RE: Good lug sailmaker?
Thank you for posting this.  My light air sail will have one reef and being a loose footed standing lug sail I was not sure how I was going to tie in the reef.  Now I won't have to reinvent something already solved.
Eric
i don't know if it's been suggested, but i would check duckworks magazine. i ordered a sprit sail through them to replace one i had been using for 17 years. i made the original out of an old head sail from a large cutter. it always worked well, but i thought a professionally made sail might make a difference. their cost was reasonable and the quality was excellent. the new sail pulls like a champ. the difference is amazing.
i know a sprit sail isn't a lug sail but, they certainly must understand four sided sails and the quality of the sail i got from them is excellent.i drew the sail i wanted, with dimensions and CE on the drawing, and emailed it to them. i received my sail in the mail and it was exactly what i wanted.
Eric, well, I found out that Manchester Sailmakers IS STILL in business, but now answers the phone under Doyle. 508-992-6322. 278 Elm St. S. Dartmouth, MA 02748. Don’t know if all the four-sided sailmaking skills went out the door with Ike, but their website professes expertise in this area. Anyways, there it is. Sorry for the confusion.
From:bolger@yahoogroups.com [mailto:bolger@yahoogroups.com]On Behalf Ofphilbolger@...
Sent:Sunday, January 26, 2014 11:13 AM
Subject:Re: [bolger] RE: Good lug sailmaker?
Check out Sail-Maker Roy Downs of Danvers, MA.
He did the 900+sq.ft. Dipping-Lug for Design #621 “REIVER-II”, and it looked decent with adequate draft, if I recall correctly...
It seems that he understands 4-sided sails, unlike quite a few others.
Susanne Altenburger, PB&F
Sent:Sunday, January 26, 2014 10:26 AM
Well Ike is out of the business and brewing beer in Portland. Paint me green..
Sorry that lead ran out.
Sent from my iPhone
On Jan 25, 2014, at 7:54 PM, "eric14850@..." <eric14850@...> wrote:
Contact information for Manchester Sails?
A nice solution for reefing a large sprit sail....perhaps?
From the Wharram group.
Pat
Sent from my iPhone
Sent from my iPhone
Checking.
Sent from my iPhone
Mason's critique is why I went to Doug first, and he lives just down the street from me.  However, he does not build sails as large as I need.
Patrick and Leigh,thank you for your suggestions.  I will check both shops out.
Eric
I’d recommend Douglas Fowler, of Ithaca, NY, who has made all my sails for Goodboats and Rushton Vespers, Bolger Birdwatchers and Micro. I think they are astutely cut, with plenty of draft via broadseam. He’s a one-man shop, not high-tech. As I said recently here, his standing lugsails for the Goodboats sailed rings around the very well-made but flat sails I was using at first. To judge from the informal match sailing we did with two other Micros at Gloucester, at Phil’s memorial gathering, Douglas’s Micro sails are relatively fast too. I also had him make a working jib for a 23’ antique sloop that transformed our sailing in that 1951 CYC raceboat. The sails are durable but not overdone—appropriate to my uses. Good prices too.  ---Mason
From:bolger@yahoogroups.com [mailto:bolger@yahoogroups.com]On Behalf Oferic14850@...
Sent:Sunday, January 12, 2014 9:52 PM
Subject:[bolger] Good lug sailmaker?
Can anyone recommend a sailmaker skilled at sewing lug sails properly?  I need three sails sewn for me.  A balanced lug of approx 110 sq ft.  Balanced lug of approx 250 sq ft and a standing lug of approx 250 sq ft.  I expect 90* tacks which is what ROGUE will do with the cobbled sails I am currently using.  And I expect them to pull like genoas.  In other words I expect better results than with the chopped up used sails I have been getting by with.
Eric
Manchester sails did mine and a fine job too.
Sent from my iPhone
Eric
I gotta set of sails for my Martha Jane from Peak Sails for just over $800. Haven't used them yet so can't comment on the cut or durability. Other quotes ranged from $2400 to $1200.
Leigh Ross
484 464 1575 C
610  624 1730 H
Eric
Eric
