your fingers - sense data - see it empirically - perception. A reliable personal experience, or something else?
Propositions of math have meaning - but mathematical truths are empty tautologies - or so once said the last great empiricist to date, A J Ayer "..Mathematics is analytic. 2 + 2 = 4 tells you nothing fresh about the world, or about anything other than itself. It is just a convenient way of telling you that 1 + 1 + 1 + 1 = 1 + 1 + 1 + 1 ..Logic similarly is an empty verbal phenomenon." ..Ayer gave up on verification theory, while others not of the empiricist bent, such as Wittgenstein, and Popper said it's not really a personal thing, knowledge that is - like we're all in a boat we construct together. Foucault said the powerful build that boat, which should be deconstructed to see the plan, bom, and a better way to build.
In Meranti:
6mm 27.5 lbs
9mm 43 lbs
I don't care about percentages. I just want to know how much extra weight!
When I built my Bantam I used their tables to figure out that using a 4mm ply over the 3mm ply in Bolger's plans for the external skin on the roof would add about 10 lbs. Not enough extra weight to make much difference. I wanted a bit more thickness as I intended to, and do walk on the cabin top a lot. In fact I sit up there when using the bow mounted trolling motor with the remote while sneaking up on birds in refuge areas.
Bob
I will NOT add another thing to this discussion except to say that the teacher that taught y'all fractions has gone back and changed all of your grades to Fs. :)
The way you boys do carry on!
@yahoogroups.com]On Behalf OfChief Redelk
Sent:Friday, December 27, 2013 5:03 PM
Subject:Re: 50% heavier.. WAS.. [bolger] Re: Options for ply thickness for similar sharpie construction on simila
I think the KEY to this is to understand the 50% added is the 1/3
MORE.. We know that 1/4 is = to 2/8 that means 1/8 is half of or 50 %
of 1/4....
When I read the 50 percent increase in wood thickness I wrongly
thought they meant was to DOUBLE the weight of the boat.
I read it to fast..
To double the weight of the boat one would have to increase wood
thickness from 1/4 to 1/2 wood which would be 100 % increase in
plywood thickness. I feel sure the extra glue may add some weight too
so the increase may be a little more than double..
I am a "Hands on man".. I cut a deck for my boat out of 1/4 plywood
and one out of 3/8 ply.. For that small a piece of wood I could not
tell a big difference in weight.. They were weighed by the pick up one
sit it down pick up the other one, wink one eye, lay the head aside
and make a mmmmmm sound.. Nothing scientific but it satasfied me..So,
I opted for the 3/8 plywood..
My new boat is 8 feet long almost 4 feet wide. The bow deck is
something I stand on so I like it strong..The sides are Luan both ends
are Luan the bottom is 1/4 plywood. This made a nice strong boat. The
aft deck is also 3/8 plywood.. The boat is not heavy compared to my
Puddle Duck. In fact the PDR is heavier..
IF I build a 12 foot scow with the sides made out of 1/4 plywood and
the top decks made out of 3/8 and the bottom made out of 3/8 then
weigh the boat and build another one exactly like it except I make the
sides out of 3/8 saving that 1/8 extra weight on the sides will not
make enough difference in the total weight to be worth buying 1/4
plywood..UNLESS..
Here is where the builder gets the door prize..Unless I can manage to
not have as much scrap..
I have not lay a pencil to paper but off the top of my very thinnin
hair I would venture to guess I could get 2,,,12 foot long ,,,18 inch
high sides and maybe both ends out one sheet of 1/4 ply..That may save
me a few dollars and a small amount of weight..
But before we start the tractor lets check the gas tank.. So.. Consider this..
If we use all 3/8 plywood ( differs with the plans ) we just may not
have any scrap wood left over and the boat won't be a LOT heavier but
it will be a LOT stronger..
Since I do want 3/8 on the bottom and the top decks,, well it may be
simpler to just use all 3/8..
Building boats is a lot like making breakfast..Much of what we buy and
what we do depends upon what we want to achieve.. We don't need a
dozen eggs for a small omlet.. Are we feeding 2 or 10?
Will the boat see rough seas, hard rocks or be dragged over the beach?
I have achieved a strong bottom on a boat that had Luan on it by
laminating Canvase over the bottom.. It was hard work and the boat got
heavier from the process. It may have been about as good to use 3/8
ply and be done..
The beauty of life is in many things there is no clear cut "Right" or
"Wrong" way.
This is why we can buy fixed or folding blades on Buck Knives and then
who is to say they are better than Gerber or Kershaw just because
someone who loves knives swear by them ?
I would suppose in brain surgery and wiring houses we may need to
stick closely to the rules but boats are things that float.. Water
wind and location is different , building methods are different,
materials are different, so in the end a boat may be a work of art
built to be admired by different viewers and cultures....
This discussion should be helpful to all of us.
By expressing our ideas the seeds of wisdom is spread as when a bird
eats fruit and craps the seeds out miles from home.
Even with all the crap posted on this subject we find good solid
information. smile...
Be well, Chief.
On 12/27/13, tom sorensen <tdsoren@...> wrote:
> This one has been fun to watch.
> Reminds me of whenever I have to explain that a 50% markup gives you a 33%
> gross margin to folks in the office.
> Tom
> On Dec 26, 2013, at 9:14 PM, Chief Redelk <chiefredelk@...> wrote:
>> Right you are.. That is my way of seeing this. 3/8 is 1/8the more than
>> the original 2/8 boat. So in my mind the boat would weigh 1/3 more.
>> Not a lot if you trailer. BUT I did understand the other post too.
>> Both were correct. One was put differently BUT for me the old country
>> boat builder I will just go with the boat being 1/3 more and be done..
>> BUT rest assured John was correct about the 50 percent comment..But to
>> keep it simple I think the way you put it is just simple and easy for
>> the masses..
>> I am a "Math Nut". So I liked all of the info.. When I was in
>> electronics we carried our math out to 12 places. Lots of little
>> "Zero's" but very important for electronics..
>> However I like simple now that I am lazy so I don't bother with the
>> small details as long as I can get a good estimate..
>> For example we know a cubic foot of "Fresh water" should weight bout
>> 62.4 lbs or something near that. Since I like to be on the safe side I
>> just figure it at a flat 62 lbs and go ahead.
>> Nothing bad is going to happen if I am a bit off except my draft line
>> may be a little off. The boat will work fine..
>> However my scientific background does admire men who will do the hard
>> math and give us details..It's just not me anymore. smile...
>> Math has it's own type of Poetry and it's really beautiful. Smile BUT
>> I may see life a little different than the everyday guy. Smile..
>> We all know the old KISS formula for happiness means keep it simple
>> stupid..Well that was how I was taught and it's working for me...
>> smile.
>> That means I am not afraid to use 3/8 plywood on my next 12 foot boat...
>> Another formula learned from the red necks is WGAS ? ( who gives a *)
>> about details as long as the boat floats good, sails well and can be
>> carried on a trailer..Smile..
>> Many of my ancestors build good boats and most of them could not count
>> past the number of toes and fingers they had. A few had parts of
>> fingers missing so guess they could do fractions. Smile..
>> Coming up in La. I saw boats made out of 12 inch wide boards,
>> houseboats sitting on top of logs and boats made out of most anything
>> that floated. Compared to those my boats mine look great. Smile..
>> Good day.. ..Chief..
>> On 12/26/13,sirdarnell@...<sirdarnell@...> wrote:
>> > 1/4 to 3/8, when you are working with fractions you first need to make
>> > your
>> > bases (the number on the bottom) the same, so instead of 1/4 you'd use
>> > 2/8ths, which is the same thing but now both numbers have the same base
>> > and
>> > you can do all you your math using just the top numbers. Now, we are
>> > making
>> > 2/8 thick boat a 3/8 thick boat. If our 2/8 (1/4) boat weights 60 lbs.
>> > then
>> > (1/8) weights 30 lbs and 3/8 would weight 3 times the 1/8 weight or 90
>> > lbs.
>> > It is all easier once you have a common base.
of 1/4....
I read it to fast..
plywood..UNLESS..
ply and be done..
"Wrong" way.
Be well, Chief.
> Tom
>> the masses..
>> smile.
>> > your
>> > and
>> > making
>> > then
>> > lbs.
Ha! Yes, so if I have a 3/8 boat and want one a third lighter I would use 1/4 ply, right?
frank!
Sent from my iPad
> the masses..
> smile.
> On 12/26/13, sirdarnell@... <sirdarnell@...> wrote:
>> 1/4 to 3/8, when you are working with fractions you first need to make your
>> 2/8ths, which is the same thing but now both numbers have the same base and
>> you can do all you your math using just the top numbers. Now, we are making
>> 2/8 thick boat a 3/8 thick boat. If our 2/8 (1/4) boat weights 60 lbs. then
>> (1/8) weights 30 lbs and 3/8 would weight 3 times the 1/8 weight or 90 lbs.
> - Unsubscribe: bolger-unsubscribe@yahoogroups.com
> - Open discussion: bolger_coffee_lounge-subscribe@yahoogroups.com Yahoo Groups Links
frank!
Sent from my iPad
> the masses..
> smile.
> - Open discussion:bolger_coffee_lounge-subscribe@yahoogroups.comYahoo Groups Links
the masses..
smile.
the masses..
smile.
Sent:Thursday, December 26, 2013 8:55:56 AM
Subject:RE: 50% heavier.. WAS.. [bolger] Re: Options for ply thickness for similar sharpie construction on simila
1/4 to 3/8, when you are working with fractions you first need to make your bases (the number on the bottom) the same, so instead of 1/4 you'd use 2/8ths, which is the same thing but now both numbers have the same base and you can do all you your math using just the top numbers. Now, we are making 2/8 thick boat a 3/8 thick boat. If our 2/8 (1/4) boat weights 60 lbs. then (1/8) weights 30 lbs and 3/8 would weight 3 times the 1/8 weight or 90 lbs. It is all easier once you have a common base.
Isn’t it worth reminding ourselves that plywood is not all the boat? In very few boats is it a high percentage of the weight. I think that in my Constant Camber Goodboats, the hull panels, which require no framing or chines or anything but a shoe keel, weigh maybe 25 lbs apiece (1/4” compound curved red cedar plywood for a 17’ x 42” hull) but the finished boat weighs about 115 lbs. The rest must be the epoxy, sheathing, knees, risers, inwales, outwales, hardware, varnish and paint. Then there is the boat with us in it, and whatever else. The fraction added by another eighth inch of ply grows small. And we would only add the extra eighth where it does some good—not over the whole hull.---Mason
From:bolger@yahoogroups.com [mailto:bolger@yahoogroups.com]On Behalf Ofsirdarnell@...
Sent:Thursday, December 26, 2013 9:56 AM
I always struggled with fractions and percentages. In an earlier life, I
used to hang out with insurance actuaries and they tried very hard to
educate me. (Sometimes they were successful and sometimes I stayed
confused.) It all depends on whether you start with the large number as the
base or the small number as the base. Assume that a boat is built out of
3/8" ply and weighs 90 lbs. Build the same boat out of 1/4" and it will
weigh 60 lbs or be 1/3 lighter than the 3/8's inch boat. But the 3/8's inch
boat will be 30 lbs heavier (50%) than the 1/4" boat. The difference is 30
lbs either way. Whether the 30 lbs is 50% or 33.3% depends on which boat you
use as the base.
Don't feel bad; one of my employees never could figure it out!
JohnT
Leigh Ross
484-464-1575 (C)
www.unicornkayaks.com
> On Dec 24, 2013, at 18:19, John Weiss <jrweiss98020@...> wrote:
> 3/8 is 50% more than 1/4:
> 150% = 150/100 = 3/2
> 1/4 x 3/2 = 3/8
>> On 12/24/2013 11:05, Chief Redelk wrote:
>> Quote..<If you assume that ¼” and 3/8’” plywood have equal densities,
>> 3/8” weighs 50% more than ¼”. If you assume a straight substitution of
>> 3/8” for ¼” (with no change in framing), then a hull made if 3/8” will
>> weigh 50% more than an identical hull made of ¼”.>
>> John, not doubting you but my thinking went like this..
>> If a boat would weigh 60 lbs in 1/4 ply it seems 3/8 ply would be
>> adding only 1/3 more wood..it should weigh 1/3 more..For example a 90
>> lbs boat normally made out of 1/4 built with 3/8 ply should have 30
>> lbs more wood added so it seems it would weight 120 lbs built using
>> 3/8 ply...
1/4 x 3/2 = 3/8
> 3/8 ply...
use as the base.
JohnT
Chief Redelk
Sent: Tuesday, December 24, 2013 2:06 PM
Subject: 50% heavier.. WAS.. [bolger] Re: Options for ply thickness for
Quote..<If you assume that ¼ and 3/8 plywood have equal densities,
3/8 weighs 50% more than ¼. If you assume a straight substitution of
3/8 for ¼ (with no change in framing), then a hull made if 3/8 will
weigh 50% more than an identical hull made of ¼. >
3/8 ply...
From what I understood in your quote that same boat would weigh 90lbs
+ 45lbs and equal 135lbs. net weight finished..15 lbs more than my
figures....
I can see that if we build 1/2 ply instead of 1/4 we should have
doubled the wood and therefore doubled the net weight.
But when we change from 1/4 ply to 3/8 ply we did increase our wood
thickness by 1/3 but how can 1/3 more change the boat to half as much
again..?..
Can you explain how you did the math to get 50 percent more weight..
If I build a small boat in 1/4 and it comes in net weight at 90 lbs
it's much to heavy for me to handle without a trailer..
SO IF I build that same boat using 3/8 and it comes in only 1/3
heavier and rides on a trailer I can live with that and in my mind is
not a big difference in net boat weight..
In fact I can live with 50 percent more weight but I am not sure how
you got that figure.
I did the math a few different ways and once I got the same figures
you did. I am not sure what I did to arrive there,, smile..
If you have the time would you explain your math..I mean how did you
arrive that 3/8 ply would be 50 percent heavier..?.. Is that just a
known standard...?
Thanks, Chief..
On 12/24/13, John Trussell <jtrussell2@...> wrote:
> If you assume that ¼ and 3/8 plywood have equal densities, 3/8 weighs
> 50% more than ¼. If you assume a straight substitution of 3/8 for ¼
> (with
> no change in framing), then a hull made if 3/8 will weigh 50% more than
an
> There are a variety of ways to address boat weight, strength, and
> stiffness.
> Decks which are not intended to support people (such as those on kayaks)
> can
> be very thin (and some of these are made of fabric). However, very thin
> bottoms dont work very well due to flexibility and lack of durability.
The
> trick is to use thicker stuff where you need it and thinner stuff
> elsewhere.
> Another approach is to support relatively thin skins with closely spaced
> framing. Some examples, such as skin on frame boats are obvious. Others,
> such as the stringers on cold molded boats, the laps on lapstrake boats,
or
> even the fillets on stitch and glue boats are somewhat less obvious.
> Another
> possibility is to box in the space between longitudinal thwarts and the
> bottom of the boat, creating box girders for torsional stiffness and for
> adding a longitudinal frame on the bottom.
> Finally, it is possible to add strength and stiffness to a hull by adding
> layer of fiberglass on the outside of the boat. Many strip build boats add
> a
> layer of fiberglass on the inside and outside of the boat creating a wood
> cored fiberglass boat. This can create a very light, strong, and stiff
> boat.
> All boats are compromises and one of the areas of compromise is
scantlings.
> Many stitch and glue boats were designed on the premise that they would be
> built out of readily available, construction grade material and ¼ works
> pretty well for most small boats. But without constraints dictated by the
> need to market boat plans, it is likely that many small boats would have
> heavier bottoms and thinner sides.
> JohnT
> _____
> Chief Redelk
> Sent: Monday, December 23, 2013 5:40 PM
> Subject: Re: [bolger] Re: Options for ply thickness for similar sharpie
> I made that discovery on small boats too..
> I am of the opinion that 3/8 plywood is MUCH stiffer than 1/4,
> stronger and not a lot heavier..
> I find a full 3/8 plywood deck well supported works well..When I
> design a deck that will be walked on I think of picture frames or 4
> sides boxes 12 inches wide by 12 inches long by 3 inches deep..Bracing
> like that well supported then covered with 3/8 ply is very strong..I
> think that a brace every 12 inches is my standard.. Ribs once were set
> that close but on some boats I open them up to 16 inches.. However,
> Stitch and glue boats don't fit that rule..
> My next boat will have a 3/8 plywood bottom, 3/8 decks and maybe 3/8
> all over.. BUT since it's gonna be a 12 feet long scow maybe I will
> make the sides out of 1/4 ext ply...BUT the fact is I am not sure the
> weight difference is worth all the trouble of using two thicknesses of
> plywood..
> In my mind there are TWO boat options when it comes to materials.. ONE
> for boats on trailers and the other ONE for boats designed to be
> LIGHT.. Since I trailer all my boats, just a tad Heavier is not a
> problem..
> I am not talking excessively Heavy boats or over built boats.. just
> boats using 3/8 versus 1/4 plywood..1 inch by 1 inch bracing is good
> IF it's not hanging in the air..Well braced boats need to be
> overweight.. Good day, Chief..
> On 12/23/13, MylesJ. Swift <mswift@...> wrote:
>> I ended up doubling the ¼ inch bottom and main deck on my Micro. With
>> four
>> 200pounds plus guys dancing on the deck it flexed too much for my
>> comfort.
>> MylesJ
horses
(978) 282-1349
Groups Links
weigh 50% more than an identical hull made of ¼”. >
3/8 ply...
figures....
again..?..
known standard...?
Thanks, Chief..
> If you assume that ¼” and 3/8’” plywood have equal densities, 3/8” weighs
> 50% more than ¼”. If you assume a straight substitution of 3/8” for ¼”
> (with
> no change in framing), then a hull made if 3/8” will weigh 50% more than an
> stiffness.
> can
> bottoms don’t work very well due to flexibility and lack of durability. The
> elsewhere.
> such as the stringers on cold molded boats, the laps on lapstrake boats, or
> Another
> Finally, it is possible to add strength and stiffness to a hull by adding a
> a
> boat.
> All boats are compromises and one of the areas of compromise is scantlings.
> built out of readily available, construction grade material and ¼” works
> JohnT
> _____
> Chief Redelk
> plywood..
> problem..
>> four
>> comfort.
>> MylesJ
