Re: [bolger] list of over 300 different rowboats
On May 5, 2015, at 7:50 PM,philbolger@...[bolger] <bolger@yahoogroups.com> wrote:Good to be able to count on good spirits out there.
Bruce’s list is more inclusive than my brief assessment.
And that is all to better.
Here in Gloucester the seemingly ‘endless’ boat-project a.k.a. SACPAS-3 should at long last get wet soon.
With perfect weather on hand some minor epoxy work is left, a final coat of paint over near everything inside her, a bit more wiring, and a shrinking list of modest hardware-installations such as those fine SS-Cleats.
The 225HP V-6 that looks so imposing up close tilts up very nicely within the boat’s stern-extension with about 1.5 inches to spare to cover different prop-configurations, -diameter and -pitch – very gratifying that, in terms of not having dreamt up and then carefully built an incorrect geometry...
And that means that to ready her for use after the shipment to who-knows-where in the standard ISO 40-foot container is a matter of pulling her out of the box on to rollers (freshly-cut saplings), recharging the batteries, putting fresh fuel into those tanks and once afloat tilting down the OB to dead-vertical.
Next question: How will that container-procedure work ?
I’ll keep you posted.
Susanne Altenburger, PB&FSent: Tuesday, May 05, 2015 5:09 PMSubject: Re: [bolger] list of over 300 different rowboatsHi Peter,I too have been working on a list including Bolger rowboats, by my quick and dirty count there are 63.You may not be aware of my (presently neglected) listing of Bolger designs atBelow is a table listing the 63 designs that involve oar power:
BoatName BoatDesc BoatNo BoatSize Published Comments Casual Sailing Dinghy Sail Row Cartoon#40 16' or 19'6 X 6' SBJ#64 gaff cat, centreboard, day-racer-sailer. aka Cartoon 40 aka Plywood Catboat Amesbury Skiff 'Mippet' oar #260 9'6" x 3'6" Multi-chined rowing skiff - Ref. SmallBoats Ch#1 Anhinga Sailing canoe + oars #484 23'3" x 5' x 7" V06-N11 Built by David Bredemeier, aka "Sandy Bottoms", spare plywood water ballasted sharpie. Auray Punt Row #599 9'9" x4'2" V10-N18,V18-N08, BWAOM Ch#05 Punt - plywood Beach Cruiser Concept Cat yawl/rowboat 19' x 4'3" V16-N01 Quick to build solo beach cruiser Birdwatcher II Sail, oar, power #496B 23'6" x 5'7" Small Craft Advisor #69, 2004 upgrade of Birdwatcher, ref: Wooden Boat Magazine Aug2004 issue. Breakdown Punt Row 5'6" x3'6" BWAOM Ch#01, SBJ#65 Punt - plywood tender. aka "Nesting Punt" Brick 7ft oars, 59sf Sail, 837lbs displ. #458 8' x4' V15-N23, CSD, BWAOM Ch#02 Punt - plywood 'best possible use of three sheets of plywood' Camp Cruiser Sail or oars Concept 19'0"x4'4" V13-N09 Concept design, with low freeboard for good rowing geometry, small/narrow cockpit to allow knockdown without swamping. Rockered bottom as typical of sharpie sailboats. Designed for Dr. Barry Taylor. Cartopper sail, row, power #519 11'6'X4' Ceremonial Barge Row 23'3" x4'6" BWAOM Ch#12, SBJ#62 Rowboat - plywood, four oars Cruising Rowboat Row - 2,050lbs displ. 21' x5' BWAOM Ch#13 Rowboat - strip planked aka "Lun" Crystal Row - 593lbs. displ. #352 15'6"" x 3'6" SBJ#13, V19-N05, DiffBoats Ch#03 Utility Rowboat with floatation chambers, plywood, 150lbs Defender oar #236 11' x 3'10" Vintage lapstrake yacht tender Dido Sprit Cat Yawl, w/ 9' oar #431 25'7"x6'7"x7" Fiberglass/Airex homebuild option to a Dovekie + precurser to Birdwatcher. Dolphin Row, Sail - 1,200lbs #259 18' x4' SmallBoats Ch#9 Dayboat - round-bilge double-ender Donovan's Tender Oars #647 11'8" x 4'2" V15-N18 Modified punt rowboat with low power OB option. Dovekie Sail, Row #292 21.4' x6' FoldingSch Ch#24 Cruiser - production fibreglass Dugong 167 sf sail / oars #365 26'0"x5'4"x3 ft SBJ#20, DiffBoats Ch#08, CSD#15 Cold-molded shallow draft camp cruiser big sister to Dovekie, subject of Ida Little's book "Beach Cruising and Coastal Camping" Featherwind sail/row #262 15'6" x 4'6" Modified twice by Carnell, approved by Bolger. Hermes Long Distance Rowing #585 21' V17-N23 Long Distance Rowing Cruiser June Bug Row Sail, 1,000lbs displ, 100lbs wt. #400 14'x3'3" V15-N17, SBJ#21 Plywood box boat. "best compromise available for maximum capacity and stability on minimum dimensions and weight" Keel Sailing Dinghy row/sail cat rig #427 8' x 3'9" x 8" V11-N09 Yacht tender, clinker w/bent frames, full keel. Light Dory (Type 1) Golden River Oar 1952? 15'6" x 4' SBJ#07 Planked round-sided dory, early Light Dory design #140 Light Dory (Type 2) Oar 140-11-60 15' 5-1/2" x 4' 0" SBJ#07 1961 Similar brief to round sided Golden River, but flat sided. PCB's own selfbuilt Light Dory (Type 3) Oar #140-3 15'6" SBJ#07 SBJ Feb. 1980. "How to build the Gloucester Light Dory", Payson 1982. Light Dory (Type 4) Glouchester Gull 7ft Oar #140-3 15'6" x 4' SBJ#07, Texas Dory plan 11 Gloucester Gull rowing dory, plans sold by Capt. Jim Orrell. Light Dory (Type 5) oar #265 4.74 m x 1.22 m SBJ#07, BDQ#16 1973 Double-ended. Metric."Small Boats", Ch4, "Light Dory Type V" Light Dory (Type 6) Gloucester Gull Oar #140-6 15'6" x 4' SBJ#07 aka Gloucester Gull rev. Light Dory design #140 - 4 (Type 4) for Dynamite Light Dory (Type 7)) Row #526 19' 6" x 4' V24-N20 Up to 3 people, 1 or 2 rowing. aka "Long Light Dory", Stretched Light Dory Light Dory (Type 8) Three Man rowboat #555 23'6" x 4' V18-N01, V24-N20 Up to 3 rowers. Largest stretch of the "Gull". Light Peapod oars #390 12'0"x3'8" V13-N14 Cold-molded wooden rowboat. Longship Sail, Row 38' x8' BWAOM Ch#39 Open Boat - Viking ship representation Morning Light 22 Sail, Power, & Oar. #190 22'4.5" x 6'6" Texas Dory plan 17 Sea/Surf & Rescue. July 1965. Fishing surf boat (motor well for small OB) boomless 80sf gunter rig w/36sf jib Motor Canoe Row - 545lbs displ. #582 15'9" x3' V09-N20 BWAOM Ch#14 Dayboat - outboard, round bilge Navel Jelly Row #296 31' x4'3" FoldingSch Ch#07 Disposable Racer - 'instant boat' plywood Nymph sail/oar #425 7'9"x3'6" Ocean-Crossing Rowboat Row, Sail - 4,300lbs Concept 33' x6' FoldingSch Ch#25 Rowboat - proposal Ocean-Going Rowing Project Row - 1,600lbs displ. 30' x4'8" SmallBoats Ch#6 Rowboat - round-bilge singlehander Petty Yacht Tender Row, Sail - 430lbs displ. #184 7'9" x 3'10" FoldingSch Ch#18 Dinghy - fibreglass Pirogue 16 sail, oars, paddles #451 16'0"x3'3" Plywood flat-bottom boat with decks designed for cheap fast construction. Plywood Trireme Row FoldingSch Ch#17 Cruiser - undeveloped idea Pointy Skiff Power/Row #329 10'6" x 3'6" SBJ#11, V17-N19 Row or small outboard (3HP) Payson "Instant Boat" Poohsticks oar #010-ii-57 11'4" x 3'10" Small Boats Child's rowing skiff ( Prince William Sound Yawl Sail, OB or oar auxillary #356 16' 3"x 4'6" 200# SBJ#08, V16-N23, DiffBoats Ch#06 Cold-molded cat yawl "maximum car top boat" Recreational Rowboat Row - 630lbs displ. #300 13'9" x4' V18-N22, FoldingSch Ch#21 Dinghy - moulded hull Rose Pinnace Row, Sail #229 28' x6'6" SmallBoats Ch#11 Dayboat - round bilge Rose Yawlboat oar or OB 16'0"x4'5" V13-N10 Steam-bent framed carvel planked deckboats for use on the ship Rose Row/Sail Tender for Tahiti Sail/Oar #655 8' punt with gaff sail & leeboard Rubens Nymph sail, row or 2 HP #516 7'9"x4'6" Same length and construction as Nymph, but wider. Shoebox Punt Oar #539 5'6"x3'6" V07-N02 Compact pram/rowboat for efficient storage. Yacht dingy/tender. Singapore Cutter Sail/oars #617 29'6"x7'6" V12-N01, V18-N15 open sprit yawl designed for up to eight oars . Spur II Utility Rowboat #600 15'4"x4'6" V10-N21, BWAOM Ch#11, BDQ#11, SBJ#77 Rowboat - lapstrake 500lbs displ. aka "Utility Rowing Boat" Spur l (1963) Oar - Whithall Type 16'0" x 4'5" V21-N19 Popular Boating Dec 1964 (cover story); 15Feb2004; See "Small Boats" dust Sweet Pea Row, Sail - weighs 150lbs #570 15' x4'4" BWAOM Ch#10 Dayboat - plywood surf dory sprit or sharpie rig Teal Row-Sail #310 12' X 3'6" V16-N21 elegant small craft, 2 sheets of plywood, "Instant Boat type" Ultra-light rowboat for homebuilders oar Cartoon#05 15' x 3'10" SBJ#29 30-35lbs plywood lapstrake w/truss frames dbl ended rowboat Utility Nesting Skiff Rowboat Concept 11'6"x4'2" V13-N19 Rowboats designed to stack inside each other. Victoria Row - 800lbs displ. #210 15'6" x4'2" V08-N15 SmallBoats Ch#5 Rowboat - round-bilge wooden hull Viking Longship 247sf sail, 14 oars #572 38'x8'x1'11" V09-N05, V20-N04 Built by Willi Hesse, replica of Viking longboat Big Tortoise Row/sail #597 8' x 3'2" Payson Larger version of Tortoise, build by John Kolb. Ch. 10 in Payson's latest book. Perfect Skiff '08 Row/Sail 15'6" Folding skiff, lifeboat capabilities Plywood Canoe Yawl 209sf sail, oar aux 19ft SBJ#48 aka "Cartoon #24" Water ballasted 'vee' bottom plywood canoe yawl On Thu, Apr 30, 2015 at 7:44 AM, peterevans_33@... [bolger] <bolger@yahoogroups.com> wrote:
(Message over 64 KB, truncated)
On Wed, May 6, 2015 at 9:29 PM, Mark Albanesemarka97203@...[bolger]<bolger@yahoogroups.com>wrote:Bruce, your isometric page remains the world's foremost public compendium of Phil Bolger's designs.
Here's another for the list, from almost the last of the SBJ series, Boat Journal #77, 3/91.
The shape is in the same league as Victoria and Spur2.
This was intended to be repeatable in small lots for a builder who had a small clientele of former competitive rowers wanting a great boat to take out the grandkids.
It's built with many plywood chines, faired round bottom smooth and sheathed overall with, "Any convenient cloth," or built plywood lapstrake if preferred.
You have encountered the cost differential between mass produced boats and hand crafted boats. Its called productivity. In the US , you can buy a thermoplastic dinghy which rows pretty well and sails after a fashion for less than $1000. To build a similar sized lapstrake dinghy (Oughtreds Guillemot), you could buy a kit for around $1500, buy the necessary timber (not included in the kit) for $100-150, add in a couple of hundred dollars for epoxy and another couple of hundred for paint, a hundred or so for various disposable items (gloves, sandpaper, masks, brushes, etc), and whatever you want to spend on fasteners and hardware. Spend a 100 hours or so putting the thing together and another 50 hours painting and fitting out (or a lot more if you are going for “yacht” level finish). The result will certainly be superior to a Walker Bay dinghy, but even not counting anything for labor, twice the cost. To build a Guillemot commercially, I think you would have to charge somewhere around $6-7000.
Unfortunately, there is not a large market for rowing boats in the US and the limited number of commercial builders is concentrated in the northeast and northwest of a very large country, so shipping costs add to the purchase price. Ergo, for most of us, the only way to obtain a rowing boat is to build one. One need not have a lapstrake boat. And there are many flat-bottomed and/or stitch and glue row boat plans available from everyone from Atkins to Welford. There is good news. Forty years ago, there was a paucity of row boat plans and they were advertised in specialty news letters. There has since been a revival in wooden/amateur built boat plans, including rowing boats. With the advent of the internet, it is possible to buy plans from designers all over the world and my plan collection includes plans from England and New Zeeland as well as the US . It could be argued that we are in the golden age of small boats.
Finally, I will observe that everything has two prices—what the seller will take and what the buyer will pay. I think that it is unlikely that anyone will pay $20K for an Acorn !5 unless, perhaps, they are buy a piece of art. My boats get used, are finished to workboat standards, and are lightly maintained—scruffy, but loved, and worth more to me than what most buyers would be willing to pay…
JohnT
bolger@yahoogroups.com ]
Sent:Wednesday, May 06, 2015 4:00
AM
Subject:Re: [bolger] list of over
hello
Bruce,
I am very much aware of your isometrics, I have been looking at it in detail.
It gets complicated for me, because if I wish to use another designers boat, I
simply list to one website, then the prospective builder can buy the boat, or
buy the boat plan.
I have 16 Phil Bolger boats on the list.
Some of the boats might be too much sail and not really enough oar. The
delineation between a boat optimised for sail, and rowing is not easy, there
are probably a few too many on the list, because there are some boats that are
too much optimised for sailing, all I can say is the list is imperfect
For Bolger books, I only have dynamite payson's book, which is not actually
written by Phil Bolger. Need to rectify this
The world is moving to the internet, when there is a boat plan that is easily
accessed via the internet, a simple link suffices. For a few cases I have had
to list a Phil Bolger boat twice, once to show the photos, and once to show
where the plans can be bought. The work involved in getting all 600 of Phil
Bolger's boat plans easily accessable via the internet is huge. Would be nice,
but the huge amount of work, for a modest financial return, its very
understandable why it is not done. (yes there are a few on instant boats.com)
Going off topic, last couple weeks I have been looking at heaps of rowboats,
close to 330 or 340 at this time. I came across an Iain Oughtred Acorn 15 boat
for sale for $20K US. You gotta be kidding me. For comparison I came across
some plastic boats sold in Finland ,
called Suvi boats. Very nice rowboats, they have a little transom where a 2hp
motor can be added. They are a fraction heavy, 85kg for a 15ft boat, the
hullform is a little bit of a compromise being fuller aft to support weight of
a person sitting aft with the outboard, but they are not bad. The thing that
struck me, was the cost, $1500 US for a 15ft rowboat
They make hundreds of these boats, and can use economies of scale to keep the
costs down. It does seem teh way of the future, fiberglass/plastic production
rowboats, not quite as good as wood ones, but if the price is a tenth that of a
quality wood boat, what is going to sell? I cannnot explain why US plastic
rowboats cost so much, and similar boats in
Finland cost so little. If Suvi
start exporting their boats to the
US , I am sure they would so well
(no I dont have shares in Suvi boats)
Myydään
Suvi-veneet | Nettivene
| Myydään Suvi-veneet | Nettivene Oletko ostamassa tai myymässä? Nettivene listaa kaikki Suvi-veneet. Löydät palvelusta kätevästi myynnissä olevat Suvi moottori- ja soutuveneet. |
Preview by Yahoo | |||||
I am very much aware of your isometrics, I have been looking at it in detail. It gets complicated for me, because if I wish to use another designers boat, I simply list to one website, then the prospective builder can buy the boat, or buy the boat plan.
Some of the boats might be too much sail and not really enough oar. The delineation between a boat optimised for sail, and rowing is not easy, there are probably a few too many on the list, because there are some boats that are too much optimised for sailing, all I can say is the list is imperfect
For Bolger books, I only have dynamite payson's book, which is not actually written by Phil Bolger. Need to rectify this
The world is moving to the internet, when there is a boat plan that is easily accessed via the internet, a simple link suffices. For a few cases I have had to list a Phil Bolger boat twice, once to show the photos, and once to show where the plans can be bought. The work involved in getting all 600 of Phil Bolger's boat plans easily accessable via the internet is huge. Would be nice, but the huge amount of work, for a modest financial return, its very understandable why it is not done. (yes there are a few on instant boats.com)
Going off topic, last couple weeks I have been looking at heaps of rowboats, close to 330 or 340 at this time. I came across an Iain Oughtred Acorn 15 boat for sale for $20K US. You gotta be kidding me. For comparison I came across some plastic boats sold in Finland, called Suvi boats. Very nice rowboats, they have a little transom where a 2hp motor can be added. They are a fraction heavy, 85kg for a 15ft boat, the hullform is a little bit of a compromise being fuller aft to support weight of a person sitting aft with the outboard, but they are not bad. The thing that struck me, was the cost, $1500 US for a 15ft rowboat
They make hundreds of these boats, and can use economies of scale to keep the costs down. It does seem teh way of the future, fiberglass/plastic production rowboats, not quite as good as wood ones, but if the price is a tenth that of a quality wood boat, what is going to sell? I cannnot explain why US plastic rowboats cost so much, and similar boats in Finland cost so little. If Suvi start exporting their boats to the US, I am sure they would so well (no I dont have shares in Suvi boats)
Scot McPherson, PMP CISSP MCSA
On May 5, 2015, at 5:09 PM, BruceHallmanhallman@...[bolger] <bolger@yahoogroups.com> wrote:
BoatName BoatDesc BoatNo BoatSize Published Comments Casual Sailing Dinghy Sail Row Cartoon#40 16' or 19'6 X 6' SBJ#64 gaff cat, centreboard, day-racer-sailer. aka Cartoon 40 aka Plywood Catboat Amesbury Skiff 'Mippet' oar #260 9'6" x 3'6" Multi-chined rowing skiff - Ref. SmallBoats Ch#1 Anhinga Sailing canoe + oars #484 23'3" x 5' x 7" V06-N11 Built by David Bredemeier, aka "Sandy Bottoms", spare plywood water ballasted sharpie. Auray Punt Row #599 9'9" x4'2" V10-N18,V18-N08, BWAOM Ch#05 Punt - plywood Beach Cruiser Concept Cat yawl/rowboat 19' x 4'3" V16-N01 Quick to build solo beach cruiser Birdwatcher II Sail, oar, power #496B 23'6" x 5'7" Small Craft Advisor #69, 2004 upgrade of Birdwatcher, ref: Wooden Boat Magazine Aug2004 issue. Breakdown Punt Row 5'6" x3'6" BWAOM Ch#01, SBJ#65 Punt - plywood tender. aka "Nesting Punt" Brick 7ft oars, 59sf Sail, 837lbs displ. #458 8' x4' V15-N23, CSD, BWAOM Ch#02 Punt - plywood 'best possible use of three sheets of plywood' Camp Cruiser Sail or oars Concept 19'0"x4'4" V13-N09 Concept design, with low freeboard for good rowing geometry, small/narrow cockpit to allow knockdown without swamping. Rockered bottom as typical of sharpie sailboats. Designed for Dr. Barry Taylor. Cartopper sail, row, power #519 11'6'X4' Ceremonial Barge Row 23'3" x4'6" BWAOM Ch#12, SBJ#62 Rowboat - plywood, four oars Cruising Rowboat Row - 2,050lbs displ. 21' x5' BWAOM Ch#13 Rowboat - strip planked aka "Lun" Crystal Row - 593lbs. displ. #352 15'6"" x 3'6" SBJ#13, V19-N05, DiffBoats Ch#03 Utility Rowboat with floatation chambers, plywood, 150lbs Defender oar #236 11' x 3'10" Vintage lapstrake yacht tender Dido Sprit Cat Yawl, w/ 9' oar #431 25'7"x6'7"x7" Fiberglass/Airex homebuild option to a Dovekie + precurser to Birdwatcher. Dolphin Row, Sail - 1,200lbs #259 18' x4' SmallBoats Ch#9 Dayboat - round-bilge double-ender Donovan's Tender Oars #647 11'8" x 4'2" V15-N18 Modified punt rowboat with low power OB option. Dovekie Sail, Row #292 21.4' x6' FoldingSch Ch#24 Cruiser - production fibreglass Dugong 167 sf sail / oars #365 26'0"x5'4"x3 ft SBJ#20, DiffBoats Ch#08, CSD#15 Cold-molded shallow draft camp cruiser big sister to Dovekie, subject of Ida Little's book "Beach Cruising and Coastal Camping" Featherwind sail/row #262 15'6" x 4'6" Modified twice by Carnell, approved by Bolger. Hermes Long Distance Rowing #585 21' V17-N23 Long Distance Rowing Cruiser June Bug Row Sail, 1,000lbs displ, 100lbs wt. #400 14'x3'3" V15-N17, SBJ#21 Plywood box boat. "best compromise available for maximum capacity and stability on minimum dimensions and weight" Keel Sailing Dinghy row/sail cat rig #427 8' x 3'9" x 8" V11-N09 Yacht tender, clinker w/bent frames, full keel. Light Dory (Type 1) Golden River Oar 1952? 15'6" x 4' SBJ#07 Planked round-sided dory, early Light Dory design #140 Light Dory (Type 2) Oar 140-11-60 15' 5-1/2" x 4' 0" SBJ#07 1961 Similar brief to round sided Golden River, but flat sided. PCB's own selfbuilt Light Dory (Type 3) Oar #140-3 15'6" SBJ#07 SBJ Feb. 1980. "How to build the Gloucester Light Dory", Payson 1982. Light Dory (Type 4) Glouchester Gull 7ft Oar #140-3 15'6" x 4' SBJ#07, Texas Dory plan 11 Gloucester Gull rowing dory, plans sold by Capt. Jim Orrell. Light Dory (Type 5) oar #265 4.74 m x 1.22 m SBJ#07, BDQ#16 1973 Double-ended. Metric."Small Boats", Ch4, "Light Dory Type V" Light Dory (Type 6) Gloucester Gull Oar #140-6 15'6" x 4' SBJ#07 aka Gloucester Gull rev. Light Dory design #140 - 4 (Type 4) for Dynamite Light Dory (Type 7)) Row #526 19' 6" x 4' V24-N20 Up to 3 people, 1 or 2 rowing. aka "Long Light Dory", Stretched Light Dory Light Dory (Type 8) Three Man rowboat #555 23'6" x 4' V18-N01, V24-N20 Up to 3 rowers. Largest stretch of the "Gull". Light Peapod oars #390 12'0"x3'8" V13-N14 Cold-molded wooden rowboat. Longship Sail, Row 38' x8' BWAOM Ch#39 Open Boat - Viking ship representation Morning Light 22 Sail, Power, & Oar. #190 22'4.5" x 6'6" Texas Dory plan 17 Sea/Surf & Rescue. July 1965. Fishing surf boat (motor well for small OB) boomless 80sf gunter rig w/36sf jib Motor Canoe Row - 545lbs displ. #582 15'9" x3' V09-N20 BWAOM Ch#14 Dayboat - outboard, round bilge Navel Jelly Row #296 31' x4'3" FoldingSch Ch#07 Disposable Racer - 'instant boat' plywood Nymph sail/oar #425 7'9"x3'6" Ocean-Crossing Rowboat Row, Sail - 4,300lbs Concept 33' x6' FoldingSch Ch#25 Rowboat - proposal Ocean-Going Rowing Project Row - 1,600lbs displ. 30' x4'8" SmallBoats Ch#6 Rowboat - round-bilge singlehander Petty Yacht Tender Row, Sail - 430lbs displ. #184 7'9" x 3'10" FoldingSch Ch#18 Dinghy - fibreglass Pirogue 16 sail, oars, paddles #451 16'0"x3'3" Plywood flat-bottom boat with decks designed for cheap fast construction. Plywood Trireme Row FoldingSch Ch#17 Cruiser - undeveloped idea Pointy Skiff Power/Row #329 10'6" x 3'6" SBJ#11, V17-N19 Row or small outboard (3HP) Payson "Instant Boat" Poohsticks oar #010-ii-57 11'4" x 3'10" Small Boats Child's rowing skiff ( Prince William Sound Yawl Sail, OB or oar auxillary #356 16' 3"x 4'6" 200# SBJ#08, V16-N23, DiffBoats Ch#06 Cold-molded cat yawl "maximum car top boat" Recreational Rowboat Row - 630lbs displ. #300 13'9" x4' V18-N22, FoldingSch Ch#21 Dinghy - moulded hull Rose Pinnace Row, Sail #229 28' x6'6" SmallBoats Ch#11 Dayboat - round bilge Rose Yawlboat oar or OB 16'0"x4'5" V13-N10 Steam-bent framed carvel planked deckboats for use on the ship Rose Row/Sail Tender for Tahiti Sail/Oar #655 8' punt with gaff sail & leeboard Rubens Nymph sail, row or 2 HP #516 7'9"x4'6" Same length and construction as Nymph, but wider. Shoebox Punt Oar #539 5'6"x3'6" V07-N02 Compact pram/rowboat for efficient storage. Yacht dingy/tender. Singapore Cutter Sail/oars #617 29'6"x7'6" V12-N01, V18-N15 open sprit yawl designed for up to eight oars . Spur II Utility Rowboat #600 15'4"x4'6" V10-N21, BWAOM Ch#11, BDQ#11, SBJ#77 Rowboat - lapstrake 500lbs displ. aka "Utility Rowing Boat" Spur l (1963) Oar - Whithall Type 16'0" x 4'5" V21-N19 Popular Boating Dec 1964 (cover story); 15Feb2004; See "Small Boats" dust Sweet Pea Row, Sail - weighs 150lbs #570 15' x4'4" BWAOM Ch#10 Dayboat - plywood surf dory sprit or sharpie rig Teal Row-Sail #310 12' X 3'6" V16-N21 elegant small craft, 2 sheets of plywood, "Instant Boat type" Ultra-light rowboat for homebuilders oar Cartoon#05 15' x 3'10" SBJ#29 30-35lbs plywood lapstrake w/truss frames dbl ended rowboat Utility Nesting Skiff Rowboat Concept 11'6"x4'2" V13-N19 Rowboats designed to stack inside each other. Victoria Row - 800lbs displ. #210 15'6" x4'2" V08-N15 SmallBoats Ch#5 Rowboat - round-bilge wooden hull Viking Longship 247sf sail, 14 oars #572 38'x8'x1'11" V09-N05, V20-N04 Built by Willi Hesse, replica of Viking longboat Big Tortoise Row/sail #597 8' x 3'2" Payson Larger version of Tortoise, build by John Kolb. Ch. 10 in Payson's latest book. Perfect Skiff '08 Row/Sail 15'6" Folding skiff, lifeboat capabilities Plywood Canoe Yawl 209sf sail, oar aux 19ft SBJ#48 aka "Cartoon #24" Water ballasted 'vee' bottom plywood canoe yawl On Thu, Apr 30, 2015 at 7:44 AM,peterevans_33@...[bolger]<bolger@yahoogroups.com>wrote:I have written up a list of over 300 different rowboat designs. The list is open source, anyone is free to copy, paste, modify, edit it in any way. There are a few bolger rowboats on there. My main aim was to provide a useful resource to allow the builder ,designer or buyer to find what rowboats are in existence and find the best one that suits them. I have tried to find as many as I could, the list is not perfect as I only know what I know. At the moment I am up to about 310 different boats. Hopefully it may alleviate the questions like,,, looking for a rowboat about 12ft,,, what do you think is a good one.
The list is sorted by length, has length, beam and a link to a website for each rowboat. Please feel free to copy the list if you wish, please feel free to paste it anywhere if you wish and add to it at your leisure. I have not got every boat out there, but feel it is a pretty good start. more rowboats are always welcome. The list can be seen here
tacking-outrigger.com Rowboat List
tacking-outrigger.com Rowboat ListHome LIST OF 300 DIFFERENT ROWBOATS About this list Now for a list of Rowboats, length and width and website link for each rowboat are included. Preview by Yahoo
| BoatName | BoatDesc | BoatNo | BoatSize | Published | Comments |
| Casual Sailing Dinghy | Sail Row | Cartoon#40 | 16' or 19'6 X 6' | SBJ#64 | gaff cat, centreboard, day-racer-sailer. aka Cartoon 40 aka Plywood Catboat |
| Amesbury Skiff 'Mippet' | oar | #260 | 9'6" x 3'6" | Multi-chined rowing skiff - Ref. SmallBoats Ch#1 | |
| Anhinga | Sailing canoe + oars | #484 | 23'3" x 5' x 7" | V06-N11 | Built by David Bredemeier, aka "Sandy Bottoms", spare plywood water ballasted sharpie. |
| Auray Punt | Row | #599 | 9'9" x4'2" | V10-N18,V18-N08, BWAOM Ch#05 | Punt - plywood |
| Beach Cruiser Concept | Cat yawl/rowboat | 19' x 4'3" | V16-N01 | Quick to build solo beach cruiser | |
| Birdwatcher II | Sail, oar, power | #496B | 23'6" x 5'7" | Small Craft Advisor #69, | 2004 upgrade of Birdwatcher, ref: Wooden Boat Magazine Aug2004 issue. |
| Breakdown Punt | Row | 5'6" x3'6" | BWAOM Ch#01, SBJ#65 | Punt - plywood tender. aka "Nesting Punt" | |
| Brick | 7ft oars, 59sf Sail, 837lbs displ. | #458 | 8' x4' | V15-N23, CSD, BWAOM Ch#02 | Punt - plywood 'best possible use of three sheets of plywood' |
| Camp Cruiser | Sail or oars | Concept | 19'0"x4'4" | V13-N09 | Concept design, with low freeboard for good rowing geometry, small/narrow cockpit to allow knockdown without swamping. Rockered bottom as typical of sharpie sailboats. Designed for Dr. Barry Taylor. |
| Cartopper | sail, row, power | #519 | 11'6'X4' | ||
| Ceremonial Barge | Row | 23'3" x4'6" | BWAOM Ch#12, SBJ#62 | Rowboat - plywood, four oars | |
| Cruising Rowboat | Row - 2,050lbs displ. | 21' x5' | BWAOM Ch#13 | Rowboat - strip planked aka "Lun" | |
| Crystal | Row - 593lbs. displ. | #352 | 15'6"" x 3'6" | SBJ#13, V19-N05, DiffBoats Ch#03 | Utility Rowboat with floatation chambers, plywood, 150lbs |
| Defender | oar | #236 | 11' x 3'10" | Vintage lapstrake yacht tender | |
| Dido | Sprit Cat Yawl, w/ 9' oar | #431 | 25'7"x6'7"x7" | Fiberglass/Airex homebuild option to a Dovekie + precurser to Birdwatcher. | |
| Dolphin | Row, Sail - 1,200lbs | #259 | 18' x4' | SmallBoats Ch#9 | Dayboat - round-bilge double-ender |
| Donovan's Tender | Oars | #647 | 11'8" x 4'2" | V15-N18 | Modified punt rowboat with low power OB option. |
| Dovekie | Sail, Row | #292 | 21.4' x6' | FoldingSch Ch#24 | Cruiser - production fibreglass |
| Dugong | 167 sf sail / oars | #365 | 26'0"x5'4"x3 ft | SBJ#20, DiffBoats Ch#08, CSD#15 | Cold-molded shallow draft camp cruiser big sister to Dovekie, subject of Ida Little's book "Beach Cruising and Coastal Camping" |
| Featherwind | sail/row | #262 | 15'6" x 4'6" | Modified twice by Carnell, approved by Bolger. | |
| Hermes | Long Distance Rowing | #585 | 21' | V17-N23 | Long Distance Rowing Cruiser |
| June Bug | Row Sail, 1,000lbs displ, 100lbs wt. | #400 | 14'x3'3" | V15-N17, SBJ#21 | Plywood box boat. "best compromise available for maximum capacity and stability on minimum dimensions and weight" |
| Keel Sailing Dinghy | row/sail cat rig | #427 | 8' x 3'9" x 8" | V11-N09 | Yacht tender, clinker w/bent frames, full keel. |
| Light Dory (Type 1) Golden River | Oar | 1952? | 15'6" x 4' | SBJ#07 | Planked round-sided dory, early Light Dory design #140 |
| Light Dory (Type 2) | Oar | 140-11-60 | 15' 5-1/2" x 4' 0" | SBJ#07 | 1961 Similar brief to round sided Golden River, but flat sided. PCB's own selfbuilt |
| Light Dory (Type 3) | Oar | #140-3 | 15'6" | SBJ#07 | SBJ Feb. 1980. "How to build the Gloucester Light Dory", Payson 1982. |
| Light Dory (Type 4) Glouchester Gull | 7ft Oar | #140-3 | 15'6" x 4' | SBJ#07, Texas Dory plan 11 | Gloucester Gull rowing dory, plans sold by Capt. Jim Orrell. |
| Light Dory (Type 5) | oar | #265 | 4.74 m x 1.22 m | SBJ#07, BDQ#16 | 1973 Double-ended. Metric."Small Boats", Ch4, "Light Dory Type V" |
| Light Dory (Type 6) Gloucester Gull | Oar | #140-6 | 15'6" x 4' | SBJ#07 | aka Gloucester Gull rev. Light Dory design #140 - 4 (Type 4) for Dynamite |
| Light Dory (Type 7)) | Row | #526 | 19' 6" x 4' | V24-N20 | Up to 3 people, 1 or 2 rowing. aka "Long Light Dory", Stretched Light Dory |
| Light Dory (Type 8) Three Man | rowboat | #555 | 23'6" x 4' | V18-N01, V24-N20 | Up to 3 rowers. Largest stretch of the "Gull". |
| Light Peapod | oars | #390 | 12'0"x3'8" | V13-N14 | Cold-molded wooden rowboat. |
| Longship | Sail, Row | 38' x8' | BWAOM Ch#39 | Open Boat - Viking ship representation | |
| Morning Light 22 | Sail, Power, & Oar. | #190 | 22'4.5" x 6'6" | Texas Dory plan 17 | Sea/Surf & Rescue. July 1965. Fishing surf boat (motor well for small OB) boomless 80sf gunter rig w/36sf jib |
| Motor Canoe | Row - 545lbs displ. | #582 | 15'9" x3' | V09-N20 BWAOM Ch#14 | Dayboat - outboard, round bilge |
| Navel Jelly | Row | #296 | 31' x4'3" | FoldingSch Ch#07 | Disposable Racer - 'instant boat' plywood |
| Nymph | sail/oar | #425 | 7'9"x3'6" | ||
| Ocean-Crossing Rowboat | Row, Sail - 4,300lbs | Concept | 33' x6' | FoldingSch Ch#25 | Rowboat - proposal |
| Ocean-Going Rowing Project | Row - 1,600lbs displ. | 30' x4'8" | SmallBoats Ch#6 | Rowboat - round-bilge singlehander | |
| Petty Yacht Tender | Row, Sail - 430lbs displ. | #184 | 7'9" x 3'10" | FoldingSch Ch#18 | Dinghy - fibreglass |
| Pirogue 16 | sail, oars, paddles | #451 | 16'0"x3'3" | Plywood flat-bottom boat with decks designed for cheap fast construction. | |
| Plywood Trireme | Row | FoldingSch Ch#17 | Cruiser - undeveloped idea | ||
| Pointy Skiff | Power/Row | #329 | 10'6" x 3'6" | SBJ#11, V17-N19 | Row or small outboard (3HP) Payson "Instant Boat" |
| Poohsticks | oar | #010-ii-57 | 11'4" x 3'10" | Small Boats | Child's rowing skiff ( |
| Prince William Sound Yawl | Sail, OB or oar auxillary | #356 | 16' 3"x 4'6" 200# | SBJ#08, V16-N23, DiffBoats Ch#06 | Cold-molded cat yawl "maximum car top boat" |
| Recreational Rowboat | Row - 630lbs displ. | #300 | 13'9" x4' | V18-N22, FoldingSch Ch#21 | Dinghy - moulded hull |
| Rose Pinnace | Row, Sail | #229 | 28' x6'6" | SmallBoats Ch#11 | Dayboat - round bilge |
| Rose Yawlboat | oar or OB | 16'0"x4'5" | V13-N10 | Steam-bent framed carvel planked deckboats for use on the ship Rose | |
| Row/Sail Tender for Tahiti | Sail/Oar | #655 | 8' | punt with gaff sail & leeboard | |
| Rubens Nymph | sail, row or 2 HP | #516 | 7'9"x4'6" | Same length and construction as Nymph, but wider. | |
| Shoebox Punt | Oar | #539 | 5'6"x3'6" | V07-N02 | Compact pram/rowboat for efficient storage. Yacht dingy/tender. |
| Singapore Cutter | Sail/oars | #617 | 29'6"x7'6" | V12-N01, V18-N15 | open sprit yawl designed for up to eight oars . |
| Spur II | Utility Rowboat | #600 | 15'4"x4'6" | V10-N21, BWAOM Ch#11, BDQ#11, SBJ#77 | Rowboat - lapstrake 500lbs displ. aka "Utility Rowing Boat" |
| Spur l (1963) | Oar - Whithall Type | 16'0" x 4'5" | V21-N19 | Popular Boating Dec 1964 (cover story); 15Feb2004; See "Small Boats" dust | |
| Sweet Pea | Row, Sail - weighs 150lbs | #570 | 15' x4'4" | BWAOM Ch#10 | Dayboat - plywood surf dory sprit or sharpie rig |
| Teal | Row-Sail | #310 | 12' X 3'6" | V16-N21 | elegant small craft, 2 sheets of plywood, "Instant Boat type" |
| Ultra-light rowboat for homebuilders | oar | Cartoon#05 | 15' x 3'10" | SBJ#29 | 30-35lbs plywood lapstrake w/truss frames dbl ended rowboat |
| Utility Nesting Skiff | Rowboat | Concept | 11'6"x4'2" | V13-N19 | Rowboats designed to stack inside each other. |
| Victoria | Row - 800lbs displ. | #210 | 15'6" x4'2" | V08-N15 SmallBoats Ch#5 | Rowboat - round-bilge wooden hull |
| Viking Longship | 247sf sail, 14 oars | #572 | 38'x8'x1'11" | V09-N05, V20-N04 | Built by Willi Hesse, replica of Viking longboat |
| Big Tortoise | Row/sail | #597 | 8' x 3'2" | Payson | Larger version of Tortoise, build by John Kolb. Ch. 10 in Payson's latest book. |
| Perfect Skiff '08 | Row/Sail | 15'6" | Folding skiff, lifeboat capabilities | ||
| Plywood Canoe Yawl | 209sf sail, oar aux | 19ft | SBJ#48 | aka "Cartoon #24" Water ballasted 'vee' bottom plywood canoe yawl |
Rowboat List Home
included. | |||||
Preview
by Yahoo | |||||
Phil Bolger & Friends
Susanne
Suzanne,
I should know the address, but I don’t. Where should I mail the check?
JohnT
From:bolger@yahoogroups.com [mailto: bolger@yahoogroups.com ]
Sent:Thursday, April 30, 2015
1:18 PM
Subject:Re: [bolger] list of over 300
different rowboats
Hello John,
plans
for Design #218 VICTORIA are $75.- to build one
boat.
Personal Check or Money Order made out to Phil Bolger & Friends Inc
will do.
Susanne
Altenburger, PB&F
Sent:Thursday, April 30, 2015 1:10 PM
Subject:RE: [bolger] list of over 300 different rowboats
Suzanne,
I live in the mid south and around 1970, rowboat designs were difficult to come by. I credit Phil with starting the wooden/traditional boat resurrection with his Glouster Gull and at one point, I built a Thomaston Galley (and much later, a Sweet Pea and a Scooner (now named Light Schooner).Happily, there is now a plethora of rowing/pulling boat designs available and the internet makes plans available from all over the world. At the moment, my rowing boat is one of Doug Hylan’s Beach Peas. But I’m looking at Victoria . Are plans available? If so, how much?
In the early 70’s, I bought a “portfolio” of boat plans from Phil (primarily to get plans for Monhegan) which included plans for Victoria . The portfolio was incorporated intoSmall Boatsand I suppose I could loft and build from either one, but my old eyes appreciate bigger plans and I’m happy to pay for the convenience.
A dedicated book or web site would be welcome.
John
Sent:Thursday, April 30, 2015 11:07
AM
different rowboats
Peter,
good idea to attempt
to accumulate human/oar-powered designs.
But “...a few Bolger
rowboats...?”
There are over 4 dozen designs from short fat square
punts over gorgeous pulling-boats, pinnaces, and proven ocean-crossing cruisers
to a long-ship you can go row yourself right now. Many of these have been
built.
I’ll claim that few design-houses have covered and see executed this breadth of conceptual approaches on oar-powered craft. However I am too booked to help add to your list, but a lot of these designs have been ‘out there’ in books and magazines for a long time.
This episode here
suggests that many folks will have to help you with this endeavor in order for
it to achieve plausible ‘online authority’ as a depository of increasingly
comprehensive knowledge and data.
So, lets hope that folks here will
point you to designs out of this office not on your list yet.
Of course,
we/I should long ago have put a dedicated book into print to cover those
designs...
Sent:Thursday, April 30, 2015 10:44 AM
Subject:[bolger] list of over 300 different rowboats
I have written up a
be seen here
List
tacking-outrigger.com Rowboat List Home LIST OF 300 DIFFERENT ROWBOATS About this list Now for a list of Rowboats, length and width and website link for each rowboat are included. | |||||
Suzanne,
JohnT
1:18 PM
Hello John,
plans for Design #218 VICTORIA
are $75.- to build one boat.
Personal Check or Money Order made out to Phil Bolger & Friends Inc will
do.
Suzanne,
John
11:07 AM
Peter,
good idea to attempt to accumulate human/oar-powered designs.
But “...a few Bolger rowboats...?”
There are over 4 dozen designs from short fat square punts over gorgeous
pulling-boats, pinnaces, and proven ocean-crossing cruisers to a long-ship you
can go row yourself right now. Many of these have been built.
This episode here suggests that many folks will have to help you
with this endeavor in order for it to achieve plausible ‘online authority’ as a
depository of increasingly comprehensive knowledge and data.
So, lets hope that folks here will point you to designs out of this office not
on your list yet.
Of course, we/I should long ago have put a dedicated book into print to cover
those designs...
Rowboat List
Preview by Yahoo |
plans for Design #218 VICTORIA are $75.- to build one boat.
Personal Check or Money Order made out to Phil Bolger & Friends Inc will do.
Suzanne,
John
11:07 AM
different rowboats
Peter,
rowboats...?”
built.
This episode here
Of course,
designs...
I have written up a
be seen here
I am all for you doing this. Obviously.
So let’s hope for folks helping you.
And, yes, the books will be one solid resource.
Testing your library’s Inter-Library Loan reach is a good exercise anyway.
Messing About In Boats out of Wenham, MA has featured near 490 design-columns by Bolger and PB&F.
hello Susanne
my trouble is that Phil Bolgers boat designs tend to be
in books, and dont turn up in google searches very well. I can go to the local
library and start reading. I have read one of Phil's books a whilst back, but my
memory has dimmed the details.
Again, the list is just a start, the more
the better. My apologies for my lack of knowledge, I tonly know what I know. I
have no trouble at all, with anyone taking over the list,,, improving it,,
making additions, and putting it in a place that it will receive more traffic,
then that improved list can be the official list. My guess is the official list,
is the one that someone calls official. Again the list is a just a start and is
totally open source
Suzanne,
John
11:07 AM
Peter,
folks will have to help you with this endeavor in order for it to achieve
plausible ‘online authority’ as a depository of increasingly comprehensive
knowledge and data.
on your list yet.
those designs...
Rowboat List
Preview by Yahoo |
my trouble is that Phil Bolgers boat designs tend to be in books, and dont turn up in google searches very well. I can go to the local library and start reading. I have read one of Phil's books a whilst back, but my memory has dimmed the details.
Again, the list is just a start, the more the better. My apologies for my lack of knowledge, I tonly know what I know. I have no trouble at all, with anyone taking over the list,,, improving it,, making additions, and putting it in a place that it will receive more traffic, then that improved list can be the official list. My guess is the official list, is the one that someone calls official. Again the list is a just a start and is totally open source
There are over 4 dozen designs from short fat square punts over gorgeous pulling-boats, pinnaces, and proven ocean-crossing cruisers to a long-ship you can go row yourself right now. Many of these have been built.
So, lets hope that folks here will point you to designs out of this office not on your list yet.
Of course, we/I should long ago have put a dedicated book into print to cover those designs...
The
