Re: [bolger] RE: Tennessee build
Thanks for the correction.
More precise than my quick note.
“You’ll know it when you see it...”
Susanne Altenburger, PB&F
Engineer's scale rules measure in tenths and other odd scales, don't you
mean an architect's scale rule? They're in
fractions:
http://www.amazon.com/exec/obidos/ASIN/B001DNHG64/themotherofal-20
http://www.amazon.com/exec/obidos/ASIN/B00006IAOX/themotherofal-20
On
Sat, 15 Feb 2014 16:29:12 -0800, Susanne wrote:
> Unless‘reverse-engineering’ matters for whatever reasons, STAPLES will
> sellyou a six-sided ‘Engineers Scale’ @ $8.- with which just about all
> ofPB&F plans’ scales can be read reliably.
John (jkohnen@...)
If one morning I walked on top of the water across the Potomac River, the
headline that afternoon would read "President Can't Swim.” Lyndon Johnson
mean an architect's scale rule? They're in fractions:
On Sat, 15 Feb 2014 16:29:12 -0800, Susanne wrote:
> Unless ‘reverse-engineering’ matters for whatever reasons, STAPLES will
> sell you a six-sided ‘Engineers Scale’ @ $8.- with which just about all
> of PB&F plans’ scales can be read reliably.
John (jkohnen@...)
Some scales
to help with reading your blueprints:
In our case
3/4" = 1'0" which comes out to 1/16th of a inch = 1 inch on the
prints.
Conversion
Table: True Size (Feet) to Scale Size (Inches):
The
following table, developed by Ken Dorr, allows you to convert dimensions on
prototype, measured in feet, to dimensions on a model, measured in inches. To
use the table, find the prototype dimension in feet in the left hand column.
Then translate across until you reach the scale column for the scale of your
model, and read off the scale dimension in inches. If the dimension you are
looking for is not on the chart, you can find it by adding two other dimensions.
Example #1 : A plank on the original ship is 20 feet long. To determine the
length of this plank at 3/8"=1' scale, find the row for 20 feet, then translate
across to the column labeled 3/8. The value at the intersection (7-1/2) is the
length of the scale plank in inches. Example #2: A ship's boom on the prototype
is 38 feet long. You which to determine the scale length of the boom at 3/16"=1'
scale. Since this value is not shown on the chart, two look-up operations are
needed. First, look up 30 feet in the right hand column. Translating across to
the 3/16 column, we find the value 4-5/8 inches. This gives you the length of a
30 foot boom at 3/16"=1' scale. Next, starting in the left-most column with a
length of 8 feet, translate across to the 3/16 column. This gives you scale
length of the remaining 8 feet, 1-1/2 inch. Adding the two scale sizes together,
you find that the length of the 38 foot boom is 4 5/8 + 1 1/2 = 6 1/8 inches in
length at 3/16"=1' scale.
In our case 3/4" = 1'0" which comes out to 1/16th of a inch = 1 inch on the prints.
Conversion Table: True Size (Feet) to Scale Size (Inches):
The following table, developed by Ken Dorr, allows you to convert dimensions on prototype, measured in feet, to dimensions on a model, measured in inches. To use the table, find the prototype dimension in feet in the left hand column. Then translate across until you reach the scale column for the scale of your model, and read off the scale dimension in inches. If the dimension you are looking for is not on the chart, you can find it by adding two other dimensions. Example #1 : A plank on the original ship is 20 feet long. To determine the length of this plank at 3/8"=1' scale, find the row for 20 feet, then translate across to the column labeled 3/8. The value at the intersection (7-1/2) is the length of the scale plank in inches. Example #2: A ship's boom on the prototype is 38 feet long. You which to determine the scale length of the boom at 3/16"=1' scale. Since this value is not shown on the chart, two look-up operations are needed. First, look up 30 feet in the right hand column. Translating across to the 3/16 column, we find the value 4-5/8 inches. This gives you the length of a 30 foot boom at 3/16"=1' scale. Next, starting in the left-most column with a length of 8 feet, translate across to the 3/16 column. This gives you scale length of the remaining 8 feet, 1-1/2 inch. Adding the two scale sizes together, you find that the length of the 38 foot boom is 4 5/8 + 1 1/2 = 6 1/8 inches in length at 3/16"=1' scale.
