Re: Engine size
Good luck
Pat
Sent from my iPad
Leigh Ross
On Aug 28, 2014, at 13:04, "mswift@...[bolger]" <bolger@yahoogroups.com> wrote:
I traded mail with Phil Bolger on this exact point for my Micro. He said 8hp if you ever have to come in against wind and tide, 5hp in protected water. I use a 3hp electric on Micro to get in and out of the marina at half to full power in decent weather. I think one of those 9.9hp motors with the high thrust prop would cover all cases for your Martha Jane, less in sheltered water.MylesJ
http://www.onlineoutboards.com/Tohatsu-3-5-hp-Outboards.html
Looking for group wisdom. I launched my Martha Jane and found out that my mighty 1.2hp Cruise n Carry just wasn't up to the job of powering such a huge vessel. I'm now considering moving up to a 3.5 Mercury Mariner. I m not looking for passage making ability, just to get off the launch ramp and back in. Also don't want a very heavy engine. Or expensive. Does anyone have experience with this and have any suggestions as to suitable motors, horse power etc. ?
This email is free from viruses and malware becauseavast! Antivirusprotection is active.
I might add- two stroke. Cheaper and easier to maintain and a lot lighter. Flush out the engine after using in salt water!
After 24 years I recently had the lower unit and carb rebuilt by a local motorhead after the shaft seal failed. $324.00- the first dollars expended (other than the $85 prop) since purchased. Compression still on spec . on a $250 motor bought used. I have heard a lot of complaints on the more recent Tohatsu's but the older ones are good motors.
Patrick A. Connor
Executive Vice President & Manager,
National Services Group
Old Republic National Title Insurance Company
141 East Town Street, Suite 101
Columbus, Ohio 43215-5142
Phone: 614-341-1900
Mobile: 614-208-9308
Facsimile: 614-341-1903
From:bolger@yahoogroups.com [mailto:bolger@yahoogroups.com]
Sent:Wednesday, August 27, 2014 9:39 AM
To:Bolger Group
Subject:[bolger] Engine size
Looking for group wisdom. I launched my Martha Jane and found out that my mighty 1.2hp Cruise n Carry just wasn't up to the job of powering such a huge vessel. I'm now considering moving up to a 3.5 Mercury Mariner. I m not looking for passage making ability, just to get off the launch ramp and back in. Also don't want a very heavy engine. Or expensive. Does anyone have experience with this and have any suggestions as to suitable motors, horse power etc. ? |
Find a good used two stroke 5HP or so. I found an aftermarket 4-blade prop for the1990 8hp Nissan on the stern of my Whalewatcher that moves her forward and more importantly, backward, with authority. this motor has worked flawlessly for motoring over many, many windless miles of cruising. You need a good motor/prop combination with these high-sided sharpies for close in low speed maneuvering in marinas, etc.; the rudders are small and simply not efficient enough for good control at low speeds.
Raise the motor when sailing!
Patrick A. Connor
Phone: 614-341-1900
To:Bolger Group
